ÒôƵ¼¼ÊõÃû´ÊÓ¢ºº¶ÔÕÕ
A/D£¬D/A
Conversion Ä£/Êý£¬Êý/ģת»»
Afterglow ϦÑôʱ·ÖЧ¹û
Ambient »·¾³£¨»ØÉù£©
Analogic Ä£ÄâµÄ
Bypass ÅÔ·
Canon ¿¨Ù¯Ð§¹û
Canyon ɽ¹ÈЧ¹û
Cathedral ½ÌÌûìÏìЧ¹û
Chamber ÃÜÊÒ»ìÏì
Chord ºÍÏÒ
Chorus ºÏ³ª
Decay Ë¥¼õ
Delay ÑÓ³Ù
Delay Effect Processor ÑÓ³ÙЧ¹û´¦ÀíÆ÷
Digital Êý×ÖµÄ
Dual Ë«ÖØÉù£¬Ë«Éù¹ì
Dynamic Doubling ¶¯Ì¬Ë«Éù
Echo »ØÉù
Edit ±à¼­
Effector Ч¹ûÆ÷
Effect Processor Ч¹û´¦ÀíÆ÷
EQ=Equalizer ¾ùºâÆ÷
ER=Early Reflection ÔçÆÚ·´Éä
Footswitch ½Å̤¿ª¹Ø
Fullness ·áÂú¶È
Gate ѡͨÃÅ
Gate Rev. ѡͨ»ìÏì
Guitar ¼ªËû
Gymnasium ÌåÓý¹ÝЧ¹û
Hall ÌüÌûìÏì
Hold ±£³Ö
Interparameter ÄÚ²¿²ÎÊý
Inversive Rev. ÄæÊ½»ìÏì
Keycontrol ¼ü¿Ø
long ³¤£¨»ØÉù£©
Memory ¼Ä´æÆ÷£¬¼ÇÒä
MIDI=Music Instrument Digital Interface µç×ÓÀÖÊý
Mix »ìºÏ
Modelation µ÷ÖÆ
Multi-Echo ¶àÖØ»ØÉù
Multi-Tap ¶à¹ì·ÅÒôЧ¹û
Once Touch µ¥´Î´¥·¢
Parking Terrace ½×ÌÝʽͣ³µ³¡Ð§¹û
Phase Ïàλ
Piano ¸ÖÇÙ
Pitch ±äµ÷£¬Òô¸ß
Plate ½ðÊô°æ»ìÏì
Point ±êµã
Predelay Ô¤ÑÓ³Ù
Preset Ô¤ÖÆ
Recall ºô½Ð
Reinforcement ÔöÉùЧ¹û
Remote Control Ò£¿Ø
Resonance ¹²Õñ
Rev.Time »ìÏìʱ¼ä
Reverberation »ìÏì
Reverberation Effect Processor »ìÏìЧ¹û´¦ÀíÆ÷
Reverse Reverberation µßµ¹Ê½»ìÏì
Room ·¿¼ä»ìÏì
Sample ²ÉÑù
Saxophone Èø¿Ë˹¹Ü
Scrollback ÍùǰÕÒ
Short ¶Ì£¨»ØÉù£©
Signal ÐźÅ
Slap ÅÄ´ò
Slope бÂÊ
Sound Pressure Éùѹ
Static Doubling ¾²Ì¬Ë«Éù
Stereo Flange Á¢ÌåÉù·¨À¶Ð§¹û
Store ´æ´¢
Tempo ËÙÂÊ
Thru.=Through ת½Ó
Trigger ´¥·¢
Adapter ת½ÓÆ÷
Aerial ÌìÏß
Antenna ÌìÏß
Beat Signal ²îÅÄÐźÅ
Brightness Ã÷ÁÁ¶È
Camera ÉãÏó»ú
Cases °ü×°Ïä
CD=Compact Disc ¼¤¹â³ª»ú
Clear Button Çå³ý¼ü
Clock ÖÓÂö³å
Compensate ²¹³¥
Continued Play Á¬½ÓÆ÷
Contrast Á¬Ðø²¥·Å
De-emphasis ¶Ô±È¶È
De-esser È¥¼ÓÖØ
Display È¥¡°ßÐßС±Éù
Drum ÏÔʾ
Dry ¹Ä
Dynamic Range ¶¯Ì¬·¶Î§
Erase Ĩ³ý
f&b sEARCH Buttons ǰºóËÑË÷¼ü
Flow Chart Á÷³Ìͼ
Forward &Backward Skip Buttons ǰºóÌøÔ¾¼ü
Hum and Noise ¡°ºßºß¡±ÔëÉù
IndexButton Ë÷Òý¼ü
Keyboard ¼üÅÌ
Knob ÐýÅ¥
LD=laser Disc ´óÊÓÅÌ»ú£¬ÀØÉä»ú
Multipurpose ¶àÖØÄ¿µÄ£¬¶à¹ì·ÅÉù
Pause ÔÝÍ£
Pedal ̤°å
Play Indicator ²¥·ÅָʾÆ÷
Pre-Emphsis Ô¤¼ÓÖØ
Program Play ³ÌÐò²¥·Å
Programmable ¿É±à³ÌÐòµÄ
Projector TV ͶӰµçÊÓ
Pulse Âö³å
Push-Pull ÍÆÍìµç·
Quantization Á¿»¯
Random pLay Ëæ»ú²¥·Å
Racks »ú¿ò
Receiver ½ÓÊÕ»ú
Remaining Time Ê£Óàʱ¼ä
Repeat Play ÖØ¸´²¥·Å
RF=radio Frequency É䯵
Scan Play ɨÃè²¥·Å
Selector Ñ¡ÔñÆ÷
Servo System ËÅ·þϵͳ
Shuffle Play Ëæ»ú²¥·Å
Stage Monitor Îę̀¼àÌýÒôÏä
Standby ×¼±¸
Stands »ú¼Ü
Stop Í£»ú
Synthesizer ºÏ³ÉÆ÷£¬×ÛºÏÆ÷
Tape Background Noice ´Å´ø±¾µ×ÔëÉù
Theatre ¾ç³¡
Time Code ʱ¼äÂë
Timer ¶¨Ê±Æ÷
Tip-Ring-sleeve о-»·-Ì×Ͳ
Video Signal ÊÓÆµÐźÅ
Wet ʪÉù
film industry µçÓ°¹¤Òµ
cinematograph µçÓ°ÉãÓ°»ú, µçÓ°·ÅÓ³»ú
cinema, pictures µçÓ°Ôº (ÃÀ×÷:movie theater)
first-run cinema Ê×ÂÖÓ°Ôº
second-run cinema ¶þÂÖÓ°Ôº
art theatre ÒÕÊõÓ°Ôº
