FL Studio is one of the world's most popular and exciting music production systems. Everything you need in one package to compose, arrange, record, edit, mix and master professional quality music.6 y" x5 W! X3 m* s
* [ ~4 Y" s# t* ~: F4 d5 F' PNotable New Features+ P4 D/ L0 L6 g( {8 u4 C
; T7 |6 f* U0 w; e% M+ y% N
FL Studio 64 Bit features# v8 B6 w$ q) H( J/ B$ U
¨C Access up to 512 GB memory, depending on your Windows version.; E6 ~9 R7 M& c* _( Y
¨C 32 Bit bridged and 64 Bit native VST plugin support.( B$ C2 } u9 ]7 Z$ B8 n& D, o
¨C Project compatibility between 32 and 64 Bit versions.
$ }- g- N5 S3 u$ g0 W¨C FL Studio available as a 64 Bit VST plugin for use in 64 Bit VST hosts.' u9 l4 X- J4 k: ~! v. H( D* i
4 X+ u7 |' Y* r! R1 J, S8 Y) O) n. s. W. z
Performance mode - Trigger Playlist Clips live using a mouse, touch screen, typing keyboard or MIDI controller. Supports APC20/40, Launchpad, Lemur, Block, Maschine/Mikro, padKONTROL, QuNeo, Traktor Kontrol (and more).
8 w4 q; D: }2 A) f' W+ p; Y $ w0 w! f5 B' x# K4 K* S
Multi-touch support - FL Studio and some plugins now respond to Multi-touch with Microsoft gesture functions supported.
2 |4 E) O" n: ^; s& ]0 y
; R* v3 J- \/ H% O+ H) ]Playlist - 199 Playlist tracks, increased from 99.% A# D3 ?+ G4 I9 a! c
) E& i* |$ k: q' ^4 rLinking includes MIDI input port - Links now remember the MIDI input port used to avoid conflict between controllers.& z- }7 Z; `: B; D& f: [6 `
& x; N+ e) G( C2 S; V: W" DPlaylist & Piano roll - Horizontal & vertical movement locking. Shift is horizontal lock & Ctrl is vertical lock when dragging items.
1 c- i2 v( M. N- O4 T% z
" ]0 F6 b2 x9 V1 z; z: ~2 hPiano roll - Glue notes, Mouse wheel velocity, Monophonic step entry mode & Chop chords tool.
9 i+ z+ w* \: W1 C- ~( _7 Y2 } 3 y3 k6 }" C7 D# L2 Y$ V
Right-click data entry - Most controls now allow a Right-click option to type in values.1 V, H# u1 _! z6 ^( g% Z# H H
9 P/ V: A+ U! U
Plugin Picker - Right-click to open a plugin and its presets in the Browser. Start typing plugin names to highlight entries.
0 M* H) I \% ^% M" S - R% C( L5 G0 m, q! p$ v( p) i
Mixer - Page Up/Down keyboard keys cycle through the current mixer track's plugin windows.
1 t5 I6 X* V0 | W
* d4 y6 K+ x6 H0 N5 w, BOptions - Play truncated notes in clips restores notes overlapping slice points in Pattern Clips. Click and hold functions. GUI animation level now selectable from sober to entertaining.
4 F/ y. b, j" k
' l" ~8 h. l3 r- }, _% w, |9 b: dBugfixes:6 R- _: H+ |7 J* [5 X
Fixed crash in about window* E l) x' a3 `9 j2 o/ g2 m
Fixed alternate mixer scale/hidden Channel rack crash on load3 O+ j( D* i c$ x1 [7 ?' @
Fixed generic links behaviour for effect plugins
) p. ?+ d# B+ S1 `8 D7 X" H& eFixed loading 64bit plugins in FL 64bit+ `. b; R$ ~& v, Y* w/ k
Fixed jpg support in FL 64bit6 u7 S- `# i& _: W# r7 w S1 X3 H: L
Fixed MRU color system& O7 z. B' p! B2 r1 d$ L
Plugin Scanner: various bugfixes! D# z1 P& d" u+ m, u1 n" h: ^6 _, G
Dashboard: fixed crash when exporting as text
8 W! t2 d! ^, t# H) iSytrus: fixed X/Y control over other controls9 _ i2 a2 Y* e" x o: ^
Control Surface: button saves/loads wrong state- V0 V( P: t" m. i
Parametric EQ2: bugfix
# e) H$ n9 ~% n: a( @ {2 B0 TPatcher: fixed bug loading newtone# g" C" ^4 [- p. C3 Z+ v, @
Wrapper: fixed problem loading wrapper options
; l# w9 h' [& S2 W( P& X: E) xEdison, Slicex, Convolver: fixed noise profile doesn't work right in 64bit
: ?. u* J( w! c; \Scratcher: fixed crash on right click
C& p' L/ }- R% g$ V1 R 7 V M" z9 x/ m: ]* c# @1 U
Additions:
4 E9 ]5 ~9 {2 Z( Q. [Wrapper: new option to determine what bit size to load for a plugin
j; T2 ^6 P# l9 | Y0 S
% F, b) C: C, p' v' k1 N( ?* @ ?0 m, ]
: H, w7 m& _. }6 {
- g8 w# M) y: R9 \
Image-Line FL Studio Producer Edition v12.0.2 For Win5 F0 t, j( B. \( _9 m3 x
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´
# b3 \8 P! ^8 j N |
