¡¾Î÷ÃÅ·¨¹úÔ²ºÅ¡¿Westgate Studios Modular Series French Horns
²úÆ·Ãû³Æ : ¡¾Î÷ÃÅ·¨¹úÔ²ºÅ¡¿Westgate Studios Modular Series French Horns
Westgate Studios Modular Series French Horns KONTAKT | 4.14 GB
¡¡¡¡·¨¹ú½ÇÌṩÁË183¸ö²¹¶¡´ÓË«À®°È²¿·ÖÑùÆ·£¬ËĽǺÍËĽǵIJ¿·ÖÓ벿·Ö£¬ÑƺÍÍ£Ö¹¡£Ã·ÁúÕò¹¤×÷ÊÒ½éÉÜÒ»ÖÖеÄÏêϸµÄÑù±¾·á¸»µÄϵÁкÍÊìÁ·³ÌÐò²¹¶¡¡£Ä£¿é»¯ÏµÁÐÉèÖÃÁËÒ»¸öеľưÉÔÚ½»ÏìÀÖÀÖÆ÷׿Խ¡£ËäÈ»´ó¶àÊý½»ÏìͼÊé¹Ý³¢ÊÔ¸øÄãÒ»µãµãµÄÒ»ÇУ¬Õâ¸öϵÁÐÊDz»Í¬µÄ¡£ÒòΪÿһ¸öÄ£¿é»¯ÏµÁвúÆ·¶¼¼¯ÖÐÔÚÒ»¸öµ¥Ò»µÄ¹¤¾ßÉÏ£¬ËùÒÔÄã»ñµÃÁËÄÑÒÔÖÃÐŵÄÁé»îÐÔºÍϸ½Ú£¬¶øÆäËûµØ·½¸ù±¾¾Í²»¾ß±¸¡£Ä£¿é»¯ÏµÁеÄÓŵãºÍÖйúµÄµÄimidi¿ØÖÆÊ¹ÓÃרÃżÇ¼¼ä¸ôµÄÑùÆ·¸ø¾ªÈ˵ÄÏÖʵÖ÷ÒåµÄ×Ô¶¨Òå½Å±¾¡£
183²¹¶¡ÔÚËÄÀà½ØÃæµÄ½Ç£º
2½Ç¿ª
4½Ç¿ª
4½Ç¾²Òô
4½ÇÍ£Ö¹
ÀàµÄ¹Ø½Ú°üÀ¨£º
Á¦Ñ§
¿ìËÙÖØ¸´£¨2Ö»£©
²ü¶¯Éࣨ2¿ªºÍ4¿ªµÄ£©
³¤¼Ç/Á¬×à
˺ÁÑ/ÆÙ²¼£¨2¿ªºÍ4¿ªµÄ£©
¼ò¶ÌµÄ±Ê¼Ç
²üÒôFX£¨2¿ªºÍ4¿ªµÄ£©
ÏÒ´Ø£¨4¾²ÒôºÍ4Ö»£©
¶¯Ì¬Ë®Æ½²»µÈµÄMP - FFF
Á¬Òô¹¤¾ß×Ô¶¨Òå½Å±¾ºÍimidi¹æÔòÓÃÓÚ´¥·¢×¨ÃżÇÂ¼Çø¼äµÄÑù±¾£¬¸øÄã×îÁîÈËÕ𾪵ÄÏÖʵÑù±¾µÄÉ豸¸üÐÂ
ͬÑùµØÖظ´ÕâÖÖ¿ØÖÆÊǽ¨Á¢ÔÚÁ¬×๤¾ßÔÊÐíÔÚÈκνÚ×à»ò½Ú×àÖØ¸´µÄÒô·ûûÓиºÔظü¶àµÄ²¹¶¡
¹¥»÷ºÍÖØ¸´µÄÇ¿¶È¿ØÖÆ
ÂÖѯÒÇÆ÷×Ô¶¯Ñ»·Í¨¹ý¶ÌÐÅÁªÏµµÄ4µÄ±ä»¯
Óë±ä»¯µÄ¶¯Ì¬±í´ï¹¤¾ß
רҵµÄÑÝ×à·ç¸ñÈç²ü¶¯Éà¡¢²üÒô¡¢ËºÁÑ£¬ÆÙ²¼£¬ºÍÁîÈËÐ˷ܵĵçӰЧ¹ûµÄ¸÷ÖÖºÍÏÒ¼¯Èº¹Ø½Ú¡£
¹ÜÏÒÀÖ¡¢½Ç
The French Horns provides you with 183 patches with samples from a two horn section, four horn section, and four horn section with mutes and stops. Westgate Studios introduces a new series of richly detailed samples and expertly programmed patches. The Modular Series sets a new bar of excellence in symphonic instruments. While most symphonic libraries try to give you a little bit of everything, this series is different. Because each Modular Series product focuses on a single instrument, you get incredible flexibility and detail that is simply unavailable elsewhere. The Modular Series takes advantage of custom scripts for Kontakt and Gigastudio's imidi control to use specially recorded interval samples giving stunning realism.
183 patches in four categories of section horns:
2 horns open
4 horns open
4 horns mute
4 horns stop
CatEgories of articulations include:
Dynamics
Fast Repetitions (2 open only)
Flutter Tongue (2 open and 4 open only)
Long Note/Legato
Rips/Falls (2 open and 4 open only)
Short Notes
Trill FX (2 open and 4 open only)
Chord Clusters (4 mute and 4 open only)
Dynamic levels ranging from mp -fff
Legato Instruments Custom scripts and imidi rules are used to trigger specially recorded interval samples, giving you the most stunningly realistic samples instruments to date
Same Note Repetition This control is built in to the legato instruments allowing for repeated notes in any tempo or rhythm without having to load more patches
Attack and repetition strength control
Round Robin instruments automatically cycle through 4 variations of short note articulations
Expressive instruments with changing dynamics
Specialty playing styles such as flutter-tongue, trills, rips, falls, and a variety of chord cluster articulations for exciting cinematic effects.
Orchestral, Horns
+3% Recovery record. Interchangeable mirror links.
No mirrors below please. |