continuous performance cinema Ñ­»·³¡µçÓ°Ôº
film society µçӰЭ»á,µçÓ°¾ãÀÖ²¿ (ÃÀ×÷:film club)
film library µçÓ°×ÊÁϹݠ
premiere Ê×ӳʽ
film festival µçÓ°½Ú
distributor ·¢ÐÐÈË
Board of Censors Éó²éÊð
shooting schedule ÉãÖÆ¼Æ»®
ÆÀÂÛÁÐ±í£¨6£©
iZotope Â¥Ö÷
censor¡¯s certificate Éó²é¼¶±ð
release ×¼ÓèÉÏÓ³
banned film ½ûӳӰƬ
A-certificate A¼¶(¶ùͯ²»ÒË)
U-certificate U¼¶
X-certificate X¼¶(³ÉÈ˼¶)
direction µ¼ÑÝ
adaptation ¸Ä±à
scenario, screenplay, script ±à¾ç
AFL=After-Fade Listen Ë¥ºó¼àÌý
AUx.=Auxiliary ¸¨ÖúµÄ
AQ Dynaudioµ¤Äã»
ex?posureÁ¦±¦Éù¡£
Aux.return ¸¨Öú·µ»Ø
Aux.send ¸¨ÖúËͳö
Balance ƽºâ
BUs ĸÏߣ¬¹«¹²Ïß
Clip Ï÷²¨
Cue Ìáʾ£¬¼àÌý
Direct Ö±½ÓµÄ£¨Êä³ö£©²å¿Ú
Effect Ч¹û
EQ ¾ùºâÆ÷
Fader Ë¥¼õÆ÷£¬ÍÆ×Ó
flodback ·µËÍ
Gain ÔöÒæ£¬·Å´óÁ¿
Group ±à×é
HF=Hight Frequency ¸ßƵ¶Î
HP=Headphone=Phones ¶ú»ú
INS.=Insert ²åÈë²å¿Ú£¬Ò²³ÆÓÖ³öÓÖ½ø²å¿Ú
Level µçƽ
LF=Low-Mid Frequency µÍƵ¶Î
Limit ÏÞÖÆ
Line Ïß·ÊäÈë²å¿Ú
LMF=Low Frequency ÖÐµÍÆµ¶Î
Low cut µÍÇУ¨ÇÐÈ¥100HZÒÔÏÂÆµÂʳɷ֣©
L-R=Left-Right ×ó-ÓÒ
Main Sum »ìºÏµ¥Éù
Master Ö÷¿Ø
Matrix ¾ØÕó
Meter Assign ±íÍ·É趨
MF=Mid Frequency ÖÐÆµ¶Î
MHF=Mid-High Frequency ÖÐ¸ßÆµ¶Î
Mic.=Microphone ´«ÉùÆ÷²å¿Ú£¨Ë׳ƻ°Í²»òÂó¿Ë·ç£©
Mix »ìºÏ
Mixer »ìºÏÆ÷£¬»ìÒôÆ÷
Monitor ¼àÊÓ£¬¼àÌý£¬¼àÊÓÆ÷£¬¼àÌýÒôÏä
Mono µ¥Éù
Music ÒôÀÖ
Mute ÑÆÒô£¬¾²Òô
On ½Óͨ
Osc.=Oscillator Õñµ´Æ÷
Pad ¶¨ÖµË¥¼õ
Pan ÉùÏñµ÷½Ú
PFL=Pre-Fade Listen ÍÆ×Óǰ¼àÌý
Phantom+48V »ÃÏëµçÔ´+48V
PK.=Peak ·åֵָʾµÆ
Power Switch µçÔ´¿ª¹Ø
Quartz Oscillator ʯӢ¾§ÌåÕñµ´Æ÷
Slate ±ê¼Ç
Solo ¶À×à
Stereo Á¢ÌåÉù
Sub.in ¸½¼ÓÊäÈë
Tape ´Å´øÊäÈë²å¿Ú
TB=Talkback ¶Ô½²
Trem. ·Å´óÁ¿Î¢µ÷½Ú
Unbalance ·Çƽºâ
£¦#118alue ÊýÖµ
Volume ÒôÁ¿£¬¾í
Bidirectional Ë«ÏòÐԵĠ
Cardioid ÐÄÐÍ
Condendser Microphone µçÈÝʽ´«ÉùÆ÷
Counteracting Proximity Effect ¿¹½ü¾àÀëЧӦ£¨½ü½²´«ÉùÆ÷£©
Dynamic Microuphone µç¶¯´«ÉùÆ÷
Electret Condenser Microphone פÌå´«ÉùÆ÷
Frequency Range ƵÂÊ·¶Î§
Omnidirectional È«ÏòÐԵĠ
Output Impedance Êä³ö×迹
Polar Pattern ¼«ÐÔͼ
SPL=Sound Pressure Lev el Éùѹ¼«
Sensitivity ÁéÃô¶È
Supercardioid=Hypercardioid ³¬ÐÄÐÍ
Unidirectional µ¥ÏòÐԵĠ
Wireless Mic. ÎÞÏß´«ÉùÆ÷
Bridge Mono ÇÅʽµ¥Éù
Clip Ï÷²¨
Damping Factor ×èÄáϵÊý£¬×èÄáÒò×Ó
GND=Ground ½ÓµØ
Input Impedance ÊäÈë×迹
Input Level ÊäÈëµçƽ
Left ÍѵØ×´Ì¬
Parallel MOno ²¢½Óµ¥Éù
Power Amplefier ¹¦ÂÊ·Å´óÆ÷
Professional רҵµÄ
Protection ±£»¤
Rate Power ¶î¶¨¹¦ÂÊ
Singnal ÐźÅָʾ
Slew Rate ת»»ÂÊ
Stereo Mode Á¢ÌåÉùģʽ
THD=Total Harmonic Distortion ×Üг²¨Ê§Õæ
3-Way Stereo 3·ÖƵÁ¢ÌåÉù
Bass µÍÒô
Cross Frequency ½»²æÆµµã
Crossover Network=Crossover µç×Ó·ÖÆµÆ÷
Divided by 10 ±»10³ý
Enclosure ÒôÏä
HF ¸ßƵ¶Î
Input Gain ÊäÈëÔöÒæ
LF µÍƵ¶Î
MF ÖÐÆµ¶Î
Mid Range Speaker ÖÐÆµÑïÉùÆ÷
Mid ÖÐÒô
Mute ÑÆÒô£¨¼ü£©
Power Capacity ¹¦ÂÊÈÝÁ¿
Reverse Phase µ¹Ïà
Subwoofer ´ÎÖØµÍÑïÉùÆ÷
Treble ¸ßÒô
