µçÄÔÒôÀÖÓ¢ºº´Êµä
µçÄÔÒôÀÖÓ¢ºº´Êµä
A
AAC automatic ampltiude control ×Ô¶¯·ù¶È¿ØÖÆ
AB ABÖÆÁ¢ÌåÉù¼Òô·¨
Abeyancd ÔÝÍ££¬Ç±Ì¬
A-B repeat A-BÖØ¸´
ABS absolute ¾ø¶ÔµÄ£¬ÍêÈ«µÄ£¬¾ø¶Ôʱ¼ä
ABS american bureau of standard ÃÀ¹ú±ê×¼¾Ö
ABSS auto blank secrion scanning ×Ô¶¯´Å´ø¿Õ°×²¿·ÖɨÃè
Abstime ¾ø¶ÔÔËÐÐʱ¼ä
A.DEF audio defeat ÒôƵ½µÔ룬ÔëÉùÒÖÖÆ£¬°éÒô¾²Ôë
ADJ adjective ¸½ÊôµÄ£¬¸½¼þ
ADJ Adjust µ÷½Ú
ADJ acoustic delay line ÉùÑÓ³ÙÏß
Admission ÔÊÐí½øÈ룬¹©¸ø
ADP acoustic data processor ÒôÏìÊý¾Ý´¦Àí»ú
ADP(T) adapter ÑÓÅäÆ÷??
ADRES automatic dynamic range expansion system
¶¯Ì¬·¶Î§À©Õ¹ÏµÍ³
ADRM analog to digital remaster
Ä£Äâ¼Òô¡¢Êý×Ö´¦ÀíÊýÂ볪ÅÌ
ADS audio distribution system ÒôƵ·ÖÅäϵͳ
A.DUB audio dubbing ÅäÒô£¬ÒôƵ¸´ÖÆ£¬ºóÆÚ¼Òô
ADV advance ËÍÈ룬ÌáÉý£¬Ç°ÖÃÁ¿
ADV adversum ¶Ô¿¹
ADV advancer Ïàλ³¬Ç°²¹³¥Æ÷
Adventure ¾ªÏÕЧ¹û
AE audio erasing ÒôƵ£¨ÉùÒô£©²Á³ý
AE auxiliary equipment ¸¨ÖúÉ豸
Aerial ÌìÏß
AES audio engineering society ÃÀ¹úÉùƵ¹¤³ÌЭ»á
AF audio fidelity ÒôƵ±£Õæ¶È
AF audio frequency ÒôƵƵÂÊ
AFC active field control ×Ô¶¯ÆµÂÊ¿ØÖÆ
AFC automatic frequency control Éù³¡¿ØÖÆ
Affricate Èû²ÁÒô
AFL aside fade listen Ë¥¼õºó£¨ÍÆ×Ӻ󣩼àÌý
A-fader ÒôƵ˥¼õ
AFM advance frequency modulation ¸ß¼¶µ÷Ƶ
AFS acoustic feedback speaker Éù·´À¡ÑïÉùÆ÷
AFT automatic fine tuning ×Ô¶¯Î¢µ÷
AFTAAS advanced fast time acoustic analysis system
¸ß¼¶¿ìËÙÒôÏì·ÖÎöϵͳ
After ×ªÒÆ²¿·ÖÎļþ
Afterglow Óà»Ô£¬Ï¦ÕÕʱ·ÖÒôÏìЧ¹û
Against ÒÔ¡­¡­Îª±³¾°
AGC automatic gain control ×Ô¶¯ÔöÒæ¿ØÖÆ
AHD audio high density ÒôƵ¸ßÃܶȳªÆ¬ÏµÍ³
AI advanced integrated Ô¤»ãÁ÷
AI amplifier input ·Å´óÆ÷ÊäÈë
AI artificial intelligence È˹¤ÖÇÄÜ
AI azimuth indicator ·½Î»Ö¸Ê¾Æ÷
A-IN ÒôƵÊäÈë
A-INSEL audio input selection ÒôƵÊäÈëÑ¡Ôñ
Alarm ¾¯±¨Æ÷
ALC automatic level control ×Ô¶¯µçƽ¿ØÖÆ
ALC automatic load control×Ô¶¯¸ºÔØ¿ØÖÆ
Alford loop °®¸£ÌØ»·ÐÎÌìÏß
Algorithm ÑÝʾ
Aliasing Á¿»¯ÔëÉù£¬ÆµÆ×»ìµþ
Aliasing distortion ÕÛµþÊ§Õæ
Align alignment УÕý£¬²¹³¥£¬Î¢µ÷£¬Æ¥Åä
Al-Si-Fe alloy head Ìú¹èÂÁºÏ½ð´ÅÍ·
Allegretto С¿ì°å£¬ÉÔ¿ìµØ
Allegro ¿ì°å£¬Ñ¸ËÙµØ
Allocation ÅäÖ㬶¨Î»
All rating È«£¨Òô£©Óò
ALM audio level meter ÒôƵµçƽ±í
ALT alternating Õðµ´£¬½»ÌæµÄ
ALT alternator ½»Á÷·¢µç»ú
ALT altertue ת·
ALT-CH alternate channel ת»»Í¨µÀ£¬½»ÌæÉùµÀ
Alter ת»»£¬½»Á÷µç£¬±ä»»Æ÷
AM amperemeter °²Åà¼Æ£¬µçÁ÷±í
AM amplitude modulation µ÷·ù£¨¹ã²¥£©
AM auxiliary memory ¸¨Öú´æ´¢Æ÷
Ambience ÁÙ³¡¸Ð£¬»·ÈƸÐ
ABTD automatic bulk tape degausser
´Å´ø×Ô¶¯ÕûÌåÈ¥´Åµç·
Ambient »·¾³µÄ
Ambiophonic system »·ÈÆÉùϵͳ
Ambiophony ÏÖ³¡»ìÏ죬»·¾³Á¢ÌåÉù
AMLS automatic music locate system
×Ô¶¯ÒôÀÖ¶¨Î»ÏµÍ³
AMP ampere °²Åà
AMP amplifier ·Å´óÆ÷
AMPL amplification ·Å´ó
AMP amplitude ·ù¶È£¬¾àÀë
Amorphous head ·Ç¾§Ì¬´ÅÍ·
Abort ÖÕÖ¹£¬Í£Ö¹£¨Â¼ÖÆ»ò²¥·Å£©
A-B TEST AB±È½ÏÊÔÌý
Absorber ¼õÕðÆ÷
Absorption ÉùÒô±»ÎïÌåÎüÊÕ
ABX acoustic bass extension µÍÒôÀ©Õ¹
AC accumulator ³äµçµç³Ø
AC adjustment caliration µ÷½Ú-У׼
AC alternating current ½»Á÷µç£¬½»Á÷
AC audio coding ÊýÂëÉù£¬ÒôƵ±àÂë
AC audio center ÒôƵÖÐÐÄ
AC azimuth comprator ·½Î»±È½ÏÆ÷
AC-3 ¶Å±ÈÊýÂë»·ÈÆÉùϵͳ
AC-3 RF ¶Å±ÈÊýÂë»·ÈÆÉùÊý¾ÝÁ÷£¨½Ó¿Ú£©
ACC Acceleration ¼ÓËÙ
Accel ½¥¿ì£¬¼ÓËÙ
Accent ÖØÒô£¬Éùµ÷
Accentuator Ô¤¼ÓÖØµç·
Access ´æÈ¡£¬½øÈ룬Ôö¼Ó£¬Í¨Â·
Accessory ¸½¼þ£¨½Ó¿Ú£©£¬Åä¼þ
Acryl ±û»ùõ£»ù
Accompaniment °é×࣬ºÏ×࣬°éËæ
Accord ºÍг£¬µ÷ºÍ
Accordion ÊÖ·çÇÙ
ACD automatic call distributor ×Ô¶¯ºô½Ð·ÖÅäÆ÷
ACE audio control erasing ÒôƵ¿ØÖÆÏû´Å
A-Channel A£¨×ó£©ÉùµÀ
Acoumeter ²âÌý¼Æ
Acoustical ÉùµÄ£¬ÉùÒôµÄ
Acoustic coloring ÉùȾɫ
Acoustic image ÉùÏñ
Across ½»²æ£¬²¢ÐУ¬¿ç½Ó
Across frequency ½»²æÆµÂÊ£¬·ÖƵƵÂÊ
ACST access time ´æÈ¡Ê±¼ä
Active Ö÷¶¯µÄ£¬ÓÐÔ´µÄ£¬ÓÐЧµÄ£¬ÔËÐеÄ
Active crossover Ö÷¶¯·ÖƵ£¬µç×Ó·ÖÆµ£¬ÓÐÔ´·ÖƵ
Active loudsperker ÓÐÔ´ÒôÏä
Armstrong MOD °¢Ä·Ë¹ÌØÀʵ÷ÖÆ
ARP azimuth reference pulse ·½Î»»ù×¼Âö³å
Arpeggio ÅÃÒô
Articulation ÉùÒôÇåÎú¶È£¬·¢Òô
Artificial ·Â¡­¡­µÄ£¬È˹¤µÄ£¬ÊÖ¶¯£¨¿ØÖÆ£©
AAD active acoustic devide ÓÐÔ´ÉùѧÈí¼þ
ABC auto base and chord ×Ô¶¯µÍÒôºÏÏÒ
Architectural acoustics ½¨ÖþÉùѧ
Arm motor ³ª±Û³ª»ú
Arpeggio single ÅÃÒôºÍÏÒ£¬·Ö½âºÍÏÒ
ARL aerial ÌìÏß
ASC automatic sensitivity control ×Ô¶¯ÁéÃô¶È¿ØÖÆ
ASGN Assign ·ÖÅ䣬ָ¶¨£¬É趨
ASP audio signal processing ÒôƵÐźŴ¦Àí
ASS assembly ×é¼þ£¬×°Å䣬×ܳÉ
ASSEM assemble »ã±à£¬¼ô¼­
ASSEM Assembly ×é¼þ£¬×°Å䣬×ܳÉ
Assign Ö¸¶¨£¬×ª·¢£¬·ÖÅä
Assist ¸¨Öú£¨×°Öã©
ASSY accessory ×é¼þ£¬¸½¼þ
AST active servo techonology ÓÐÔ´ËÅ·þ¼¼Êõ
A Tempo »Øµ½Ô­ËÙ
Astigmatism methord ÏóÉ¢·¨
ÆÀÂÛÁÐ±í£¨19£©
B band Ƶ´ø
B Bit ±ÈÌØ£¬´æ´¢µ¥Ôª
B Button °´Å¥
Babble ¶à·¸ÐÓ¦µÄ¸´ÔÓÊ§Õæ
Back ·µ»Ø
Back clamping ·´Ïòǯλ
Back drop ½»Á÷ºßÉù£¬¸ÉÈÅÉù
Background noise ±³¾°ÔëÉù£¬±¾µ×ÔëÉù
Backing copy ¸±°æ
Backoff µ¹¿Û£¬²¹³¥
Back tracking ²¹Â¼
Back up ´Å´ø±¸·Ý£¬Ö§³Ö£¬Ô¤±¸
Backward ¿ìµ¹ËÑË÷
Baffle box ÒôÏä
BAL balance ƽºâ£¬Á¢ÌåÉù×óÓÒÉùµÀÒôÁ¿±ÈÀý£¬Æ½ºâÁ¬½Ó
Balanced ÒÑÆ½ºâµÄ
Balancing µ÷Áã×°Ö㬲¹³¥£¬ÖкÍ
Balun ƽºâ=²»Æ½ºâת»»Æ÷
Banana jack Ïã½¶²åÍ·
Banana bin Ïã½¶²å×ù
Banana pin Ïã½¶²åÍ·
Banana plug Ïã½¶²åÍ·
Band Ƶ¶Î£¬
Band pass ´øÍ¨Â˲¨Æ÷
Bandwidth Ƶ´ø¿í£¬Îó²î£¬·¶Î§
Band ´æ´¢µ¥Ôª
Bar С½Ú£¬À­¸Ë
BAR barye ΢°Í
Bargraph ÏßÌõ
Barrier ¾øÔµ£¨Ì×£©
Base µÍÒô
Bass µÍÒô£¬±¶Ë¾£¨µÍÒôÌáÇÙ£©
Bass tube µÍÒôºÅ£¬´óºÅ
Bassy µÍÒô¼ÓÖØ
BATT battery µç³Ø
Baud ²¨ÌØ£¨ÐÅÏ¢´«ÊäËÙÂʵĵ¥Î»£©
Bazooka µ¼Ï߯½ºâת½ÓÆ÷
BB base band »ù´ø
BBD Bucket brigade device ìæÁ´Æ÷¼þ£¨Ð§¹ûÆ÷£©
B BAT Battery µç³Ø
BBE ÌØÖ¸BBE¹«Ë¾Éè¼ÆµÄ¸ÄÉÆ½Ï¸ß´Îг²¨Ð£Õý³Ì¶ÈµÄϵͳ
BC balanced current ƽºâµçÁ÷
BC Broadcast control ¹ã²¥¿ØÖÆ
BCH band chorus ·ÖƵ¶ÎºÏ³ª
BCST broadcast £¨ÎÞÏߵ磩¹ã²¥
BD board ÒDZí°å
Beat ÅÄ£¬Âö¶¯ÐźÅ
Beat cancel switch ²îÅĸÉÈÅÏû³ý¿ª¹Ø
Bel ±´¶û
Below ÏÂÁУ¬ÏòÏÂ
Bench ¹¤×÷̨
Bend ÍäÇú£¬»¬Òô
Bender »¬ÒôÆ÷
BER bit error rate ÐÅÏ¢²î´íÂÊ
BF back feed ·´À¡
BF Backfeed flanger ·´À¡Ïâ±ß
BF Band filter ´øÍ¨Â˲¨Æ÷
BGM background music ±³¾°ÒôÀÖ
Bias Æ«Öã¬Æ«´Å£¬Æ«Ñ¹£¬¼È¶¨³ÌÐò
Bidirectional Ë«ÏòÐԵģ¬8×ÖÐÍÖ¸ÏòµÄ
Bifess Bi-feedback sound system Ë«·´À¡ÏµÍ³
Big bottom µÍÒôÀ©Õ¹£¬¼ÓÖØµÍÒô
Bin ½ÓÊÕÆ÷£¬²ÖÊÒ
BNG BNCÁ¬½ÓÆ÷£¨²åÍ·¡¢²å×ù£©£¬¿¨¿ÚͬÖáµçÀÂÁ¬½ÓÆ÷
Binaural effect Ë«¶úЧӦ£¬Á¢ÌåÉù
Binaural synthesis Ë«¶úºÏ³É·¨
Bin go ÒâÍâÏÖÏó
Bit binary digit ×Ö½Ú£¬¶þ½øÖÆÊý×Ö£¬Î»
Bitstream ÊýÂëÁ÷£¬±ÈÌØÁ÷
Bit yield ´æ´¢µ¥Ôª
Bi-AMP Ë«£¨Í¨µÀ£©¹¦·Åϵͳ
Bi-wire Ë«Ïߣ¨´«Êä¡¢·ÖÒô£©
Bi-Wring Ë«Ïß
BK break Í£¶Ù£¬¼ä¶Ï
BKR breaker ¶ÏµçÆ÷
Blamp Á½Â·µç×Ó·ÖÒô
Blanking ¹Ø±Õ£¬ÏûÒþ£¬¶Ï·
Blaster ±¬ÁÑЧ¹ûÆ÷
Blend Èںϣ¨¶È£©¡¢µ÷ºÍ¡¢»ìºÏ
Block ·Ö³ÌÐò£¬Áª¶¯£¬ÖжÏ
Block Repeat ·Ö¶ÎÖØ¸´
Block up ×èÈû
Bloop £¨´Å´øµÄ£©½ÓÍ·ÔëÉù£¬ÏûÒôÌùƬ
BNC bayonet connector ¿¨¿ÚµçÀÂÁ¬½ÓÆ÷
Body mike СÐÍ»°Í²
Bond ½ÓÍ·£¬Á¬½ÓÆ÷
Bongo Ë«¹Ä
Boom »ìÏ죬ºäÃùÉù
Boomy ÎËÎËÉù£¨Ö¸µÍÒô¹ýÇ¿£©
Boost ÌáÉý£¨Ò»°ãÖ¸µÍÒô£©£¬·Å´ó£¬ÔöÇ¿
Booth ¿ØÖÆÊÒ£¬Â¼ÒôÅï
Bootstrap ¸¨Öú³ÌÐò£¬×Ô¾Ùµç·
Both sides play disc stereo system
Ë«ÃæÑÝ×àʽ³ªÆ¬Á¢ÌåÉùϵͳ
Bottoming µ×²¿Çгý£¬Ä©¶ËÇгý
Bounce ºÏ²¢
Bourclon µ¥µ÷µÍÒô
Bowl Íë×´ÌåÓý³¡Ð§¹û
BP bridge bypass µçÇÅÅÔ·
BY bypass ÅÔͨ
BPC basic pulse generator »ù×¼Âö³å·¢ÉúÆ÷
BPF band pass filter ´øÍ¨Â˲¨Æ÷
BPS band pitch shift ·ÖƵ¶Î±äµ÷½ÚÆ÷
Body mike СÐÍ»°Í²
Bond ½ÓÍ·£¬Á¬½ÓÆ÷
Bongo Ë«¹Ä
Boom »ìÏ죬ºäÃùÉù
Bounce ºÏ²¢
Bourclon µ¥µ÷µÍÒô
Bowl Íë×´ÌåÓý³¡Ð§¹û
BY bypass ÅÔͨ
BR bregister ±äÖ·¼Ä´æÆ÷
BR Bridge µçÇÅ
Break ÖÐÖ¹£¨³ÌÐò£©£¬¼õÈõ
Breathing ´­Ï¢Ð§Ó¦
B.Reso base resolve »ù±¾½âÎö¶È
Bridge ÇŽӣ¬µçÇÅ£¬ÇÅ£¬£¨ÀÖÇúµÄ£©±ä×à¹ý¶É
Bright Ã÷ÁÁ£¨¸Ð£©
Brightness Ã÷ÁÁ¶È£¬Ö¸ÖиßÒôÌýÒô¸Ð¾õ
Brilliance ÏìÁÁ
BRKRS breakers ¶Ï·Æ÷
Broadcast ¹ã²¥
BTB bass tuba µÍÒô´óÀ®°È
BTL balanced transformer-less ÇÅÊ½ÍÆÍì·Å´óµç·
BTM bottom ×îС£¬µÍÒô
BU backup nuit ±¸ÓÃÆ÷¼þ
Bumper ¼õÕðÆ÷
Bus ĸÏߣ¬×ÜÏß
Busbar ĸÏß
Buss ĸÏß
Busy Õ¼Ïß
BUT button °´Å¥£¬ÐýÅ¥
BW band width Ƶ´ø¿í¶È£¬´ø¶È
BYP bypass ÅÔ·
By path ÅÔ·
BZ buzzer ·äÒôÆ÷
2005-10-12 04:59:00 »Ø¸´
C
C cathode Òõ¼«£¬¸º¼«
C Cell µç³Ø
C Center ÖÐÐÄ
C Clear Çå³ý
C Cold À䣨¶Ë£©
CA cable µçÀÂ
Cable µçÀÂ
Cabinet С²Ù×Ý̨
