¸ß¼¶¹âÆ×¿ÅÁ£ºÏ³ÉÆ÷ Tracktion Software Dawesome Novum v1.08 WIN MAC
NOVUM̽Ë÷еÄÒôËÙÓîÖæ¡£Novum ÒýÁìÏÂÒ»´ú´´Òâ²ÉÑù£¬ÎªÉùÒôµÄÎÞÏÞ¿ÉÄÜÐÔ´ò¿ªÁË´óÃÅ¡£´Óµ¥¸öÑù±¾´´½¨ÒýÈËÈëʤµÄÀÖÆ÷ ¨C ´Ó¾«Öµĵæ×Óµ½¹²ÕñºÏ³ÉÆ÷µÄ¾Þ´óǽ±Ú ¨C Novum µÄÉùÒô·¶Î§½öÊÜÄúµÄÏëÏóÁ¦µÄÏÞÖÆ¡£
Sound Clay
ÎÒÃÇϰ¹ßÓÚ½«ÒôƵ²ãµþ¼Óµ½Ò»¸öÒôƵÎļþÖС£µ«ÊÇ·´¹ýÀ´ÄØ£¿Novum µÄºËÐÄÔÚÓÚ¿ÉÒÔ½«µ¥¸öÑù±¾¡°·Ö½â¡±Îª 6 ¸ö¶ÀÁ¢µÄ²ã¡£ÕâʹÄúÒ»·½Ãæ¿ÉÒԽ⿪·ÃÎÊÒôÉ«ÌØÕ÷£¬ÁíÒ»·½Ãæ¿ÉÒÔ·ÃÎÊʱ¼ä¶¯Ì¬¡£ÕâÒ»Çж¼²»Í¬ÁË£¬½«ÄúµÄ¾²Ì¬Ñù±¾±ä³ÉÁé»îµÄÉùÒôÕ³ÍÁ¡£
½»²æºÏ³É
ÏëÄÃÒ»¸ö³¤µÑÑù±¾£¬µ«ÓøÖÇÙµÄÒôÉ«À´Ìý£¿»òÕß´¥·¢¾µäµÄ¹ýÂËÆ÷ɨÃ裬µ«Ê¹ÓýÌÌÃÖÓÉùµÄÉ«µ÷£¿Novum ÈÃÕâÒ»ÇбäµÃ¼òµ¥ ¨C ͨ¹ý¼òµ¥µÄÍÏ·Å£¬Äú¿ÉÒÔ×ÔÓɵؽ«ÉùÒôÔªËØÏ໥×éºÏ¡£ÎªÁËʹÕâ¸ö¹ý³Ì¸ü¼Ó¼òµ¥£ºµ¼ÈëÄúµÄÑù±¾£¬È»ºóËø¶¨ÆäÉ«µ÷ºÍ°üÂç¡£ÏÖÔÚ£¬Äú¿ÉÒÔä¯ÀÀÔ¤É裬ÈÃÄúµÄÑù±¾±£³ÖÔλ£ºÊýÊ®ÖÖÕæÕý¶ÀÌØµÄ±ä»¯ÔÚ¼¸ÃëÖÓÄÚ´¥Êֿɼ°¡£
¸ß¼¶¿ÅÁ£ºÏ³É
ÉÁ˸µÄÉùÒôÁ£×Ó¡¢Éù²¨ÉÁ¹âºÍÁ¼ºÃµÄÉùѧÏɳ¾¡ª¡ª¿ÅÁ£ºÏ³Éʹƽ·²µÄÊÂÎï±äµÃÃÀÀö¡£ËٶȺÍÒô¸ßÊǶÀÁ¢µÄ£¬¶øÇÒÄú¿ÉÒÔ½«¿ÅÁ£Í¬²½µ½ÄúµÄ DAW ËÙ¶ÈÒÔ´´½¨Âö³å½Ú×à¡£Novum ¶ÀÌØµÄ HOMOGENIZE ¹¦ÄÜÔÊÐíʹÓþµä¿ÅÁ£ºÏ³ÉÆ÷ÄÑÒÔ´´½¨µÄ¹â»¬¡¢Ìì¶ìÈÞ°ãµÄÎÆÀí¡£ÔÙ¼ÓÉÏÁù¸ö¿ÅÁ£²ãµÄ¾Þ´óÁ¦Á¿£¬ÄãµÄÉùÒô±ÈÉúÃü¸ü´ó¡£
ÎÞÏÞ¿ÉÄÜ
¡°Ã¿Ò»ÖÖÉùÒô¶¼¿ÉÒÔ³ÉΪһÖÖÀÖÆ÷¡±¡ª¡ªÕâÊÇ Novum µÄºËÐÄÉè¼ÆÀíÄʹÓà Comb-Filter ½«ÏÖ³¡Â¼Òô±ä³É¿É²¥·ÅµÄµ÷гÀÖÆ÷£¬Í¬Ê±±£³ÖÔÊ¼ÎÆÀí¡£Ö»Ðè¶ÔÁ£¶È²¥·Å½øÐÐһЩµ÷Õû£¬¼´¿É½«Ê§µ÷µÄСÌáÇÙÑù±¾×ª»»ÎªìÉýµÄÏÒÀÖºÏ×ࡣʹÓÃÒôÉ«»¨½«ºÏ³ªÍűä³ÉÉÁÉÁ·¢¹âµÄ²£Á§µæ£¿»òÕßʹÓà SYNTIFY ½«ÄúµÄÑù±¾×ª±äΪºÚ°µºÏ³ÉÆ÷ÎÞÈË»ú£¬¾ÍÏñÖ±½ÓÀ´×ÔÆæ¹ÖµÄÄ£¿é»¯¹ÖÎïµÄ¶«Î÷¡£Äú½«Ê¹Óà Novum ´´½¨Ê²Ã´£¿
ÌØµã
¨C ¶ÀÌØµÄËã·¨½«Ñù±¾·Ö³É²ã¡£
¨C ¶à´ï 6 ²ãµÄ¿ÅÁ£ºÏ³É¡£
¨C ÒôÉ«ºÍʱ¼äÑݱäµÄ½âñî±à¼¡£
¨C ÒôÉ«»¨ÔÊÐíÒôÉ«µÄ¹âÆ×Ð޸ġ£
¨C ͨ¹ýÍϷŽøÐн»²æºÏ³É¡£
¨C ´øÓÐ SYNTIFY¡¢Ä£ÄâÂ˲¨Æ÷ºÍÊá×´Â˲¨Æ÷µÄ¸ß¼¶¼õ·¨¡£
¨C Ç¿´ó¶øÖ±¹ÛµÄµ÷ÖÆÏµÍ³¡£
¨C ÍêÕûµÄ MPE Ö§³Ö¡£
¨C Õë¶Ô CPU ЧÂʽøÐÐÁ˸߶ÈÓÅ»¯¡£
¨C 300 ¶à¸ö¹¤³§²¹¶¡¡£
MORiA | 8 ÔÂ 11 ÈÕ | AU | VST3 | 199.05 MB
NOVUM Explore a New Sonic Universe. Ushering in the next generation of creative sampling, Novum opens the door to a universe of sonic possibilities. Create fascinating instruments from a single sample ¨C from delicate pads to massive walls of resonating synths ¨C Novum¡¯s sonic range is only limited by your imagination.
Sound Clay
We are used to summing audio layers into a single audio file. But how about the other way round? At the heart of Novum lies the possibility to ¡°decompose¡± a single sample into 6 independent layers. This gives you disentangled access to the timbral characteristic on the one hand and the temporal dynamics on the other hand. And that makes all the difference, turning your static sample into flexible sound-clay.
