Image-Line FL Studio Producer Edition v11.0.3 Beta MAC OSX
Introducing FL Studio 11
. I2 i. v, J, T2 F+ r) mFL Studio 11 is a complete software music production environment or DAW (Digital Audio Workstation) representing more than 14 years of innovative developments and our commitment to Lifetime Free Updates. Everything you need in one package to compose, arrange, record, edit, mix and master professional quality music. FL Studio 11 is the fastest way from your brain to your speakers.' _1 m1 I7 T  k7 |6 |
/ l* T% }/ e2 T+ H: U! B
Notable New Features  h" G7 ]/ {: r" h
-FL Studio 64 Bit features  & G8 f6 R$ ^$ j" I, P
¨C -Access up to 512 GB memory, depending on your Windows version.
# C" c" E3 o) U- W7 Y" b¨C -32 Bit bridged and 64 Bit native VST plugin support.
9 Y' j& s* v" r. f9 h) ^¨C -Project compatibility between 32 and 64 Bit versions.
# _9 ]( Y8 m  e. a$ P¨C -FL Studio available as a 64 Bit VST plugin for use in 64 Bit VST hosts.
& v6 y( B- `  _+ ]! z2 z! N-Performance mode ¨C Trigger Playlist Clips live using a mouse, touch screen, typing keyboard or MIDI controller. Supports APC20/40, Launchpad, Lemur, Block, Maschine/Mikro, padKONTROL, QuNeo, Traktor Kontrol (and more).
. R6 P4 x: z. ^2 b-Multi-touch support ¨C FL Studio and some plugins now respond to Multi-touch with Microsoft gesture functions supported.
2 w( B& X: C: d# C( _" _-Playlist ¨C 199 Playlist tracks, increased from 99.  I: t" `" k5 E, J
-Linking includes MIDI input port ¨C Links now remember the MIDI input port used to avoid conflict between controllers.( H9 b0 K9 M9 ^, s
-Playlist & Piano roll ¨C Horizontal & vertical movement locking. Shift is horizontal lock & Ctrl is vertical lock when dragging items." z: F& S; X  Y+ B  k
-Piano roll ¨C Glue notes, Mouse wheel velocity, Monophonic step entry mode & Chop chords tool.5 d$ b4 u+ m* V3 p+ v
-Right-click data entry ¨C Most controls now allow a Right-click option to type in values.
2 x. e: y* l, Z7 E+ O-Plugin Picker ¨C Right-click to open a plugin and its presets in the Browser. Start typing plugin names to highlight entries.* `" ^$ J$ Q" e2 b
-Mixer ¨C Page Up/Down keyboard keys cycle through the current mixer track's plugin windows.
" Z. y8 H8 M0 X& p! z3 X( v-Options ¨C Play truncated notes in clips restores notes overlapping slice points in Pattern Clips. Click and hold functions. GUI animation level now selectable from sober to entertaining.
+ e2 c# B, g) m6 o( y! F µÈµÈµÈ.JPG ) ^) C) H( F6 W6 ^$ M$ ?4 u
New Plugins, E; [  A: e8 U: _
  -BassDrum ¨C Deep Kick-Bass percussion synthesizer with sample layering. BassDrum was developed due to strong and loud customer demand for punchy kicks with a big bottom end. Our solution was to take a hybrid synthesis/sample route to provide unlimited customization for the perfect kick sound. . T- G$ N) T' D+ O6 O
-GMS (Groove Machine Synth) - Multi-timbral hybrid synthesizer & FX channel lifted from Groove Machine. Another plugin by popular demand./ F7 |5 Y. L3 ^' ~
-Effector - 12 performance oriented effects: Distortion, Lo-Fi bit reduction, Flanging, Phasing, Filter (low/high pass), Delay, Reverb, Stereo panning & binaural effect, Gating, Granulizer, Vocal formant and Ring modulation effects. Effector was introduced to compliment Performance Mode and is perfect for use with multi-touch displays & controllers.
8 F& H2 r, J# }! r$ B5 W8 r& [-Patcher ¨C Introduced with FL Studio 10 to provide a means of saving and recalling commonly used effects and plugin chains. It¡¯s in the new section as, aside from being overhauled with animated connections and a fresh interface, patcher has gained two, of many more to come, Voice Effects (VFX).
7 j9 ^0 c4 N" i-VFX Key Mapper ¨C Allows note inputs, live or from the Piano roll, to be transposed, keychanged, chorded or creatively remapped., I, E6 C- c; m2 x
-VFX Color Mapper ¨C Leverages FL Studio¡¯s 16 Piano roll note colors that have traditionally mapped to MIDI channels. Now inside Patcher note colors can control 16 independent generators/instruments or groups of generators! @5 X1 a3 f7 F6 ^6 p5 z. }
) c# |2 x2 @0 a0 y) m( N
FL Studio system requirements:
$ }' q# h$ `, R, c3 V-2Ghz Intel Pentium 4 / AMD Athlon 64 (or later) compatible CPU with full SSE2 support. The faster your CPU and more cores it has the more you will be able to do simultaneously. Download and test the demo! $ F+ l% P9 c& F
-32 or 64 Bit versions of Windows 8, Windows 7, Vista, XP (with service pack 3) 4 [* y: J5 G! v0 e! x1 G+ `6 r* h( y! F
-(or) Intel Mac with Boot Camp / Windows.