CAC coherent acoustic coding Ïà¸ÉÉùѧ±àÂë
Cache »º³å´æ´¢Æ÷
Cal calando ¼õСÒôÁ¿
CAL Calendar ·ÖÀà
CAL Caliber ¿Ú¾¶
CAL Calibrate ±ê×¼»¯
CAL Continuity accept limit Á¬ÐøÐÔ½ÓÊܼ«ÏÞ
Calibrate У׼£¬¶¨±ê
Call È¡»Ø£¬¸´³ö£¬ºô³ö
Can ¼àÌý¶ú»ú£¬´øºÐ
CANCL cancel ɾ³ý
CANCL Cancelling Ïû³ý
Cancel È¡Ïû
Cannon ¿¨Ù¯½Ó¿Ú
Canon ¹æÔò
Cap µçÈÝ
Capacitance Mic µçÈÝ»°Í²
Capacity ¹¦ÂÊ£¬µçÈÝÁ¿
CAR carrier ÔØ²¨£¬Ö§×ù£¬¼¦ÐļÐÍ·
Card ³ÌÐòµ¥£¬²å¼þ°å
Cardioid ÐÄÐ͵Ä
CATV cable television ÓÐÏßµçÊÓ
Crispness ´àÉù
Category ÖÖÀ࣬ÀàÐÍ
Cartridge Èí¼þ¿¨£¬Ê°ÒôÍ·
Carrkioid ÐÄÐÍ»°Í²
Carrier ÔØ²¨Æ÷
Cart תÔË
Cartridge ºÐʽ´æ´¢Æ÷£¬ºÐʽ´Å´ø
Cascade ´®Áª
Cassette ¿¨Ê½µÄ£¬ºÐʽµÄ
CAV constant angular velocity ºã½ÇËÙ¶È
Caution ±¨¾¯
CBR circuit board rack µç·°å¼Ü
CC contour correction ÂÖÀªÐ£Õý
CCD charge coupled device µçºÉñîºÏÆ÷¼þ
CD compact disc ¼¤¹â³ªÆ¬
CDA current dumping amplifier µçÁ÷·Å´óÆ÷
CD-E compact disc erasable ¿ÉĨʽ¼¤¹â³ªÆ¬
CDG compact-disc plus graphic ´øÓо²Ö¹Í¼ÏñµÄCD³ªÅÌ
CD constant directional horn ºã¶¨Ö¸ÏòºÅ½Ç
CDV compact disc with video ÃÜÎÆÉùÏñ³ªÆ¬
CE ceramic ÌÕ´É
Clock enable ʱÖÓÆô¶¯
Cell µç³Ø£¬Ôª¼þ£¬µ¥Ôª
Cellar club µØÏ¾ãÀÖ²¿Ð§¹û
Cello ´óÌáÇÙ
CEMA consumer electronics manufacturer'sassociation£¨ÃÀ¹ú£©Ïû·Ñµç×Ó²úÆ·ÖÆÔìÉÌЭ»á
CENELEC connector Å·ÖÞ±ê×¼21½ÅAVÁ¬½ÓÆ÷
Cent Òô·Ö
Central earth ÖÐÐĽӵØ
CES consumer electronic show £¨ÃÀ¹ú£©Ïû·Ñµç×Ó²úÆ·Õ¹ÀÀ»á
CF center frequency ÖÐÐÄÆµÂÊ
Cross fade ÈíÇл»
CH channel ÉùµÀ£¬Í¨µÀ
Chain ´«ÊäÁ´£¬ÐŵÀ
Chain play Á¬ÐøÑÝ×à
Chamber ÃÜÒôÒôÏìЧ¹û£¬ÏûÉùÊÒ
CHAN channel ͨµÀ
Change ½»»»
Chapter ÇúÄ¿
Chaper skip Ìø½Ú
CHAE character ×Ö·û£¬·ûºÅ
Characteristic curve ÌØÐÔÇúÏß
Charge ³äµç
Charger ³äµçÆ÷
Chase ¸ú×Ù
Check УÑé
CHC charge ³äµç
CH - off ͨµÀÇжÏ
Choke ºÏ³ª
Choose Ñ¡Ôñ
Chromatic É«²Ê£¬°ëÒô
Church ½ÌÌÃÒôÏìЧ¹û
CI cut in ÇÐÈë
CIC cross interleave code ½»²æ¸ôÐбàÂë
CIRC circulate Ñ­»·
Circuit µç·
CL cancel È¡Ïû
Classic ¹ÅµäµÄ
Clean ¾»»¯
CLR clear ¹éÁã
Click àÖßÕÉù
Clip Ï÷²¨£¬ÏÞ·ù£¬½ÓÏßÖù
CLK clock ʱÖÓÐźÅ
Close ¹Ø±Õ£¬Í£Ö¹
CLS ¿ØÖÆÊÒ¼àÌý
Cluster ÒôÏäÕóЧ¹û
CLV ceiling limit value ÉÏÏÞÖµ
CMP compact ѹËõ
CMPT compatibility ¼æÈÝÐÔ
CMRR common mode rejection ratio ¹²Ä£ÒÖÖÆ±È
CNT count ¼ÇÊý£¬¼ÇÊýÆ÷
CNTRL central ÖÐÐÄ£¬ÖÐÑë CO carry out ¶¨Î»Êä³ö
Coarse ´Öµ÷
Coax ͬÖáµçÀÂ
Coaxial ÊýÂëͬÖá½Ó¿Ú
Code Â룬±àÂë
Coefficient ϵÊý
Coincident ¶àÐźÅͬ²½
Cold ÀäµÄ£¬µ¥±¡µÄ
Color ȾɫЧ¹û
COM comb Êá×´£¨Â˲¨£©
COMB combination ×éºÏÒôÉ«
COMBI combination ×éºÏ£¬»ìºÏ
COMBO combination ÅäºÏ£¬×éºÏ
Combining ¼¯ºÏ£¬½áºÏ
COMM communication »»ÏòµÄ£¬Çл»×°ÖÃ
Command Ö¸Á²Ù×÷£¬ÐźÅ
COMMON ¹«¹²µÄ£¬¹«¹²µØ¶Ë
Communieation speed ͨѶËÙ¶ÈÑ¡Ôñ
COMP comparator ±È½ÏÆ÷
COMP compensate ²¹³¥
Compact ѹËõ
Compander ѹËõÀ©Õ¹Æ÷
Compare ±ÈÄâ
Compatibility ¼æÈÝ
Compensate ²¹³¥
Complex È«Ì×É豸
Copmoser ´´ÒâÕߣ¬×÷ÇúÕß
Compressor ѹËõÆ÷
COMP-EXP ѹÀ©Æ÷
Compromise £¨ÆµÂÊ£©Æ½ºâ
Computer ¼ÆËã»ú£¬µçÄÔ
CON concentric cable ͬÖáµçÀÂ
CON console ²Ù×Ý̨
CON controller ¿ØÖÆÆ÷
Concentric ͬÖáµÄ£¬Í¬ÐĵÄ
Concert ÒôÀÖÌüЧ¹û
Condenser Microphone µçÈÝ»°Í²
Cone type ×¶ÐΣ¨ÑïÉùÆ÷£©
CONFIG ²¼¾Ö£¬Ïß·½Ó·¨
Connect Á¬½Ó£¬ÁªÂç
CORR correct УÕý£¬²¹³¥£¬µÖÏû
Configuration Ïß·²¼¾Ö
Confirmation È·ÈÏ
Consent ÍòÄܲå×ù
Console µ÷Òǫ̂
Consonant ¸¨Òô
Constant ³£Êý
CONT continuous Á¬ÐøµÄ£¨ÒôÉ«ÌØÐÔ£©
CONT control ¿ØÖÆ£¬²Ù×Ý
Contact ½Ó´¥Æ÷
Content ÄÚÈÝ
Continue Á¬Ðø£¬¼ÌÐø
Continue button Á½Â¼Òô¿¨×ùÁ¬Ðø·ÅÒô¼ü
Contour ÍâÐΣ¬ÂÖÀª£¬±£³Ö
Contra ´Î°Ë¶È
Contrast ¶Ô±È¶È
Contribution ·ÖÅä
Controlled ¿É¿ØµÄ
Controller ¿ØÖÆÆ÷
CONV conventional ³£¹æµÄ
CONV convert 񄯯
CONV convertible ¿Éת»»µÄ
Copy ¸´ÖÆ
Correlation meter Ïà¹Ø±í
Coupler ñîºÏ
Cover ²¹³¥
Coverage ÓÐЧ·¶Î§
CP clock pulse ʱÖÓÂö³å
CP control program ¿ØÖƳÌÐò
CPU ÖÐÑë´¦ÀíÆ÷
CR card reader ¿¨Æ¬ÔĶÁ»ú
CRC cyclic redundancy check Ñ­»·ÈßÓàУÑé
Create ½¨Á¢£¬´´Ôì
Crescendo ½¥Ç¿»ò½¥Èõ
Crispness Çå´à¸Ð
CRM control room ¿ØÖÆÊÒ
CROM control read only memory ¿ØÖÆÖ»¶Á´æ´¢Æ÷
Crossfader ½»²æ½¥±äÆ÷
Cross-MOD ½»²æµ÷ÖÆ
Crossover ·ÖƵÆ÷£¬»»Ïò£¬ÇжÏ
Cross talk ÉùµÀ´®ÈÅ£¬´®Òô
Crunch Ħ²ÁÒô
C/S cycle/second ÖÜ/Ãë
CSS content scrambling system ÄÚÈݼÓÃÜϵͳ
CST case style tape ºÐʽ´Å´ø
CT current µçÁ÷
CTM close talking microphone ½ü½²»°Í²
CU counting unit ¼ÆÊýµ¥Ôª
Cue Ìáʾ£¬Ñ¡Ìý
Cue clock ¹ÊÕϼÆÊ±ÖÓ
Cueing Ìáʾ£¬Ö¸³ö
Cursor ָʾÆ÷£¬¹â±ê
Curve £¨ÌØÐÔ£©ÇúÏß
Custom ³£¹æ
CUT ÇÐÈ¥£¬Ó²Çл»
D
D double Ë«ÖØµÄ£¬¶ÔżµÄ
D drum ¹Ä£¬´Å¹Ä
DA delayed action ÑÓ³Ù×÷ÓÃ
D/Adigital/analog Êý×Ö/Ä£Äâ
DAB digital audio broadcasting Êý×ÖÒôƵ¹ã²¥
Damp ×èÄá
DASH digital audio stationar head Êý×̶ֹ¨´ÅÍ·
Dashpot »º³åÆ÷£¬¼õÕðÆ÷
DAT digital audio tape Êý×ÖÒôƵ´Å´ø£¬Êý×Ö¼Òô»ú
DATA Êý¾Ý
DATAtron Êý¾Ý´¦Àí»ú
DATE ÈÕÆÚ
DB(dB) decibel ·Ö±´
DB distribution ·ÖÏߺÐ
DBA decibel asolute ¾ø¶Ô·Ö±´
DBA decibel adjusted µ÷Õû·Ö±´
DBB dynamic bass boost ¶¯Ì¬µÍÒôÌáÉý
DBK decibels referred to one kilowatt ǧÍß·Ö±´
DBm decibel above one milliwatt in 600 ohms ºÁÍß·Ö±´
DBS direct broadcast satellite Ö±²¥ÎÀÐÇ
DBX ѹËõÀ©Õ¹Ê½½µÔëϵͳ
DC distance controlled Ò£¿ØÆ÷
DCA digital command assembly Êý×ÖÖ¸Áî×°ÖÃ
DCE data circuit terminating equipment
Êý¾ÝͨѶÏß·ÖÕ¶ËÉ豸
DCF digital comb filter Êý×ÖÊá×´Â˲¨Æ÷
DCH decade chorus Ê®Éù²¿ºÏ³ª
DCP date central processor Êý¾ÝÖÐÐÄ´¦ÀíÆ÷
DD direct drive Ö±½ÓÇý¶¯
DD dolby digital Êý×ֶűÈ
DDC direct digital control Ö±½ÓÊý×Ö¿ØÖÆ
DDS digital dynamic sound Êý×Ö¶¯Ì¬Éù
DDT data definition table Êý¾Ý¶¨Òå±í
Dead ¾ßÓÐÇ¿ÎüÉùÌØÐԵķ¿¼äµÄ¾²¼Å
DEC decay Ë¥¼õ£¬½¥Èõ£¬ÓàÒôЧ¹û
Decibel ·Ö±´
Deck ¿¨×ù£¬Â¼Òô×ù£¬´øÖ§¼ÓµÄ£¬×ß´ø»ú¹¹
Deemphasis ÊÍ·Å
Deep reverb ×ÝÉî»ìÏì
De-esser È¥ßÐÉùÆ÷
DEF defeat ÏûÒþ£¬¾²Ôë
Delete ɾ³ý
Delivery end ÊäÈë¶Ë
DEMO demodulator ½âµ÷Æ÷
Demo ×Ô¶¯ÑÝ×à
Demoder ½âÂëÆ÷
Density Ãܶȣ¬ÉùÒôÃܶÈЧ¹û
Detune Òô¸ß΢µ÷£¬È¥Ð³
DepFin ×ÝÉî΢µ÷
Depth Éî¶È
Denoiser ½µÔëÆ÷
Design Éè¼Æ
Destroyer ÒÖÖÆÆ÷
DET detector ¼ì²¨Æ÷
Deutlichkeit ÇåÎú¶È
DEV device ×°Öã¬ÒÇÆ÷
DEX dynamic exciter ¶¯Ì¬¼¤ÀøÆ÷
DF damping factor ¶¯Ì¬Â˲¨Æ÷
DFL dynamic filter ¶¯Ì¬Â˲¨
DFS digital frequency synthesizer Êý×ÖÆµÂÊºÏ³ÉÆ÷
DI data input Êý¾ÝÊäÈë
Diagram ͼÐΣ¬Ô­Àíͼ
Dial µ÷½Ú¶ÈÅÌ
Difference ²»Í¬£¬²î±ð
DIFF differential ²î¶¯
Diffraction ÑÜÉä£¬ÈÆÉä
Diffuse ´«²¥
Diffusion À©É¢
DIG digit Êý×Öʽ
Digital Êý×ֵģ¬Êý×Öʽ£¬¼ÆÊýµÄ
Digitalyier Êý×Ö»¯×°ÖÃ
DIM digital input module Êý×ÖÊäÈëÄ£¿é
DIM diminished Ë¥¼õ£¬¼õ°ëÒô
Dimension ·¶Î§£¬Ãܶȣ¬³ß´ç£¬£¨¿Õ¼ä£©Î¬£¬ÉùÏñ¿í¶È
Din Îåо²å¿Ú£¨µÂ¹ú¹¤Òµ±ê×¼£©
DIN digital input Êý×ÖÊäÈë
DIR direct Ö±½ÓµÄ£¬£¨µ÷Òǫ̂£©Ö±½ÓÊä³ö£¬¶¨ÏòµÄ
Direct box Ö¸ÁîºÐ£¬¿ØÖƺÐ
Direct sound Ö±´ïÉù
Directory Ŀ¼
Direction ÅäÖ÷½Ê½
Directional ·½Ïò£¬Ö¸ÏòµÄ
Directivity ·½ÏòÐÔ
DIS display ÏÔʾÆ÷
DISC disconnect Çжϣ¬¿ªÂ·
DISC discriminator ¼øÏàÆ÷
Disc ³ªÅÌ£¬³ªÆ¬£¬µú
Disc holder ³ªÆ¬³éÌë
Disc recorder ÅÌÆ¬Ê½Â¼Òô»ú
Dischage ÊÍ·Å£¬½â³ý
Disco µÏ˹¿Æ£¬µÏ˹¿ÆÒôÀÖЧ¹û
Discord ²»Ð³ºÍÏÒ
Disk ³ªÅÌ£¬µú
DISP display ÏÔʾÆ÷£¬ÏÔʾÆÁ
Dispersion ÆµÉ¢ÌØÐÔ£¬ÉùÒô·Ö²¼
Displacement ƫת£¬´ú»»
Distortion Ê§Õæ£¬»û±ä
DIST distance ¾àÀ룬¼ä¾à
DIST district Çø¼ä
Distributer ·ÖÅäÆ÷£¬µ¼Ïò×°ÖÃ
DITEC digital television camera Êý×ÖµçÊÓÉãÏñ»ú
Dim ±äÈõ£¬±ä°µ£¬Ë¥¼õ
DIV divergence ·¢É¢
DIV division ·Ö¶Î
DIV divisor ·ÖÅäÆ÷
Diversity ·Ö¼¯£¨½ÓÊÕ£©
Divider ·ÖÅäÆ÷
Divx ÃÀ¹úÊý×ÖÊÓÆµ¿ìµÝ¹«Ë¾¿ª·¢µÄÒ»ÖÖÿ´Î¹Û¿´¸¶·ÑµÄDVD
DJ Disc Jocker ³ªÆ¬ÆïÊ¿
DJ dust jacket ·À³¾ÕÖ
DJ delay ÑÓ³Ù
DLD dynamic linear drive ¶¯Ì¬ÏßÐÔÇý¶¯
DLLD direct linear loop detector Ö±½ÓÏßÐÔ»·Â·¼ì²¨Æ÷
DME digital multiple effector Êý×Ö×ÛºÏЧ¹ûÆ÷
DMS date multiplexing system Êý¾Ý¶à·´«Êäϵͳ
DMS digital multiplexing synchronizer
Êý×Ö¶à·´«Êäͬ²½Æ÷
DMX data multiplex Êý¾Ý¶à·£¨´«Ê䣩
DNL dynamic noise limiter ¶¯Ì¬ÔëÉùÒÖÖÆÆ÷
DNR dynamic noise reduction ¶¯Ì¬½µÔëµç·
DO dolly out ºóÒÆ
DO dropout ÐźÅʧÂä
DOB dolby ¶Å±È
DOL dynamic optimum loudness ¶¯Ì¬×î¼ÑÏì¶È
Dolby ¶Å±È£¬¶Å±È¹¦ÄÜ
Dolby Hx Pro dolby Hx pro headroom extension system