Cross-synthesis
Want to take a flute sample, but hear it with the timbre of piano? Or trigger a classic filter sweep, but with the tonecolours of a church bell? Novum makes this easy ¨C with a simple drag and drop you can combine sonic elements with each other freely. To make this process even simpler: import your sample, then lock its tone colours and envelopes. Now you can browse through the presets keeping your sample in place: dozens of truly unique variations are at your fingertips in seconds.
Advanced Granular Synthesis
Shimmering sound particles, sonic glitter and a good measure of acoustic fairy dust ¨C granular synthesis renders even the mundane beautiful. Speed and pitch are independent, plus you can sync the grains to your DAWs tempo to create pulsing rhythms. Novum¡¯s unique HOMOGENIZE feature allows for smooth, velvet-like textures that are hard to create with classical granular synths. Add to this the immense power of six granular layers and you have sounds bigger than life.
Endless Possibilities
¡°Every sound can be an instrument¡± ¨C this is design philosophy that lies at the heart of Novum. Turn field recordings into playable, tuned instruments with the Comb-Filter, while maintaining the original texture. Convert an out-of-tune Violin sample into a soaring string ensemble with a few tweaks of the granular playback. Use the timbre flower to transform a choir into a shimmering glass pad? Or use SYNTIFY to transmute your sample into a dark synth drone, like something straight out of a weird modular monster. What will you create with Novum?
Features
¨C Unique algorithm breaks samples into layers.
¨C Granular Synthesis with up to 6 layers.
¨C Disentangled editing of timbre and temporal evolution.
¨C Timbre flower allows spectral modification of timbres.
¨C Cross synthesis via drag and drop.
¨C Advanced subtractive with SYNTIFY, analog filter and comb filter.
¨C Powerful and intuitive modulation system.
¨C Full MPE support.
¨C Highly optimised for CPU efficiency.
¨C 300+ factory patches.
Release notes v1.08
¨C Solves an issue with occasionally failing auval in Logic Pro.
¨C Added support for the Tracktion Download Manager: the content pack auto-installs when downloaded.
¨C Added a START TRIAL button.
¨C Other minor fixes. |