Tweeter ¸ßƵÑïÉùÆ÷
Woffer µÍƵÑïÉùÆ÷
BPF=Band Pass Fliter ´øÍ¨Â˲¨Æ÷
EQ=Equalizer ¾ùºâÆ÷
EQ Control Range ¾ùºâ¿ØÖÆ·¶Î§
Graphic Equalizer ͼ±í¾ùºâÆ÷
High Cut ¸ßÇУ¨Çгý6KHZÒÔÉÏÆµÂʳɷ֣©
HPF=High Pass Fliter ¸ßͨÂ˲¨Æ÷
In/Out ½Óͨ
Input Gain ÊäÈëÔöÒæ
Low Cut µÍÇУ¨Çгý200HZÒÀϡƵÂʳɷ֣©
LPF=Low Pass Filter µÍͨÂ˲¨Æ÷
parameter Equalizer ²ÎÁ¿¾ùºâÆ÷
2004-2-26 20:09:00 »Ø¸´
sound motion picture, talkie ÓÐÉùµçÓ°
cinemascope, CinemaScope Î÷ÄùÂê˹¿ÆÆÕÐÍÁ¢ÌåÉù¿íÒøÄ»µçÓ°,±ä ÐξµÍ·Ê½¿íÒøÄ»µçÓ°
cinerama, Cinerama Î÷ÄùÀ­ÂêÐÍÁ¢ÌåÉù¿íÒøÄ»µçÓ°,È«¾°µçÓ°
title ƬÃû
original version Ô­Öø
dialogue ¶Ô°×
subtitles, subtitling ×ÖÄ»
credits, credit titles ¶ÔÔ­×÷Õß¼°ÆäËûÓй±Ï×ÕßµÄлÆôºÍÐÕÃû
telefilm µçÊÓÆ¬
actorsÑÝÔ±
cast ÕóÈÝ
film star, movie star µçÓ°Ã÷ÐÇ
star, lead Ö÷½Ç
double, stand-in ÌæÉíÑÝÔ±
stunt man ÌØ¼¼ÌæÉíÑÝÔ±
extra, walker-on ÁÙʱÑÝÔ±
character actor ÐÔ¸ñÑÝÔ±
regular player »ù±¾ÑÝÔ±
extra ÌØ±ð¿Í´®
film star µçÓ°Ã÷ÐÇ
film actor ÄеçÓ°Ã÷ÐÇ
film actress Å®µçÓ°Ã÷ÐÇ
support Åä½Ç
util ÅÜÁúÌ×
technicians ¹¤×÷ÈËÔ±
adapter ¸Ä±à
scenarist, scriptwriter ½Å±¾×÷Õß
dialogue writer ¶Ô°××÷Õß
production manager ÖÆÆ¬ÈË
producer ÖÆÆ¬Ö÷ÈΠ
film director µ¼ÑÝ
assistant director ¸±µ¼ÑÝ,ÖúÀíµ¼ÑÝ
cameraman, set photographer ÉãӰʦ
assistant cameraman ÉãÓ°ÖúÀí
property manager, propsman µÀ¾ßÔ±
art director ²¼¾°Ê¦
stagehand »¯×°Ê¦
lighting engineer µÆ¹âʦ
film cutter ¼ô¼­Ê¦
sound engineer, recording director ¼Òôʦ
script girl, continuity girl ³¡¼ÇÔ±
scenario writer, scenarist ¾ç×÷¼Ò
projection·ÅÓ³
reel, spool (ӰƬµÄ)¾í,±¾
sound track Òô´ø,Éù´ø
showing, screening, projection ·ÅÓ³
projector ·ÅÓ³»ú
projection booth, projection room ·ÅÓ³ÊÒ
panoramic screen ¿íÒøÄ»
fade-out µ­³ö
hooting ÉãÖÆ
production ÖÆÆ¬
scene ³¡¾°
to shoot ÅÄÉã
dissolve ½¥Òþ,»¯Èë,»¯³ö
Damping Factor×èÄáϵÊý
AAC automatic ampltiude control ×Ô¶¯·ù¶È¿ØÖÆ
AAD active acoustic device ÓÐÔ´ÉùѧÈí¼þ
AAD analogue tape recorder used during session recording and subsequent mixing and/or editing; digital tape recorder used during mastering(transecription)Ä£Äâ¼Òô¡¢Ä£Äâ´¦ÀíÊýÂ볪ÅÌ
AB ABÖÆÁ¢ÌåÉù¼Òô·¨
ABC auto base¡¡and chord ×Ô¶¯µÍÒôºÍÏÒ
Abeyance ÔÝÍ££¬Ç±Ì¬
A-B repeat A-B ÖØ¸´
ABS absolute ¾ø¶ÔµÄ£¬ÍêÈ«µÄ£¬¾ø¶Ôʱ¼ä
ABS american bureau of standard ÃÀ¹ú±ê×¼¾Ö
ABSS auto blank secrion scanning ×Ô¶¯´Å´ø¿Õ°×²¿·ÖɨÃè
Abstime ¾ø¶ÔÔËÐÐʱ¼ä
SBTD autonatic bulk tape degausser ´Å´ø×Ô¶¯ÕûÌåÈ¥´Åµç·
Abort ÖÕÖ¹£¬Í£Ö¹£¨Â¼ÖÆ»ò²¥·Å£©
A-B TEST AB ±È½ÏÊÔÌý
Absorber ¼õÕðÆ÷
Absorption ÉùÒô±»ÎïÌåÎüÊÕ
ABX acoustic bass extension µÍÒôÀ©Õ¹
AC accumulator ³äµçµç³Ø
AC adjustment caliration µ÷½Ú£­Ð£×¼
AC alternating current ½»Á÷µç£¬½»Á÷
AC audio coding ÊýÂëÉù£¬ÒôƵ±àÂë
AC audio center ÒôƵÖÐÐÄ
AC azinuth comprator ·½Î»±È½ÏÆ÷
AC-3 ¶Å±ÈÊýÂë»·ÈÆÉùϵͳ