¶Å±ÈHx Pro¶¯Ì¬ÓàÁ¿À©Õ¹ÏµÍ³
Dolby NR ¶Å±È½µÔë
Dolby Pro-logic ¶Å±È¶¨ÏòÂß¼­
Dolby SR-D dolby SR digital ¶Å±ÈÊý×ÖÆµÆ×¼Ç¼
Dolby Surround ¶Å±È»·ÈÆ
Dome loudspeaker Çò¶¥ÑïÉùÆ÷
Dome type Çò¶¥£¨ÑïÉùÆ÷£©
DOP doppler ¶àÆÕÀÕ£¨ÏìÓ¦£©
Double ¼Ó±¶£¬Ë«£¬´Î°Ë¶È
Doubler ±¶ÆµÆ÷£¬¼Ó±¶Æ÷
Double speed ±¶ËÙ¸´ÖÆ
D.OUT direct output Ö±½ÓÊä³ö
Down ÏòÏ£¬Ïòϵ÷Õû£¬ÏÂÒÆ£¬¼õÉÙ
DPCM differential pulse code modulation ²î¶¯Âö³åµ÷ÖÆ
DPD direct pure MPX decoder Ö±½Ó´¿¶à·½âµ÷Æ÷
DPL dolby pro logic ¶Å±È¶¨ÏòÂß¼­
DPL duplex Ë«¹¤£¬Ë«Áª
DPLR doppler ¶àÆÕÀÕ£¨ÏµÍ³£©
D.Poher effect µÂ.²¨°£Ð§Ó¦
Dr displacement corrector Î»ÒÆÐ£×¼Æ÷£¬Í¬²½»ú
DR distributor ·ÖÅäÆ÷
DR drum ´Å¹Ä
Drain ©µç£¬Â©¼«
DRAM direct read after write Ò»´ÎÐÔ¶Áд´æ´¢Æ÷
Drama ¾ç³¡Ð§¹û
DRAW Ö»¶Á×·ÒäÐ͹âÅÌ
Dr.Beat È¡×Öʱ¼äУ׼Æ÷
DRCN dynamic range compression and normalization
¶¯Ì¬·¶Î§Ñ¹ËõºÍ¹éÒ»»¯
Drive Çý¶¯£¬¼¤Àø
Dr.Rhythm ½Ú×àͬ²½Ð£×¼Æ÷
DRPS digital random program selector
Êý×Öʽ½ÚÄ¿Ëæ»úÑ¡ÔñÆ÷D
Drum ¹Ä
Drum machine ¹Ä»ú
Dry ¸É£¬ÎÞЧ¹ûÉù£¬Ö±´ïÉù
DS distortion Ê§Õæ
DSC digital signal converter Êý×ÖÐźÅת»»Æ÷
DSL dynamic super loudness µÍÒô¶¯Ì¬³¬Ïì¶È£¬ÖصÍÒô»Ö¸´
DSM dynamic scan modulation ¶¯Ì¬É¨ÃèËٶȵ÷ÖÆÆ÷
DSP digital signal processor Êý×ÖÐźŴ¦ÀíÆ÷
DSP display simulation program ÏÔʾģÄâ³ÌÐò
DSP digital sound processor Êý×ÖÉùÒô´¦ÀíÆ÷
DSP digital sound field processor Êý×ÖÉù³¡´¦ÀíÆ÷
DSP dynamic speaker µç¶¯Ê½ÑïÉùÆ÷
DSS digital satellite system Êý×ÖÎÀÐÇϵͳ
DT data terminal Êý¾ÝÖÕ¶Ë
DT data transmission Êý¾Ý´«Êä
DTL direct to line Ö±½ÓÈ¥Ïß·
DTS digital theater system Êý×ÖÓ°¾çԺϵͳ
DTS digital tuning system Êý×Öµ÷гϵͳ
DTV digital television Êý×ÖµçÊÓ
Dual ¶Ôż£¬Ë«ÖØ£¬Ë«
Dub ¸´ÖÆ£¬ÅäÒô£¬¿½±´£¬×ªÂ¼´Å´ø
Dubbing mixer »ì¼µ÷Òǫ̂
Duck °´È룬½øÈë
Dummyload ¼Ù¸ºÔØ
DUP Duplicate ¸´ÖÆ£¨Æ·£©
Duplicator ¸´ÖÆ×°Öã¬Ôö±¶Æ÷
Duration ³ÖÐøÊ±¼ä£¬¿í¶È
Duty ¸ºÔØ£¬×÷Ó÷¶Î§£¬¹¦ÂÊ
Duty cycle Õ¼¿ÕϵÊý£¬Æµ¿í±È
DUX duplex Ë«¹¤
DV device ×°Öã¬Æ÷¼þ
DVC digital video cassette Êý×Ö¼Ïó´ø
DVD digital video disc Êý×Ö¼¤¹âÊÓÅÌ
DX ÌìÏßÊÕ·¢¿ª¹Ø£¬Ë«Öصģ¬Ë«ÏòµÄ
DYN dynamic µç¶¯Ê½µÄ£¬¶¯Ì¬·¶Î§£¬¶¯È¦Ê½µÄ
Dynamic filter ¶¯Ì¬Â˲¨£¨ÌØÊâЧ¹û´¦Àí£©Æ÷
Dynamic Microphone ¶¯È¦»°Í²
Dynamic range ¶¯Ì¬·¶Î§
Dynode µç×Ó±¶ÔöÆ÷µç¼«
2005-10-12 07:28:00 »Ø¸´
E
E early warning Ô¤¾¯
E earth ÕæµØ£¬½ÓµØ
E error ´íÎ󣬲î´í£¨¹ÊÕÏÏÔʾ£©
EA earth µØÏߣ¬ÕæµØ
EAR early ÔçÆÚ£¨·´ÉäÉù£©
Earphone ¶ú»ú
Earth terminal ½ÓµØ¶Ë
EASE electro-acooustic simulators for engineers
¹¤³ÌʦÓõçÉùÄ£ÄâÆ÷£¬¼ÆËã»úµçÉùÓëÉùѧÉè¼ÆÈí¼þ
Eat ÊÕÈ¡ÐźÅ
EBU european broadcasting union Å·Ö޹㲥ÁªÃË
EC error correction Îó²îУÕý
ECD electrochomeric display µçÖ±äÉ«ÏÔʾÆ÷
Echo »ØÉù£¬»ØÉùЧ¹û£¬»ìÏì
ECL extension zcompact limitter À©Õ¹Ñ¹ËõÏÞÖÆÆ÷
ECM electret condenser microphone פ¼«Ì廰Ͳ
ECSL equivalent continuous sound level µÈ¼¶Á¬ÐøÉù¼¶
ECT electronec controlled transmission µç¿Ø´«Êä
ED edit editor ±à¼­£¬±à¼­Æ÷
Edit ±à¼­
Edge tone ±ßÀâÒô
EDTV enhanced definition television
ÔöÇ¿ÇåÎú¶ÈµçÊÓ£¨Ò»ÖֿɼæÈݸßÇåÎú¶ÈµçÊÓ£©
E-DRAW erasable direct after write ¿É´æ¿ÉĨ¶Áд´æ´¢Æ÷
EE errors excepted ÔÊÐíÎó²î
EFF effect efficiency Ч¹û£¬×÷ÓÃ
Effector ²Ù×Ý×°Öã¬Ð§¹ûÆ÷
Effects generator Ч¹û·¢ÉúÆ÷
EFM 8/14λµ÷ÖÆ·¨
EFX effect Ч¹û
EG envelope generator °üÂç·¢ÉúÆ÷
EIA electronec industries association
£¨ÃÀ¹ú£©µç×Ó¹¤ÒµÐ­»á
EIAJ electronic industries association Japan
ÈÕ±¾µç×Ó¹¤ÒµÐ­»á
EIN einstein Á¿×ÓĦ¶û£¨ÄÜÁ¿µ¥Î»£©
EIN equivalent input noise µÈЧÊäÈëÔëÉù
EIO error in operation ²Ù×÷Âë´íÎó
Eject µ¯Æð²ÕÃÅ£¬È¡³ö´Å´ø£¨¹âÅÌ£©£¬³öºÐ
EL electro luminescence ³¡Ö·¢¹â
ELAC electroacoustic µçÉù£¨Æ÷¼þ£©
ELEC electret פ¼«Ìå
Electret condenser microphone פ¼«Ì廰Ͳ
ELF extremely low frequency ¼«µÍƵ
ELEC electronec µç×ÓµÄ
Electroacoustics µçÉùѧ
EMI electro magnetic interference µç´Å¸ÉÈÅ
Emission ·¢Éä
EMP emphasispo ¼ÓÖØ
EMP empty ¿ÕÔØ
Emphasis ¼ÓÖØ
EMS emergency switch ½ô¼±¿ª¹Ø
Emulator Ä£ÄâÆ÷£¬·ÂÕæÉ豸
EN enabling Æô¶¯
Enable ¸³ÄÜ£¬³·Ïû½ûÖ¹Ö¸Áî
Encoding ±àÂë
End Ä©¶Ë£¬½áÊø£¬ÖÕÖ¹
Ending ÖÕ¶Ë£¬¶Ë½Ó·¨£¬Ïâ±ß
ENG engineering ¹¤³Ì
Engine ÔËÐУ¬Ê¹ÓÃ
ENG land ¹¤³Ì½ÓµØ
Enhance ÔöÇ¿£¬Ìá¸ß£¬ÌáÉý
ENS ensemble ºÏ×à
ENS envelope sensation Ⱥ¸Ð
Eensemble ºÏ×à
Eensemble ºÏ×à
ENT enter ¼Ç¼
Enter ¼ÇÈ룬½øÈ룬»Ø³µ
Entering ²åÈ룬¼Ç¼
Entry ÊäÈëÊý¾Ý£¬½øÈë
ENV envelope °üÂçÏß
Envelopment »·ÈƸÐ
EOP electronic overload protection µç×Ó¹ýÔØ±£»¤
EOP end of program ³ÌÐò½áÊø
EOP end output Ä©¶ËÊä³ö
EOT end of tape ´Å´øÎ²¶Ë
EP extend playing record ¶àÇúÄ¿³ªÆ¬
EP extended play ³¤Ê±¼ä·Å¼£¬Ãܼ
EPG edit pulse generator ±à¼­Âö³å·¢ÉúÆ÷
EPS emergency power supply Ó¦¼±µçÔ´
EQ equalizer ¾ùºâÆ÷£¬¾ùºâ
EQ equalization ¾ùºâ
EQL equalization ¾ùºâ
Equal-loudness contour µÈÏìÇúÏß
Equipped ×¼±¸ºÃµÄ£¬ÒÑ×°±¸
Equitonic È«Òô
Equivalence µÈЧֵ
ER erect ÉèÖÃ
ER error ´íÎó£¬Îó²î
ERA earphone ¶ú»ú
Eraser Ĩȥ£¬Ïû³ý
Erasing ²Á³ý£¬ÇåÏ´
Erasure ĨÒô
Erase Ïû³ý£¬Ïû
Er early ÔçÆÚµÄ
ERCD extended resolution CD À©Õ¹½âÎö¶ÈCD
EREQ erect equalizer
¾ùºâÆ÷£¨Æµµã£©Î»Ö㨵ãƵ²¹³¥µç·µÄÖÐµãÆµÂÊ£©µ÷Õû
ERF early reflection ÔçÆÚ·´É䣨Éù£©
Ernumber ÔçÆÚ·´ÉäÉùÁ¿
Error ´íÎ󣬳ö´í£¬²»ÕýÈ·
ES earth swith ½ÓµØ¿ª¹Ø
ES electrical stimulation µã¼¤Àø
Escqpe Í˳ö
ETER eternity ÎÞÏÞ
Euroscart Å·ÖÞ±ê×¼21½ÅAVÁ¬½ÓÆ÷
Event ʼþ
EVF envelope follower
°üÂç¸úËæÆ÷£¨ÒôÏìºÏ³É×°Öù¦Äܵ¥Ôª£©
EX exciter ¼¤ÀøÆ÷
EX exchange ½»»»
EX expanding À©Õ¹
EXB expanded bass µÍÒôÔöÇ¿
EXC exciter ¼¤ÀøÆ÷
EXCH exchange ת»»
Exclusive רÓõÄ
Excursion Æ«ÒÆ£¬Æ«×ª£¬Æ¯ÒÆ£¬Õñ·ù
EXP expender À©Õ¹Æ÷£¬¶¯Ì¬À©Õ¹Æ÷
EXP export Êä³ö
Exponential horn tweeter Ö¸ÊýÐ͸ßÒôºÅ½ÇÑïÉùÆ÷
Expression pedal
±í´ï̤°å£¨ÓÃÓÚ¿ØÖÆÀÖÆ÷»òЧ¹ûÆ÷µÄ½Å̤װÖã©
EXT extend À©Õ¹
EXT exterior Íâ½ÓµÄ£¨É豸£©
EXT external ÍⲿµÄ£¬Íâ½ÓµÄ
EXT extra ³¬¹ý
EXTN extension À©Õ¹£¬ÑÓÉ죨³Ì¿Ø×°Öù¦Äܵ¥Ôª£©
Extract ¹ìµÀÌá³ö
EXTSN extension À©Õ¹£¬ÑÓÉ죨³Ì¿Ø×°Öù¦Äܵ¥Ôª£©
2005-10-12 07:31:00 »Ø¸´
yinpin666 Â¥Ö÷
F fast ¿ì£¨ËÙ£©
F feedback ·´À¡
F forward Ïòǰ
F foot ½Å̤£¨×°Öã©
F frequency ƵÂÊ
F function ¹¦ÄÜ
Ffactor Òò×Ó£¬ÒòËØ£¬ÏµÊý£¬ÒòÊý
Fade Ë¥¼õ£¨ÒôÁ¿¿ØÖƵ¥Ôª£©
Fade in-out µ­Èëµ­³ö£¬Âýת»»
Fader Ë¥¼õÆ÷
Fade up ƽ»¬ÉÏÉý
Failure ¹ÊÕÏ
Fall Ë¥Â䣬б¶È
Faraday shield ·¨À­µÚÆÁ±Î£¬¾²µçÆÁ±Î
FAS full automatic search È«×Ô¶¯ËÑË÷
Fast ¿ìËÙ£¨×Ô¶¯ÑÝ×à×°ÖõÄËٶȵ÷ÕûÅ¥£©
Fastener ½ÓÏßÖù£¬±ÕËø
Fat »ëºñ£¨ÒôÕùµ÷ÕûÅ¥£©
Fattens out ƽֱÊä³ö
Fault ¹ÊÕÏ£¬Ëð»µ
Fader Ë¥¼õÆ÷£¬µ÷ÒôÌ¨ÍÆÀ­µçλÆ÷£¨ÍÆ×Ó£©
Fading in ½¥ÏÔ
Fading out ½¥ÏÔ
False ´íÎó
Fancier ÒôÏì·¢ÉÕÓÑ
Far field Ô¶³¡
FatEr ·áÂúµÄÔçÆÚ·´Éä
FB feedback ·´À¡£¬Éù·´À¡
FB fuse block ÈÛË¿ºÐ
F.B fiver by ÇåÎú
FBO feedback outrigger ·´À¡ÑÓÉì
FCC federal communications commission
£¨ÃÀ¹ú£©Áª°îͨÐÅίԱ»á
FD fade depth Ë¥¼õÉî¶È
FD feed À¡ÈëÐźÅ
FDR fader Ë¥¼õÆ÷
FeCr Ìú¸õ´Å´ø
Feed À¡¸ø£¬À¡È룬ÊäÈë
Feeder À¡Ïß
Feed/Rewind spool ¹©´øÅÌ/µ¹´øÅÌ
Ferrite head ÌúÑõÌå´ÅÍ·
F.&B. forward and back ǰºó
FET field effect technology ³¡Ð§Ó¦¼¼Êõ
FF flip flop ´¥·¢Æ÷
FF fast forward ¿ì½ø
FG flag generator ±êÖ¾Ðźŷ¢ÉúÆ÷
FI fade in ½¥½ø
Field Éù³¡
Field pickup ʵ¿öʰÒô
File Îļþ£¬´æÈ룬¹éµµ£¬Êý¾Ý¼¯£¬£¨Í⣩´æ´¢Æ÷
Fill-in ÌîÈë
FILT filter Â˲¨Æ÷
Final ÔÏĸ
Fine ΢µ÷
Fingered ¶àÖ¸ºÍÏÒ
Finger ÊÖÖ¸£¬µ¥Ö¸ºÍÏÒ
FIN GND ½ÓµØÆ¬
Finish ½áÊø£¬ÐÞÊÎ
FIP digital frequency display panel Êý×ÖÆµÂÊÏÔʾ°å
FIR finite-furation impulse response
ÓÐÏ޳弤ÏìÓ¦£¨Â˲¨Æ÷£©
Fire Æô¶¯
Fix È·¶¨£¬¹Ì¶¨
Fizz ˻˻Éù
FL fluorescein Ó«¹âЧ¹û
Flange ·¨À¼ÒôÏìЧ¹û£¬Ïâ±ßЧ¹û
Flanger Ïâ±ßÆ÷
Flanging Ïâ±ß
Flash ÉÁ¹âÐźÅ
Flat ƽ̹£¬Æ½Ö±
Flat noise °×ÔëÉù
Flat tuning ´Öµ÷
Flex ¹Õµã
FLEX flexible cord ÈíÏߣ¬ÈûÉþ
FLEX frequency level expander ƵÂÊÀ©Õ¹Æ÷
FLEXWAVE flexible waveguide ¿ÉÍäÇú²¨µ¼¹Ü
FLG flanger Ïâ±ßÆ÷
Flip Ìæ»»£¬µ÷»»
Floating ·Ç¹Ì¶¨µÄ£¬Ðü¸¡Ê½µÄ
Floppy disc Èí´ÅÅÌ
FLTR filter Â˲¨Æ÷
Fluorescent display Ó«¹âÏÔʾÆ÷
Flute ³¤µÑ
Flutter Ò»ÖÖ·ÅÒôÊ§Õæ£¬Âö³å¸ÉÈÅ£¬²ü¶¯
FLW follow ¸ú×Ù£¬Ë涯
FLY ¾ùºâÆ÷
FM fade margin Ë¥ÂäÉ豸
FM frequency modulation µ÷Ƶ¹ã²¥
FM/SW telescopic rod aerial µ÷Ƶ/¶Ì²¨À­¸ËÌìÏß
