»ìÏìЧ¹ûÆ÷»ù±¾²ÎÊý
»ìÏì²ÎÊý
Reverb Hall 1 Ä£Äâ´óÒôÀÖÌüµÄ»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time2.8s0.3-30.0s»ìÏìʱ¼ä
High Ratio0.80.1-1.0¸ßƵ˥¼õÂÊ
Diffusion60-10»ìÏìÀ©É¢
Ini.Dly40.0ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF7.0kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPFTHRUTHRU,32Hz-8KHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Hall 2 Ä£Äâ´óÒôÀÖÌüµÄ»ìÏìµÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time3.2s0.3-30.0s»ìÏìʱ¼ä
High Ratio0.70.1-1.0¸ßƵ˥¼õÂÊ
Diffusion80-10»ìÏìÀ©É¢
Ini.Dly38ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF6.3kHz1.0kHz-16.0kHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPFTHRUTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Room 1 Ä£ÄâË®Äàǽ±Ú·¿¼ä²úÉú´óÁ¿»ØÉùµÄ»ìÏì *Ϊ¹ÄÒôÉ«Ôö¼ÓÏÖ³¡¸Ð
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.4s0.3-30s»ìÏìʱ¼ä
Diffusion70-10»ìÏìÀ©É¢
Ini.Dly5.0ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPFTHRU1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPFTHRUTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Room 2 Room1µÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.8s0.3-30s»ìÏìʱ¼ä
High Ratio0.60.1-1.0¸ßƵ˥¼õÂÊ
Ini.Dly17ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF9kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPF80HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb STAGE ÀàËÆ³ÌÐò1£¬µ«¸üÃ÷ÁÁ£¬¸üÓÐÏÖ³¡¸Ð
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time3.4s0.3-30s»ìÏìʱ¼ä
High Ratio0.90.1-1.0¸ßƵ˥¼õÂÊ
Ini.Dly45ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
HPF70HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Plate Ä£Äâ¸ÖÅÌÀà»ìÏìϵͳ£¬ÊÊÓ¦ÐÔºÜ¹ã£¬ÌØ±ðÊÇÈËÉù£¬¹ÄºÍ´ò»÷ÀÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time2.4s0.3-30s»ìÏìʱ¼ä
Ini.Dly16ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF8kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev Ambience 1 Ä£ÄâÀÖÆ÷ÖÜΧµÄ»ìÏ죬ÓÃÓÚÈËÉù£¬ºÏ³ªºÍ´ò»÷ÀÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.2s0.3-30s»ìÏìʱ¼ä
High Ratio10.1-1.0¸ßƵ˥¼õÂÊ
Ini.Dly19ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
HPF45HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev Ambience 2 ³ÌÐò7µÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time0.8s0.3-30s»ìÏìʱ¼ä
Ini.Dly0.1ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
HPF56HzTHRU,32Hz-8kHZ¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev Live Room 1 Ä£ÄâÏÖ³¡·¿¼äµÄ»ìÏì,»ìÏì·´Éä±ÈRecerm RoomÇ¿
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
LPF7kHz1KHz-16KHz,THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev Live Room 2 ³ÌÐò9µÄ±äÖÖ
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time2.2s0.3-30.0s»ìÏìʱ¼ä
High Ratio0.50.1-1.0¸ßƵ˥¼õÂÊ
Ini.Dly12.0ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF4.0kHz1.0kHz-16.0kHz.THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Reverb Vocal ÓÃÓÚÈËÉù,ºÏ³ªµÄ»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Rev.Time1.9s0.3-30.0s»ìÏìʱ¼ä
Ini.Dly16ms0.1-200.0msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF12kHz1.0kHz-16.0kHz.THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPF100HzTHRU,32Hz-8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Chorus Reverb Á¢ÌåÉùºÏ³ªºó½Ó»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Mod.Freq0.8Hz0.1-20Hzµ÷ÖÆËÙ¶È
Mod.Depth40%0-100%µ÷ÖÆÉî¶È
Mod.Dly1.3ms0-24msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
High Ratio0.70.1-1¸ßƵ˥¼õÂÊ
Ini.Dly30ms0.1-139msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF6.3kHz1kHz--16kHz, THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPFTHRUTHRU,32Hz--8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev.Depth24%0-100%»ìÏìÉî¶È
Flange Reverb Á¢ÌåÉùÆ®ºöºó½Ó»ìÏì
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Mod.Freq1.4Hz0.1-20Hzµ÷ÖÆËÙ¶È
Mod.Depth22%0-100%µ÷ÖÆÉî¶È
FB Gain+45%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÆ®ºöµÄÔöÒæ
Mod.Dly13ms0-15.5msÔÚ¿ªÊ¼µ÷ÖÆÇ°µÄÑÓ³Ùʱ¼ä
Ini.Dly26ms0.1-200msÖ±´ïÉùÓëÔçÆÚ·´ÉäÉùÖ®¼äµÄÑÓ³Ùʱ¼ä
LPF4.5kHz1kHz--16kHz, THRUµÍͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
HPF45HzTHRU,32Hz--8kHz¸ßͨÂ˲¨Æ÷µÄ½ØÖ¹ÆµÂÊ
Rev.Depth30%0-100%»ìÏìÉî¶È
Delay L-C-R ×ó£¬ÖУ¬ÓÒÉùµÀ¶ÀÁ¢µÄÑÓ³Ù
²ÎÊýÊýÖµ·¶Î§ËµÃ÷
Dly L250ms0.1-661ms×óÉùµÀÑÓ³Ùʱ¼ä
Dly R500ms0.1-661msÓÒÉùµÀÑÓ³Ùʱ¼ä
Dly C125ms0.1-661msÖÐÑëÉùµÀÑÓ³Ùʱ¼ä
Level C700-100ÖÐÑëÉùµÀÑÓ³ÙÒôÁ¿
FB.Dly500ms0.1-661msÔÚ¿ªÊ¼·´À¡Ç°µÄÑÓ³Ùʱ¼ä
FB.Gain+40%-99--+99%´¦ÀíºóµÄÐźŷµ»ØÑÓ³ÙµÄÔöÒæ
High Ratio0.80.1-1·´À¡µÄµ÷Ƶ˥¼õÂÊ
