Burl Audio B80 10²å²Û»úÏä
An Entirely New Way to Configure Your Studio
Note: The Burl Audio B80 is an empty chassis specifically for use with Burl Audio converter modules, and does not support 500 Series modules.
The Burl Audio B80 Mothership empty converter chassis represents an innovative way of approaching digital conversion. You can create a custom, modular converter system with up to 80 channels of D/A conversion, or up to 40 channels of A/D conversion! The B80 Mothership is a 4U, 10-slot empty chassis that you can install any combination of Burl A/D and D/A converter cards. A 1U power supply is included, providing ample power for the high-headroom, low-noise converters. Burl Audio converters are renowned for their tape-machine-like response to signal level, giving you control over your signal&££39;s tone through gain staging. Burl digital converters give you a world-class analog front end with amazingly deep and detailed conversion, and the B80 Mothership makes it possible!
Burl Audio B80 Mothership Empty Chassis at a Glance:
Innovative converter design, outstanding audio performance
Modular flexibility
Robust power supply
Burl Audio&££39;s series of A/D and D/A converters sound strikingly close to an analog tape machine&££39;s front end, with the ability to shape your tone based on how hot your signals hit the converters. They sound more like a world-class analog front end than anything on the market, as well as providing digital conversation that&££39;s as precise, rich, and detailed as possible. Each A/D converter channel is transformer balanced, and the hotter the signal level the more saturated the signal becomes. You&££39;ll find you can shape your sounds the way you used to do with analog equipment, with the benefit of an ultra-precise converter to capture the tone.
Modular flexibility
Once you hear the analog goodness of Burl&££39;s converters, you&££39;ll want to run every channel of your mixes through them! Thanks to the B80&££39;s modular design, you can install any combination of 2-, 4-, or 8-channel converter modules for a seriously high I/O count. But even if you don&££39;t need 80 channels of conversion, Burl promises new modules will be available in the future to further enhance the functionality of the Burl B80 Mothership in the recording studio.
Robust power supply
When a power supply takes up its own rack space, you know that some thought went into the design. The B80 Mothership&££39;s power supply provides ample power for the high-headroom operation of the converter modules, and leads to virtually noise-free signal quality. Burl Audio knows that optimum performance depends on ample, stable power, and that&££39;s exactly what you get with the B80 Mothership.
Burl Audio B80 Mothership Empty Chassis Features:
10-slot empty chassis for Burl Audio converter modules, DigiLink format
Create your own custom converter configuration
Burl Audio promises to release additional modules to enhance the B80&££39;s studio functionality
Supports up to 80 channel of D/A conversion, or 40 channels of A/D
USB port for remote computer control |