FO fade out ½¥Òþ
Focus ½¹µã£¬ÖÐÐĵã
Foldback ·µËÍ£¬¼àÌý
Foot(board) ½Å̤°å£¨¿ª¹Ø¿ØÖÆ£©
Fomant ¹²Õñ·å
Force ¹ýÔØ£¬Ç¿ÐÐÖÃÈë
Format ¸ñʽ£¬¸ñʽ»¯£¬¹æ¸ñ£¬£¨´¢´æÆ÷Öеģ©ÐÅÏ¢°²ÅÅ
Forward תËÍ
FPR floating point routine ¸¡µã³ÌÐò
FPR full power response È«¹¦ÂÊÏìÓ¦
FR frequency ƵÂÊ
FR frequency response ƵÂÊÏìÓ¦
Frame »­Ã棬£¨µçÊӵģ©Ö¡
Frames Ö¡Êý
Free Ê£Ó࣬×ÔÓÉ
Free echoes ÎÞÏÞ»ØÉù£¨ÑÓʱЧ¹û´¦ÀíµÄÒ»ÖÖ£©
Free edge ×ÔÓÉÕÛ»·£¨ÑïÉùÆ÷£©
FREEQ frequency ƵÂÊ
F.Rew fast rewind ¿ìµ¹
Freeze Äý¹Ì£¬ÉùÒôÖèÍ££¬¾²Ö¹
FreFrequency shifter 񮮵Æ÷£¬±äƵÆ÷
Fricative ²ÁÒô
Front Ç°ÃæµÄ£¬ÕýÃæµÄ
Front balance ǰÖÃÆ½ºâ
Front process ǰÉù³¡´¦Àí
FRU field replaceable unit ²å¼þ£¬¿É»»²¿¼þ
FS frequency shift ÆµÒÆ£¬±äµ÷
FS full short È«¾°
FT facility terminal É豸£¨Êä³ö£©¶Ë¿Ú
FT fine tuning ΢µ÷
FT foot ½Å̤װÖÃ
FT function tist ¹¦ÄܲâÊÔ
FT frequency tracke ƵÂʸú×ÙÆ÷
FTG fitting ½ÓÍ·£¬Åä¼þ
FTS faverate track selection ×î¼ÑÉù¼£Ñ¡Ôñ
Full ·áÂú£¬±¥ºÍ
Full auto È«×Ô¶¯
Full effect recording ȫЧ¹û¼Òô
Full range È«ÒôÓò£¬È«Æµ
2005-10-12 16:57:00 »Ø¸´
yinpin666 Â¥Ö÷
G
G gate ÃÅ£¨µç·£©
G ground ½ÓµØ
GA general average ×ÜÆ½¾ùÖµ
Gain ÔöÒæ£¬ÌáË¥Á¿
Game ¿¨À­OKÒôÏìЧ¹û
Gamut ÒôÓò
Gap ¼ä¸ô£¬Í¨µÀ
Gate ÔëÉùÃÅ£¬ÃÅ£¬Ñ¡Í¨
Gated Rev ѡͨ»ìÏ죨¿ªÃŵÄʱ¼äÄÚÓлìÏìЧ¹û£©
GB ¼ª×Ö½Ú
Gear ·ç¸ñ£¬¸ñµ÷
GEN generator £¨Ðźţ©·¢ÉúÆ÷
General ×ÛºÏЧ¹û
Generator Ðźŷ¢ÉúÆ÷
GEQ graphie equalizier ͼʾ¾ùºâÆ÷
GD ground ½ÓµØ
Girth ¼¤ÀøÆ÷µÄµÍÒôÇ¿¶Èµ÷½Ú
Glide strip »¬×àÌõ£¨ÑÝ×à×°Öã©
GLLS-sando »¬½µ£¨ÑÝ×àµÄЧ¹û£©
Global ×ÜÌåÉè¼Æ
GM genertal MIDI ͨÓÃÀÖÆ÷Êý×Ö½ÓÆ÷
GND ground µØÏߣ¬½ÓµØ¶Ë GP group ±à×é
GPR general purpose receiver ͨÓýÓÊÕ»ú
GPI general purpose interface ͨÓýӿÚÉ豸
Govern µ÷Õû£¬¿ØÖÆ£¬²Ù×÷£¬ÔËת
GR group ×éºÏ
Gramophone ÁôÉù»ú£¬³ª»ú
Graphic equalizer ͼʾ¾ùºâÆ÷£¬Í¼±í¾ùºâÆ÷
GRND ground ½ÓµØ
Groove ¹âÅÌÂÝÐýµÀµÄ²Û
Group ±à×飨µ÷Òǫ̂£©£¬×é
Growler ÏßȦ¶Ì·²âÊÔÒÇ
GT gate ÃÅ£¬ÔëÉùÃÅ
GT gauge template Ñù°å
GTE gate ÃÅ£¨µç·£©
GTR gate reverb ÃÅ»ìÏì
Guard ±£»¤£¬·À»¤×°ÖÃ
GUI graphical user interface ͼÐÎÓû§½Ó¿Ú
Guitar ¼ªËü
Guy À­Ïß
Gymnasium ÌåÓý¹ÝЧ¹û
Gyrator »ØÐýÆ÷
2005-10-12 16:59:00 »Ø¸´
H
HQAD high quality audio disc ¸ßƷλÒôƵ¹âÅÌ
HR handing room ²Ù×÷ÊÒ
HR high resistance ¸ß×迹£¨ÐźŶË×ÓµÄ×è¿¹ÌØÐÔ£©
HRTF head-related transfer function ÈËÄÔÏà¹Ø×ª»»¹¦ÄÜ
HS head set Í·´÷ʽ¶ú»ú
HS hybrid system »ìºÏϵͳ
HT home theater ¼ÒÍ¥Ó°Ôº£¬¼ÒÍ¥¾ç³¡
Hubrid »ìºÏÍøÂ磬ÇŽӲí·
Hum ½»Á÷ºßÉù£¬½»Á÷µÍƵ£¨50Hz£©ÔëÉù
Hum and Noise ºßÔÓÉù£¬½»Á÷ÔëÉù
Humidity ʪ¶È£¬ÊªÆø
HUT homes using TV ¼ÒÓõçÊÓ
HVDS Hi-visual dramatic sound ¸ß±£ÕæÏÖ³¡¸ÐÒôÏìϵͳ
HX headroom extension ¶¯Ì¬ÓàÁ¿À©Õ¹£¨ÏµÍ³£©£¨Ò»ÖֶűȽµÔëϵͳ£©£¬¾»¿ÕÑÓÉì
H horizonal ˮƽ£¨×´Ì¬£©
H hot ÈÈ£¨Æ½ºâÐźŶ˿ڵġ°Èȶˡ±£©
Hall ÌüÌÃЧ¹û
Handle ÊÖ±ú£¬¿ØÖÆ
HAR harmonec г²¨
Hard knee Ó²¹Õµã£¨Ñ¹ÏÞÆ÷£©
Harmonic г²¨
Harmonic distortion г²¨Ê§Õæ
Harmonic Generator г²¨·¢ÉúÆ÷
Harmonize £¨Ê¹£©ºÍг£¬Ð£Òô
Harmony ºÍг
Harp ÊúÇÙ
Hash ÔÓÂÒÂö³å¸ÉÈÅ
Hass effect ¹þ˹ЧӦ
HD harmonic distortion г²¨Ê§Õæ
HDCD high definition compatible digital
¸ß·Ö±æÂʼæÈÝÐÔÊý×Ö¼¼Êõ
HDTV hight definiton television ¸ßÇåÎú¶ÈµçÊÓ
Head ¼Òô»ú´ÅÍ·£¬Ç°Öõ쬳ªÍ·
Head azimuth ´ÅÍ··½Î»½Ç
Head gap ´ÅÍ··ì϶
Headroom ¶¯Ì¬ÓàÁ¿£¬¶¯Ì¬·¶Î§ÉÏÏÞ£¬µçƽ´¢±¸
Headphone Í·´÷ʽ¶ú»ú
Headset Í·´øÊ½¶ú»ú
Heavy metel ÖØ½ðÊô
HeiFin ´¹Ö±Î¢µ÷
Hearing Ìýµ½£¬Ìý¾õ
Heat sink É¢ÈȰå
Help £¨¶Ô³ÌÐòµÄ£©½âÊÍ
HF high frequency ¸ßƵ£¬¸ßÒô
Hi hign ¸ßƵ£¬¸ßÒô
HI band ¸ßƵ´ø
Hi-end ×î¸ßÆ·ÖÊ£¬¶¥¼¶
Hi-BLEND ¸ßƵ»ìºÏָʾ
High cut ¸ßÇÐ
High pass ¸ßͨ
Highway ×ÜÏߣ¬ÐÅϢͨµÀ
Hi-Fi high fidelity ¸ß±£Õ棬¸ß±£ÕæÒôÏì
Hiss ßÐÉù
Hi-Z ¸ß×迹
HL half reverb ´óÌü»ìÏì
Hoghorn Å×ÎïÃæÀ®°È
Hoisting ÌáÉý
Hold ±£³Ö£¬ÎÞÏÞÑÓÐø£¬±£³Öʱ¼ä
Holder Ö§¼Ü£¬¹Ì¶¨¼Ü
Hold-off ½â³ý±£³Ö
Home ¼ÒÍ¥£¬ÊµÓÃ
Home theatre ¼ÒÍ¥Ó°Ôº
Horizontal ˮƽµÄ£¬ºáÏòµÄ
Horn ¸ßÒôºÅ½Ç£¬ºÅͲ£¬Ô²ºÅ
Hornloaded ºÅ½Ç´¦Àí
Hot Èȶˣ¬¸ßµçλ¶Ë
Hour Сʱ
Howling Ð¥½ÐÉù
Howlround Ð¥½Ð
H.P headphone Í·´÷ʽ¶ú»ú
HPA haas pan allochthonous ¹þ˹ÉùÏñÆ¯ÒÆ
HPF high pass filter ¸ßͨÂ˲¨Æ÷
HQ high quality ¸ßÖÊÁ¿£¬¸ßƷλ
Hyper Condenser ³¬ÐÄÐ͵Ä
HZ hertz ºÕ×È
H hard Ó²µÄ£¨ÒôÏìЧ¹ûÌØÕ÷£©
2005-10-12 20:59:00 »Ø¸´
I
IC integrated circuit ¼¯³Éµç·
ID identification ʶ±ð
ID identify ±êÖ¾
Idle ¿ÕÔØµÄ£¬ÎÞЧ¹ûµÄ
IDTV improved definition television
¸Ä½øÇåÎú¶ÈµçÊÓϵͳ
IEC international electrical commission
¹ú¼Êµç¹¤Î¯Ô±»á
IEEE institute of electrical&electronic engineers
µçÆø¼°µç×Ó¹¤³Ìʦѧ»á
IF intermidiate frequency ÖÐÆµµÄ
I/F interface ½Ó¿Ú
IHF the institute of high fidelity ¸ß±£ÕæÑ§»á
IIR infinite-duration impulse response
ÎÞÏ޳弤ÏìÓ¦
IKA Interactive knee adapt
»¥µ÷¹ÕµãÊÊÅ䣬Èí¹Õµã I/O input/output ÊäÈë/Êä³ö
IM impulse modulation Âö³åµ÷¼Á
IM image Ó°Ïó
IMD intermodulation distortion »¥µ÷Ê§Õæ
IMP impedance ×迹
IMP impedence ×迹
IMP interface message processor ½Ó¿ÚÐÅÏ¢´¦Àí»ú
Improper ´íÎóµÄ
IN inductor ¸ÐÓ¦Æ÷
IN input ÊäÈë
IN inverter ·´ÑÝÆ÷£¬µ¹ÏàÆ÷
Inactive ÔÝÍ££¬Ê§Ð§µÄ
INC incoming ÒýÈëÏß
INC increase Ôö¸ß
INCOM intercom ÄÚ²¿Í¨»°£¨ÏµÍ³£©
In phase ͬÏà
IND index Ë÷Òý£¬±êÖ¾£¬Ö¸Êý
IND indicator ָʾÆ÷
Indicator ÏÔʾÆ÷£¬Ö¸Ê¾Æ÷
Indirect ¼ä½Ó
Inductance µç¸Ð
Induction ¸ÐÓ¦£¬ÒýÈë
INF infinite ÎÞÏÞ´ó
Infrared ºìÍâÏßµÄ
Infra-red remote control ºìÍâÏßÒ£¿Ø
INH inhibit ÒÖÖÆ£¬½ûÖ¹
Initial Éùĸ£¬³õʼ»¯
In/Out ¼ÓÓë²»¼ÓÑ¡Ôñ£¨Ï൱ÓÚÅÔ·£©¿ª¹Ø£¬½Óͨ¿ª¹Ø
Infinite ÎÞÏ޵쬷ÇÏÞ¶¨µÄ
Increase Ôö¼Ó
Initial Delay ÔçÆÚÑÓʱ£¬³õ´ÎÑÓʱ
Inject ×¢È룬ÖÃÈë Inlead ÒýÈëÏß
Inlet ÒýÈëÏߣ¬²åÈë In-line ´®ÁªµÄ£¬ÔÚÏßµÄ
INP input ÊäÈ루¶Ë¿Ú£©
INV invertor µ¹ÏàÆ÷£¬·­×ªÆ÷£¬·´ÏàÆ÷£¬±ä»»Æ÷
Inverse µ¹Ïà
Inverseve Rev µßµ¹Ê½»ìÏìЧ¹û
Invert ÂÖÁ÷£¬·´×ª
I/O in/out
ÊäÈë/Êä³ö£¨½Ó¿Ú£©£¬ÐźŲåÈë½Ó¿Ú I/O
instead of Ìæ´ú
IPE integrated parameter editing ×ۺϲÎÁ¿±à¼­
IR infrared sensor ºìÍâÏß´«¸ÐÆ÷
IROA impulse response optimum algorithm
Âö³åÏìÓ¦×î¼ÑËã·¨
IS information separators ÐÅÏ¢·Ö¸ô×Ö·û
IS in service ²»ÖжϷþÎñ
ISO International Standardization Organization¹ú¼Ê±ê×¼»¯×éÖ¯
Input ÊäÈë
Indicator ÏÔʾÆ÷£¬Ö¸Ê¾µÆ
INS insert ²åÈ루Ðźţ©£¬²åÈë½Ó¿Ú
INSEL input select ÊäÈëÑ¡Ôñ
INST instant Ö±½ÓµÄ£¬ÊµÊ±
INST institution ½¨Á¢£¬ÉèÖÃ
INST instrument ÒÇÆ÷£¬ÀÖÆ÷
Instrument ÀÖÆ÷
Insulator ¾øÔµÌå
INT intake ½øÈ룬Èë¿Ú INT intensity Ç¿¶È£¬ÁÒ¶È
INT interior ÄÚ²¿
INT interrupter ¶Ï·Æ÷
Integrated ×éºÏµÄ
Integrated amplifier
ǰÖÃ-¹¦ÂÊ·Å´óÆ÷£¬×ۺϹ¦ÂÊ·Å´óÆ÷
Intelligate ÖÇÄÜ»¯ÔëÉùÃÅ
Intelligibility ¿É¶®¶È
Interactie Ï໥×÷Óã¬ÈË»ú¶Ô»°£¬Èí¹Õµã
Interval Òô¸ß²î±ð
Integrated ¼¯³ÉµÄ£¬ÍêÈ«µÄ
Intercom ¶Ô½²£¬Í¨»°
Interconnect »¥ÏàÁªÏµ
Inter cut ²å²¥
Interface ½Ó¿Ú£¬¶Ô»°×°ÖÃ
Interference ¸ÉÈÅ£¬¸ÉÉæ£¬´®ÈÅ
Interim ÁÙʱµÄ£¬¹ý¶ÉÌØÕ÷
Intermodulation »¥µ÷£¬ÄÚµ÷ÖÆ
Intermodulation distortion ½»Ô½Ê§Õæ
Internal Äڴ棬¶Ô½²»ú
Internally ÔÚÄÚ²¿£¬ÄÚ´æ
Inter parameter ÄÚ²¿²ÎÊý
Interval Òô¸ß²î±ð
Interplay Ï໥×÷Óã¬ÄÚ²¿²¥·Å
Interval shifter ÒôÐªÒÆÏàÆ÷
Intimacy Ç×ÇиÐ
Intonation Éùµ÷
INTRO introduction ½éÉÜ£¬ä¯ÀÀ£¬ÒýÈ룬£¨ÀÖÇúµÄ£©Ç°×à
INTRO sacn ÇúÍ·¼ìË÷£¨½ÚÄ¿ËÑË÷£©
INTRO sensor ÇúÍ·¶Á³öÆ÷£¨½ÚÄ¿²éѯ£©
Introskip ÄÚÒÆ£¬ÄÚÌø
ISS insertion test signal ²åÈëÇл»ÐźÅ
ISS interference suppression switch ¸ÉÈÅÒÖÖÆ¿ª¹Ø
ITS insertion test signal ²åÈë²âÊÔÐźÅ
IV interval ¼ä¸ôËÑË÷
IV inverter µ¹ÏàÆ÷
IWC interrupted wave ¶ÏÐø²¨
IX index ±êÅÌ£¬Ö¸Õ룬Ë÷Òý
2005-10-12 21:49:00 »Ø¸´
yinpin666 Â¥Ö÷
J
jack ²å¿×£¬²å×ù£¬´«¶¯×°ÖÃ
Jack socket ²å¿×
Jaff ¸´¸ÉÈÅ
Jagg club ¾ôÊ¿ÀÖ¾ãÀÖ²¿Ð§¹û
Jam ÒÖÖÆ£¬¸ÉÈÅ
Jamproof ¿¹¸ÉÈŵÄ
Jazz ¾ôÊ¿
JB junction box ½ÓÏߺÐ
JIS ÈÕ±¾¹¤Òµ±ê×¼
Job ʼþ£¬×÷ÒµÖ¸Á³ÉÆ·
Jog ÐýÅÌ»º½ø£¬Âý½ø£¬Í»È»×ªÏò
Joker °µ²ØµÄ²»ÀûÒòËØ£¬º¬»ì²»Çå
Joystick ¿ØÖÆÊÖ±ú£¬²Ù×ݸˣ¬Ò¡¸Ë
JSS jet servo system ÅçÉäËÅ·þÊ½ÖØµÍÒôÑïÉùÆ÷ϵͳ
Jumper ÌøÏߣ¬ÌõÐÎ½ÓÆ¬
Justify µ÷Õû
quency divider ·ÖƵÆ÷
2005-10-12 21:56:00 »Ø¸´
K-L
K key °´¼ü
Karaoke ¿¨À­OK£¬ÎÞÈ˰é×àÀÖ¶Ó
KB key board ¼üÅÌ£¬°´Å¥
Kerr ¿Ë¶úЧӦ£¬£¨¿É¶Áд¹âÅÌ£©´Å¹âЧӦ
Key ¼ü£¬°´¼ü£¬Éùµ÷
Keyboard ¼üÅÌ£¬°´Å¥
Key control ¼ü¿Ø£¬±äµ÷¿ØÖÆ
Keyed ¼ü¿Ø
Key EQ Òôµ÷¾ùºâ
kHz Kiloherts ǧºÕ×È
Kikll Çå³ý£¬ÏûÈ¥£¬ÒÖÖÆ£¬Ë¥¼õ£¬¶Ï¿ª
