ÒôƵ²ÉÑùADºÍ»ù±¾¸ÅÄî
תÌû
Ò»¡¢ÒôƵ²ÉÑùADºÍ»ù±¾¸ÅÄî
1.1 ²ÉÑùAD
        ÊýÂëÒôƵϵͳÊÇͨ¹ý½«Éù²¨²¨ÐÎת»»³ÉÒ»Á¬´®µÄ¶þ½øÖÆÊý¾ÝÀ´ÔÙÏÖԭʼÉùÒôµÄ£¬ÊµÏÖÕâ¸ö²½ÖèʹÓõÄÉ豸ÊÇÄ£/Êýת»»Æ÷£¨A/D£©ËüÒÔÿÃëÉÏÍò´ÎµÄËÙÂʶÔÉù²¨½ø ÐвÉÑù£¬Ã¿Ò»´Î²ÉÑù¶¼¼Ç¼ÏÂÁËԭʼģÄâÉù²¨ÔÚijһʱ¿ÌµÄ״̬£¬³ÆÖ®ÎªÑù±¾¡£½«Ò»´®µÄÑù±¾Á¬½ÓÆðÀ´£¬¾Í¿ÉÒÔÃèÊöÒ»¶ÎÉù²¨ÁË£¬°ÑÿһÃëÖÓËù²ÉÑùµÄÊýÄ¿³ÆÎª²ÉÑù ƵÂÊ»ò²ÉÂÊ£¬µ¥Î»ÎªHZ£¨ºÕ×È£©¡£²ÉÑùƵÂÊÔ½¸ßËùÄÜÃèÊöµÄÉù²¨ÆµÂʾÍÔ½¸ß¡£²ÉÑùÂʾö¶¨ÉùÒôƵÂʵķ¶Î§£¨Ï൱ÓÚÒôµ÷£©£¬¿ÉÒÔÓÃÊý×Ö²¨Ðαíʾ¡£ÒÔ²¨ÐαíʾµÄƵ ÂÊ·¶Î§Í¨³£±»³ÆÎª´ø¿í¡£ÒªÕýÈ·Àí½âÒôƵ²ÉÑù¿ÉÒÔ·ÖΪ²ÉÑùµÄλÊýºÍ²ÉÑùµÄƵÂÊ¡£
ÒôƵÏà¹Ø»ù´¡ÖªÊ¶£¨²ÉÑùÂÊ¡¢Î»Éî¶È¡¢Í¨µÀÊý¡¢PCM¡¢AAC£©
1.2 ÒôƵ£º
        CDÒôÖÊ£¬Ò»°ã2ͨµÀ£¬Ô­Ê¼ÒôƵÊý¾Ý1ÃëÖÓµÄÊý¾ÝÁ¿ÊÇ44.1k£¨²ÉÑùÂÊ£©*16£¨Î»Éî¶È£©*2£¨ÉùµÀÊý£©=1411.2kbits£¬¿ÉÇóµÃÕû¸öÒôƵÎļþµÄ´óС=ʱ³¤£¨300s£©*ÂëÂÊ(1411.2)/1024/8=51.67M¡£Ñ¹Ëõ³É128kbpsµÄMP3£¬1ÃëÖÓÊý¾Ý¾Í±ä³ÉÁË128kbitsÁË¡£
1.2 ²ÉÑùÂÊ
        Íâ½çµÄÉùÒô¶¼ÊÇÄ£ÄâÐźţ¬ÔÚÊý×ÖÉ豸ÖÐA/Dת»¯³ÉΪÁËÓÉ0¡¢1±íʾµÄÊý×ÖÐźź󱻴¢´æÏÂÀ´¡£Êý×ÖÐźŶ¼ÊÇÀëÉ¢µÄ£¬ËùÒÔ²ÉÑùÂÊÊÇÖ¸Ò»ÃëÖÓ²ÉÑùµÄ´ÎÊý£¬²ÉÑùÂÊÔ½¸ß£¬»¹Ô­µÄÉùÒôÒ²¾ÍÔ½ÕæÊµ¡£ÓÉÓÚÈ˶úÌý¾õ·¶Î§ÊÇ20Hz~20kHz£¬¸ù¾ÝÏãÅ©²ÉÑù¶¨Àí(Ò²½ÐÄοüË¹ÌØ²ÉÑù¶¨Àí)£¬ÀíÂÛÉÏÀ´Ëµ²ÉÑùÂÊ´óÓÚ40kHzµÄÒôƵ¸ñʽ¶¼¿ÉÒÔ³ÆÖ®Îª