Tachyon Sonics releases Tachyon Audio Time Stretch
2022-3-21 11:43| ·¢²¼Õß: hooks| ²é¿´: 1270| ÆÀÂÛ: 0
ÕªÒª: Tachyon Sonics releases Tachyon Audio Time StretchTachyon Sonics has released Tachyon Audio Time Stretch, a new stand-alone application that does only one thing: time stretching audio files.Its main d ...
Its main design goal is to achieve the highest possible quality rather than high performance. A fast CPU is required, and only off-line processing is possible. It is available for Windows (64-bit) and macOS (universal binary).
It is now for sale at the KVR Marketplace for $120.
Features:
Time stretches any music, track, speech or sound by any amount between 4 times slower and 4 times faster.
Professional-grade audio quality, based on state-of-the-art algorithms.
Supports mono, stereo and multi-channel (5.1, 7.1) audio files. Fully preserves the stereo / spatial field.
Loads and saves WAVE (*.wav), AIFF/AIFC (*.aiff, *.aifc) and AU Sun/NeXT (*.au) audio files, in PCM 16-bit / 24-bit integer, or in 32-bit IEEE floating point format. Also loads FLAC, OGG, MP3 and M4A files.
Supports sampling rates from 8 kHz to 384 kHz.
The time stretching factor can be specified in many ways: length change, speed change, length from/to, tempo from/to, video FPS from/to, etc.
Accurate to a single sample (with sub-sample accuracy internally).
Transforms multiple audio files simultaneously on multi-core computers.
Four quality settings (default 4 - highest quality) are available. Real-time processing speed on most computers with quality setting 1 (lowest).
Integrated mini player to preview the result before it is fully transformed.
Read more at
www.tachyon-sonics.com
·¹ý
À×ÈË
ÎÕÊÖ
ÏÊ»¨
¼¦µ°
È«²¿»Ø¸´(0)
ÒôƵ±à¼­Èí¼þ
