J¨²nior Porci¨²ncula Yamaha S90 ES v1.6 KONTAKT
ʹÓÃmLan16Êä³ö£¨Digital FireWire£©×Ðϸ²ÉÑùÁË14¸öYamaha S90 ES²¹¶¡
¾ßÓÐÓïÒôºÍË«ÖØÓïÒôÔ¤ÉèµÄÏÔʾ£¬¾ßÓжÀÁ¢µÄÒôÁ¿¿ØÖÆ¡£ Äú¿ÉÒÔÔÚ²»¼ôÇÐÒôƵµÄÇé¿öÏÂÇл»²¹¶¡¡£ Èç¹ûÄú±£´æÒÇÆ÷£¬Ëü½«±£ÁôÄúÒÑÍê³ÉµÄ×îºóÉèÖá£
ÑÅÂí¹þS90 ES£º
×ÔÈ»S.
ÓÅÑŵÄS.
Ã÷ÁÁµÄS.
ºÚ°µS.
Ç×ÃÜ
DigiGrand
ȫʢ´ó
PianoBack
¸ÖÇÙÓ뺣Ͽ
BalladKey
E¸ÖÇÙ2
TX802
Yama EP's
ChorusDyno
Ô­ÎÄ
14 timbres do Yamaha S90 ES cuidadosamente sampleadas usando a sa¨ªda mLan16 (FireWire Digital). Display mostrando o preset do Voice e Dual Voice, com controle de volume independente. Voc¨º pode alternar entre os timbres sem cortar o ¨¢udio. Se voc¨º salvar o instrumento, manter¨¢ as ¨²ltimas configurações que voc¨º realizou.
14 patches of Yamaha S90 ES carefully sampled using the mLan16 output (Digital FireWire)
Display with Voice and Dual Voice preset, with independent volume control. You can switch between the patches without cut audio. If you save the instrument it will retain the last settings you've done.
Yamaha S90 ES:
Natural S
Elegant S
Bright S
Dark S
Intimate
DigiGrand
Full Grand
PianoBack
Piano&Str
BalladKey
E Piano 2
TX802
Yama EP's
ChorusDyno
J¨²nior Porci¨²ncula Yamaha S90 ES v1.6 KONTAKT | 1.22 GB
ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨1£©
J¨²nior Porci¨²ncula Yamaha S90 ES v1.6 KONTAKT·ÖÏí
2009-7-27 09:29:34 »Ø¸´