AC-3 RF ¶Å±ÈÊýÂë»·ÈÆÉùÊý¾ÝÁ÷£¨½Ó¿Ú£©
ACC Acceleration ¼ÓËÙ
Accel ½¥¿ì£¬¼ÓËÙ
Accent ÖØÒô£¬Éùµ÷
Accentuator Ô¤¼ÓÖØµç·
Access ´æÈ¡£¬½øÈ룬Ôö¼Ó£¬Í¨Â·
Accessory ¸½¼þ£¨½Ó¿Ú£©£¬Åä¼þ
Acryl ±û»ùõ£»ù
Accompaniment °é×࣬ºÏ×࣬°éËæ
Accord ºÍг£¬µ÷ºÍ
Accordion ÊÖ·çÇÙ
ACD autonatic call distributor ×Ô¶¯ºô½Ð·ÖÅäÆ÷
ACE audio control erasing ÒôƵ¿ØÖÆÏû´Å
A- Channel A£¨×ó£©ÉùµÀ
ACIA asynchronous communication interface adapter Ò첽ͨÐŽӿÚÊÊÅäÆ÷
CAN active commix network ÓÐÔ´»ìºÏÍøÂç
Acoumeter ²âÌý¼Æ¡¡£Ácoustical ÉùµÄ£¬ÉùÒôµÄ
Acoustic coloring ÉùȾɫ
Acoustic image ÉùÏñ
2004-3-2 05:46:00 »Ø¸´
iZotope Â¥Ö÷
Across ½»²æ£¬²¢ÐУ¬¿ç½Ó
Across frequency ½»²æÆµÂÊ£¬·ÖƵƵÂÊ
ACST access time ´æÈ¡Ê±¼ä
Active Ö÷¶¯µÄ£¬ÓÐÔ´µÄ£¬ÓÐЧµÄ£¬ÔËÐеĠ
Active crossover Ö÷¶¯·ÖƵ£¬µç×Ó·ÖÆµ£¬ÓÐÔ´·ÖƵ
Active loudspeaker ÓÐÔ´ÒôÏä
Active page »î¶¯Ò³
Activity £¨ÏßȦ£©Õ¼¿ÕϵÊý£¬¶¯×÷
Actual level ÓÐЧµçƽ
ACTV advanced compatible television ÓëÆÕͨµçÊÓ¼æÈݵĸßÇåÎú¶ÈµçÊÓϵͳ
ACU automatic calling unit ×Ô¶¯ºô½Ð×°Öà
Adagio Èá°å£¨´ÓÈݵأ©
ABAP Adapter ÊÊÅäÆ÷£¬Íâ½ÓµçÔ´
A/D audio to digital Ä£Ä⣯Êý×Ö
ADC audio digital conversion Ä£ÄâÊý×Öת»»
ADD <alogue tape recorder used during session recording; digital tape recorder used during
subsequent mixing ang/or editing ang during mastering (transcription) Ä£Äâ¼Òô¡¢Êý×Ö´¦ÀíÊýÂ볪ÅÌ >
ADD address µØÖ·
Adder »ìƵÆ÷
DTV Êý×ÖµçÊÓ
DCE Êý¾ÝͨÐÅÉ豸
HDTV ¸ßÇåÎú¶ÈµçÊÓ
DAB Êý×ÖÒôƵ¹ã²¥
EDTV ÔöÇ¿ÇåÎú¶ÈµçÊÓ
DBS Ö±²¥ÎÀÐÇ
SDTV ±ê×¼ÇåÎú¶ÈµçÊÓ
DNA Êý×ÖÍøÂçÌåϵ½á¹¹
DDN Êý×ÖÊý¾ÝÍøÂç
DSP Êý×ÖÐźŴ¦ÀíÆ÷
DTB Êý×ÖµØÃæ¹ã²¥
DVI ½»»¥Ê½Êý×ÖÊÓÆµ
DVB Êý×ÖÊÓÆµ¹ã²¥
VOD ÊÓÆµµã²¥
DET Êý¾ÝÖÕ¶ËÉ豸
NVOD ×¼ÊÓÆµµã²¥
BREATHCONTROLLER:ºôÎü¿ØÖÆÆ÷¡£½«ºôÎüÆøÑ¹×ª»»³ÉMIDIÐÅÏ¢µÄ¿ØÖÆÆ÷¡£
BUFFER:»º³åÆ÷¡£Éè¼ÆÓÃÀ´×è¸ôÐźÅÔ´Óë¸ºÔØÖ®¼äÖ±½ÓÁª½ÓµÄµç·£¬Ê¹Æä²»ÊÜÄ¿±êÉ豸¸ºÔØ×迹µÄÓ°Ïì¡£
BUFFERMEMORY:»º³åÄڴ档һЩ¼ÆËã»ú²Ù×÷ʹÓõÄÁÙʱ´æ´¢Æ÷£¬ÔÚ¼ÆËã»úÖ´ÐÐÆäËûÈÎÎñʱ¿ÉÒÔ·ÀÖ¹Êý¾ÝÁ÷Öжϡ£
BUG:¹ÊÕÏ¡£¼ÆËã»úµÄÐл°ÖÐÖ¸Èí¼þ»òÉ豸Éè¼ÆÖдæÔÚµÄȱÏÝ¡£
BUS:×ÜÏß¡£ÔÊÐíµç×ÓÐźÅͨ¹ýµÄ¹«ÓÃͨ·£¬ÔÚµ÷Òǫ̂ÖÐÓÐһЩ´«ËÍÁ¢ÌåÉù»ìºÏ¡¢±à×飬¸¨Öú·¢Ë͵ÈʹÓõÄ×ÜÏß¡£µçÔ´ÔòÓÐ×Ô¼ºµÄ×ÜÏß¡£
BYTE:×Ö½Ú¡£8¸ö±ÈÌØ×é³ÉµÄÊý×ÖÊý¾Ý¡£
CARDIOID:ÐÄÔàÐΡ£ÃèÊöµ¥·½ÏòÂó¿Ë·çµÄÖ¸ÏòÐÎ×´¡£
CD-R:Ò»ÖÖ¿ÉÒÔдÈëÊý¾ÝµÄCD£¬µ«ÊÇÖ»ÄÜдһ´Î£¬²»ÄÜĨȥÊý¾ÝÔÙ´ÎʹÓá£
CD-RBURNER:CD¿Ì¼»ú¡£Äܹ»Íù¿Õ°×CD-RÅÌÆ¬ÖÐдÈëÊý¾ÝµÄÉ豸¡£
CV:¿ØÖƵçѹ¡£ÔÚÄ£ÄâºÏ³ÉÆ÷ÖÐÓÃÒÔ¿ØÖÆÕñµ´Æ÷µÄÒô¸ß»òÂ˲¨Æ÷ƵÂʵȡ£Ðí¶àÄ£ÄâºÏ³ÉÆ÷×ñѭÿ¸ö°Ë¶È1·üµÄ¹ßÀý£¬Ò²ÓÐÀýÍ⡣ΪÁËMIDI¿ØÖÆÏÂʹÓÃǰMIDIʱ´úµÄÄ£ÄâºÏ³ÉÆ÷£¬ÐèÒªÓÃÒ»¸öMIDIµ½CVת»»Æ÷¡£
CAPACITANCE:µçÈÝ¡£µç×ÓÔª¼þ´æ´¢µçºÉµÄÌØÐÔ¡£
CAPACITOR:µçÈÝÆ÷¡£Äܹ»´æ´¢µçºÉµÄµç×ÓÔª¼þ¡£ÓÐʱÓÃÀ´³ÆºôµçÈÝÂó¿Ë·ç¡£
CAPACITORMICROPHONE:µçÈÝÂó¿Ë·ç¡£ÉùѹÒýÆðÕñĤÓëµ××ùÖ®¼äµÄµçÈݱ仯£¬´Ó¶ø²úÉúÐźŵçÁ÷µÄÉùÒô´«¸ÐÆ÷¡£
CHANNEL:ͨµÀ¡£µ÷Òǫ̂ÉÏÁ¬½Óһ·ÊäÈ뵽һ·»òÒ»¶ÔÖ÷/¼àÌýÊä³öµÄ·¾¶¡£ÔÚMIDI·½Ã棬ͨµÀÖ¸¿ÉÒÔÊÕ·¢MIDIÊý¾ÝµÄÐéÄâ·¾¶£¬Ã¿Ò»ÌõMIDIµçÀ¿ÉÒÔͬʱ´«µÝ16ͨµÀ£¨Ï൱16Éù²¿»ò16¼þÀÖÆ÷£©µÄÊý¾Ý¡£