Killer ÒÖÖÆÆ÷£¬¶Ï·Æ÷
Kit É趨
Knee ѹÏÞÆ÷¹Õµã
Knob °´Å¥£¬ÐýÅ¥£¬µ÷½ÚÆ÷
KP key pulse ¼ü¿ØÂö³å
KTV karaoke TV °è³ªµçÊÓ£¨½ÚÄ¿£©
KX key ¼ü¿Ø
Lesion ¹ÊÕÏ£¬Ëðº¦
Leslie ÁÐ˹Àû
£¨Ò»ÖÖµ÷ÏàЧ¹û´¦Àí·½Ê½£©
LEV level µçƽ
LEVCON level control µçƽ¿ØÖÆ
Level µçƽ£¬Ë®Æ½£¬¼¶
LF low frequency µÍƵ£¬µÍÒô
LFB local feedback ±¾»ú·´À¡£¬¾Ö²¿·´À¡
LFE lowfrequency response µÍƵÏìÓ¦
LFO low frequency oscillation µÍƵÕñµ´ÐźÅ
LGD long delay ³¤ÑÓʱ
LH low high µÍÔëÉù¸ßÊä³ö
LH low noise high output µÍÔëÉù¸ßÊä³ö´Å´ø
L.hall large hall ´óÌüЧ¹û
Lift ÌáÉý£¨Ò»ÖÖÌáÉýµØµçλµÄ×°Öã©
Lift up ÉýÆð
Labial ´½Òô
L left ×ó£¨Á¢ÌåÉùϵͳµÄ×óÉùµÀ£©
L line Ïß·
L link Á´Â·
L long ³¤£¨Ê±¼ä£©
LA laser ¼¤¹â£¨ÀØÉ䣩
Lag ÑÓ³Ù£¬Öͺó
Lamp µÆ£¬ÕÕÃ÷µÆ
Land ¹âÅÌÂÝÐýµÀµÄ¼ç£¬½ÓµØ£¬ÕæµØ
Lap dissolve Âýת»»
Lapping SW ͨ¶Ï¿ª¹Ø
Large ´ó£¬´óÐÍ
Large hall ´óÌü»ìÏì
Larigot Áù±¶Òô
Laser ¼¤¹â£¨ÀØÉ䣩
Latency ¿Õת£¬´ý»ú
Launching ¼¤Àø£¬·¢Éä
Layer ²ãµþ¿ØÖÆ£¬¶àÒôɫͬ²½¿ØÖÆ
LCD liquid crystal display Òº¾§ÏÔʾ
LCR left center right ×óÖÐÓÒ
LD laser vision disc ¼¤¹âÊÓÅÌ£¬Ó°µú»ú
LD load ¸ºÔØ
LDP input Ó°µúÊäÈë
LDTV low definition television
µÍ·Ö±æÂÊÊý×ÖµçÊÓ
LCD projictor Òº¾§Í¶Ó°»ú
Lead ͨµÀ£¬Ç°Öã¬ÊäÈë
Lead-in ÒýÈëÏß
Leak ©й
Learn ѧϰ
LED light emitting deivce ·¢¹â·øÉäÆ÷£¬·¢¹âÆ÷¼þ
LED litht emitting diode ·¢¹â¶þ¼«¹Ü£¨ÏÔʾ£©
Legato Á¬×à
Length ×Ö³¤£¬·¶Î§
Lento Âý°å
Light switch ÕÕÃ÷¿ª¹Ø
2005-10-12 23:11:00 »Ø¸´
M
M main Ö÷ÐŵÀ
M master Ö÷¿Ø
M memory ´æ´¢Æ÷
M mix »ìƵ
M moderate ÊÊÖеÄ
M music ÒôÀÖ
Mac manchester auto code ÂüÇÐË¹ÌØ×Ô¶¯Âë
MADI musical audio digital interface ÒôƵÊý×Ö½Ó¿Ú
Main Ö÷ÒªµÄ£¬Ö÷Ïߣ¬Ö÷ͨµÀ£¬µçÔ´
MAG magnet ´ÅÌú
Magnetic tape ´Å´ø
Magnetic type recorder ´Å´øÂ¼Òô»ú
Main µçÔ´£¬Ö÷ÒªµÄ
Major chord ´óÈýºÍÏÒ
Make ½Óͨ£¬±ÕºÏ
Makeup ½Óͨ£¬Ñ¡Åä
Male ²åÍ·£¬²å¼þ
MAN manual ÊÖ¶¯µÄ£¬ÊÖ¿Ø
Manifold technology £¨ÒôÏ䣩¶àÆç¹Ü¼¼Êõ
Manipulate ²Ù×÷£¬¼ü¿Ø
MANP ÊÖ¶¯´©²å
Manual ÊÖ¶¯µÄ£¬È˹¤µÄ£¬Êֲᣬ˵Ã÷Êé
March ½øÐÐÇú
Margin £¨µçƽ£©ÓàÁ¿
Mark ±êÖ¾£¬·ûºÅ£¬±ê¼Ç
Mash ѹµÍ£¬ÄëËé
Masking ÑÚ±Î
Master ×ÜÒôÁ¿¿ØÖÆ£¬µ÷Òǫ̂£¬Ö÷ÅÌ£¬±ê×¼µÄ£¬Ö÷µÄ£¬×Ü·
MAR Matrix ¾ØÕ󣬵÷Òǫ̂¾ØÕó£¨M£©£¬±à×é
Match Æ¥Å䣬ÊÊÅ䣬Åä¶Ô
Matrix quad system ¾ØÕóËÄÉùµÀÁ¢ÌåÉùϵͳ
MAX maximum ×î´ó£¬×î´óÖµ
MB megabytes Õ××Ö½Ú
Mb/s megabytes per second Õ××Ö½Ú/Ãë
MC manual control ÊÖ¿Ø£¬ÊÖ¶¯¿ØÖÆ
MCH multiple chorus ¶à·ºÏ³ª
MCR multiple cjhannel amplification reverberation
¶à·»ìÏìÔöÇ¿
MD mini disc ¹â´ÅÅ̳ª»ú£¬Ð¡Ðͼ·Å³ªÅÌ
MD moving coil ¶¯È¦Ê½
MDL modulation delay µ÷ÖÆÑÓʱ
MEAS measure ²âÁ¿£¬·¶Î§£¬²âÊÔ
Measure ÀÖÇúµÄ£¬Ð¡½Ú
Meas edit С½á±à¼­
MECH mechanism »úеװÖÃ
MED medium ÊÊÖУ¬Öм䣨µ²Î»£©
Medley »ìºÏ
Mega bass ³¬ÖصÍÒô
MEM memory ´æ´¢Æ÷£¬´æ´¢£¬¼ÇÒä
Member ²¿¼þ£¬³ÉÔ±
Menu ²Ëµ¥£¬Ä¿Â¼£¬±í¸ñ
MEQ mono equalizer µ¥ÉùµÀ¾ùºâÆ÷
Merge ºÏ²¢£¬»ã×Ü£¬ÈÚºÏ
Meridian ¶¥µãµÄ£¬·åÖµ
Measure С½á
Megaphone À®°ÈͲ
Mel ÃÀ£¨Òôµ÷µ¥Î»£©
Menu ²Ëµ¥£¬½ÚÄ¿±í
Message ͨÐÅ£¬ÁªÏµ
Metal ½ðÊô£¨Ð§¹ûÉù£©
Metal tape ½ðÊô´Å´ø
Meter µçƽ±í£¬±íÍ·£¬ÒDZí
Metronome ½ÚÅÄÆ÷
MF matched filter Æ¥ÅäÂ˲¨Æ÷
MF maveform ²¨ÐÎ
MF middle frequency ÖÐÆµ£¬ÖÐÒô
MFL multiple flange ¶à²ã·¨À¼£¨Ïâ±ß£©Ð§¹û
MFT multiplprogramming with a fixed number of tasks
ÈÎÎñÊýÁ¿¹Ì¶¨µÄ¶àͨµÀ³ÌÐòÉè¼Æ
MIC micro ΢Ã×
MIC microphone »°Í²£¬Âó¿Ë·ç£¬´«ÉùÆ÷
Michcho level »°Í²»ìÏìµçƽ
Micro monitor amp ΢Òô¼àÌý·Å´óÆ÷
MICROVERB microcomputer reverb ΢´¦Àí»ú»ìÏì
MID middle ÖмäµÄ£¬Öв¿µÄ£¬ÖÐÒô£¬ÖÐÆµ
MIDI music instrument digital interface
µç×ÓÀÖÆ÷Êý×Ö½Ó¿Ú
MIN minimum ×îС£¬×îСֵ
MIN minute ·ÖÖÓ
MIND master integrated network device
Ò»Ìå»¯ÍøÂç×Ü×°ÖÃ
Minitrim ΢µ÷
Minitrue ΢»úµ÷Õû
Minor chord СÈýºÍÏÒ
Mismatch ʧÅä
Mistermination ÖÕ¶ËʧÅä
MIX »ìºÏ£¬ÒôÁ¿±ÈÀýµ÷½Ú
Mixer µ÷Òǫ̂£¬»ìÒôÆ÷
MM moving magnet ¶¯´Åʽ
MNTR monitor ¼à¿ØÆ÷
MNOS metallic nitrogen - oxide semiconductor
½ðÊôµªÑõ»¯Îï°ëµ¼Ìå
MO magneto optical ¿ÉĨ¿É¼Ð͹âÅÌ
MOC magnet oscillator circuit Ö÷Õñµ´µç·
MOD mode ״̬£¬·½Ê½£¬Ä£Ê½
MOD model Ðͺţ¬Ñùʽ£¬Ä£ÐÍ£¬µäÐ͵Ä
MOD modulation µ÷ÖÆ
Mode ״̬£¬£¨ÀÖÇúµÄ£©µ÷ʽ
Mode select ·½Ê½Ñ¡Ôñ
Mush ÔëÉù¸ÉÈÅ£¬·Öг²¨
Mush area ²»Á¼½ÓÊÕÇø
Music ÒôÀÖ£¬ÀÖÇú
Music center ÒôÀÖÖÐÐÄ£¬×éºÏÒôÏì
Music conductor ÒôÀÖ¿ØÖÆÆ÷
MUT mute ¾²Òô£¬ÑÆÒô£¬ÔëÉù¿ØÖÆ
Muting ÒÖÖÆ£¬Ïû³ý
Multiple ¸´ºÏµÄ£¬¶àÏîµÄ£¬¶àÖØµÄ
MV mean value ƽ¾ùÖµ
MV multivibrator ¶àгÕñµ´Æ÷
MW medium wave Öв¨
MXE mono exciter µ¥ÉùµÀ¼¤ÀøÆ÷
MXR mixer »ìƵÆ÷ Name Ãû³Æ£¬ÃüÃû
MODEM modulator demodulator µ÷ÖÆ½âµ÷Æ÷
Moderato ÖÐËÙ
Modifier µ÷½ÚÆ÷
Modify Ð޸쬵÷ÊÔ£¬Ä¦»ú£¬ÏÞ¶¨
Modulator µ÷ÖÆÆ÷
Module Ä£¿é£¬×é¼þ£¬ÒòÊý£¬³ÌÐòƬ
MOL maximum output level ×î´óÊä³öµçƽ
MON monitor ¼àÌý£¬¼àÊÓÆ÷
MONI ¼àÌý£¬µ÷Òôʦ
Monkey chatter ´®Òô£¬ÁÚÆµ¸ÉÈÅ£¬½»²æÊ§Õæ
Mono µ¥ÉùµÀ£¬µ¥Ò»
Monopit µ¥Éù±äµ÷
Motor cue »»»úÐźţ¬Çл»ÐźÅ
MOS metal-oxide semiconductor ½ðÊôÑõ»¯Îï°ëµ¼Ìå
Motor Âí´ï£¬µç»ú
Movie theater Ó°¾çÔº
Moviola Éù»­¼ô¼­»ú
Moving-iron loudspeaker Éà»ÉÑïÉùÆ÷
MPEG motion picture coding experts group
»î¶¯Í¼Ïñ±àÂëר¼Ò×飬Êý×ÖÉùÏñÐÅϢѹËõ±ê×¼
MPF master pre feed Ö÷¿ØÇ°À¡ËÍ
MPH multiple phaser ¶à¼¶ÒÆÏàÆ÷
MPO maximum power output ×î´óÊä³ö¹¦ÂÊ
MPO music power output ÒôÀÖÊä³ö¹¦ÂÊ
MPR master pre return Ö÷¿ØÇ°·µ»Ø
MPS main power switch Ö÷µçÔ´¿ª¹Ø
MPS manual phase shifter ÊÖ¿ØÏàÒÆÆ÷
MPS microphone power supply »°Í²µçÔ´
MPS microprocessor system ¶àÓÃ;ȡÑùϵͳ
MPX multiplex ¶à·´«Ê䣬¶à´ÎÖØ¸´Ê¹Ó㬶à·ת»»£¬¸´ºÏ
MPX multiplexer ¶à·ת»»Æ÷£¬¶à·µ÷ÖÆÆ÷
MPX VCO ¶à·½âµ÷ѹ¿ØÕñµ´
MQSS music quick select system ¿ìËÙÒôÀÖÑ¡Ôñϵͳ
MR memory read ´æ´¢Æ÷¶Á³ö
MS manual search ÊÖ¶¯¼ìË÷
MS middle side Ò»ÖÖµüºÏ¼Òô¼¼Êõ
MS(MSEC) millisecond ºÁÃë
MSSS multi space ound system ¶àά¿Õ¼äÉùϵͳ
MST(MSTR) master Ö÷¿Ø
MSW microswitch ΢¶¯¿ª¹Ø
MT multi track ¶à¹ì
MTD multiple delay ¶à´ÎÑÓʱ
MTR magnetic tape redorder ´Å´ø¼Ç¼Æ÷
MTR micro-wave transmission ΢²¨´«Êä
MTR motor µç¶¯»ú
MTS multi-channel television sound ¶àÉùµÀµçÊÓ°éÒô
MTV music TV ÒôÀÖµçÊÓ£¨½ÚÄ¿£©
MUF maximum usable frequency ×î¸ß¿ÉÓÃÆµÂÊ
MULT multiplier ±¶ÔöÆ÷£¬¹âµç±¶Ôö¹Ü
Multi ²¢ÁªµÄ£¬¶à·ϵͳ
Multidimention control Éù³¡Õ¹¿í¿ØÖÆ£¬¶àά¿ØÖÆ
Multiband ¶àƵ¶Î
Multi-echo ¶àÖØ»ØÉù
Multi plex ¶à·´«Éù
Multitap ת½Ó£¬£¨¶à²åÍ·£©²å×ù
Multiple channel ¶àͨµÀ
Multiple effects ×ÛºÏЧ¹û´¦Àí×°ÖÃ
Multiple jack ¶àÑÛ²å×ù
Multisound ԭʼÒôÉ«
MUPO maximum undistorted power output
×î´ó²»Ê§ÕæÊä³ö¹¦ÂÊ
MUSE multiple sub-Nyquist sompling encoding
¶àÖØÄοüË¹ÌØÈ¡Ñù±àÂë
MIDI ¸ñʽÎļþ
MIDI ÐÅÏ¢£¬È«¹ý³Ì
2005-10-12 23:25:00 »Ø¸´
N
Natural ×ÔÈ»µÄ£¬ÌìÈ»µÄ£¬¹ÌÓеÄ
Naught Á㣬ÎÞ¼ÛÖµ
NC network controller ÍøÂç¿ØÖÆÆ÷
NC numberical control Êý×Ö¿ØÖÆ
NC needle chatter ³ªÕëÔëÉù
Nazard Èý±¶Òô
Near field ½ü³¡
NEG negative ¸º£¬Òõ£¨¼«£©
NEMO ʵ¿öת²¥
NEP noise equivalent power ÔëÉùµÈЧ¹¦ÂÊ
News ÈËÉù¹ã²¥ÒôÏìЧ¹û£¬ÐÂÎÅ
Next ÏÂÒ»¸ö£¬³ªÆ¬Ìø»ØÏÂÇú¼ü
NF NFB negative feedback ¸º·´À¡
NG no go ²»Í¨£¬²»¹¤×÷
NG noise generator ÔëÉù·¢ÉúÆ÷
Ni-Cd nickel-cadmium ÄøïÓ³äµçµç³Ø
NICAM near instantaneous companded audio multiplex׼˲ʱѹÀ©ÉùÒô¶à·¸´Ó㬵çÊÓÀöÒô£¬Êý×Ö¶à·°éÒôϵͳ
NIL Áãµã
N normal Õý³££¬ÆÕͨ£¬±ê×¼
N negative Òõ¼«£¬¸º¼«
Noise ÔëÒô
Noise gate ÔëÉùÃÅ£¬Ñ¡Í¨Æ÷
Noise suppressor ÔëÉùÒÖÖÆÆ÷
NOM nominal ±ê³ÆµÄ£¬¶î¶¨µÄ
Non-direction È«ÏòµÄ£¬ÎÞÖ¸ÏòÐÔµÄ
Nonieme ¾Å±¶Òô
NOP no operation ÎÞ²Ù×÷Ö¸Áî
NOR(NORM) normal ÆÕͨµÄ£¬±ê×¼µÄ£¬Õý³£µÄ£¬³£¹æµÄ
NORM ƽ¾ùÖµ
Normal frequency ¼òÕý£¨¹²Õñ£©ÆµÂÊ
Notch ´¥µã
Note ·ûºÅ£¬×¢ÊÍ£¬Òôµ÷£¬ÒôÂÉ£¬¼Ç¼
Notice ×¢ÒâÊÂÏ¼ò½é
NO number Êý×Ö£¬ºÅÂë
NR noise ratio ÔëÉù±È
NR noise reduction ½µÔ룬ÔëÉùÏû³ý
NR number Êý×Ö£¬±àºÅ
NAB national association of broadcasters
¹ú¼Ò¹ã²¥¹¤×÷ÕßЭ»á
NTSC national television system committee£¨ÃÀ¹ú£©¹ú¼ÒµçÊÓϵͳίԱ»á£¬Õý½»Æ½ºâµ÷·ùÖÆ²ÊÉ«µçÊÓÖÆÊ½
Null ¿Õ룬ÎÞЧµÄ
NV noise variance ÔëÉù·½²î
NVT network virtual terminal ÍøÂçÐéÄâÖÕ¶Î
2005-10-12 23:27:00 »Ø¸´
O
ohm Å·Ä·£¨µç×èµÄµ¥Î»£©
Oboe Ë«»É¹Ü
O/C open circuit ¿ªÂ·
OCK operation control key ²Ù×÷¿ØÖƼü
OCL output capacitorless ÎÞÊä³öµçÈݹ¦ÂÊ·Å´óÆ÷
OCL output control line Êä³ö¿ØÖÆÏß
OCT octave ±¶Æµ³Ì£¬°Ë¶ÈÒô