ÎÞËð¸ñʽ¡£µ«ÔÚ40kHz²ÉÑùÂÊϵõ½µÄÉùÒôÒÑûÓÐϸ½Ú¿ÉÑÔ£¬ËùÓÐÆµÂʶ¼ÊÇÖ»²ÉÑùÁËÒ»¸ö²¨·åÒ»¸ö²¨¹È¡£ÏÖÒ»°ãµÄרҵÉ豸µÄ²ÉÑùƵÂÊΪ44.1kHz¡£44.1kHzÊÇרҵÒôƵÖеÄ×îµÍ²ÉÑùÂÊ£¬Ò²½Ð¡±CD¼¶ÒôÖÊ¡±(22.05kHz²ÉÑùÂÊΪ¹ã²¥¼¶ÒôÖÊ)¡£¸üϸ»¯µÄ»¹ÓÐ96kHz£¬192kHzµÈµÈ£¬µ±È»ÒªÌýµ½ÕâЩ¸ü¸ß²ÉÑùÂÊÖеÄϸ½ÚÈ¡¾öÓÚ¶ú¶äºÍÉ豸ÁË¡£
1.3. ÉùµÀÊý
        ÓÉÓÚÒôƵµÄ²É¼¯ºÍ²¥·ÅÊÇ¿ÉÒÔµþ¼ÓµÄ£¬Òò´Ë£¬¿ÉÒÔͬʱ´Ó¶à¸öÒôƵԴ²É¼¯ÉùÒô£¬²¢·Ö±ðÊä³öµ½²»Í¬µÄÑïÉùÆ÷£¬¹ÊÉùµÀÊýÒ»°ã±íʾÉùÒôÂ¼ÖÆÊ±µÄÒôÔ´ÊýÁ¿»ò»Ø·ÅʱÏàÓ¦µÄÑïÉùÆ÷ÊýÁ¿¡£µ¥ÉùµÀ£¨Mono£©ºÍË«ÉùµÀ£¨Stereo£©±È½Ï³£¼û£¬¹ËÃû˼Ò壬ǰÕßµÄÉùµÀÊýΪ1£¬ºóÕßΪ2¡£
1.4 ÂëÂÊ
        ÔÚ ÎÞËðÎÞѹËõ¸ñʽÖÐ(Èç.wav)£¬ÂëÂÊ=²ÉÑùÂÊxλÉî¶ÈxÉùµÀÊý¡£ÔÚÓÐËðѹËõÖÐ(Èç.mp3)ÂëÂʱ㲻µÈÓÚÕâ¸ö¹«Ê½ÁË£¬ÒòΪԭʼÐÅÏ¢ÒѾ­±»ÆÆ»µ¡£ÂëÂÊÃèÊöÁËÒ»ÃëÖӵĸÃÒôƵµÄÐÅÏ¢Á¿£¬Òò¶øÉùÒôÎļþ×ܵĴóСÊÇÂëÂÊx×Üʱ³¤¡£ÂëÂÊÒ²½ÐλËÙ£¬µ¥Î»ÊÇ ±ÈÌØÂÊ(bps,bit per second)¡£Í¨³£Ìý¸èʱºòµÄ128kbps¡¢320kbps¾ùΪÂëÂÊ£¬ÆäÖÐ320kbpsÊÇmp3¸ñʽµÄ×î¸ß±ÈÌØÂÊ¡£µ«ºÍ44.1kHz²ÉÑùÂÊ¡¢16bitλÉîµÄwavÎļþ±ÈÆðÀ´(¼ÆËãÒ»ÏÂË«ÉùµÀµÄÂëÂÊÊÇ44.1x16x2=1411.2kbps)£¬ÏàÈ¥ÉõÔ¶¡£Ñ¹ËõºóÂëÂʱ㷢ÉúÁ˱仯¡£ÎÞËðѹËõÖеÄÂëÂÊÓëÒôÖÊÎ޹أ¬ÓÐËðѹËõÖеÄÂëÂʺÍÒôÖÊÕýÏà¹Ø¡£
1.5 ÎÞËðѹËõ
        ÎÞËðѹËõÖ¸µÄÊÇÔÚÎÞËð¸ñʽ֮¼äµÄѹËõ(ת»»)£¬ÎÞÂÛѹËõ(ת»»)³Éʲô¸ñʽ£¬ÒôÖʶ¼ÊÇÏàͬµÄ£¬²¢ÇÒ¶¼ÄÜ»¹Ô­³É×î³õͬÑùµÄÎļþ¡£Æ½Ê±Ëù˵µÄÎÞËð¾ùÊÇÖ¸ÎÞËðѹËõ£¬Ã»ÓÐÎÞËðÂëÂʵÄ˵·¨¡£¶ÔÓÚ¸÷ÖÖ¸ñʽµÄѹËõ¶¼ÊǶÔÓ¦×ÅÒ»ÖÖËã·¨(»òÕß˵±àÂë)£¬²¥·ÅµÄʱºòÐèÒªÓнâÂëÆ÷½øÐÐÒëÂ룬¶øÇÒ²»Í¬µÄ½âÂëÆ÷Ò²¿ÉÄÜ»áÓ°Ïì½âѹ³öÀ´µÄÎļþÍêÕûÐÔ¡£³£¼ûµÄÎÞËð¸ñʽÓУº