CHASE:¸ú×Ù¡£´ÔÊôÉ豸Á¦Í¼Í¬²½ÓÚÖ÷É豸¡£ÔÚMIDIÒôÐòÖÐChase»¹ÒâζʼþµÄ¸ú×Ù£¬»Ø¹ËÀÖÇú¿ªÊ¼²¥·Åµã֮ǰµÄ³ÌÐò±ä»»ºÍÆäËûʼþ¡£
CHIP:оƬ¡£¼¯³Éµç·¡£
CHORD:ºÍÏÒ¡£3¸ö»ò¸ü¶à²»Í¬µÄÒô·ûͬʱÑÝ×à¡£
CHORUS:ºÏ³ª¡£°ÑÐźżӱ¶²¢¼ÓÉÏÑÓ³ÙÓëÒô¸ßµ÷ÖÆ²úÉúµÄЧ¹û¡£
CHROMATIC:°ëÒô½×¡£
CLICKTRACK:½ÚÅÄÒô¹ì¡£°ïÖúÒôÀÖ¼Ò°´½ÚÅÄÑÝ×àµÄ½ÚÅÄ»úÂö³å¡£
CLIPPING:¼ôÇС£ÐÎÈÝÐźų¬³öÒ»¼þÉ豸Äܹ»´¦ÀíµÄ×î¸ßµçƽ֮ºóÒýÆðµÄÑÏÖØÊ§Õæ¡£
CLONE:¿Ë¡¡£¾«È·¸´ÖÆ£¬Í¨³£Ö¸Êý×Ö´Å´øµÄÊý×Ö¿½±´¡£
COMMONMODEREJECTION:¹²Ä£ÒÖÖÆ¡£ºâÁ¿Æ½ºâµç·2¸öÊäÈë¶Ë¶ÔͬһÐźŵÄÒÖÖÆ³Ì¶È¡£
COMPANDER:ѹËõÀ©Õ¹Æ÷¡£±àÂëʱ½øÐÐѹËõ£¬½âÂëʱ½øÐÐÀ©Õ¹µÄÉ豸¡£
COMPRESSOR:ѹËõÆ÷¡£ÓýµµÍ¸ßµçƽÐźŻòÔö´óµÍµçƽÐźŵķ½·¨À´¼õÉÙÒôƵÐźŵĶ¯Ì¬·¶Î§µÄÉ豸¡£
COMPUTER:¼ÆËã»ú¡£´¢´æºÍ´¦ÀíÊý×ÖÊý¾ÝµÄÉ豸¡£
CONDUCTOR:µ¼Ìå¡£¶ÔÓÚµçÁ÷×èÁ¦ºÜСµÄ²ÄÁÏ¡£
CONSOLE:¿ØÖÆÌ¨¡£µ÷Òǫ̂µÄÁíÒ»Öֳƺô¡£
CONTACTENHANCER:½Ó´¥ÔöÇ¿¼Á¡£Éè¼ÆÓÃÀ´Ôö¼ÓµçÆøÔª¼þÈç²åÏú¡¢²å×ù¡¢Ó¡Ë¢°å²åÍ·µÈµçÆø´«µ¼µÄ»¯ºÏÎï¡£
CONTINUOUSCONTROLLER:Á¬Ðø¿ØÖÆÆ÷¡£Ò»ÀàMIDIÐÅÏ¢£¬ÓÃÀ´½âÊÍ̤°å¡¢¿ØÖÆÂÖ¡¢ºôÎü¿ØÖÆÆ÷µÈÉ豸µÄÁ¬Ðø¸Ä±ä¡£
COPYPROTECTION:¸´ÖƱ£»¤¡£Èí¼þ³§ÉÌÓÃÒÔ·ÀÖ¹·Ç·¨¿½±´µÄ·½·¨¡£
CRASH:ËÀ»ú¡£¼ÆËã»ú³ÌÐò·¢Éú¹ÊÕϵÄË׳ơ£
CUTANDPASTEEDITING:¼ôÌù±à¼­¡£¸´ÖÆ»òÒÆ¶¯Ò»¶Î¼Òôµ½ÐÂλÖõı༭¡£
CUTOFFFREQUENCY:½ØÖ¹ÆµÂÊ¡£ÔÚÒ»¸öÂ˲¨Æ÷ÖиßÓÚ»òµÍÓÚÕâ¸öƵÂʵÄÐźű»Ë¥¼õ¡£
CYCLE:ÖÜÆÚ¡£ÉùÔ´»òµç·µÄÒ»´ÎÍêÕûÕñ¶¯¡£Ã¿ÃëÒ»´ÎµÄÖÜÆÚ±í´ïΪ1ºÕ×È-1Hertz(Hz)¡£
CV:¿ØÖƵçѹ¡£ÔÚÄ£ÄâºÏ³ÉÆ÷ÖпØÖÆÕñµ´Æ÷»òÂ˲¨Æ÷µÄƵÂÊ¡£
DAMPING:×èÄá¡£ÔÚ»ìÏì¼¼ÊõÖУ¬dampingÖ¸»ìÏìÄÜÁ¿±»»·¾³¸÷ÖÖ±íÃæÎüÊյıÈÂÊ¡£
DAISYCHAIN:Á´½Ó¡£É豸»òÄ£¿éÖ®¼äµÄ´®ÐÐÁ¬½Ó¡£
DATigitalAudioTapeÊý×ÖÒôƵ´Å´øÂ¼Òô»ú¡£¸ü׼ȷµÄ³ÆºôÓ¦¸ÃÊÇR-DAT£¬ÒòΪËüÃÇÓë¼Ïñ»úÒ»ÑùʹÓÃÐýת´Å¹Ä¡£ÁíÓÐʹÓù̶¨´ÅÍ·µÄS-DAT»úÆ÷¡£
DATA:Êý¾Ý¡£¼ÆËã»ú´æ´¢ºÍʹÓõÄÐÅÏ¢¡£
DATACOMPRESSION:Êý¾ÝѹËõ¡£Ò»ÖÖÄܹ»¼õС±»Ãè»æÒôƵÐźÅÊý¾Ý×ÜÁ¿µÄϵͳ£¬·ÖÎÞËðºÍÓÐËðÁ½Àà¡£ÓÐËðѹËõͨ¹ý¶ªÆú²»ÖØÒªµÄÒôƵÐÅÏ¢´ïµ½¸ü´óµÄѹËõ±È¡£
dB:deciBel·Ö±´¡£ÓÃÒÔ±í´ïÁ½¸öµçѹ¡¢¹¦ÂÊ»òÉùÒôµÄÏà¶ÔË®×¼¡£
dBm:·Ö±´µÄÒ»¸ö±äÖÖ£¬0dB=1mWinto600Ohms
dBv:·Ö±´µÄÒ»¸ö±äÖÖ£¬0dB=0.775volts.
dBV:·Ö±´µÄÒ»¸ö±äÖÖ£¬0dB=1volt.
dB/Octave:·Ö±´/°Ë¶È¡£Â˲¨Æ÷бÂʵıí´ï·½Ê½£¬Ã¿¸ö°Ë¶ÈµÄ·Ö±´ÊýÔ½´ó˵Ã÷бÏ߸ü¶¸Ö±¡£
DC:Ö±Á÷µç¡£
DCChilipsÑÐÖÆµÄÒ»Ö̶ֹ¨´ÅÍ·Êý×Ö¼Òô»ú£¬Ê¹ÓÃÊý¾ÝѹËõ¼¼Êõ¼õС´æ´¢µÄÊý¾ÝÖØÁ¿¡£
dbx:Ò»ÖÖÉÌÒµÓ¦Óõıà/½âÂë´Å´øÔëÉùÏû³ýϵͳ¡£Â¼ÒôʱѹËõÐźţ¬·ÅÒôʱÒÔͬÑùµÄ±ÈÂÊÀ©Õ¹Ðźš£
DCOigitallyControlledOscillatorÊý¿ØÕñµ´Æ÷
DDLigitalDelayLineÊý×ÖÑÓ³ÙÏß
DE-ESSER:È¥³ýÈËÉùÐźŵ±ÖгÝÒô¡°ßС±ÉùµÄÉ豸¡£
DEOXIDISINGCOMPOUND:ÍÑÑõ»¯ºÏÎï¡£
DECAY:Ë¥ÍË¡£ÉùÒô»òµç×ÓÐźÅËæ×Åʱ¼äÖð²½¼õС·ù¶ÈµÄ½ø³Ì¡£ÔÚADSR°üÂçÖУ¬µ±Éϳå½×¶Î´ïµ½×î´óÖµ£¬Ë¥Í˽׶ÎÁ¢¼´¾Í¿ªÊ¼£¬µçƽ½«½µµ½Óû§É趨µÄ±£³Ö£¨Sustain£©µçƽ£¬±£³Öµ½ÇÙ¼ü±»·Å¿ª£¬´Ëʱ½øÈëÊÍ·Å£¨Release£©½×¶Î¡£
DEFRAGMENT:ÕûÀíË鯬¡£ÕûÀíÓ²ÅÌÉϵÄÎļþ£¬Ê¹ËüÃǾ¡¿ÉÄÜÁ¬Ðø´æ·Å£¬ÌÚ³ö¾¡¿ÉÄܶàµÄÁ¬Ðø¿Õ¼ä¡£
DETENT:¶¨Î»µã¡£Ò»Ð©¿ØÖÆÆ÷ÈçÉùÏñ¡¢¾ùºâÐýÅ¥µÄÖÐÐĵ㱸ÓиоõµÃµ½µÄ¶¨Î»µã¡£
DIirectInjectµÄ¼òд£¬Ö±½Ó×¢Èë¡£ÐźŲ»¾­¹ýÂó¿Ë·çÖ±½Ó×¢ÈëÒôƵÁ´¡£
DIBOXIºÐ¡£Æ¥ÅäÐźÅÔ´Óë´Å´øÂ¼Òô»ú»òµ÷Òǫ̂ÊäÈëÖ®¼äµçƽ×迹µÄÉ豸¡£
