2nd Sense Audio Wiggle v1.1.9 PC/MAC
2nd Sense Audio Wiggle v1.1.9 Incl Keygen (WiN and OSX)-R2R
4¸öÇ¿´óµÄÉùÒô·¢ÉúÆ÷ÔÊÐíÄúÖ±½Ó²Ù×ݺÍ×Ô¶¯»¯²¨±í¡£Ó벨ÐΣ¬ÏàÎ»Ê§ÕæºÍËæ»ú»¯¹¤¾ßÒ»Æð£¬´´Ôì±íÏÖÁ¦µÄÉùÒôÊǺÁ²»·ÑÁ¦µÄ¡£
Áé»îµ÷ÖÆ
8¸öÃâ·Ñ»æÖÆLFO / EnvelopeºÍ4¸öרÓõ÷ÖÆÆ÷¿ÉÒÔ½øÐÐÍÏ·Å£¬ÒÔ¿ØÖƴ󲿷ֺϳɲÎÊý¡£ÁíÓÐ8¸ö²½½øÊ½µ÷ÖÆÆ÷Ò²¿É¹©ÄúʹÓá£
Ç¿´óµÄ±äÐÎ
WiggleµÄ´ó²¿·Ö²ÎÊý¿ÉÒÔ±»²¶»ñΪ¡°snapshot¡±¡£Äú¿ÉÒÔ×î¶àʹÓÃ4¸öÄúÕýÔÚ´¦ÀíµÄÉùÒôƬ¶Î£¬²¢¿ÉÒÔÊÖ¶¯»ò×Ô¶¯µØÔÚÆä¼ä½øÐбäÐΡ£ÓÉÄã´´Ôì΢ÃîµÄÒôÉ«±ä»¯»ò¾çÁÒµÄÉùÒôת»»¡£
Ö±¹ÛµÄFM
²ÊÉ«±àÂëµÄFM¾ØÕóÇå³þµØÏÔʾÁ˵÷ÖÆÆ÷/ÔØ²¨¹ØÏµ¡£¾ØÕóÉϵÄËùÓвÎÊý¶¼¿ÉÒÔ±»µ÷ÖÆ¡£ºÜÈÝÒ×ΪÉùÒôÔö¼Ó¸´ÔÓÐÔºÍÌØÐÔ¡£
¶à¹¦ÄÜÅÅÐòÆ÷
WiggleµÄ²½½øÒôÐòÆ÷ΪÄúÌṩÏêϸµÄ¿ØÖÆ£¬ÒÔ°²ÅÅÒôÀֺ͵÷ÖÆÄ£Ê½¡£Ëù²úÉúµÄÒôÀÖͼ°¸¿ÉÒÔÍÏÈëÄúµÄDAW¡£
·½±ã³éÑù
WiggleµÄÄÚ²¿¼Ç¼¹¦ÄÜ¿ÉÒÔÈÃÄú¿ìËÙ²¶»ñÉùÒôʵÑé
ÔÎÄ
4 powerful sound generators allow you to directly manipulate and automate the wavetable. Together with waveshaping, phase distortion and randomization tools, creating expressive sounds is effortless.
Flexible Modulations
8 free drawing LFO/Envelope and 4 specialized modulators can be drag-and-drop to control most of the synth parameters. Another 8 step-based modulators are also at your disposal.
Powerful Morphing
Most of Wiggle¡¯s parameters can be captured as a ¡°snapshot¡±. You can take up to 4 snapshots of the sound you¡¯re working on and morph between them smoothly, either manually or automatically. It¡¯s up to you to create subtle timbre variations or drastic transformation of sounds.
Intuitive FM
The color-coded FM Matrix clearly shows the modulator/carrier relationship. All the parameters on the matrix can be modulated. It¡¯s easy to add complexity and character to the sound.
Versatile Sequencer
Wiggle¡¯s step sequencer offers you detailed controls to arrange both musical and modulation patterns. The resulting musical pattern can be dragged into your DAW.
Convenient Sampling
Wiggle¡¯s internal recording function allows you to quickly capture your sonic experimentat
DATE : 2017.03.29 | NUMBER : 5760/5761 | SiZE : 65.8 MB/89.9 MB
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´