OD operations directive ²Ù×÷ָʾ
OD optical density ¹âÃܶÈ
OD over drive ¹ý¼¤Àø
OFC office Ö°ÄÜ
OFC oxygen-free cupreous ÎÞÑõÍ­µ¼Ïß
Off ¹Ø±Õ£¬¶Ï¿ª
Offering ÌîÈ룬Ìṩ
Offset £¨ÒÆÏࣩ²¹³¥£¬ÐÞÊΣ¬Æ«ÖÃ
OFHC oxygen free high conductivity copper
¸ßµ¼µçÂÊÎÞÑõÍ­µ¼Ïß
Ohm Å·Ä·
OK È·ÈÏ
OL on line ÔÚÏߣ¬Á¬»ú
OL over load ¹ýÔØ
Omnidirectional ÎÞ·½ÏòÐÔµÄ
On ¿ª£¬½Óͨ
Once Ò»´Î£¬µ¥´Î
One-way relay play µ¥ÏòÌæ»»·ÅÒô
Online Áª»ú£¬ÁªÏß
Only ½ö½ö£¬Ö»
On-mike ÕýÔÚËÍ»°£¬¿¿½ü»°Í²
One touch µ¥´¥Á¬½Ó
OP output ÐźÅÊä³ö
OP over pressure ¹ýѹ
Open ´ò¿ª£¬¿ªÆô
Opera ¸è¾ç
Operate ²Ù×÷£¬ÔËת
Operation ²Ù×÷£¬ÔËת
Operator ²Ù×ÝÆ÷£¬ºÏ³ÉÆ÷Ëã×Ó
Optical ÊýÂë¹âÀ½ӿÚ
Optical master ¼¤¹âÆ÷
Option Ñ¡ÐÍ£¬Ñ¡Ôñ
Optimum ×î¼Ñ״̬
OPTOISO optoisolator ¹â¸ôÀëÆ÷
Or »ò£¬»òÕß
ORC optimum recording current ´ÅÍ·×î¼Ñ¼Ç¼µçÁ÷
Orchestra ¹ÜÏÒÀÖÆ÷
Organ ·çÇÙ£¬Ôª¼þ Original Ô­£¨³ÌÐò£©£¬³õʼ£¨»¯£©
OSC oscillator Õñµ´Æ÷£¬ÊÔ»úÐźţ¨Ò»Ç§ºÕ×È£©
OSC oscillograph ʾ²¨Æ÷
OSS optimal stereo signal ×î¼ÑÁ¢ÌåÉùÐźÅ
OTL ÎÞÊä³ö±äѹÆ÷¹¦ÂÊ·Å´óÆ÷
OTR one-touch time recording µ¥´¥Ê½¶¨Ê±Â¼Ïñ
OTR operation temperature range ¹¤×÷ζȷ¶Î§
OTR overload time relay ¹ýÔØÏÞʱ¼ÌµçÆ÷
OUT output Êä³ö
Outage ÖжÏ
Out-burst Âö³å£¬ÉÁ¹â£¬ÉÁÁÁ
Outcome ½á¹û£¬Êä³ö£¬¿ªÊ¼
Out let Êä³ö¶Ë×Ó£¬Òý³öÏß
Outline ÂÖÀªÏß
Out phase ·´Ïò
OVDB ÖØµþ¼Òô
Overall ÂÖÀª£¬×ÜÌåÉÏ
Overcut ¹ýµ÷ÖÆ
Over drive ¹ý¼¤Àø
Overdubs µþ¼
Overflow ÐźŹýÇ¿
Overhang £¨¼¤ÀøÆ÷£©µÍÒôÑÓÉìµ÷½Ú
Overhearing ´®Òô
OVLD over lode ¹ýÔØ£¬³¬¸ººÉ
Over sampling ¹ýÈ¡Ñù
Overtone ·ºÒô
OVWR overwrite ¸²¸Çʽ¼Òô
2005-10-12 23:28:00 »Ø¸´
P
Proximity effect ½ü¾àÀëЧ¹û
Prwsnt Í»³ö¸Ð
PS position λÖã¬×´Ì¬
PSC program switching center ½ÚÄ¿Çл»ÖÐÐÄ
PSL phase sequence logic Ïàλ˳ÐòÂß¼­
PSM peak selector memory ·åֵѡÔñ´æ´¢Æ÷
PSM phase shifter module ÒÆÏàÄ£¼þ
PSM pitch shift modulation ½»Æµµ÷ÖÆ
PST posterrior ºóÃæ
PST preset Ô¤ÖÃ
PSU power supply ¹©µç
Psychological acoustics ÐÄÀíÉùѧ
PT power transformer µçÔ´±äѹÆ÷
PT portable ±ãЯʽ
PT pulse timer Âö³å¼ÆÊ±Æ÷
PTD pan turnout piece delay ÉùÏñ·ÖÖ§ÑÓʱ
PTE private רÓõÄ
PTN pattern ģʽ£¬Ñùʽ
PTN procedure turn ³ÌÐò±ä»¯
PU pickup ʰÒô
PU power unit µçÔ´É豸
Pull À­£¬Ç÷Ïò
Pull-in ½Óͨ£¬ÒýÈë
Pumping ³éÆøÐ§Ó¦
Pure tone ´¿Òô
Purging ¾»»¯
Push ÍÆ£¬°´Å¥£¬Ñ¹
Push-pull ÍÆÍìʽµÄ
PWM pulse width modulation Âö³å¿í¶Èµ÷ÖÆ
PWR power µçÔ´£¬¹¦ÂÊ
PZM pressure zone microphone ѹÁ¦Çø»°Í²
P.P.Panoramic potentiometer È«¾°µçλÆ÷
P-P peak-Peak ·å-·åÖµ
PPD pingpong delay ƹÅÒÑÓʱ
PPG programme pulse generator Âö³å³ÌÐò·¢ÉúÆ÷
PPI peak program indicator ·åÖµÏÔʾÆ÷
PPI programmable peripheral interface ³ÌÐòÍⲿ½Ó¿Ú
PPL peak program level ·åÖµÒôÁ¿µçƽ
PPM peak program meter ·åÖµ½ÚÄ¿±í£¬·åÖµÒôÁ¿±í
PPM pulse phase modulation Âö³åÏàλµ÷ÖÆ
Pr power rate ¹¦ÂʱÈ
PR program register ³ÌÐò¼Ä´æÆ÷
PRC precision ¾«È·£¬¾«Ï¸£¬¾«ÃܶÈ
Pre ǰÖã¬Ô¤±¸£¬Ö®Ç°
Pre-delay Ô¤ÑÓ³Ù
Pre echoes Ô¤»ØÉù
Pre emphasis Ô¤¼ÓÖØ
PREAMP preamplifier ǰÖ÷ŴóÆ÷
Preselection Ԥѡ
Presence ÁÙ³¡Ð§¹û£¬ÏÖ³¡¸Ð
Present µ±Ç°ÈÕÆÚ£¬ÏÖʱ£¬¼´Ê±
Preserve ±£´æ£¬Î¬³Ö
Preset Ô¤Öã¬Ô¤µ÷
Press °´£¬Ñ¹
PREV ³ªÆ¬Ìø»ØÉÏÇú¼ü
Preview Ô¤ÑÝ
Previous Ïòǰ£¬Ç°Î»µÄ
Prime ͬ¶ÈÒô
PRM parameter ²ÎÁ¿
PRO professional רҵµÄ
Probe ´«¸ÐÆ÷
Process ´¦Àí£¬¼Ó¹¤
PROCR processor ´¦ÀíÆ÷
PROG program ³ÌÐò£¬»ù±¾ÒôÉ«
Program cartridge ³ÌÐòºÐʽ´æ´¢Æ÷
Program set indicator µçÄÔÑ¡Çú½ÚĿѡ¶¨Ö¸Ê¾
Prosody ÔÏÂÉ
Protect ±£»¤£¬·À»¤
Protocol ͨÐÅЭÒé
POSTF ºóÖã¨Íò·Ö£©
POT potentiometer µçλÆ÷£¬µçλ¼Æ
Potable ±ãЯµÄ£¬Ð¡Ð͵Ä
Power µçÔ´£¬¹¦ÂÊ
Power amplifier ¹¦ÂÊ·Å´óÆ÷
Power dump ÇжϵçÔ´
Power out ¹¦ÂÊÊä³ö
Piower supply µçÔ´¹©¸ø
PP peak power ·åÖµ¹¦ÂÊ
PP personal preference ¸öÈËÔ¤ÖÃP plug ²åÍ·
P positive Õý¼«
P pulse Âö³å
P power ¹¦ÂÊ
PA preamplifier ǰÖ÷ŴóÆ÷
PA public address À©Éù
Pace ²½ËÙ£¬¼¶Êý
Packed cell »ý²ãµç³Ø
Packing ͼÏñѹËõ
P-I-P picture in picture »­Öл­
PAD ¶¨ÖµË¥¼õ£¬Ë¥¼õÆ÷£¬£¨´ò»÷ÀÖ´ó°´¼üµÄ£©¹Äµæ
Padding ͳµ÷£¬Ê¹¡­¡­Æ½Ö±
Paddle ¿ª¹Ø£¬Ãŵç·
Page Ò»Ãæ£¬£¨´æ´¢Æ÷£©Ò³ÃæµØÖ·£¬Ñ°ÕÒ
Pair £¨Á¢ÌåÉù£©Åä¶Ô£¬±È½Ï
PAL phase alternation line ÖðÐе¹Ïà²ÊÉ«µçÊÓÖÆÊ½
PAM pulse amplitude modulation Âö·ùµ÷ÖÆ
PAM pole amplitude modulation ¼«µãµ÷·ù
Pan panorama ÉùÏñµ÷½Ú£¬¶¨Î»£¬È«¾°
Panel Ãæ°å£¬²Ù×ݰ壬ÅäµçÅÌ
Panotrope µç³ª»ú
Paper cone Ö½Åè
Parallel ²¢Áª£¬Æ½ºâ
PAR(PARAM) parameter ²ÎÊý£¬²ÎÁ¿£¬ÏµÊý
Parametric ²ÎÁ¿µÄ
Part Éù²¿Êý£¬²¿·Ö
Partial tone ·ÖÒô£¬·ºÒô
PAS public address system À©Éùϵͳ
PASC precision adaptive subband coding
¾«ÃÜ×ÔÊÊÓ¦·Ö¶Î±àÂë
Pass ͨ¹ý
Passive ±»¶¯£¬±»¶¯·ÖƵ£¬¹¦ÂÊ·ÖÆµ
Paste Õ³Ìù
PAT pattern Ä£·Â£¬Ðͺţ¬Í¼Æ×ÌØÐÔÇúÏß
Patch ÁÙʱ£¬²å½ÓÏߣ¬ÓÃÁ¬½ÓµçÀ²åÈë
Patch bay ÅäµçÅÌ
Patch board ²åÏß°å
Patching ÁÙʱ½ÓÏߣ¬²¹³¥
Patching cord system µ÷¶ÈÈûÉþϵͳ
Path ÐźÅͨ·
Pattern Ñùʽ£¬·½Ê½£¬Ñù°å
Pause ÔÝÍ££¬¼äЪ£¬Í£¶Ù
PB playback ²¥·Å£¬ÖØ·Å
PB push button °´Å¥¿ª¹Ø
PBASS proper bass active supply system
×î¼ÑµÍÒôÖØ·Åϵͳ
PBC play back control ÖØ·Å¿ØÖÆ£¬»Ø·Å¿ØÖÆ
PC perceptual coding ¸Ð¾õ±àÂë
PC program control ³ÌÐò¿ØÖÆ
PCB printed circuit board Ó¡Ë¢Ïß·°å
PCC phase correlation cardioid microphone
ÏàλÏà¹ØÐÄÐλ°Í²
PCM precision capacitor microphone ¾«ÃܵçÈÝ»°Í²
PCM pulse code modulation Âö³å±àÂëµ÷ÖÆ
PCM card ²¨ÐÎÀ©³ä¿¨£¨Ôö¼ÓÐÂÒôÉ«£©
PC-COC pure copper continuous casting Á¬ÐøÖýÔì´¿Í­µ¼Ïß
PD power divider ¹¦ÂÊ·ÖÅäÆ÷
PD power doubler ¹¦Âʱ¶ÔöÆ÷
PD program directive ³ÌÐòÖ¸Áî
PD pro-digital רҵÊý×Ö½Ó¿Ú
PD protective device ±£»¤×°ÖÃ
PDM pulse density modulation Âö³åÃܶȵ÷ÖÆ
PDP plasma display panel µÈÀë×ÓÏÔʾ°å
PDS partitioned data set ·ÖÇøÊý¾Ý×é
PDS programmable data system ³ÌÐò¿É¿ØÏµÍ³
PDS power distribution system Åäµçϵͳ
PE phase encoding Ïàλ±àÂë
PE program execution ³ÌÐòÖ´ÐÐ
Peak ·åÖµ£¬Ï÷²¨£¨µÆ£©
Peak and dip ·åʽƵÂÊÅ·ÖÞ±ê×¼21½ÅAV½Ó¿Ú
Pedal ̤°å
PEM pulse edge molulation Âö³å±ßÔµµ÷ÖÆ
Pentatonic ÎåÉùµ÷ʽ
PEQ parameter equalizer ²ÎÁ¿¾ùºâÆ÷
PERC percussion ´ò»÷ÀÖÆ÷
PERCUS ´ò»÷ÀÖÆ÷
Performance Ê©ÐУ¬±íÑÝ£¬±íÏÖ£¬Ñݳö
Permalloy head ÆÂĪºÏ½ð´ÅÍ·
Permutator ת»»¿ª¹Ø£¬±ä»»Æ÷
Perspective Á¢Ìå¸Ð
Perform Ö´ÐУ¬Íê³É£¬Ê©ÐÐ
Period ÖÜÆÚ
PFL per fader louder speaker Ë¥¼õǰ¼àÌý£¬Ô¤¼àÌý
PG pulse generator Âö³å·¢ÉúÆ÷
PGM program ½ÚÄ¿£¬³ÌÐò
Pgmno/Step ½ÚÄ¿ºÅÂë/²½Öè
Pgmtime ½ÚĿʱ¼ä
PH phase Ïàλ
PH phasemeter ÏàλÒÇ
PHA phase Ïàλ
Phantom »ÃÏñµçÔ´£¬»ÃÏ󹩵ç
Phase Ïàλ£¬×´Ì¬
Phase REV µ¹Ïࣨµç·£©
Phaser ÒÆÏàÆ÷
Phasing ÏàλУÕý£¬ÒÆÏàЧ¹û
Phon ·½£¨Ïì¶Èµ¥Î»£©
Phone ¶ú»ú£¬¶ú»ú²å¿Ú
Phoneme ÒôËØ
Phono(phonograph) ³ª»ú
PHS phaser ÒÆÏàÆ÷
Physiological acoustics ÉúÀíÉùѧ
PI phase inversion µ¹Ïà
PIA peripheral interface adapter ÍâΧ½Ó¿ÚÊÊÅäÆ÷
Pianotron µç×Ó¸ÖÇÙ
Piano ¸ÖÇÙ
Piano whine ¸ÖÇÙÃùÉù
Piccolo ¶ÌµÑ
Pick-up ʰÒôÆ÷£¬³ªÍ·£¬´«¸ÐÆ÷
Piezoelectric polymer earphone ѹµç¾ÛºÏÎï¶ú»ú
Pilot ָʾÆ÷£¬µ÷½ÚÆ÷
Pilot jack ¼àÌý²å¿×
Pin ÕëÐͲå¿Ú£¬²»Æ½ºâÒôƵ²å¿Ú
PIN position indercator λÖÃָʾÆ÷
PIN positive-intrinsic-negative Õý-±¾-¸º
Pinboard ת½Ó°å£¬²å½Ó°å
Ping ±¬ÃùÉù£¬ÉùÏì
Pink noise ·ÛºìÔëÉù
Pipe ¹Ü£¬µÑ
Pitch Òô¸ß£¬Òôµ÷
Pitch shifter ±äµ÷Æ÷£¬ÒÆÆµÆ÷
PK peak Ï÷²¨£¨µÆ£©£¬·åÖµ
PL parental lock ·ÀÖ¹Îó¶¯Ëø¶¨
PL phase lock ÏàÎ»Ëø¶¨£¬ËøÏà
PL pilot lamp ָʾµÆ
PL pre listen Ô¤¼àÌý£¬Ë¥¼õǰ¼àÌý
Place ÖÃÈ룬Æð×÷ÓÃ
Placement Á¬½Ó·½Ê½
Plate ½ðÊô°åЧ¹û£¬°å»ìÏìÆ÷
Play ²¥·Å£¬ÖØ·Å£¬µ¯×à
Playback ²¥·Å
Player ³ª»ú£¬·ÅÒôÆ÷
Plesoelectric supper tweeters ѹµçʽ³¬¸ßÒôÀ®°È
PLL phase locked loop ËøÏà»ØÂ·
PLR plate reverb ½ðÊô°å»ìÏì
Plug ²åÍ·
Plunge ÇÐÈë
PMPO peak music power output ÒôÀÖ·åÖµ¹¦ÂÊÊä³ö
PN pseudo noise Î±Ëæ»úÔëÉù
Pneumatic loudspeaker Æø¶¯ÑïÉùÆ÷
PNM pulse number modulation Âö³åÊýµ÷ÖÆ£¬Âö³åÃܶȵ÷ÖÆ
Point ½Óµã£¬Î»Ö㬽»»ãµã
Point soure µãÉùÔ´
Pointer ָʾÆ÷£¬Ö¸Õë
Polarity ¼«ÐÔ
Poly ¸´Òô£¬¶à·£¬¶à
Pop ͻȻ£¬±¬ÆÆÒô£¬£¨»°Í²½ü½²Ê±µÄ£©ÆøÏ¢àÛàÛÉù
Pop filter àÛÉùÂ˳ýÆ÷
Pops Á÷ÐÐÒôÀÖ£¬Á÷ÐÐÒôÀÖÒôÏìЧ¹û
Portamento »¬Òô
Ported reflex Ô¤·ÅÓ³
Position λÖã¬×´Ì¬
POSITVE positive Ñô¼«
2005-10-12 23:47:00 »Ø¸´
Q-R
Q quality factor Æ·ÖÊÒòÊý£¬QÖµ£¬Æµ´ø¿í¶È
QD quadrant ÏóÏÞ