wav£ºÎ¢Èí¹«Ë¾µÄÒ»ÖÖÉùÒôÎļþ¸ñʽ£¬ÊÇÎÞѹËõµÄ×î½Ó½üÕæÊµÉùÒôµÄ¸ñʽ(Æä´ÎÊÇmidi)£¬Ö§³Ö¶à²ÉÑùÂʶàÁ¿»¯¾«¶È¡£ËùÓеÄÎÞËð¸ñʽ±¾Öʶ¼ÊÇwavµÄѹËõ£¬ÔÚ²¥·Åʱ»áת»Øwav¡£
flac£ºFree Lossless Audio Coded£¬Êǹú¼ÊͨÓøñʽ£¬ÌصãÊÇѹËõ±È¸ß£¬±àÂëËã·¨Ò²Ï൱³ÉÊ죬µ±flacÎļþÊÜËðʱÒÀÈ»ÄÜÕý³£²¥·Å¡£ÁíÍ⣬¸Ã¸ñʽҲÊÇ×îÏȵõ½¹ã·ºÓ²¼þÖ§³ÖµÄÎÞËð¸ñʽ¡£
ape£ºÊ¹ÓÃMonkey¡¯s AudioÈí¼þ¶ÔCD×¥¹ì¶ø×ª»»³ÉµÄÎļþ¸ñʽ£¬µ«ÓÅÊÆ²¢²»Í»³ö£¬½âÂë½ÏÂý¡£
wma-lossless£ºÒ²ÊÇ΢Èí¹«Ë¾³öÆ·£¬ÌصãÊÇѹËõ±È¸ß£¬µ«Î´³ÉΪÖ÷Á÷¡£
aiff£ºÆ»¹û¹«Ë¾³öÆ·£¬ÊÇAppleÆ»¹ûµçÄÔÉÏÃæµÄ±ê×¼ÒôƵ¸ñʽ¡£
DSD£ºSony´ó·¨µÄ£¬²»ÊǺÜÁ˽⣬ÐÀÉͲ»À´À±ÖÖÎÄ»¯£¬µ«¾Í˵µ¥´¿µÄ³å£¬»¹ÊÇÒª³åµÄ¡£
¶þ¡¢²ÉÑùλÊý ²ÉÑù¾«¶È λÉî¶È
        ²ÉÑùλÊý¿ÉÒÔÀí½âΪ²É¼¯¿¨´¦ÀíÉùÒôµÄ½âÎö¶È¡£Õâ¸öÊýÖµÔ½´ó£¬½âÎö¶È¾ÍÔ½¸ß£¬Â¼ÖƺͻطŵÄÉùÒô¾ÍÔ½ÕæÊµ¡£ÎÒÃÇÊ×ÏÈÒªÖªµÀ£ºµçÄÔÖеÄÉùÒôÎļþÊÇÓÃÊý×Ö0ºÍ1À´ ±íʾµÄ¡£ËùÒÔÔÚµçÄÔÉϼÒôµÄ±¾ÖʾÍÊǰÑÄ£ÄâÉùÒôÐźÅת»»³ÉÊý×ÖÐźš£·´Ö®£¬ÔÚ²¥·ÅʱÔòÊǰÑÊý×ÖÐźŻ¹Ô­³ÉÄ£ÄâÉùÒôÐźÅÊä³ö¡£²É¼¯¿¨µÄλÊÇÖ¸²É¼¯¿¨Ôڲɼ¯ºÍ ²¥·ÅÉùÒôÎļþʱËùʹÓÃÊý×ÖÉùÒôÐźŵĶþ½øÖÆÎ»Êý¡£²É¼¯¿¨µÄλ¿Í¹ÛµØ·´Ó³ÁËÊý×ÖÉùÒôÐźŶÔÊäÈëÉùÒôÐźÅÃèÊöµÄ׼ȷ³Ì¶È¡£8λ´ú±í2µÄ8´Î·½--256£¬16 λÔò´ú±í2µÄ16´Î·½--64K¡£±È½Ïһϣ¬Ò»¶ÎÏàͬµÄÒôÀÖÐÅÏ¢£¬16λÉù¿¨ÄܰÑËü·ÖΪ64K¸ö¾«¶Èµ¥Î»½øÐд¦Àí£¬¶ø8λÉù¿¨Ö»ÄÜ´¦Àí256¸ö¾«¶Èµ¥Î»£¬ Ôì³ÉÁ˽ϴóµÄÐźÅËðʧ£¬×îÖյIJÉÑùЧ¹û×ÔÈ»ÊÇÎÞ·¨ÏàÌá²¢Â۵ġ£
