Exceptional Conversion Quality, Plus USB Convenience
The Lynx Aurora 16-USB AD/DA converter with USB 2.0 interface makes a great product even better and more functional! The Aurora 16-USB provides up to 192kHz resolution, 16 input and output channels, AES/EBU and word clock I/O, and an onboard 32-channel digital mixer for easy signal routing. The installed LT-FW USB 2.0 L-slot interface allows up to 16 channels of digital and analog input and output at up to 96kHz sample rates (8 channels at 192kHz). Now you can get pristine audio for everything from desktop studio projects to surround applications right out of the box with the Aurora 16-USB AD/DA converter!
Lynx Aurora 16-USB AD/DA Converter at a Glance:
Onboard 32-channel Mixer
USB 2.0 Interface installed
SynchroLock Jitter Reduction
DB-25 Connectors
The on-board 32-channel digital mixer provides extensive routing and mixing options. Acting as a powerful patch bay-style digital router, Aurora 16-USB can easily route signals between analog and digital inputs on a channel-by-channel basis. Mixing capability on each output also provides flexible zero-latency monitoring.
USB 2.0 interface installed
The preinstalled Lynx LT-USB interface card gives your Aurora 16-USB AD/DA converter USB 2.0 connectivity and control! Equipped with the LT-USB, the Aurora easily interfaces with USB 2.0 computer connections, even from laptop Mac and PC units. The interface allows up to 16 channels of digital and analog input and output at up to 96kHz sample rates (8 channels at 192kHz).
Lynx&££39;s proprietary SynchroLock jitter reduction technology gives the Aurora 16-USB incredibly clear audio performance. This provides extreme jitter reduction of up to 3000:1, allowing the Aurora 16-USB to output an extremely clean clock signal for driving your digital audio system.
DB-25 Connectors
All analog and digital connections use DB-25 connectors with industry standard pin-outs, which are compatible with off-the-shelf cables Lynx as well as from manufacturers such as ProCo, Hosa, and others.
Lynx Aurora 16-USB AD/DA Converter Features:
Simultaneous 16-channel Analog I/O and 16-channel AES/EBU I/O
24-bit/192kHz mastering quality A/D and D/A conversion
Single-rackspace design
Extensive remote control capability via Lynx AES16, IrDA and MIDI
Installed LT-FW USB 2.0 interface
Onboard digital mixer provides flexible I/O routing
Word clock I/O with Lynx SynchroLock Jitter Reduction Technology
Lynx Aurora 16-USB gives you 16 channels of premium conversion plus USB 2.0!
Tech Specs
| Channels | 16 | | A to D | Yes | | D to A | Yes | | Sample Rate | 192kHz | | Bit Depth | 24-bit | | Analog Inputs | 2 x DB25 | | Analog Outputs | 2 x DB25 | | Digital Inputs | 1 x DB25 (AES/EBU) | | Digital Outputs | 1 x DB25 (AES/EBU) | | Clock Inputs | 1 x Word Clock | | Clock Outputs | 1 x Word Clock | | Other I/O | MIDI In/Out | | Expansion Slots | One expansion slot, with pre-installed LT-USB interface card | | Rack Spaces | 1U | | Height | 1.75" | | Depth | 9" | | Width | 19" | | Weight | 12 lbs. shipping weight |