DIGITAL:Êý×ֵġ£ÓÃ0ºÍ1±íʾÐźÅÊý¾ÝµÄµç×Óϵͳ¡£
DIGITALDELAY:Êý×ÖÑÓ³Ù¡£·¢ÉúÑӳٺͻØÉùЧ¹ûµÄÊý×Ö´¦ÀíÆ÷¡£
DIGITALREVERB:Êý×Ö»ìÏ졣ģ·Â»·¾³»ìÏìµÄÊý×Ö´¦ÀíÆ÷¡£
DINCONNECTORIN£¨µÂ¹ú¹¤Òµ±ê×¼£©½Ó²åÁ¬½Ó¡£ÓÃÓÚÏû·ÑÊг¡µÄ¶àÕëÁ¬½ÓÐÎʽ£¬MIDIµçÀÂҲʹÓÃËü¡£³ýÁËMIDIµÄ180¶È²¼¾Ö£¬DIN»¹ÓжàÖÖÕë½Å·Ö²¼¹æ¸ñ¡£
DIRECTCOUPLING:Ö±½ÓñîºÏ¡£Á½¸öÁ¬ÔÚÒ»ÆðµÄµç·£¬½»Á÷ºÍÖ±Á÷ÐźŶ¼Äܹ»Í¨¹ý¡£
DITHER:¶¶¶¯¡£Ò»¸öΪÊý×Ö»¯ÒôƵÐźżÓÉÏµÍµçÆ½ÔëÉùµÄϵͳ£¬Äܹ»À©Õ¹µÍµçƽµÄ·Ö½â¶È¡£
DISC:¶ÔËܽº³ªÆ¬¡¢CD³ªÆ¬ºÍMiniDiscsµÄͳ³Æ¡£
DISKisketteµÄ¼òд£¬ÏÖÔڳƺôµçÄÔÈíÅÌ¡¢Ó²Å̺ͿÉÒÆ¶¯´ÅÅÌ£¨¹âÅÌ£©µÈ
DMAirectMemoryAccess£¨´æ´¢Æ÷Ö±½Ó·ÃÎÊ£©µÄËõд¡£Ò»²¿·ÖµçÄÔ²Ù×÷ϵͳÔÊÐíÍâΧÉ豸²»¾­¹ýCPUÖ±½Ó·ÃÎʼÆËã»ú´æ´¢Æ÷¡£
DOLBY:¶Å±È¡£Ò»ÖÖÉÌÒµÓ¦Óõıà/½âÂë´Å´øÔëÉùÏû³ýϵͳ¡£Â¼ÒôʱÀ©´óµÍµçƽµÄ¸ßƵÐźţ¬·ÅÒôʱ»¹Ô­¡£¶Å±ÈÓÐÓÃÓÚ°ëרҵ»úÆ÷µÄB,CºÍSºÍÓÃÓÚרҵ»úÆ÷µÄAÓëSR¼¸ÖÖÀàÐÍ£¬»¥Ï಻¼æÈÝ¡£ÓÃÒ»ÖÖϵͳ¼Òô±ØÐëͬһϵͳ»Ø·Å¡£
DOSiskOperatingSystem£¨´ÅÅ̲Ù×÷ϵͳ£©PCµçÄÔ»ò¼æÈÝ»úʹÓõÄÒ»ÖÖ²Ù×÷ϵͳ¡£
DSPigitalSignalProcessorÊý×ÖÐźŴ¦ÀíÆ÷¡£Ò»ÖÖÇ¿ÓÐÁ¦µÄ΢оƬ£¬ÓÃÀ´´¦ÀíÊý×ÖÐźš£
DRIVER:Çý¶¯Æ÷¡£´¦ÀíÖ÷³ÌÐòºÍÓ²¼þÍâΧÈçÉù¿¨¡¢´òÓ¡»ú¡¢É¨ÃèÒǵÈÖ®¼äͨѶµÄÈí¼þ¡£
DRUMPAD:¹Äµæ¡£ºÏ³ÉµÄÑÝ×à±íÃæ£¬Í¨¹ý¹Äé³»÷´ò²úÉúµç×Ó´¥·¢Ðźš£
Mac manchester auto code ÂüÇÐË¹ÌØ×Ô¶¯Âë
MADI musical audio digital interface ÒôƵÊý×Ö½Ó¿Ú
Main Ö÷ÒªµÄ£¬Ö÷Ïߣ¬Ö÷ͨµÀ£¬µçÔ´
MAG magnet ´ÅÌú
Magnetic tape ´Å´ø
Magnetic type recorder ´Å´øÂ¼Òô»ú
Main µçÔ´£¬Ö÷ÒªµÄ
Major chord ´óÈýºÍÏÒ
Make ½Óͨ£¬±ÕºÏ
Makeup ½Óͨ£¬Ñ¡Åä
Male ²åÍ·£¬²å¼þ
MAN manual ÊÖ¶¯µÄ£¬ÊÖ¿Ø
Manifold technology £¨ÒôÏ䣩¶àÆç¹Ü¼¼Êõ
Manipulate ²Ù×÷£¬¼ü¿Ø
MANP ÊÖ¶¯´©²å
Manual ÊÖ¶¯µÄ£¬È˹¤µÄ£¬Êֲᣬ˵Ã÷Êé
March ½øÐÐÇú
Margin £¨µçƽ£©ÓàÁ¿
Mark ±êÖ¾£¬·ûºÅ£¬±ê¼Ç
Mash ѹµÍ£¬ÄëËé
Masking ÑÚ±Î
Master ×ÜÒôÁ¿¿ØÖÆ£¬µ÷Òǫ̂£¬Ö÷ÅÌ£¬±ê×¼µÄ£¬Ö÷µÄ£¬×Ü·
MAR Matrix ¾ØÕ󣬵÷Òǫ̂¾ØÕó£¨M£©£¬±à×é
Match Æ¥Å䣬ÊÊÅ䣬Åä¶Ô
Matrix quad system ¾ØÕóËÄÉùµÀÁ¢ÌåÉùϵͳ
MAX maximum ×î´ó£¬×î´óÖµ
MB megabytes Õ××Ö½Ú
Mb/s megabytes per second Õ××Ö½Ú/Ãë
MC manual control ÊÖ¿Ø£¬ÊÖ¶¯¿ØÖÆ
MCH multiple chorus ¶à·ºÏ³ª
MCR multiple cjhannel amplification reverberation¶à·»ìÏìÔöÇ¿
MD mini disc ¹â´ÅÅ̳ª»ú£¬Ð¡Ðͼ·Å³ªÅÌ
MD moving coil ¶¯È¦Ê½
MDL modulation delay µ÷ÖÆÑÓʱ
MEAS measure ²âÁ¿£¬·¶Î§£¬²âÊÔ
Measure ÀÖÇúµÄ£¬Ð¡½Ú
Meas edit С½á±à¼­
MECH mechanism »úеװÖÃ
MED medium ÊÊÖУ¬Öм䣨µ²Î»£©
Medley »ìºÏ
Mega bass ³¬ÖصÍÒô
MEM memory ´æ´¢Æ÷£¬´æ´¢£¬¼ÇÒä
Member ²¿¼þ£¬³ÉÔ±
Menu ²Ëµ¥£¬Ä¿Â¼£¬±í¸ñ
MEQ mono equalizer µ¥ÉùµÀ¾ùºâÆ÷
Merge ºÏ²¢£¬»ã×Ü£¬ÈÚºÏ
Meridian ¶¥µãµÄ£¬·åÖµ
Measure С½á
Megaphone À®°ÈͲ
Mel ÃÀ£¨Òôµ÷µ¥Î»£©
Menu ²Ëµ¥£¬½ÚÄ¿±í
Message ͨÐÅ£¬ÁªÏµ
Metal ½ðÊô£¨Ð§¹ûÉù£©
Metal tape ½ðÊô´Å´ø
Meter µçƽ±í£¬±íÍ·£¬ÒÇ±í
Metronome ½ÚÅÄÆ÷
MF matched filter Æ¥ÅäÂ˲¨Æ÷
MF maveform ²¨ÐÎ
MF middle frequency ÖÐÆµ£¬ÖÐÒô
MFL multiple flange ¶à²ã·¨À¼£¨Ïâ±ß£©Ð§¹û
MFT multiplprogramming with a fixed number of tasksÈÎÎñÊýÁ¿¹Ì¶¨µÄ¶àͨµÀ³ÌÐòÉè¼Æ
MIC micro ΢Ã×