Èý¡¢ÒôƵ²ÉÑùƵÂÊ Fs
        ÊýÂëÒôƵϵͳÊÇͨ¹ý½«Éù²¨²¨ÐÎת»»³ÉÒ»Á¬´®µÄ¶þ½øÖÆÊý¾ÝÀ´ÔÙÏÖԭʼÉùÒôµÄ£¬ÊµÏÖÕâ¸ö²½ÖèʹÓõÄÉ豸ÊÇÄ£/Êýת»»Æ÷£¨A/D£©ËüÒÔÿÃëÉÏÍò´ÎµÄËÙÂʶÔÉù²¨½ø ÐвÉÑù£¬Ã¿Ò»´Î²ÉÑù¶¼¼Ç¼ÏÂÁËԭʼģÄâÉù²¨ÔÚijһʱ¿ÌµÄ״̬£¬³ÆÖ®ÎªÑù±¾¡£½«Ò»´®µÄÑù±¾Á¬½ÓÆðÀ´£¬¾Í¿ÉÒÔÃèÊöÒ»¶ÎÉù²¨ÁË£¬°ÑÿһÃëÖÓËù²ÉÑùµÄÊýÄ¿³ÆÎª²ÉÑù ƵÂÊ»ò²ÉÂÊ£¬µ¥Î»ÎªHZ£¨ºÕ×È£©¡£²ÉÑùƵÂÊÔ½¸ßËùÄÜÃèÊöµÄÉù²¨ÆµÂʾÍÔ½¸ß¡£ ²ÉÑùƵÂÊÊÇָ¼ÒôÉ豸ÔÚÒ»ÃëÖÓÄÚ¶ÔÉùÒôÐźŵIJÉÑù´ÎÊý£¬²ÉÑùƵÂÊÔ½¸ßÉùÒôµÄ»¹Ô­¾ÍÔ½ÕæÊµÔ½×ÔÈ»¡£ÔÚµ±½ñµÄÖ÷Á÷²É¼¯¿¨ÉÏ£¬²ÉÑùƵÂÊÒ»°ã¹²·ÖΪ 22.05KHz¡¢44.1KHz¡¢48KHzÈý¸öµÈ¼¶£¬22.05 KHzÖ»ÄÜ´ïµ½FM¹ã²¥µÄÉùÒôÆ·ÖÊ£¬44.1KHzÔòÊÇÀíÂÛÉϵÄCDÒôÖʽçÏÞ£¬48KHzÔò¸ü¼Ó¾«È·Ò»Ð©¡£¶ÔÓÚ¸ßÓÚ48KHzµÄ²ÉÑùƵÂÊÈ˶úÒÑÎÞ·¨±æ±ð³ö À´ÁË£¬ËùÒÔÔÚµçÄÔÉÏûÓжàÉÙʹÓüÛÖµ
ËÄ¡¢WAVÒôƵ¸ñʽÎļþ´óС¡¢²¥·Åʱ¼ä»»Ëã
        ²ÉÑùÂÊÒ»°ãÊÇ44.1K£¬16bit²ÉÑù¾«¶È£¬´æ´¢³ÉWAV¸ñʽ´óС = 44.1KHz(²ÉÑùÂÊ) X 16bit(²ÉÑù¾«¶È) X 2(Ë«ÉùµÀ) X  ²¥·Åʱ¼ä
        WAV¸ñʽÊÇûÓÐѹËõÎÞËðµÄ£¬MP3¸ñʽÊǰ´1:12ѹËõ±£´æµÄ£¬ËùÒÔMP3¸ñʽ´óСµÈÓÚÉÏʽµÄ1/12¡£
Îå¡¢Ó¢ÎÄ´Ê»ãºÍ³£¼û·­Òë
5.1. Sample¡¢Frame¡¢Packet
        ÕâÈý¸ö¸ÅÄîºÜÖØÒª£¬ºÜÈÝÒ׸ã»ì£¬Æ»¹ûÔÚÆäCore Audio ¹Ù·½ÎĵµÖÐÃ÷È·¶¨ÒåÁË audio stream, channel, sample, frame, packet ºÍ sample rate_ÕâЩ¸ÅÄî £ºWhat Is Core Audio?_
A sample is single numerical value for a single audio channel in an audio stream.
