°®Î¬µÂ|Avid C|24/C24 ¼ÒôÅïÌ××°´øProTools|HDX
A Great Deal on a Complete Pro Tools|HDX Studio Bundle!
Avid&££39;s Pro Tools|HDX is beyond a doubt the most powerful DAW system on the planet. When you add the amazing flexibility of Avid&££39;s C|24 (their most accessible large-format control surface), you get even more functionality than ever. This amazing offer from Avid lets you save big on a complete Pro Tools|HDX system, including a C|24, an HDX DSP-acceleration card, an expanded HD I/O interface, and (of course) Avid&££39;s acclaimed Pro Tools HD DAW software. You also get all of the cabling you need to hook it up. It&££39;s the perfect solution for any small to midsize recording studio, editing suite, or mixing house. What&££39;s more, the C|24 Studio Bundle with ProTools|HDX lets you save big on a complete Pro Tools|HDX rig from Avid!
Avid C|24 Studio Bundle with ProTools|HDX at a Glance:
The versatility of Avid&££39;s Pro Tools HD DAW software
The raw power of Avid&££39;s HDX DSP-acceleration
The flexibility of Avid&££39;s C|24 large-format control surface
The amazing sound quality of Avid&££39;s HD I/O interface
Avid Pro Tools HD is the most comprehensive audio and music production environment to date. Powerful new AAX plug-ins, ultra-fast workflows, and over 50 more exciting new features give you more flexibility than ever before. Whether you run a recording facility, editing suite, or post-production house, Avid Pro Tools HD 11 is going to rock your world!
Disk Caching lets you load your entire sessions into RAM, giving you instant response and incredible real-time editing capabilities. Pro Tools HD 11 also gives you advanced Mida Composer integration and network storage compatibility (must haves for post work). There&££39;s a ton to know about Avid Pro Tools HD 11, so be sure to call your sales engineer with any questions you may have.
Each Avid HDX card is like having about the equivalent of an HD3 or HD4 system on a single card. To put it mildly, that&££39;s a ton of DSP power for your DAW! What&££39;s more, there&££39;s a separate FPGA processor for your mix bus, so all of your HDX card&££39;s DSP power is dedicated to running plug-ins. Each HDX card gives you 256 voices, a full four times the routing capacity of an Accel card. That means you can freely use Avid&££39;s new AAX plug-ins, without worrying about running out of voices.
Here&££39;s where it gets even cooler. HDX cards and AAX plug-ins are ready for a 64-bit world. Although Pro Tools HD is still in transition from 32-bit to 64-bit, you still get the advantages of onboard 64-bit architecture. For one thing, the HDX summing bus is true 64-bit, giving you amazing headroom to mix with. Speaking of headroom, Pro Tools|HDX also gives you 32-bit floating-point processing between plug-ins, increasing your mix bus&££39;s dynamic range to over 1000dB. That makes clipping and dither buildup things of the past.
Avid&££39;s C|24 gives you 24 bankable channel strips, each with a touch-sensitive, motorized fader, motion-sensitive encoder and LED ring, and dedicated Mute, Solo, Select, Input, Record, EQ, Dynamics, Insert, Send, and Automation illuminated switches. High-quality analog components provide you with great sound on the front end, as well as the outputs you need to handle tasks such as monitoring. Easy-to-read, dual-row LED scribble strip displays also let you easily keep tabs on each channel. The C|24 comes equipped with a 5.1 surround analog monitor section for post-production work, and a built-in talkback mic, plus inputs for remote talkback and listen-back, which simplify your control room. It&££39;s the perfect addition to a basic professional-level Pro Tools|HDX system!
The HD I/O from Avid offers unrivaled fidelity and lower latency than any HD series interface to date. To make tracking with the HD I/O easier than ever, Avid gave it their fantastic soft-knee analog limiter. This dynamics processor, named Curv, catches fast transients, letting you track hotter without clipping. What&££39;s more, the Curv won&££39;t unnecessarily color your sound, so you get top-quality completely headache free. This version of the HD I/O is equipped with 16 channels of analog input, eight channels of analog output, and eight channels of digital I/O.