MIC microphone »°Í²£¬Âó¿Ë·ç£¬´«ÉùÆ÷
Michcho level »°Í²»ìÏìµçƽ
Micro monitor amp ΢Òô¼àÌý·Å´óÆ÷
MICROVERB microcomputer reverb ΢´¦Àí»ú»ìÏì
MID middle ÖмäµÄ£¬Öв¿µÄ£¬ÖÐÒô£¬ÖÐÆµ
MIDI music instrument digital interfaceµç×ÓÀÖÆ÷Êý×Ö½Ó¿Ú
MIN minimum ×îС£¬×îСֵ
MIN minute ·ÖÖÓ
MIND master integrated network deviceÒ»Ìå»¯ÍøÂç×Ü×°ÖÃ
Minitrim ΢µ÷
Minitrue ΢»úµ÷Õû
Minor chord СÈýºÍÏÒ
Mismatch ʧÅä
Mistermination ÖÕ¶ËʧÅä
MIX »ìºÏ£¬ÒôÁ¿±ÈÀýµ÷½Ú
Mixer µ÷Òǫ̂£¬»ìÒôÆ÷
MM moving magnet ¶¯´Åʽ
MNTR monitor ¼à¿ØÆ÷
MNOS metallic nitrogen - oxide semiconductor½ðÊôµªÑõ»¯Îï°ëµ¼Ìå
MO magneto optical ¿ÉĨ¿É¼Ð͹âÅÌ
MOC magnet oscillator circuit Ö÷Õñµ´µç·
MOD mode ״̬£¬·½Ê½£¬Ä£Ê½
MOD model Ðͺţ¬Ñùʽ£¬Ä£ÐÍ£¬µäÐ͵Ä
MOD modulation µ÷ÖÆ
Mode ״̬£¬£¨ÀÖÇúµÄ£©µ÷ʽ
Mode select ·½Ê½Ñ¡Ôñ
Mush ÔëÉù¸ÉÈÅ£¬·Öг²¨
Mush area ²»Á¼½ÓÊÕÇø
Music ÒôÀÖ£¬ÀÖÇú
Music center ÒôÀÖÖÐÐÄ£¬×éºÏÒôÏì
Music conductor ÒôÀÖ¿ØÖÆÆ÷
MUT mute ¾²Òô£¬ÑÆÒô£¬ÔëÉù¿ØÖÆ
Muting ÒÖÖÆ£¬Ïû³ý
Multiple ¸´ºÏµÄ£¬¶àÏîµÄ£¬¶àÖØµÄ
MV mean £¦#118alue ƽ¾ùÖµ
MV multivibrator ¶àгÕñµ´Æ÷
MW medium wave Öв¨
MXE mono exciter µ¥ÉùµÀ¼¤ÀøÆ÷
MXR mixer »ìƵÆ÷
MODEM modulator demodulator µ÷ÖÆ½âµ÷Æ÷
Moderato ÖÐËÙ
Modifier µ÷½ÚÆ÷
Modify Ð޸쬵÷ÊÔ£¬Ä¦»ú£¬ÏÞ¶¨
Modulator µ÷ÖÆÆ÷
Module Ä£¿é£¬×é¼þ£¬ÒòÊý£¬³ÌÐòƬ
MOL maximum output level ×î´óÊä³öµçƽ
MON monitor ¼àÌý£¬¼àÊÓÆ÷
MONI ¼àÌý£¬µ÷Òôʦ
M£¦#111nkey chatter ´®Òô£¬ÁÚÆµ¸ÉÈÅ£¬½»²æÊ§Õæ
2004-3-2 20:12:00 »Ø¸´
Mono µ¥ÉùµÀ£¬µ¥Ò»
Monopit µ¥Éù±äµ÷
Motor cue »»»úÐźţ¬Çл»ÐźÅ
MOS metal-oxide semiconductor ½ðÊôÑõ»¯Îï°ëµ¼Ìå
Motor Âí´ï£¬µç»ú
Movie theater Ó°¾çÔº
Moviola Éù»­¼ô¼­»ú
Moving-iron loudspeaker Éà»ÉÑïÉùÆ÷
MPEG motion picture coding experts group»î¶¯Í¼Ïñ±àÂëר¼Ò×飬Êý×ÖÉùÏñÐÅϢѹËõ±ê×¼
MPF master pre feed Ö÷¿ØÇ°À¡ËÍ
MPH multiple phaser ¶à¼¶ÒÆÏàÆ÷
MPO maximum power output ×î´óÊä³ö¹¦ÂÊ
MPO music power output ÒôÀÖÊä³ö¹¦ÂÊ
MPR master pre return Ö÷¿ØÇ°·µ»Ø
MPS main power switch Ö÷µçÔ´¿ª¹Ø
MPS manual phase shifter ÊÖ¿ØÏàÒÆÆ÷
MPS microphone power supply »°Í²µçÔ´
MPS microprocessor system ¶àÓÃ;ȡÑùϵͳ
MPX multiplex ¶à·´«Ê䣬¶à´ÎÖØ¸´Ê¹Ó㬶à·ת»»£¬¸´ºÏ
MPX multiplexer ¶à·ת»»Æ÷£¬¶à·µ÷ÖÆÆ÷
MPX VCO ¶à·½âµ÷ѹ¿ØÕñµ´
MQSS music quick select system ¿ìËÙÒôÀÖÑ¡Ôñϵͳ
MR memory read ´æ´¢Æ÷¶Á³ö
MS manual search ÊÖ¶¯¼ìË÷
MS middle side Ò»ÖÖµüºÏ¼Òô¼¼Êõ
MS(MSEC) millisecond ºÁÃë
MSSS multi space ound system ¶àά¿Õ¼äÉùϵͳ
MST(MSTR) master Ö÷¿Ø
MSW microswitch ΢¶¯¿ª¹Ø
MT multi track ¶à¹ì
MTD multiple delay ¶à´ÎÑÓʱ
MTR magnetic tape redorder ´Å´ø¼Ç¼Æ÷
MTR micro-wave transmission ΢²¨´«Êä
MTR motor µç¶¯»ú
MTS multi-channel television sound ¶àÉùµÀµçÊÓ°éÒô
MTV music TV ÒôÀÖµçÊÓ£¨½ÚÄ¿£©
MUF maximum usable frequency ×î¸ß¿ÉÓÃÆµÂÊ
MULT multiplier ±¶ÔöÆ÷£¬¹âµç±¶Ôö¹Ü
Multi ²¢ÁªµÄ£¬¶à·ϵͳ
Multidimention control Éù³¡Õ¹¿í¿ØÖÆ£¬¶àά¿ØÖÆ
