Flawless editing in OS® X
Sound Forge Pro Mac 2 users are invited to install the free 2.5 update. Now with CD burning capability, the stand-alone Convrt Batch Processing Automation Tool, and our classic Wave Hammer compressor on board, Sound Forge for OS X has hit a highly anticipated benchmark.
Disc-at-once CD burning
Create tracks and burn a disc from a single file, or burn all open files to disc. Burn gapless live sets and Red Book compliant master discs.
Wave Hammer Compressor/Limiter
A Sound Forge classic plug-in, now available on the Mac. Sophisticated compression and volume maximization deliver master recordings with classic Sound Forge clarity and punch.
Focused editing
Sound Forge Pro Mac is the second-generation audio editing application designed exclusively for OS X, with expanded editing features incorporated by popular demand. Configurable viewing panels allow you to toggle to any project view you need in seconds¡ªsee everything at once or toggle your view to see only the features you want, when you want. Easily navigate the entire interface and work quickly, even on laptops.
Record high-resolution audio
Assigning hardware, metering input signals, arming tracks, and recording high-resolution multichannel audio is a simple and fluid process in Sound Forge Pro Mac. Route your inputs, position the Record tool, click Record, and you
Sony Sound Forge Pro v2.5.133 For OSX
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´ |
