ÃÀ¹úEV EVID C8.2 C4.2 ¶¨×è/¶¨Ñ¹Îü¶¥À®°È ÕýÆ·Ðлõ
tumuren
2008-11-13 15:01:39
ÒôÏäÉ豸
ÃÀ¹úEV EVID C8.2 C4.2 ¶¨×è/¶¨Ñ¹Îü¶¥À®°È ÕýÆ·Ðлõ f356c2129823a29a590ba02a1c547030.jpg
C4.2
EVIDϵÁÐ4¡°Ë«Â·Îü¶¥ÏµÍ³ÊÊÓÃÓÚ³£¹æÊÒÄÚ·¿¼ä¡£C4.2´ø¿í³öÉ«£¬ÒôÖÊÓÅÃÀ£¬°²×°ÍâÐβ»ÕÅÑï¡£Ëü²ÉÓýô´ÕÐÍÉè¼Æ£¬ÊÊÓÃÓÚ¿Õ¼äÏÁСµÄÇøÓò£¬ÍêÈ«ÄÜÅäºÏͨ·ç¿Õ¼äµÄÒªÇó¡£
ÊÊÓÃÓÚͨ·ç¿Õ¼ä£»4¡±µÍÒôµ¥Ôª£»²¨µ¼ñîºÏµÄîÑĤ°ëÇòÐθßÒôµ¥Ôª£»Èýµã°²×°ÏµÍ³£¬°²×°·½±ã£»×Ô´ø°²×°»·ºÍµ¼¹ì£»¶ÔÓÚ´ó¶àÊý°²×°£¬ÎÞÐè¶îÍâÅä¼þ£»ÓкÚÉ«ÐͺſÉÑ¡
µ×ÅÌ´óС101.6 mm (4")
ÑÕÉ«White (paintable surface)
¸²¸Ç£¨-6dB±ê×¼£©130 conical
Ö±¾¶£¨×î´ó£©181 mm (7.13")
ÊäÈë¸ñʽ8 ¦¸, 70 V, 100 V
°²×°ÏµÍ³Integrated 3-point toggle anchors
ÑïÉùÆ÷ÀàÐÍPorted cabinet, internally damped, two-way passive crossover included
±äѹÆ÷Yes
±äѹÆéÍ·(½öÏÞ±äѹÆ÷°æ±¾)(1.88 - 70 V only), 3.75, 7.5, 15, 30
ƵÂÊÏìÓ¦£¨-10·Ö±´£©65 - 20000 Hz
ÁéÃô¶È£¨1Íß/1Ã×£©86 dB
ϵͳ¹¦ÂÊ´¦Àí£¨Á¬Ðø/ÒôÀÖ//·åÖµ£©80 Watts Overload Protected
µÍƵ»»ÄÜÆ÷4-inch polypropylene cone
¸ßƵ»»ÄÜÆ÷0.75-inch (19 mm) Ti Mylar Laminate Dome
ÏäÌå²ÄÁÏSteel enclosure and UL94V-0 rated baffle and bezel
»§ÍâµÄNo
Õ¤¸ñPowder-coated steel
¸ß¶È176 mm (6.93")
¾»ÖØ2.7 kg (5.95 lbs)
C8.2
Îü¶¥ÑïÉùÆ÷:¸ÖÖÆÏäÌ壬8¡å¸ßÈá˳ȫÌìºòÇý¶¯Æ÷µÍƵ»»ÄÜÆ÷£¬1¡åîѽðÊô±íÃæ°ëÇòÐÎ¸ßÆµ»»ÄÜÆ÷
ƵÏì75Hz-18KHz£¬¸ºÔع¦ÂÊ£¨Á¬Ðø/·åÖµ£©100W/400W£¬110¡ã¸²¸ÇͼÐΣ¬ÁéÃô¶È89dB,1W,1m,±ßȦֱ¾¶300mm£¬ÖØÁ¿5kg
²úÆ·ÌØµã£º
¡¤ ÄÜÆ¥ÅäÆäËûEVID±íÃæ°²×°ÏµÁÐÑïÉùÆ÷µÄÒôÖÊ
¡¤ ÄÜæÇÃÀͬÀàÆäËûÆ·ÅÆ
¡¤ ·ûºÏUL¼°NFPAͨ·ç¿Õ¼ä¹æ¸ñ
¡¤ ÄÜÈ«Ãæ½â¾öÈκΰ²×°ÎÊÌâ
¡¤ ËùÓÐEVIDÎü¶¥ÑïÉùÆ÷ÄÜ×÷70V/100V»ò8Å·ÔË×÷£¬ÎÞÐè¶îÍ⹺ÂòÌØ±ðÐͺÅ
ÏäÌå½á¹¹   ¸ÖÖÆÏäÌå
8"¸ßÈá˳ȫÌìºòÇý¶¯Æ÷
1"îѽðÊô±íÃæ°ëÇòÐÎ
¹¤×÷»·¾³  Î¶È0¶È-130¶È
±¸ÓÐÑÕÉ«   °×É«£¨¿ÉÍ¿±íÃæ£©
ƵÏì   50Hz-20kHz
·ù¸ÇͼÐÎ110¶È
ÁéÃô¶È91DB£¬1W£¬1m
Ìå»ý  178mm*270mm
±ßȦֱ¾¶   300mm
ÆÀÂÛÁÐ±í£¨1£©
:victory: :victory: :victory:
2008-11-18 00:20:19 »Ø¸´
