SHURE EZG18SE ¶ì¾±µçÈÝ»áÒ黰Ͳ(45CM)
ÆäËü²úÆ·
SHURE EZG18SE ¶ì¾±µçÈÝ»áÒ黰Ͳ(45CM)ÊÛ¼Û£º£¤1822Ôª
»ù±¾ÃèÊö£º
Êæ¶ûÓÐÏßÂó¿Ë·çEZG18SEÊæ¶ûÓÐÏßÂó¿Ë·çEZG18SEÃèÊö£ºÊæ¶ûEasyflex EZG/18SEÊÇÒ»¸ö΢ÐÍÂó¿Ë·ç¶ì¾±Ê½µçÈÝʽÂó¿Ë·ç £¬ Ö÷ÒªÓÃÓÚÓïÒôºÍÉùÀÖÆ¤¿¨Éè¼Æ¡£Ëü¿ÉÒÔ°²×°ÔÚ½²Ì¨£¬½²Ì³£¬»ò»áÒé×ÀÉÏ¡£°üÀ¨Ò»¸öǰÖ÷ŴóÆ÷¡£ ¶ì¾±µÄ΢Ð͵çÈÝÂó¿Ë·çEasyflex·Ïß £¬ ÊÇÍêÃÀµÄÑ¡Ôñ²¶»ñ½²»°ºÍ»·¾³ÉùÔÚÆ·ÖÊ£¬¼ÛÖµºÍÔ¤ËãµÄÖ÷Òª¿¼ÂÇÒòËØ¡£
Êæ¶û
µçÈÝʽÂó¿Ë·çµÄ¶ì¾±ÐŦÄܵÄÒ»¼«¸ñ¾Ö£¬¶øÇÒÔÚËÄÖÖ²»Í¬µÄÐͺţ¬Ôڸ߶ÈÒÀÀµºÍ°²×°Ó¦ÓóÌÐòÌṩ¡£Êæ¶ûÓÐÏßÂó¿Ë·çEZG18SEÌØµã£º¿¿½üÂó¿Ë·çÉú²ú»ùµØÂó¿Ë·çµÄ¶ì¾±foreasy·½Ïòµ¥½Ú¡£ ¹ÜǰÖûú¹¹µ÷ÕûÒÔÊÊÓ¦Ðí¶àstandardaccessories¡£ »ÃµÆÆ¬µÄµ²·ç²£Á§¡£ 5/8-27ÂÝĸÓëCA¾ùºâÆ÷³ö¿ÚÌṩÁËÔ½À´Ô½¶àµÄ¿ÉÄÜÐÔavariety¡£  ½µµÍÍⲿǰÖÃÂó¿Ë·ç¿É¼ûµÄ´óС¡£ Shure Wired Microphone EZG18SE Specifications: Frequency Response: 50 to 17,000 Hz Polar Pattern: Cardioid Output Impedance (at 1 kHz): Rated at 150 ? Êæ¶ûÓÐÏßÂó¿Ë·çEZG18SE¼¼ÊõÖ¸±ê£ºÆµÂÊÏìÓ¦£º50ÖÁ17,000 HzÖ¸ÏòÐÔ£ºÐÄÊä³ö×迹£¨1ǧºÕ£©£º150¶î¶¨£¿ (180 ?actual) Open Circuit Sensitivity (at 1 kHz, ref. 1 V/Pascal):-45.7 dB (5.19 mV) Maximum SPL (1 kHz at 1% THD, 1 k? load): 129 dB Equivalent Output Noise (A-weighted): 29 dB SPL Signal to Noise Ratio (referenced to 94 dB SPL): 65 dB Dynamic Range (at 1 k? Load): 100 dB Common Mode Rejection: 45 dB minimum Preamplifier Output Clipping Level (1 kHz at 1% THD,1 k? load): -12.0 dBV (0.25 V) Polarity: Positive sound pressure on diaphragmproduces positive voltage on pin 2 relative to pin 3 of output connector. £¨180£¿Êµ¼Ê£©¿ªÂ·ÁéÃô¶È£¨ÔÚ1 kHz£¬²Î¿¼¡£1·ü/ÅÁ˹¿¨¶û£©£ºÔÚ1£¥-45.7·Ö±´£¨5.19»ú¶¯³µÁ¾£©×î´óÉùѹ¼¶£¨1 kHz×Üг²¨Ê§Õ棬1ǧ£¿¸ºÔØ£©£º129 dBµÈЧÊä³öÔëÉù£¨ A¼ÓȨ£©£º29 dBÉùѹ¼¶ÐÅÔë±È£¨²Î¿¼94 dBÉùѹ¼¶£©£º65 dB¶¯Ì¬·¶Î§£¨1ǧ£¿¸ºÔØ£©£º100 dBµÄ¹²Ä£ÒÖÖÆ£º45 dB×îСǰÖ÷ŴóÆ÷Êä³öÏÞ·ùµçƽ£¨1ǧºÕʱ1 £¥×Üг²¨Ê§Õ棬1ǧ£¿¸ºÔØ£©£º-12.0 dBV£¨0.25Î壩¼«ÐÔ£ºÕýÉùѹÔÚÕë½ÅÉÏdiaphragmproducesÕýµçѹ2Ïà¶ÔÓÚÕë½ÅµÄÊä³ö½ÓÍ·3¡£ Power Requirements: 11 to 52 Vdc phantom, 2.0 mA Environmental Requirements Operating Temperature Range: -18¡ã C to 57¡ã C (0¡ã F to 135¡ã F) Relative Humidity: 0 to 95% Dimensions Gooseneck: 18" (457 mm) Head Diameter: 0.46" (11.68 mm) Get your Shure Wired Microphone EZG18SE Today !!! µçÔ´ÒªÇó£º11ÖÁ52 Vdc»ÃÏó£¬2.0 mA»·¾³ÒªÇó¹¤×÷ζȷ¶Î§£º-18 ¡ã CÖÁ57¡æ£¨0 ¡ã Fµ½135 ¡ã F£©Ïà¶Ôʪ¶È£º0ÖÁ95£¥³ß´ç¶ì£º18¡°£¨457ºÁÃ×£©Í·Ö±¾¶£º0.46¡°£¨11.68ºÁÃ×£©ÔÚÄúÐèÒªµÄÊæ¶ûÓÐÏßÂó¿Ë·çEZG18SE½ñÌ죡
ÆÀÂÛÁÐ±í£¨2£©
:victory:
2009-8-4 18:24:01 »Ø¸´
:victory::victory:Ö§³Ö£¡
2009-8-9 16:43:14 »Ø¸´
