Global Audio Tools 24K 808s KONTAKT
Äã×¼±¸ºÃÈ¥ÈÏÖ¤»Æ½ðµØÎ»£¿ È«ÇòÒôƵ¹¤¾ßΪÄú´øÀ´'24K 808s KontaktͼÊé¹Ý' - µ«²»Òªµ£ÐÄËùÓеÄ808ÉùÒô¶¼ÒÔWAV¸ñʽ³öÏÖ - ËùÒÔÎÒÃǶ¼¿ÉÒÔʹÓÃÕâ¸ö´ò»÷¹¤¾ß£¡
Õâ¸öȫеÄKontakt¿âÅ䱸ÁË40¸öµ÷г808s£¬ÒÔ¼°ÓÅÑŵÄÓû§½çÃæºÍ°åÔØ¿ØÖƺÍFXÄÚÖò˵¥ÏµÍ³À´Ñ¡ÔñÊʵ±µÄ808.Èç¹ûÄãÕýÔÚѰÕÒһЩеÄ808s£¬ÄÇôÄã²»ÄÜÒ²²»»á ÓÃÕâ¸ö¹¤¾ßÔÚÕâÀï³ö´í£¡ ½ñÌ칺ÂòÄãµÄ¸±±¾¡£
ϸ½Ú£º
40µ÷808µÄ
Wav / Kontakt 5¸ñʽ
44.1kHzµÄ/µ¥ÉùµÀ/ WAV /24λ
Windows / Mac¼æÈÝ
KontaktÐèÒª5.4.1»ò¸ü¸ß°æ±¾
Ô­ÎÄ
Are you ready to go Certified Gold status? Global Audio Tools is bringing you the '24K 808s Kontakt Library' - but don¡¯t worry all 808 sounds come in WAV format as well - so we all can use this hit making tool!
This brand new Kontakt Library comes equipped with 40 tuned 808s as well as an elegant user interface and onboard controls and FX with a built in menu system to select the proper 808. If you are looking for some new 808s then you can not and will not go wrong with this tool right here! Purchase your copy today.
Details:
40 Tuned 808's
Wav/Kontakt 5 Format
44.1khz/Mono/Wav/24-bit
Windows/Mac Compatible
Kontakt 5.4.1 or higher required
Global Audio Tools 24K 808s KONTAKT | 105 Mb
ÆÀÂÛÁÐ±í£¨2£©
:victory: :victory: :victory: Global Audio Tools 24K 808s KONTAKT
2008-8-3 09:11:43 »Ø¸´
recang Â¥Ö÷
2008-8-6 14:03:32 »Ø¸´