A frame is a collection of time-coincident samples. For instance, a linear PCM stereo sound file has two samples per frame, one for the left channel and one for the right channel.
A packet is a collection of one or more contiguous frames. A packet defines the smallest meaningful set of frames for a given audio data format, and is the smallest data unit for which time can be measured. In linear PCM audio, a packet holds a single frame. In compressed formats, it typically holds more; in some formats, the number of frames per packet varies.
´ÓÉÏÃæÎĵµ¶¨Ò壬¼òµ¥À´Ëµ£¬¿ÉÒÔÕâÑùÀí½â£º
sample ÊÇÒ»¸öÉùµÀµÄÒ»¸ö²ÉÑù¡£
frame ÊÇÒ»¸öʱ¼äµãµÄÑù±¾¼¯ºÏ£¬¾ÙÀýÀ´Ëµ£¬Ò»¸öÏßÐÔµÄPCM Ë«ÉùµÀÒôƵÎļþÿ¸öFrameÓÐ2¸öÑù±¾£¬Ò»¸ö×óÉùµÀÑù±¾£¬ºÍÒ»¸öÓÒÉùµÀÑù±¾¡£
packet ÊÇÒ»¸ö»ò¶à¸ö frame µÄ¼¯ºÏ£¬Ò»¸ö packet °üº¬¶àÉÙ¸ö frame£¬ÊÇÓÉÉùÒôÎļþ¸ñʽ¾ö¶¨µÄ¡£Æ©Èç PCM Îļþ¸ñʽÖÐÒ»¸ö packet °üº¬ 1 ¸öframe¡£¶ø MP3 Îļþ¸ñʽÖÐÒ»¸ö packet °üº¬ 1152 ¸öframes¡£
´ÓÉÏÃæ¶¨ÒåÀ´¿´ÕâÈý¸ö¸ÅÄÏà¶ÀÁ¢£¬¶¨ÒåÇåÎú¡£
5.2 ÕâЩ¸ÅÄîΪʲôÈÝÒ׸ã»ì£¿
        È»¶øÔÚÈÕ³£ÌÖÂÛÖУ¬»áÔÚ¶àÖÖ³¡ºÏÏÂʹÓà frame ºÍ packet Á½¸ö´Ê£¬µ«ÊǸ÷ÖÖ³¡ºÏÏÂËüÃÇ´ú±íµÄº¬ÒåÊDz»Í¬µÄ£¬ËùÒԱȽÏÈÝÒ׸ã»ì¡£
        ¾ÙÏÂÃæ²»Í¬³¡¾°µÄÀý×ÓÀ´ËµÃ÷£º
