Sound Aesthetics Sampling Autumn Choirs KONTAKT
ÒôÔ´
Õâ¸ö¿â°üº¬³¾ÍÁ·ÉÑïµÄÎËÃùºÍ²ÄÖÊ¡£ËäÈ»Äú¿ÉÒÔÁ¢¼´Ê¹ÓÃÔ´ÉùÒô£¬µ«ÄúÒ²¿ÉÒÔͨ¹ýʹÓñäÐÎÆ÷´´½¨ÓÐȤµÄ½Ú×࣬Âö³å£¬É¨ÃèµÈµÈ¡£Ëü»¹°üÀ¨´óÁ¿µÄÔ¤É裨160+£©£¬ÎÒÃÇÕæµÄŪ»µÁËÉùÒô²¢ÀûÓÃÁËÒýÇæ¡£
Ö÷Òª½Ó¿Ú
¸Ã¿â½¨ÔÚË«²ãÒýÇæÄÚ£¬Òò´ËÄú¿ÉÒÔÇáËɵؽ«Á½¸öÉùÒô»ìºÏÔÚÒ»Æð£¬²¢·Ö±ðµ÷Õûÿ¸öÉùÒôµÄÉèÖ᣸ýӿÚΪÄúÌṩÍêÕûµÄADSR¿ØÖÆ£¬²¢¾ßÓÐÖ÷¿Ø²¿·Ö£¬Äú¿ÉÒÔÔÚÆäÖÐÉèÖÃÁ¢ÌåÉù¿í¶È£¬Â˲¨Æ÷£¨LP£©½ØÖ¹ÆµÂÊ£¬Êä³öÔöÒæºÍÈ«¾°Î»Öá£ÁíÍ⻹ÓÐÒ»¸öÔ˶¯Ð§¹û£¬ÈÃÄã´´ÔìÒÆ¶¯µÄÉùÒô;Ò²¿ÉÒÔµ¥¶ÀÓÃÓÚÿ¸öͼ²ã¡£
MORPHER
MorpherÕæµÄÊÇÒýÇæµÄºËÐÄ¡£Äú¿ÉÒÔʹÓÃËüÀ´´´½¨Æð·ü²»¶¨µÄ½Ú×࣬»òÕß¼òµ¥µØ´ÓÒ»¸öÒôÉ«±äΪÁíÒ»¸öÒôÉ«£¬¾ÍÏñLFOÒ»Ñù¡£Èç¹ûÄãÏëͨ¹ýÄãµÄModwheel»òÆäËû¶«Î÷±äÐΣ¬ÄãÒ²¿ÉÒÔÖ»ÉèÖÃËüµÄ·¶Î§¶ø²»±Ø¼¤»îÒôÐòÆ÷¡£ÄúÉõÖÁ¿ÉÒÔͨ¹ý¼ÓÔØºÍ±£´æ°´Å¥¼ÓÔØÒôÐòÆ÷Ô¤Éè¡£
Ч¹û³¡
Fx»ú¼Ü°üÀ¨»ìÏ죬ÏàλÆ÷£¬ÑÓ³Ù£¬LoFi£¬¾í»ý£¬Ê§Õ棬Ïâ±ß£¬ºÏ³ªºÍEQ¡£Ëü·ÖΪÈý¸öÑ¡Ï¡£
¹æ¸ñ
160¶à¸öKontakt²¹¶¡£¨.nki£©
62¸öÑù±¾£¨×î¶à48khz / 24bit£©
12¸ö×Ô¶¨ÒåIR
592 MB£¨´ÓԭʼÊý¾Ý776 MBѹËõncw£©
ÐèÒªKontakt 5.5.2»ò¸ü¸ß°æ±¾£¨²»ÊÇKontakt Player£©
Ô­ÎÄ
This library contains dusty & dirty drones and textures. While You can use the source sounds right out of the box are You also able to create interesting rhythms, pulses, sweeps and much more by only using the morpher. It also includes a vast collection of presets (160+) where we really mangled the sounds and took advantage of the engine.
MAIN INTERFACE
The library is built within a dual layer engine so You can easily mix two sounds together and adjust settings for each one individually. The interface gives you full ADSR control and has a master section where you can set Stereo width, Filter (LP) cutoff, Output gain and Panorama position. Also there is a Movement Effect, which let's You create moving sounds; also available for each layer individually.
THE MORPHER
The Morpher is really the core of the engine. You can use it to create choppy rhythms or simply morph from one to another sound just like sort of a LFO. You can also set only the range of it without having to activate the sequencer if You want to morph via Your Modwheel or something. You can even load Sequencer presets via the load and save buttons.
THE EFFECT RACK
The Fx rack includes Reverb, Phaser, Delay, LoFi, Convolution, Distortion, Flanger, Chorus and an EQ. It is divided into three tabs.
SPECIFICATIONS
160+ Kontakt patches (.nki)
62 samples (Most 48khz/24bit)
12 custom IRs
592 MB (ncw compressed from 776 MB of raw data)
Requires Kontakt 5.5.2 or higher (NOT Kontakt Player)
Sound Aesthetics Sampling Autumn Choirs KONTAKT | 583 MB
              ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
