音频应用 首页 音频插件 查看内容
U&I Software MetaSynth CTX, the epic painting with sound workstation is back
2021-8-3 09:17| 发布者: 2802350| 查看: 1658| 评论: 0
摘要: SYNTH ANATOMY uses affiliation partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Thanks!UI Software Metasynth CTX, the “Photoshop” for ...
SYNTH ANATOMY uses affiliation & partner programs (big red buttons) to finance a part of the activity. If you use these, you support the website. Thanks!
U&I Software Metasynth CTX, the “Photoshop” for sound designers is back in a revised version with new image synthesis features & support for macOS 11.0
Without sounds, no music composition, and production. Sounds can come from synthesizers, drum machines, guitars, violins … or even from field recordings. There is a huge variety of sources. The process in which musicians turn their sources into their sound is called sound design. It’s an art and everyone has their own approach. There is no perfect sound. That’s special about it.
The sound design begins with sound generation (programming a synth, how you play a guitar + effects…)  and ends in the mastering of a track. All use audio as a basis, whether with hardware (tape recorder …) or in software with a DAW and plugins. But there’s another way. MetaSynth, for example, is a software application that turned the process upside down by offering sound creation using image synthesis.
MetaSynth is a sound design toolbox packed with innovative tools used by many composers including Richard D James (Aphex Twin). The software is divided into different sections. It starts with Image Synth which is an environment where you paint your sounds. It allows you to create your own loops. The developer promises a host of available synthesis methods with nearly infinite customizable micro-tonality. Plus, you can combine it with a sampler or sequencer for further playability.
Image Filter gives you two dynamic stereo filters in the hand for classic filtering up to experimental, otherwordly sounds. Then, you have the Spectrum Synth that analyses your sounds and creates events that capture the original’s harmonics. You can then manipulate, filter, and re-arrange them to create new sounds. Here it goes the other way around: from audio files to paintings.
Effects Room is U&I Software’s interpretation of a multi-effect processor. Instead of switching it on/off, you can draw advanced graphic envelopes which you can set the effects in motion. Initially more innovative, now you can find it also in classic DAWs through automation. It includes classic effects like delay, reverb, chorus but also more unique ones like grain (granular-synthesis) or shuffler.
The last part is the Montage Room, a non-MIDI 24-track sequencer where you can compose entire tracks without pre-rendering your sequences. Each track can have images and samples that make it super unique.
With the MetaSynth CTX, the two-man developer company U&I brings the well-known image Synthesizer workstation back in a revised version for modern Mac computers. Yes, so far no Windows version but will come in the future says the developer. The remake not only brings support for modern Macs but also numerous new features for each section. Here are some highlights:
16-bit image support for Image Synth & Image Filter: increases low amplitude representation, subtlety in re-synthesis, and improved analysis fidelity.
four new choices of color/luminosity display and additional custom tuning & scales for Image Synth & Image Filter
Spectrum Synth and Sequencer gets unlimited length limits
Sequencer includes seamless dynamic selection playback looping.
Effect Room now has an auto-save function for the entire effect state.
Sample Editor can now generate loop or one-shot samples
… and more
MetaSynth is a terrific sound design tool. It’s definitely for nerds who want to fine-tune the sounds in every last detail or want to get inspired by new sound creation tools. If you have a Richard Devine, Richard D James (Aphex Twin) .. in you, MetaSynth is certainly very exciting for your work.
U&I Software MetaSynth CTX is available now for 306
路过
雷人
握手
鲜花
鸡蛋
最新评论
音频应用广告
音频编辑软件
GMT+8, 2025-7-3 10:50 , Processed in 0.029294 second(s), 10 queries , Redis On.