QD quick disconnect ѸËÙ¶Ï¿ª
Quack àÐÔÓÉù
QUAD quadriphonic ËÄÉùµÀÁ¢ÌåÉù
Quadrature Õý½»£¬90¶ÈÏàλ²î£¬¾«µ÷
Quality ÒôÖÊ£¬ÉùÒô
QUANT quantitative ¶¨Á¿µÄ
QUANT quantize Á¿»¯£¬Êý×Ö»¯
Quantizing Á¿»¯
Quartz synthesized FM/AM digital tuner
ʯӢ¾§Ì寵ÂʺϳÉʽµ÷Ƶ/µ÷·ùÊý×Öµ÷гÆ÷
Quartz PLL frequency synthesizer ¾§ÌåÏúÏ໷ƵÂÊ
Quaver °Ë·ÖÒô·û
Quench ¶Ï¿ª£¬ÒÖÖÆ
Quint Îå¶È£¬´ÎÈý±¶Òô
Quiver ²ü¶¯Éù
Ribbon microphone ÂÁ´ø»°Í²£¬Ñ¹Á¦´ø»°Í²
Richness ·áÂú¶È
Rhythm ½Ú×à
Right ÓÒÉùµÀ£¬´¹Ö±µÄ£¬Êʵ±µÄ
Ring »·£¬´óÈýо»·¶Ë£¬Àä¶Ë½Óµã£¬ÕñÁå
Ring mode Éù·´À¡ÁÙ½çÕñÁåÕñµ´ÏÖÏó
Rit ½¥Âý
RF radio frequency É䯵£¬¸ßƵ
RM regular matrix record Õý¹æ¾ØÕóʽËÄ·³ªÆ¬
RM ring modulation »·Ðε÷ÖÆÆ÷
RMD fing mode decoupling £¨ÒôÏ䣩ÕñÁåÍËñî¼¼Êõ
RMR room reverb ·¿¼ä»ìÏì
RMS random music sensor Ëæ»úÒôÀÖ̽²âÆ÷
Rms root mean square ÓÐЧֵ
RND random Ëæ»úµÄ
RNG ring ÕñÁå
Roadrack רҵÆ÷²Ä¼Ü
Rock Ò¡¹öÀÖ¡¢Ò¡¹öÀÖÒôÏìЧ¹û
Rod antenna À­¸ËÌìÏß
RODS reverberation on demand system »ìÏìÇëÇóϵͳ
Rolloff ¸ßµÍƵ¹æÂÉÐÔË¥¼õ£¬¹ö½µ
ROM read only memory Ö»¶Á´æ´¢Æ÷
Room ·¿¼ä
Rose ½ÓÏߺÐ
Rotary Ðýת
RT60 Reverberation time »ìÏìʱ¼ä
Rough ´ÖµÄ£¬´Ö²ÚµÄ£¬½üËÆµÄ
Routing »ìºÏĸÏßÑ¡Ôñ
RP record playback ¼·Å
RP repeater ÔöÒôת·¢Æ÷
RPLC replace Ìæ»»
RSS Roland sound space processing system
ÂÞÀ¼Éù¿Õ¼ä´¦Àíϵͳ
RT rael time ʵʱ·ÖÎö
RT recovery time »Ö¸´Ê±¼ä
RT return ·µ»Ø
RTA real time analyzer ʵʱ·ÖÎö£¨ÒÇ£©£¬ÆµÆ×·ÖÎö£¨ÒÇ£©
RTS real time simulator ʵʱģÄâ
RTS real time system ʵʱϵͳ
RTY rotary Ðýת£¨ÑïÉùÆ÷£©
Rubber corrugated ri loudspeaker ÏðÆ¤±ßÑïÉùÆ÷
Ruby stylus ºì±¦Ê¯³ªÕë
Rumba Â×°Í
Rumble £¨µÍƵ£©Â¡Â¡Éù
RV rendezvous »á¾Ûµã
RVS reverse shift ·´ÏòÒÆ¶¯
RZ return to zero ¹éÁã
Reversal ·´Ï࣬Ïà·´£¬·´×ª£¬¸Ä±ä¼«ÐÔ
Reverse »Ø¸´£¬·­×ª£¬·´»ìÏì
Revert ¸´Ô­£¬·µ»Ø
Review ¼ì²é£¬¸´²é£¬Öظ´
Revolve Ðýת£¬Ñ­»·
REW rewind ¿ìËÙµ¹´ø
RF reception fair ½ÓÊÕÇé¿öÁ¼ºÃ
RFI RF interface É䯵½Ó¿Ú
RFI RF interferece É䯵¸ÉÈÅ
Revcolor »ìÏìȾɫÉùRPS direct program Ö±½Ó½ÚÄ¿ËÑѰ£¬¿¨À­OKËÑË÷
R(RD)radio É䯵
R(RD)read ¶ÁÈ¡
R receiver ½ÓÊÕ»ú
R register ¼Ä´æÆ÷
R right ÓÒÉùµÀ
Rack »ú¼Ü£¬Ö§¼Ü£¬»ú¹ñ£¬¹æ¶¨¿í¶È£¬Õð¶¯Éù
Radiation ·øÉä
Radio ÎÞÏߵ磬µëÒô»ú£¬É䯵
Ram random access memory Ëæ»ú´æ´¢Æ÷
RAM ÌîÈ룬װÈë
RAN random Ëæ»úµÄ£¬ÈÎÒâµÄ£¬ÎÞ¹æÔòµÄ
Range ·¶Î§£¬×î´óÌáË¥Á¿£¬·ù¶È
Rate ±ÈÂÊ£¬ËÙÂÊ£¬±ä»¯ÂÊ£¬ÆµÂÊ
Ratio ѹËõ±È£¬À©Õ¹±È£¬±È£¬ÏµÊý
RCA radio corporation of America ÃÀ¹úÎÞÏߵ繫˾
RCA jack Á«»¨½Ó¿Ú
R-CH ÓÒÉùµÀ
R-DAT rotary head-DAT Ðýת´ÅͷʽÊý×Ö¼Òô»ú
RE rack earth Íâ¿Ç½ÓµØ
RE reset ¸´Î»
RE right end ÓÒ¶Ë
Reactance µç¿¹
Readjustment ÖØµ÷
Ready Ô¤±¸£¬×¼±¸Íê±Ï
Rear ±³Ã棬ºó²¿£¬ºóÖÃ
REC recording ¼Òô£¬¼Ç¼£¬Â¼ÖÆ
Recall Õлأ¬µ÷³ö£¬ÖØÂ¼
Receiver ½ÓÊÜ»ú£¬½ÓÊÜÆ÷
Recharge ÔÙ³äµç
Record ¼Ç¼£¬Â¼ÖÆ£¬³ªÆ¬
Recorder ¼Òô»ú
Recovery »Ö¸´£¬¸´Ô­
Red ºìÉ«
Redo ÔÙÖ´ÐвÙ×÷
Reduce ¼õÉÙ£¬½µµÍ£¬ËõС
Reduction ѹËõ£¬Ë¥¼õ£¬ÐγÉ
Reecho »ØÉù
REF Reference ˵Ã÷Ê飬²Î¿¼£¬»ù×¼£¬¶¨Î»
REF Reflection ·´Éä
Refraction ÕÛÉä
Refresh »Ö¸´
REG register ¼Ä´æÆ÷
REG regulate ¿ØÖÆ£¬Ð£×¼£¬µ÷½Ú
REGEN regeneration ÔÙÉú£¨»ìÏìÉùÕóÐγɷ½Ê½£©£¬Õý·´À¡
Rehearsal ÅÅÁ·£¬Ô¤ÑÝ
Reject ³ýÈ¥£¬ÂËÈ¥
Rejection ÒÖÖÆ
Reinforcement À©Éù
Relay ¼ÌµçÆ÷£¬ÖØ·Å£¬×ª·Å
Release »Ö¸´Ê±¼ä£¬ÊÍ·Å£¬¶Ï·Æ÷
Rename ¸ÄÃû£¬ÃüÃû
Remain ±£³Ö£¬Ê£Óà
REM remote Ò£¿ØµÄ£¬Ò£Ô¶µÄ£¬Ô¶¾àÀëµÄ
REM removable ¿É²ð×°µÄ
REM remove ³ýÈ¥
Remain ÓàÁ¿£¬×´Ì¬±£³Ö
Renumber ÖØÐ´ºÅÂë
REP repeat ÖØ¸´£¬·´¸´£¬ÖØ·Å
Repeat mode Ë«Ãæ·´¸´·ÅÒô£¨Â¼Òô»ú£©
Replacing Ìæ»»£¬Öû»£¬¸´Î»
REQ room equalizer ·¿¼ä¾ùºâÆ÷
Reset ¸´Î»£¬»Ö¸´£¬¹éÁã£¬ÖØ¸´£¬ÖØÐ°²×°
Resolution ·Ö±æÂÊ£¬·ÖÎö
Resonance ¹²Õñ£¬»ØÉù
RESP response ÏìÓ¦£¬ÌØÐÔÇúÏߣ¬»Ø´ð
Resistance ×迹
Resister µç×è
Resonance ¹²Ãù£¬Ð³Õñ Rest ÐÝÖ¹·û£¬¾²Ö¹£¬Í£Ö¹
Restraint ÒÖÖÆ£¬ÏÞÖÆÆ÷
RET return ·µ»Ø£¬»ØËÍ
REV reverse µßµ¹£¬·´×ª
REV reverberation »ìÏ죬²ÐÏì
Reverb depth control »ìÏìÉî¶È¿ØÖÆ
RIAA recording industry association of America
ÃÀ¹ú¼Òô¹¤ÒµÐ­»á
2005-10-13 04:51:00 »Ø¸´
S-T
SAF Safety °²È«×°Ö㬱£ÏÕ×°Ö㬱£»¤×°ÖÃ
Safeguard by ·À»¤Æ÷
SALT symmetry air load technique ¶Ô³Æ¿ÕÆø¸ºÔؼ¼Êõ
Samba É£°Í
Sample ÉùÒôÐźÅÑùÆ·£¬²ÉÑù£¬È¡Ñù£¬³éÑù
Sampling ³éÑù£¬Âö³åµ÷ÖÆ
SAP second audio program µÚ¶þÌ×ÒôƵ½ÚÄ¿
SAT saturate ±¥ºÍЧ¹û´¦Àí
Save Öü´æ
Save ´æ´¢£¬±£´æ
Saxophoneb Èø¿Ë˾¹Ü
Saxophome ¶¥À¡Ö±ÏßÌìÏß
SC set clock ÖÃλʱÖÓ
SC sigmal control ÐźſØÖÆ
SC subcarrier ¸±Ôز¨
SC system controller ϵͳ¿ØÖÆÆ÷
SC scan ɨÃè
Scale Òô½×£¬¿Ì¶È³ß±ê
Scale unit ±ê¶Èµ¥Î»£¬·ÖƵÆ÷
Scan ËÑË÷£¬¼Ç¼£¬É¨Ãè
Scar ¼¤¹â³ªÆ¬ÉϵÄȱÏÝ SCART connector
Å·ÖÞ±ê×¼21½ÅAV½Ó¿Ú
Scattering É¢Éä
Scene ʵ¿ö£¬³¡Ãæ
SCH search ËÑË÷£¬Ñ°ÕÒ
Scheme Éè¼ÆÍ¼£¬Ô­Àíͼ
SCMS serial copy management system ³ÉÌ׸´ÖƹÜÀíϵͳ
Screw ÂÝË¿¶¤
Scrollback »ØÕÒ
SCH stereochrous Á¢ÌåÉùºÏ³ª
Schmidt trigger Ê©ÃÜÌØ´¥·¢Æ÷
Scintillation ÉÁ˸£¬µ÷ÖÆÒýÆðµÄÔØÆµ±ä»¯
SCMS successive copy manage system
Á¬Ðø¸´ÖƹÜÀíϵͳ£¨DATÉ豸ÖзÀÖ¹¶à´Îת¼½ÚÄ¿µÄϵͳ£©
Scoop ìæ¶·£¬ÊÕ¼¯Æ÷
Scope ·¶Î§£¬ÏÔʾÆ÷
Scoring ÒôÀÖ¼Òô
SCR signal to clutter ratio ÐÅÔë±È
SCR silicon controlled rectifier ¾§Õ¢¹ÜÕûÁ÷Æ÷
Scraper ¹ÎÉùÆ÷
Screen ÆÁ±Î
SD space division ¿Õ¼ä·Ö²¼
S-DAT stationary head DAT ¹Ì¶¨´ÅÍ·DAT»ú
SDDS sony dynamic digital sound Ë÷Äᶯ̬Êý×Ö»·ÈÆÉùϵͳ
SDI standard data interface ±ê×¼Êý¾Ý½Ó¿Ú
SDLC synchronous data link control ͬ²½Êý¾ÝÁ´¿ØÖÆÆ÷
SE single end µ¥¶ËµÄ
SE sound effect ÒôÏìЧ¹û
SE storage element ´æ´¢Ôª¼þ
SE support equipment Ö§Ô®É豸
SEA soond effect amplifier ÒôÏìЧ¹û·Å´óÆ÷
SEA special effects amplifier ÌØÊâЧ¹û·Å´óÆ÷
Search ËÑË÷£¬É¨Ãè
Searcher ɨÃèÆ÷
SEC Second Ã룬µÚ¶þ
SECAM sequential color and memory µ÷ƵÐÐÂÖ»»²ÊÉ«ÖÆÊ½
Section µ¥Ôª£¬»·½Ú
Sectoral horm ÉÈÐκÅͲ
Security ±£ÏÕ£¬¼ÓËø
SED system effectiveness demonstration ϵͳЧ¹ûÑÝʾ
Seek ËÑË÷
SEL selector Ñ¡Ôñ×°Öã¬Ñ°Ï߯÷£¬×ª»»¿ª¹Ø
Select Ñ¡Ôñ
Selectivity £¨ÊÕÒô»ú£©Ñ¡ÔñÐÔ
Semi- °ë-
Semibreve È«Òô·û
Semioctave °ë¸ö°Ë¶ÈÒô
Semit °ëÒô
SEN sensor ´«¸ÐÆ÷
Send Ëͳö£¬·¢ËÍ£¬·¢Éä
SENS Sensitivity ÁéÃô¶È
Sense ·Ö±æÂÊ
Sensor ´«¸ÐÆ÷
Sentinel ·¢ÉäÆ÷£¬´«ËÍÆ÷
SEP standard electronic package ±ê×¼µç×Ó×é¼þ
SEP system engineering process ϵͳ¹¤³Ì´¦Àí
Separator ·ÖÀëÆ÷£¬·Ö½âÆ÷
Septieme Æß±¶Òô
SEQ sequencer ÒôÐòÆ÷£¬¶¨ÐòÆ÷
SEQ Stereo equalizer Á¢ÌåÉù¾ùºâÆ÷
Sequence ÅÅÐò£¬ÐòÁÐ
Series ϵÁУ¬´®Á¬
Service άÐÞ£¬·þÎñ
Servo ËÅ·þ»ú¹¹£¬Ëæ»úϵͳ
Servo motor ËÅ·þÂí´ï
SES spatial effect system Á¢ÌåÉù¿Õ¼äЧ¹ûϵͳ
Session ¸úËæ×Ô¶¯°é×à
Set µ÷Õû£¬É趨£¬×°Ö㬶¨Î»£¬½ÓÊÕ»ú
Setout ¿ªÊ¼£¬×¼±¸
Setup É趨£¬¹¹³É£¬²Ëµ¥£¬×éºÏ£¬µ÷Õû
SFC sound field composer Éù³¡ºÏ³É×°ÖÃ
SFL stereo flange Á¢ÌåÉù·¨À¼Ïâ±ß
SFS sound field synthesis Éù³¡ºÏ³É
SG signal generator Ðźŷ¢ÉúÆ÷
SGL signal ÐźÅ
S-hall small hall СÐÍÌüÌÃЧ¹û
Shake Õð¶¯
Shape ²¨ÐΣ¬ÂÖÀÈ
Shaper ÕûÐÎÆ÷£¬Âö³å³ÉÐÎ
Share drum С¾ü¹Ä
Sharpness ÇåÎú¶È£¬ÏÊÃ÷¶È£¬Èñ¶È
Shelving Â˳ý£¬Â˲¨´¦Àí
SHG sub harmonic generator ´Î£¨·Ö£©Ð³²¨·¢ÉúÆ÷
Shield ±£»¤£¬ÆÁ±Î
Shift ת»»£¬±äµ÷£¬ÒÆÆµ£¬Æ¯ÒÆ
Shock ³å»÷
Short ¶ÌµÄ
Short gate ¶ÌʱѡͨÃÅ£¨»ìÏìЧ¹û£©
Shower ָʾÆ÷£¬ÏÔʾÆ÷
SHUF Shuffle Ëæ»ú˳Ðò½ÚÄ¿²¥·Å
Shunt ·Ö·£¬²¢Áª
SHUTT shuttle ±äËÙËÑË÷£¬Íù¸´
SI sneak in µ­Èë
Sibilance ³ÝÒô£¬ßÐÒô
Sibilant ßÐÒô
Sibilation ßÐÒô£¬¸ßƵÉù»û±ä
SICS sound image control system ÉùÏñ¿ØÖÆÏµÍ³
Side ±ß£¬Ã棬²àÃæ£¬·½Ãæ
Side chain ÅÔÁ´
SIG signal ÉùÒôÐźÅ
Signature ÌØÕ÷£¬ÒôÀֵĵ÷ºÅ
SIF °éÒôÖÐÆµ
Silencer ¾²ÔëÆ÷
Silent ¾²Ôëµ÷г
Simple tone ´¿Òô
Simplex µ¥¹¤
Simulate Ä£ÄâµÄ
Simultaneous ͬ²½£¬ÁªÁ¢
SINAD signal to noise and distortion ratio
ÐźŶÔÔëÉùºÍÊ§Õæ±È
Sine wave ÕýÏÒ²¨
Single µ¥£¬µ¥´ÎµÄ£¬µ¥¶ÀµÄ£¬µ¥µú
SIP solo in place ¶À×àÈëλ
SIP standard information package ±ê×¼ÐÅÏ¢°ü
Siren ÐýµÑ
Size ³ß´ç
Skew control ŤÇúУÕý£¬ÁâÐÎÊ§ÕæÆ÷
Skip ÌøÔ¾£¬Ê¡ÂÔ
SL signal level ÐÅºÅµçÆ½
Slap ÅÄ´òЧ¹û
Slap back ɽ¹È»ØÉù
Slap reverb ɽ¹È»ìÏìЧ¹û
Slate Ô¤¶¨£¬±ê¼Ç£¬£¨Â¼Òôµ÷Òǫ̂£©±ê¼Ç¿ª¹Ø
Slave ´ÓÊôµÄ£¬´Ó»ú£¬´Ó¶¯µÄ
Sleep ˯Ãß¶¨Ê±¿ª¹Ø£¬¾²Ö¹
Sleeve(SLE) ½ÓµØµã£¬Ðä¶Ë£¬Ì×
Slew rate ˲̬ÂÊ
Sliding tone »¬Òô
Slope бÂÊ£¬ÆÂ¶È£¬¿çµ¼
Slow ÂýËÙ
SLP super long play ³¬³¤£¨Èý±¶£©Ê±¼ä²¥·Å
Sliding tone »¬Òô
SLS studio listen Ñݲ¥ÊÒ¼àÌý