Avid C|24 Studio Bundle with ProTools|HDX Features:
Avid Pro Tools HD DAW Software Features:
Digital Audio Workstation (DAW) software for Mac and PC
NEW: Support for Avid&££39;s HDX cards and AAX plug-in format
NEW: Disk Caching lets you cache your entire sessions into RAM, dramatically speeding up your workflow
NEW: Read and record from flash drives, RAID systems, and server storage systems such as Avid&££39;s ISIS 5000
NEW: Increased Automatic Delay Compensation (up to 16,383 samples)
NEW: Sessions can contain various audio file types and formats
NEW: Down Mixer sums sessions from up to 7.1 surround down to 5.1, 2.1, 2.0, and even mono mixes
NEW: 32-bit floating-point audio lets you store higher-quality audio
NEW: Clip Gain adds dynamic volume flexibility and increases integration with Media composer
NEW: Upgraded AudioSuite processing includes handles, whole file processing, and reverse delay/reverb processing
NEW: Channel Strip plug-in format delivers the sound of the legendary System 5 console
NEW: Advanced EUCON support adds over 500 controllable commands to your EUCON-equipped control surface plus EUCON support for XMON
NEW: Real-time fades eliminate the need for fade files and allow you to apply fades with the timeline running
NEW: Rewritten Disc Scheduler is more forgiving for slower hard drives and allows use of network access storage drives
NEW: Handy visual indicators for mutes and solos
NEW: Bus Interrogation lets you track your signal flow
NEW: Export Selected Tracks as New Session command make collaboration easier
NEW: 24-hour timeline support for enhanced post-production compatibility
NEW: Export to iTunes and Export to SoundCloud
Works with any audio interface or standalone
Multitrack Beat Detective and Elastic Audio let you correct timing across all of your tracks
Up to 256 voiceable tracks at 44.1/48kHz
Up to 768 channels of simultaneous I/O
OMF/AAF/MXF interchange support built in
MP3 Export Option with built in
Full-time code support with feet and frames rulers
Adjustable stereo pan depth feature
Over 70 plug-ins and virtual instruments for sound shaping
Score Editor and MIDI Editor windows for comprehensive composing
Create a flawless performance using track compositing features
Automation and controller lanes provide easy editing access
QuickTime HD support on Mac OS X-based systems
Avid HDX DSP-acceleration Card Features:
Incredible DSP power for Avid&££39;s AAX plug-in format
3-7 times the power of an HD Accel system on a single PCIe card
FPGA mix processor frees up DSPs for powering plug-ins
256 voices per card (4x the voices HD Accel)
Connect up to four HD series interfaces per card
64-bit floating-point summing sounds amazing
32-bit floating-point processing between plug-ins preserves quality and dramatically increases headroom
Expand your system by adding more HDX cards
64-bit-ready architecture is ready for the future of Pro Tools HD
Avid C|24 Control Surface Features:
Touch-sensitive motorized faders
Dedicated Mute, Solo, Select, Input, Record, EQ, Dynamics, Insert, Send, and Automation illuminated switches
Dual-row LED scribble strip displays
16 high-quality, low-noise mic/line/DI preamps
8 x 2 stereo line submixer
Built-in talkback mic and inputs for remote talkback and listen-back
Avid HD I/O Audio Interface with HDAD Expansion Module Features:
High-performance AD/DA converters
Redesigned analog section with state-of-the-art filtering and design
Power supply improves noise performance and jitter
Lower latency
Updated digital card
192kHz AES/EBU and S/PDIF single-wire
ADAT S/MUX II and S/MUX IV (enclosure and expansion card)
Curv analog limiting circuitry on input
16 analog inputs (using 2 x DB-25)
Eight analog outputs (using DB-25)
Additional digital I/O: 2 channels of AES/EBU I/O (supports 192kHz single-wire), 2 channels of S/PDIF I/O, 8 channels of ADAT I/O (supports S/MUX II and IV)
Additional Components Include:
DB-25-XLRM Digisnake 12&££39; x 1
DB-25-XLRF Digisnake 12&££39; x 2
DB-25-DB-25 Digisnake 12&££39; x 3
DB-25-TRS Digisnake 12&££39; x 7
ÆÀÂÛÁÐ±í£¨2£©
2009-2-20 22:49:22 »Ø¸´
:victory: :victory: :victory:
2009-2-24 09:37:07 »Ø¸´