ÔÚÌÖÂÛ MPEG ¸ñʽµÄʱºò£¬ÈçÍøÉϳ£¼ûµÄMPEGÎļþ¸ñʽ½éÉÜ£¬°Ñ MPEG Ò»¸ö header + payload £¨Ö¡Í· + Êý¾ÝÄÚÈÝ£©µÄÊý¾Ý½á¹¹½Ð×öÒ»¸ö frame (MPEGÊý¾ÝÖ¡)£¬Ò»¸ö MPEG Êý¾ÝÖ¡°üº¬Á˶à¸öÒôƵ֡¡£ÊÂʵÉÏÕâ¸ö¶«¶«ÔÚÉÏÊö iOS Core Audio ¶¨ÒåÖУ¬È´ÓÖ±»³ÆÎªÒ»¸ö packet¡£ËùÒÔÁ½·ÝÎĵµÖУ¬·Ö±ðʹÓÃÁË packet ºÍ frame Á½¸ö´ÊÖ¸´úͬһ¸ö¸ÅÄî¡£
ÍøÂç´«ÊäÒôƵµÄʱºò£¬»á°ÑÒôƵÊý¾Ý½øÐдò°ü·¢ËÍ£¬Õâ¸öʱºòÒ²Óõ½ packet µÄ¸ÅÄËûÓÐ×Ô¼º¶ÀÁ¢µÄ packet header ¶¨Ò壬ÓÖ¸ú iOS Core Audio ¶¨ÒåµÄ packet ²»ÊÇͬһ¸öÁË¡£
ÔÚÌÖÂÛ¼ÆËã»úÍøÂçʱ£¬Ó²¼þÊý¾ÝÖ¡³ÆÎª frame£¬¶øÊý¾ÝÁ´Â·²ã½« frame ´ò°ü³É packet Ö®ºóÌṩ¸øÉϲãÍøÂç²ãʹÓᣠÕâÀï frame ºÍ packet µÄ¸ÅÄîÓÖ¸úÒôƵÌÖÂÛÖеĺ¬Òå²»Ò»ÑùÁË¡£
FFmpegÊÇÒ»¸öÒô/ÊÓÆµ±àÂë½âÂ뼰ת»»µÄ¿ªÔ´Èí¼þ¡£Ëü¶¨ÒåÁËÁ½¸ö½á¹¹Ì壬AVPacket Ò»·Ý´ú±í¾­¹ýѹËõµÄÒôƵ/ÊÓÆµÊý¾Ý£¬AVFrame ´ú±íÒ»·Ý½âѹºóµÄÒ»¸öÒôƵ/ÊÓÆµÊý¾Ý¡£ÊÓÆµÒ»¸ö AVPacket ͨ³£Ö»°üº¬Ò»¸ö AVFrame£¬¾­¹ýѹËõµÄÒôƵ AVPacket ͨ³£°üÀ¨¶à¸ö AVFrame¡£¿ÉÒÔ¿´µ½ FFmpeg ÔÚ´¦ÀíÒôƵºÍÊÓÆµÊ±£¬¶Ô packet ºÍ frame ¸ÅÄîµÄʹÓøú iOS Core Audio »ù±¾Ò»Ö¡£
´ÓÉÏÃæÀý×Ó¿ÉÒÔ¿´µ½£¬²»Í¬³¡¾°Ï¶¼Ê¹ÓÃÁË frame ºÍ packet Á½¸ö´ÊÓï»á´ú±í²»Ò»ÑùµÄº¬Òå¡£¸üÔã¸âµÄÊÇ£¬Èç¹ûʹÓÃÁËÖÐÎÄ¡±Ö¡¡±£¬ÔÚijЩÓᄈϣ¬µ½µ×ÊÇ´ú±íÊý¾ÝÖ¡¡¢ÒôƵ֡¡¢packet »¹ÊÇ frame ÄØ£¬¾Í¸üÈÝÒ×·Ö²»Çå³þÁË¡£
ÆÀÂÛÁÐ±í£¨2£©
E-MU Â¥Ö÷
2009-5-17 15:53:47 »Ø¸´
Äܳª³öÀ´¾ÍºÃÁË
2010-3-1 20:45:11 »Ø¸´