SM sequential machine ʱÐò»ú SM signal meter ÐźÅÇ¿¶È¼Æ
SM storage mark ´æ´¢±êÖ¾
S/M speech/music ÓïÑÔ/ÒôÀÖ
S/N signal-to-noise radio ÐÅÔë±È
Small club С¾ãÀÖ²¿Ð§¹û
Smear ҷ⣬ÍÏ⣬»ë×Dz»Çå
Smear correction ÍÏβУÕý
SMF Standard MIDI File ±ê×¼
SMP sampler È¡ÑùÆ÷
SMPTE society of motion picture television engineers
£¨ÃÀ¹ú£©µçÓ°¼°µçÊÓ¹¤³Ìʦѧ»á
S/N signal/noise ÐźÅ/ÔëÉù£¬ÐÅÔë±È
SND sound ÉùÒô£¬ÒôÏ죬°éÒô
Snake ¼¯ÌåÏß
Snapshot Ƭ¶Î£¬³¡¾°×´Ì¬ÉèÖÃ
Snubber »º³åÆ÷£¬¼õÕðÆ÷
SO sneak out µ­³ö
Socket ²å×ù£¬²å¿Ú
Soft Èí, , µÄ£¬ÈáºÍµÄ
Soft click ÈáÐÔóéλ
Soft knee Èí¹Õµã£¨Ñ¹ÏÞÆ÷£©
Soft-touch Çᴥʽ
Software ¼ÆËã»úÈí¼þ
Solo ¶À³ª£¬¶À×à
Sone ËΣ¨Ïì¶Èµ¥Î»£©
Song ÀÖÇú
Sound colum ÉùÖù
Sound field Éù³¡
Sound image ÉùÏñ
Sound intensity ÉùÇ¿
Sound shadow region ÉùÓ°Çø
Sound cousole desk µ÷Òǫ̂
Source ÉùÔ´
SOS sound on sound µþ¼Ó¼Òô
SP speaker ÑïÉùÆ÷
SP speed ËÙ¶È
SP standard-play ±ê×¼×ß´øËٶȼ·Å
SPA stereo pan allochthonous Á¢ÌåÉùÉùÏñÆ¯ÒÆ
Space ¼ä϶£¬¿Õ¼äЧ¹û
Spaciousness ¿Õ¼ä¸Ð
ST stereo Á¢ÌåÉù£¬Á¢Ìå
STI speech transmission index ÓïÑÔ´«Êäϵͳ
Sticks ²Ù×÷¸Ë£¬°²Ö㬿¨×Ó
Still ¾²Ö¹
STM send test massage ·¢ËͲâÊÔÐźÅ
STO stand point λÖÃ
STO stereo Á¢ÌåÉù
STO stop ֹͣ
STO store ´æ´¢£¬´æ´¢Æ÷
STP shielded twisted pnir ÆÁ±ÎË«½ÊÏß
Strike note »÷ÏÒÒô£¬×²»÷Éù
String instrument ÏÒÀÖÆ÷
Strip жϸ½ÊôÉ豸£¬¹ìµÀ£¬Àà±ð
Strobe ѡͨÂö³å£¬ÆµÉÁ·Åµç¹Ü
Strong ÓÐÁ¦µÄ
Structure ×°Ö㬽ṹ
STU Studio Ñݲ¥ÊÒЧ¹û
SUB ¸±£¬¸¨Öú£¬¸½¼Ó£¬µÍÒô
Subgroup ¸±£¬£¨µ÷Òǫ̂µÄͨµÀ¼¯ÖпØÖÆÍøÂ磩±à×é
Suboctave ´Î°Ë¶È
Subsonic ´ÎÉù£¬³¬µÍÒô
Subwoofer ³¬µÍÒô
Sum ºÍ£¬×ܺͣ¬×ÜÊý
SUP Supply µçÔ´
Supper ³¬
Super bass ³¬µÍÒô
Super over drive ³¬¼¤Àø
Suppressor ÒÖÖÆÆ÷
Support programs Ö§Ô®³ÌÐò
SUR Surround »·ÈÆÉù£¬»·ÈÆ£¬°üΧ
Sustain ±£³Ö£¬Î¬³Ö
SVP surge voltage protector ÀËФµçѹ±£»¤Æ÷
SW signal wire ÐźÅÏß
SW S-Wite ÈûÌ×ÒýÏß
SW switch ¿ª¹Ø£¬Çл»
SW short wave ¶Ì²¨
S/W specification of wiring ²¼Ïß¹æ¸ñ
Swap ½»»»£¬µ÷¶¯£¨µÈÁ¿Æë¹Û£©£¬µ÷»»
Sweep ɨÃ裬ÇúÏß
Swell ÔöÒôÆ÷
Swing °Ú·ù£¬Ò¡°ÚÎè
Swishing ì¬ì¬Éù
SX simplex µ¥¹¤
SXE stereo exciter Á¢ÌåÉù¼¤ÀøÆ÷
Symphobass µ÷гµÍÒôϵͳ
Symphonic ½»Ï죬гÒô
SYS Ex system expanding ϵͳÀ©Õ¹TRIG trigger ´¥·¢£¬´¥·¢Æ÷£¬´¥·¢Âö³å
SPD speed µ÷ÖÆËÙ¶È
SPDIF sony/philips digital interface Ë÷Äá/·ÉÀûÆÖÊý×Ö½Ó¿Ú
SPE speaker ÑïÉùÆ÷£¬ÒôÏä
Special ÁÙʱ£¨×°Öã©£¬ÌØÉèµÄ
Specificatin ÐÔÄÜ
Spectrum ÒôÓò£¬ÆµÆ×
Speech ÓïÑÔ£¬ÓïÒô
Speed ËÙ¶È£¬µ÷ÖÆËÙ¶È
Speed select £¨Â¼Òô»ú£©´øËÙÑ¡Ôñ
SPG severo pulse generator ËÅ·þÂö³å·¢ÉúÆ÷
SPH single phase µ¥Ïà
SPL sound pressure level Éùѹ¼¶
Split ·Ö¸î£¬·ÖÅ䣬µÈÐźÅÇø
SPM spiral modulation ÂÝÐýµ÷ÖÆ
Spot effects ÏÖ³¡Ð§¹û
Spring µ¯»ÉЧ¹û£¬µ¯»É»ìÏìÆ÷
SPS stereo pitch shift Á¢ÌåÉù±äµ÷
SPSS self program search system ×Ô¶¯½ÚÄ¿ËÑË÷ϵͳ
Sport Ô˶¯³¡Ð§¹û
SQ squelch ¾²Ô룬ÔëÉùÒÖÖÆ£¨µç·£©
SQ stereo quadraphonic record ËÄÉùµÀÁ¢ÌåÉù³ªÆ¬
Square ¹ã³¡ÒôÏìЧ¹û
Squawker ÖÐÒôÑïÉùÆ÷
Squeal Ð¥½Ð
Squegger ¼äЪÕñµ´Æ÷
Squib drivers µç±¬¼¤ÀøÆ÷
SR Ò£¿Ø²Ù×÷
SR speed ratio ת»»ËÙÂÊ
SR stabilizeation receiver Îȶ¨½ÓÊÕ»ú
SRL standard recording level ±ê׼¼Òôµçƽ
SRS sound retrieval system ÉùÒô¹éÕæ£¨»Ö¸´£©ÏµÍ³£¬ÊÇÒ»ÖÖÀûÓÃË«ÉùµÀ²úÉú»·ÈÆÉù³¡µÄÐéÄâ»·ÈÆÉù·½Ê½¡£
SS starting -point sensor £¨´Å´ø£©Ê¼¶Ë¸ÐÓ¦Æ÷
SS switch selector ¿ª¹ØÑ¡ÔñÆ÷
SSG synchronizing signal generator ͬ²½Ðźŷ¢ÉúÆ÷£¬Í¬²½»ú¡£
SSLSC solid state logic studio computer
¹Ì̬Âß¼­Â¼ÒôÊÒ¼ÆËã»úϵͳ
ST sawtooth ¾â³Ý²¨
ST start Æô¶¯£¬¿ªÊ¼
ST status ״̬£¬×´¿ö
ST stereo Á¢ÌåÉù
ST store ´æ´¢
Stability ƽºâ£¬Îȶ¨ÐÔ
Stacking Õ¼¿ÕϵÊý
Stadium ¶ÌìÌåÓý³¡Ð§¹û
Stage Îę̀Ч¹û£¬¼¶£¬½×¶Î
Stand-by µÈ´ý£¬×¼±¸£¬±¸ÓÃ
Standard ±ê×¼£¬ÖÆÊ½£¬¹æ¸ñ
Standing wave פ²¨
Star ÐÇ£¬ÐÇÐΣ¬ÐǺÅ
Start Æô¶¯£¬¿ªÊ¼£¬Ê¼¶Ë
Start Id Æðʼʶ±ð
Static doubling ¾²Ì¬Ë«Éù
Station ²Ù×÷̨
Status ״̬£¬×´¿ö
ST-BY standey ×¼±¸
STD standard ±ê×¼£¬¹æ¸ñ
STD stereo delay Á¢ÌåÉùÑÓʱ
Step ²½Ö裬¼¶£¬µµ£¬½×ÌÝ£¬²½½ø
Step back ºóÍË
Steer ²Ù×Ý£¬¿ØÖÆ
Symphony ½»ÏìÀÖ£¬½»ÏìÀÖЧ¹û
SYN(SYNC)synchronism ͬ²½
SYN synthesizer ºÏ³ÉÆ÷
SYNC synchronizer ͬ²½Æ÷
Sychro ͬ²½»ú
Synth ºÏ³É
Synthesis ºÏ³É£¬×ÛºÏ
SYS system ϵͳ£¬ÖÆÊ½
SYS Ex system exchange ϵͳ½»»»
2005-10-13 13:47:00 »Ø¸´
T talk ºô½Ð£¬ÁªÂç
Tab ·ÀÎóĨµ²Æ¬
TACH tachometer ²âËÙÆ÷
TADI time assigument digital tnterpolation
ʱ·ÖÊý¾Ý²å¿Õ£¨¼¼Êõ£©
Tag µçÀ²åÍ·
Take ʵ¼
Takeoff È¡³ö
Takeover »Ö¸´£¬»°ÒôµþÈ룬ÉÌÒé
Talkback ¶Ô½²£¬ÁªÂç
Tally ²¥³ö£¬Ìáʾ£¬²åÈë
Tap µçÁ÷Êä³ö£¬½ÚÅÄ
Tape ´ø£¬´Å´ø
Tango ̽¸ê
TB talkback ¶Ô½²»ØËÍ
TB terminal board ½ÓÏß¶Ë×Ó×Ó°å
TB time base ʱ»ù
TBC time base corrector ʱ»ùУÕýÆ÷
TBK tallback ¶Ô½²
TC telecine µçÓ°µçÊÓ»ú
TC time code ʱ¼äÂë
TC transmitter-tunning circuit ·¢Éä»úµ÷гµç·
TC trim coil ΢µ÷ÏßȦ
TCC tripl concentric cable ÈýоͬÖáµçÀÂ
TDE time domain equalizer ʱÓòµÈ»¯Æ÷
TECH technique ¼¼Êõ£¬¼¼ÄÜ£¬¼¼ÇÉ
TED television disk µçÊÓ³ªÆ¬
TEL telescopic À­¸ËÌìÏß
TEMP temperature ζÈ
Temp ½Ú×à
TEMOP temporary Öм䣨¹¤×÷£©µ¥Ôª
TEMPO Tempo ½Ú×࣬Á¬½Ó£¬ËÙ¶È
Terminal ÖÕ¶Ë£¬½ÓÏßÖù£¬ÒýÏߣ¬½ÓÍ·
Tentelometer ÕÅÁ¦±í
TER termination ÖÕ¶Ë
Test ²âÊÔ£¬ÊÔÑ飬¼ìÑé
THD total harmonic distortion ×Üг²¨Ê§Õæ
Theater ¾ç³¡Ð§¹û£¬ÏÖ³¡
Thermal noise ÈÈÔëÉù
Thick ÉòÖØ£¬ºñÖØ¶È
Thin µ¥±¡ÉùÒô
Thinness ±¡£¨´ò»÷ÀÖ£©
THR THRESH threshold ãÐÖµ£¬ãУ¬ÃÅÏÞ
Thresh thrash ¶à´Î·´¸´
Three dimension 3DÒôÏ죬ÈýάÁ¢ÌåÉùÒôÏìϵͳ
Throat ¸ßÒôºÅ½ÇµÄºí
THRU through ͨ¹ý£¬¹ýÇÅ£¬Ö±½ÓתËÍ
Trump ¼ü»÷ÔëÉù£¬µÍƵÔëÉù£¬¿ª»úÅéÉù
Thrust ²åÈ룬ǿÐмÓÈë
THX tom holman"s eXpriment ÌÀ•»ô¶ûÂüʵÑ飬¼ÒÍ¥Ó°Ôº
TI temperatun indicator ζÈָʾÆ÷
TIE terminal interface exchange Öն˽ӿڽ»»»
Tie Á¬½Ó·ûºÅ£¬À¡Ïߣ¬Í¨ÐÅ
Tierce µÚÈýÒô£¬Îå±¶Òô
Tight Ó²£¬½ô£¬Ó²ÀÊ
TIM transient intermodulation ˲̬»¥µ÷Ê§Õæ
Timber ÒôÖÊ£¬ÒôÉ«
Timbre Éù²¿
Time ʱ¼ä£¬±¶£¬´Î£¬¶¨Ê±µÄ
Timer ¶¨Ê±Æ÷£¬¼ÆÊ±Æ÷
Tininess µ¥±¡
Tint É«µ÷
TIP terminal interface processor Öն˽ӿڴ¦Àí»ú
Tip Í·¶Ë£¬ÈȶË
Title ±êÌ⣬×ÖÄ»
TK track Òô¹ì
TL track loss ¹ì¼£¶ªÊ§
TLE trunk line equipment ¸ÉÏßÉ豸
TM trade mark ×¢²áÉ̱ê
TMS transmission mesurement set µçƽ±í
TMT transmit ·¢ËÍ
TN tuning unit µ÷гװÖÃ
TOC ½ÚĿĿ¼
Tone Òôµ÷£¬Éùµ÷£¬´¿Òô
Tone burst â§·¢Òô
Tone color ÒôÉ«
Tone quality ÒôÉ«£¬ÒôÆ·
Tonic ÂÉÒô
Top ×î¸ß
TOS tape operating system ´Å´ø²Ù×÷ϵͳ
Total ×Ü£¬×ܹ²
Total tune ÕûÌåЭµ÷£¬×ܵ÷г
Touch ´¥£¬Ñ¹£¬°´
Touch sens ¼üÅÌÀÖÆ÷Ö¸´¥µÄ´¥¸Ð
TPD turnout piece delay ·ÖÖ§ÑÓʱ
TR tape recorder ´Å´øÂ¼Òô»ú
TR telerecording µçÊÓÆÁϼÏñ
TR tracking ¸ú×Ù
TR transfer ´«Êä£¬×ªÒÆ
TR trick ÌØ¼¼Ð§¹û
Track ÇúÄ¿ºÅ£¬´Å¼££¬Òô¹ì
Tracking Ѱ¼££¬¸ú×Ù£¬Í³µ÷
Tracking monitor µ÷У¼àÌý
Trad Ïݲ¨Æ÷£¬´ø×èÂ˲¨Æ÷
Tramp ÈýͨµÀ¹¦·Åϵͳ
Transfer תӡ£¬×ª½Ó
Transformer ±äѹÆ÷
Transpose תµ÷£¬±ä»»Æ÷£¬ÒƵ÷
Transport ÔËÐУ¬·¢ËÍ
Transient ˲̬
Transient distortion Ë²Ì¬Ê§Õæ
Transient response ˲̬·´Ó¦
Transmit ·¢Éä
Transistor ¾§Ìå¹Ü£¬Èý¼«¹Ü
Transponder תµ÷Æ÷£¬±ä»»Æ÷
Transposer ±äµ÷Æ÷
Transversal equalizers ºáÏò¾ùºâÆ÷
Treble ¸ßÒô£¬Èý±¶µÄ£¬ÈýÖØµÄ
Tremold tremor ²üÒô
Tremolo ÕðÒô
Tremor ²üÒô£¬ÕñÒô×°ÖÃ
Triamp Èý·µç×Ó·ÖÒô
Trick ÌØ¼¼
Trig ÐÞÊÎ Spatializer Éù³¡¶¨Î»¼¼Êõ
Trim µ÷Õû£¬Î¢µ÷£¬µ÷г£¬Ï÷²¨
TRK track Òô¹ì
TRK trunk ×ÜÏߣ¬Ä¸Ïߣ¬¸ÉÏß
Trouble ¹ÊÕÏ
Trumpet СºÅ
TRS time reference system ʱ¼ä»ù׼ϵͳ
TST test ²âÊÔ
TTY teleltypewriter Ò£¿Ø´òÓ¡»ú£¬µç´«»ú
Tube µç×ӹܣ¬Õæ¿Õ¹Ü
Tune µ÷г£¬ºÍг£¬µ÷Òô
Tuner µ÷гÆ÷
Tunetable £¨³ªÅ̵ģ©×ªÅÌ
Tunnel reverb ËíµÀ»ìÏìЧ¹û
Tupe ´¦Àíģʽ
Turbo distortion ÎÐÂÖÊ§ÕæÐ§¹û
Turntable µç³ªÅÌ£¬×ªÌ¨
TV television µçÊÓ
Tweeter ¸ßÒôÑïÉùÆ÷•
Twin channel ˫ͨµÀ
Two complement ²¹Âë
Two way mode Ë«ÃæÂÖÁ÷·ÅÒôģʽ£¨Â¼Òô»ú£©
TX transmit ·¢ËÍ£¬·¢Éä
TX transmitter ·¢Éä»ú
TYP trpe ÀàÐÍ
Typical ±ê×¼µÄ£¬µäÐ͵Ä
TRIG trigger ´¥·¢´¥·¢Æ÷£¬´¥·¢Âö³å
TRK track Òô¹ì
Trouble ¹ÊÕÏ
Trumpet СºÅ
TST test ²âÊÔ
TTY teletypewriter Ò£¿Ø´òÓ¡»ú£¬µç´«»ú
Tube µç×ӹܣ¬Õæ¿Õ¹Ü
Tune µ÷г£¬ºÍг£¬µ÷Òô
Tuner µ÷гÆ÷
Tupe ´¦Àíģʽ
TV television µçÊÓ
Tweeter ¸ßÒôÑïÉùÆ÷
Twin channel ˫ͨµÀ
Two complement ²¹Âë
TYP type ÀàÐÍ
2005-10-13 22:27:00 »Ø¸´
лл¥Ö÷£¬ÎÒÊÕ²ØÁË
2005-10-14 01:07:00 »Ø¸´
лл´ó¼ÒµÄÎÄÕ£¬ÎÒÊÕ²ØÁË
2005-10-14 20:15:00 »Ø¸´
