Dangerous Music D-Box×ۺϿØÖÆÆ÷' h: i5 e7 f3 U. `
* u5 q7 i4 P* w& N$ _& f. B
D-BoxÊÇÒ»¸öDAWÊý×ÖÒôƵ¹¤×÷Õ¾Óû§µÄºÃ°ïÊÖ£¬Ëû×ÛºÏÁËSumming¡¢¼àÌý¿ØÖÆ¡¢Êý×Ö/Ä£Äâת»»Æ÷¡¢¶Ô½²¡¢¶ú»ú·Ö·Êä³ö¡¢¶à·ÊäÈë¼àÌý¹¦ÄÜÓÚÒ»Éí£¬¶øÇÒÕâЩ¹¦ÄÜÈ«²¿¼¯ÖÐÔÚ1UµÄ¿Õ¼äÄÚ¡£" k2 P o& {( Y: Q s M( z
: D4 z# U @' b& P0 A
D-BoxÖ÷ÒªÌØÐÔ£º
' I5 y7 g- x1 R7 e* N# a/ ]- B$ \! B" h; ^/ F) b: G2 ?
8·ÊäÈ룬¿É×Ô¶¯µ÷½ÚÔöÒæ×öSumming% I& s2 d: ^5 a; K" i; P$ i) f
( Y# D" Z# F& b9 y7 u. E( b3 T
Ö÷Êä³ö¿Éµ÷½ÚÒôÁ¿
6 l; z& \2 z3 [8 N3 g( M& C) u% n1 T4 ~
ÊäÈë7¡¢8ͨµÀ¿É¿ØÖÆÉùÏñ
2 c: t X$ N) T# g. h$ Z) f
3 U5 G3 `2 r3 c* F+ V3 v4 nÿ¸öÊäÈëͨµÀ¶¼´øµçƽ±í
2 L. z: ^) t. A$ l
5 M0 u3 y( H: ?0 l* g2×é¼àÌýÊä³ö£¬¿É×ö¼àÌý¿ØÖÆÆ÷ÓÃ
; y6 f& i! x- }$ ]' |) k9 @
+ m. F0 V! g2 [# |$ b% _* W´ø2·AES»òSPDIFÊä³ö£¬32kHz-100kHz¾«¶È
0 [* S. G$ A7 g- ]3 J! q! O/ [
ÄÚÖöԽ²Âó¿Ë·ç
0 w, Q: L7 e! f* ~
6 M9 c6 o8 \9 w+ `2¸ö¿É¶ÀÁ¢µ÷½ÚÒôÁ¿µÄ¶ú»úÊä³ö½Ó¿Ú7 R7 z) @1 _& W" ]3 X" |6 d; f
9 a0 a) w: B& M# C' f4 H5 y) }6 W1 m5 D
Dangerous Music D-Box Features:7 w# w# P- ^- ?& X
. J5 U( y9 a! j# h5 x( J
Mastering grade monitor path, because "you can&££39;t mix what you can&££39;t hear."
8 J" P& N5 j' ?$ Y% ]. d' J" t6 u5 M- g# q
Eight channels of summing to restore punch, low end and the stereo soundstage& e/ p- v" j. c% \) o
+ \" ]2 u4 A1 @Transparent D/A converter translates the mix across every playback system
( S+ B q( D- b* C% B( F/ g, u+ `, }! V2 n `% W
Two independent 20W headphone amps provide substantial headroom for emotive performances and accurate headphone mixes.4 K' O' ^0 Z# `' l
# ]" ~5 y( q9 M3 @- z
2 Speaker Outputs7 Q& i3 i1 \' P9 w7 x8 i' l% e
% M I$ l1 P1 _( ~6 c. @Affordable for All DAW Studio Owners+ G) b5 s" A4 L$ S. X
$ F& T5 ] p9 f5 U8 input dedicated fixed-gain analog summing buss
3 a9 j. N9 i0 e# x0 L4 d. l
8 S/ o# E1 Q; \( ^+ oMaster output trim with 10dB range
- D! l* U5 \$ {/ T
' F1 A6 n$ {1 [( |8 \! eInputs 7-8 with pan control2 v1 m/ N B' }; M. e% x# }/ Z
. n" a3 \8 @$ s/ LSignal present indicators for all inputs( _: O M" r, M4 W
& x5 ^0 e- j7 w! z& uAnalog and digital capable input selector designed specifically to facilitate the analog summing workflow
$ c# d9 h3 f1 \- t7 o7 G* u# U: K/ \+ w: w
Programmable exclusive/additive function- listen to selected inputs individually or combined
, Z& p2 d# V# P8 X* D( B! `; s- s" o3 v& G6 q
2 digital inputs - AES or S/PDIF 32kHZ - 100kHz sample rate
( L" Z* H* I, V: y+ _
; Y/ f2 o" P" v* k3 R: @" vAuxiliary stereo analog input- +4 dBU or - 10 dBV programmable
: h8 h5 z7 Y S4 J% }5 y
4 S9 Y b- u/ U9 _6 \ ]+ qMono function
1 E" ]1 r# L% W# o$ p; N
$ Q# D# G% t6 Q3 A7 O7 HBuilt-in talkback microphone with "momentoggle" switching+ L! \3 I b$ [
0 z! X+ G7 V& C' n8 c, h4 e
2 headphone outputs with independent level controls2 C; d& G1 T0 O
% b! {7 _" ?1 n$ C1 m- K
Auxiliary talkback switch inputTech Specs | Number of Input Channels | 8 | | Number of Output Channels | 4 | | Analog Inputs | 2 x XLR, 1 x D-Sub | | Analog Outputs | 6 x XLR | | Digital Inputs | 2 x XLR | | Digital Outputs | No Digital Outputs | | Headphones | 2 x 1/4" | | Talkback | Yes | | Form | Rackmount | | Height | 1.75" | | Depth | 9.5" | | Width | 19" | | Weight | 12 lbs.8 ]& e: r, M" d* Q# W3 a
1 v* l7 f- f- E/ b9 E | * }' c' `% v) n4 l