Multiband ¶àƵ¶Î
Multi-echo ¶àÖØ»ØÉù
Multi plex ¶à·´«Éù
Multitap ת½Ó£¬£¨¶à²åÍ·£©²å×ù
Multiple channel ¶àͨµÀ
Multiple effects ×ÛºÏЧ¹û´¦Àí×°ÖÃ
Multiple jack ¶àÑÛ²å×ù
Multisound ԭʼÒôÉ«
MUPO maximum undistorted power output×î´ó²»Ê§ÕæÊä³ö¹¦ÂÊ
MUSE multiple sub-Nyquist sompling encoding¶àÖØÄοüË¹ÌØÈ¡Ñù±àÂë
MIDI ¸ñʽÎļþ
MIDI ÐÅÏ¢£¬È«¹ý³Ì
N normal Õý³££¬ÆÕͨ£¬±ê×¼
N negative Òõ¼«£¬¸º¼«
µ¥¿Ø £ó£é£î£ç£ì£å £ã£ï£î£ô£ò£ï£ìÒ»¸ö¿ØÖÆ»ØÂ·µÄ¶ÀÁ¢¿ØÖÆ¡£
×é¿Ø £ç£ò£ï£õ£ð £ã£ï£î£ô£ò£ï£ì¾ßÓÐÏàͬÁÁ¶ÈµÄÈô¸É¿ØÖÆ»ØÂ·µÄ¼¯ÖпØÖÆ¡£
¼¯¿Ø £ó£õ£â£í£á£ó£ô£å£ò £ã£ï£î£ô£ò£ï£ì¾ßÓв»Í¬ÁÁ¶ÈµÄÈô¸É¿ØÖÆ»ØÂ·µÄ¼¯ÖпØÖÆ¡£
¶Î¿Ø £ã£ï£î£ã£å£î£ô£ò£á£ô£ï£ò £ã£ï£î£ô£ò£ï£ìʵÏÖ¶ÎÓë¶ÎÖ®¼äµÆ¹â½»Ìæ±ä»¯µÄ¿ØÖÆ·½Ê½¡£
×Ü¿Ø £ç£ò£á£î£ä£í£á£ó£ô£å£ò×î¸ßÒ»¼¶µÄ¿ØÖÆ¡£
½¥Ã÷ £æ£á£ä£å £é£îµÆ¹âÔÚÔ­Óлù´¡ÉÏÖð½¥±äÁÁ¡£
½¥°µ £æ£á£ä£å £ï£õ£ôµÆ¹âÔÚÔ­Óлù´¡ÉÏÖ𽥱䰵¡£
Í»Ã÷ £ó£õ£ä£ä£å£î £â£ò£é£ç£è£ôµÆ¹âÔÚÔ­Óлù´¡ÉÏ˲ʱ±äÁÁ¡£
Í»°µ £ó£õ£ä£ä£å£î £ä£á£ò£ëµÆ¹âÔÚÔ­Óлù´¡ÉÏ˲ʱ±ä°µ¡£
Çй⠣â£ì£á£ã£ë£ï£õ£ô½«Êܿصƹâ˲¼ä¹ØÃð¡£
Ԥѡ £ð£ò£å£ó£å£ôµÆ¹â³¡µÄÔ¤ÏÈÉèÖá£
½»Ìæ±ä»¯ £ã£ò£ï£ó£ó£æ£á£ä£åÔÚͬһʱ¼äÄÚ£¬Ò»Ð©µÆ¹â±äÃ÷£¬ÁíһЩµÆ¹â±ä°µµÄ¹ý³Ì¡£Ä£ÄâÏÔʾ £í£é£í£é£ã £ä£é£ó£ð£ì£á£ùÄÜͬʱֱ¹ÛÏÔʾËùÓÐÊܿصÆÎ»¼°ÁÁ¶ÈµÄÏÔʾ·½Ê½¡£
ÑÝÔ±¿ª¹Ø £á£ã£ô£ï£ò £ó£÷£é£ô£ã£èÔÚÑݳöÖУ¬Îª¾çÇéÐèÒªÉèÖõÄÓÉÑÝÔ±²Ù×ݵĿª¹Ø¡£ÏµÍ³ÉèÖà £ó£å£ô£õ£ð¶Ôϵͳ²ÎÊý¡¢ÍâÉè²Ù×÷¡¢¸÷ÀàÇúÏߵȵı༭ºÍÑ¡Ôñ¡£
ºê¶¨Òå £í£á£ã£ò£ïΪ¼ò»¯²Ù×÷²½Öè¶ø½«Èô¸É¸ö˳ÐòµÄ²Ù×÷²½Öè×éºÏÔÚijһ¼üÉÏ£¬²¢¸³ÓèÆäÌØÊⶨÒå¡£
¶ÀÁ¢ £é£î£ä£å£ð£å£î£ä£å£î£ôÓëÖ®Ïà¹ØÁªµÄ¿ØÖÆ»ØÂ·£¬²»ÔÙÊÜ¿ØÓÚÆäËüµ÷¹â¿ØÖÆÆ÷µÄ¿ØÖÆ·½Ê½¡£
²Ù×÷¸Ë £æ£á£ä£å£òÄÜÁ¬Ðø¸Ä±äÁÁ¶È»òʱ¼äÐźŵĿØÖÆÆ÷£¬¼ò³Æ¸Ë¡£
¿ØÖÆÂÖ £÷£è£å£å£ìͨ¹ýÂÖµÄת¶¯Á¬Ðø¸Ä±äÁÁ¶È»òʱ¼äÐźŵĿØÖÆÆ÷¡£
ÏÔʾ £ä£é£ó£ð£ì£á£ù¹ØÓÚͨµÀÁÁ¶È¡¢±àÅÅÄÚÈÝ¡¢ÏµÍ³ÉèÖõȸ÷ÖÖÐÅÏ¢µÄÖ±¹ÛÌáʾ¡£
Ô¤ÑÝ £ð£ò£å£ö£é£å£÷½öÔÚÏÔʾÆÁÉÏÏÔʾԤѡÄÚÈݶø²»ÊµÊ±Êä³öµÄÒ»ÖÖ״̬¡£
Ñݳö±í £ð£ì£á£ù£â£á£ã£ë £ó£è£å£å£ô¹æ¶¨ÑݳöÖÐÈ«²¿£Ñ¡¢Ð§¹ûµÈÑݳö´ÎÐò£¬¼°Ï໥ʱ¼ä¹ØÏµµÄ±í¸ñ¡£
Ò³ £ð£á£ç£åÀ©Õ¹Ãæ°åµ¥¿Ø¸Ë»ò¼¯¿Ø¸ËÊýÁ¿µÄÒ»ÖÖ·½Ê½£»À©Õ¹ÆÁÄ»ÏÔʾÄÚÈݵÄÒ»ÖÖÐÎʽ¡£
°µ¸Ä £â£ì£é£î£ä £í£ï£ä£é£æ£é£ã£á£ô£é£ï£îÔÚÑݳö״̬Ï£¬²»Ó°ÏìʵʱµÆ¹âÊä³ö״̬µÄÒ»ÖÖÐ޸ķ½Ê½¡£
×Ô¶¯Ìæ»» £ô£ò£á£ã£ë£ó£è£å£å£ô±»Ð޸ĿØÖÆ»ØÂ·ÔÚÑݳöÖÐÓɹ涨ÁËÁÁ¶È°Ù·Ö±ÈµÄÌæ»»¿ØÖÆ»ØÂ·£¬×Ô¶¯È¡´úµÄÒ»ÖÖÐ޸ķ½Ê½¡£
Áª½á £ì£é£î£ëÑݳö±íÖÐÈ·¶¨£ÑµÄÑݳö˳Ðò¹ØÏµ¡£
Åä½Ó £ð£á£ô£ã£è¿Éͨ¹ý¼üÅÌÉèÖÿØÖÆ»ØÂ·Óëµ÷¹â»ØÂ·µÄ¶ÔÓ¦¹ØÏµ¡£
±ÈÀýÅä½Ó £ð£ò£ï£ð£ï£ô£é£ï£î£á£ì £ð£á£ô£ã£è´øÁÁ¶È±ÈÀýµÄÅä½Ó¡£
ÁÁ¶ÈÓÅÏÈ £è£é£ç£è£å£ó£ô £ô£á£ë£å£ó £ð£ò£å£ã£å£ä£å£î£ã£å µ±Ä³¸ö¿ØÖÆ»ØÂ·Í¬Ê±ÊÜÒ»ÖÖÒÔÉϲÙ×÷¿ØÖÆÊ±£¬¸Ã¿ØÖÆ»ØÂ·Êä³öÆäÖÐ×î¸ßµÄÁÁ¶ÈÖµ¡£
ʱ¼äÓÅÏÈ £ì£á£ô£å£ó£ô £ô£á£ë£å£ó £ð£ò£å£ã£å£ä£å£î£ã£åµ±Ä³¸ö¿ØÖÆ»ØÂ·Í¬Ê±ÊÜÒ»ÖÖÒÔÉϲÙ×÷¿ØÖÆÊ±£¬¸Ã¿ØÖÆ»ØÂ·Êä³öÆäÖÐ×îºóÒ»¸ö²Ù×÷µÄÁÁ¶ÈÖµ¡£
Ò£¿Ø×°Öà £ò£å£í£ï£ô£å £ã£ï£î£ó£ï£ì£å·ÖÀëÓÚÖ÷¿ØÌ¨Ö®ÍâµÄµ÷¹â¿ØÖÆ×°Öá£
½âÂëÆ÷ £ä£å£ã£ï£ä£å£òÄܽ«¿ØÖÆÌ¨Êä³öÐźÅת»»³Éµ÷¹âÆ÷ËùÐè¿ØÖÆÐźŵÄ×°Öá£
2004-3-9 05:26:00 »Ø¸´
·ÖÏí£¬Ð»Ð»°¡
2004-3-11 20:58:00 »Ø¸´
ͬÒ⣡
2004-3-14 06:31:00 »Ø¸´