  t) v# i/ b- x3 E. ARunning XP (with service pack 3), Vista or Windows 7 (in 32 or 64 Bit): U! k* \* M( `0 J7 E3 m. i/ ~5 `
-(or) Intel Mac with OS X 10.8 or 10.9 for the FL Studio Mac OS X BETA (Crossover Wrapped)
8 O2 ]5 Y9 K1 O: `Attention: Yosemite not supported.
% s  _+ j- E3 \' K9 t-1 Gb or more RAM recommended ' |: b9 I3 f+ X# }
-1 Gb free disk space
1 N  O$ O$ b4 \* n2 `$ f1 H-Soundcard with DirectSound drivers. ASIO/ASIO2 compatible required for audio recording (FL Studio installs with generic ASIO4ALL drivers) ; M" M& l" S& J) I
4 S6 [  l$ m% g7 t, P; AWhat can FL Studio 11 do? : j/ X/ e3 y6 a  x7 e7 K2 `
-Audio editing and manipulation including pitch correction, pitch shifting, harmonization, time-stretching, beat-detection & slicing, audio warping and standard audio manipulation (cut/paste etc).
9 t$ E% @% J% [; S-Automate most interface and all plugin parameters by recording, drawing, spline-based automation curves, automation generators with formula based control of links.
9 @& O+ ^$ `% b* w& o& l# L-Be hosted in other DAWs as a VST or connected through ReWire. 32bit and 64bit hosts.
. s5 x( q* H7 u-Live music performance including video effect visualization.7 D: C% \) |0 P& M
-Mix and remix audio including apply real-time audio effects including delay, reverb & filtering.2 y+ e+ ^4 [1 _( y  y+ q
-Multi-track audio recording up to the limit of your audio-interface inputs.# |  X& u0 t; s/ x9 b- h; L  A
-Record & play MIDI input recording from keyboards, drum pads and controllers.! ]( j. {7 p( k8 Z/ L: P' q
-Sequencing and arranging with pattern and linear workflow possible.
- p! A. f; u7 r9 y-Synthesizer & effect plugin hosting VST 32 & 64 bit, DX and FL Native formats.
% d2 n6 e9 R1 F7 \' F2 |
# L) o! \/ O& N% DInstruments, k. h; R( s7 y/ a5 s
-Make virtually any sound - FL11 includes over 30 software synthesizers covering acoustic/synthetic bass, electric guitar, multi-sampler tools including piano & strings, general sample playback and beat-slicing (With Rex 1 & 2 support). 3 a4 |* G; ^* H+ @: F, ], t, I: E1 }
-Synthesis techniques - span subtractive, modelling, FM, RM, granular and additive. With the addition of FL SynthMaker you can further create & share your own FL instruments, effects & MIDI control dashboards without the need to write basic code.
4 ?$ Z( }5 d7 e( L6 t5 d% K-Open plugin standards ¨C FL Studio supports all PC industry plugin instrument standards including VST, DX, Buzz and Rewire. This means you can sequence with your favorite plugins and applications.
- o( v! n" p, f3 b' d" ]% @ 2 K7 I! a" C, i: R
Audio Recording & Editing2 u% y9 ~9 R4 z) R. O( ]
-Multi-channel audio inputs - With the ability to simultaneously capture all the inputs on your audio-interface, FL Studio has the flexibility to record a single vocalist, guitar or a full symphony orchestra. ' t6 \0 Q5 M9 f, s, g3 A2 b
-Arranging audio - Audio can be arranged, with complete freedom in the Playlist. Features include the ability to host an unlimited number of audio recordings, time-stretching, pitchshifting, beat-slicing, cropping, editing and the re-arranging of audio with only a few mouse clicks.
9 z' o8 M3 Y, V-Edison ¨C FL Studio¡¯s audio capabilities are further enhanced with Edison, the recording wave editor. Edison is an integrated audio editing and recording tool with spectral analysis, convolution reverb, noise reduction, loop-recording, loop-construction tools and more.
2 u$ m  Q( h" k0 B! W$ H1 G9 N-Newtone ¨C Pitch corrector/editor. Correct, slice, edit, stretch vocals, instrumentals and other monophonic recordings. Convert audio to MIDI data and re-pitch any monophonic melody to another. FL Studio supports WAV, MP3, OGG, WavPack, AIFF, and REX audio formats. Sequencing Compose and record your musical performances and ideas in the most logical way.
5 `1 W# Y) ?! `/ x3 u2 y0 j-Pattern or track sequencing ¨C You choose, record your musical performances and ideas in the most logical way. FL Studio 11 can simultaneously function as a pattern and track based sequencer. Reuse patterns as Pattern Clips in the Playlist or record song-length sequences, as desired.
! Z* o/ Q0 {/ y0 {+ W8 J-Step sequencer or Piano roll - Scoring tools include FL Studio¡¯s legendary Step-sequencer, one of the most advanced Piano roll¡¯s in any software studio, event and multipoint automation envelopes. FL Studio supports MIDI input, standard controller compatibility, and the ability to simultaneously control multiple instrument channels from separate controllers.* b1 [3 \% M3 y' m5 Q9 |  D4 \  o
# {6 o, s, W  t2 T8 U+ B; f# hArranging+ {# p% O6 J; R: ~" K- H
FL Studio allows you to do what you want where and when you want.
3 [9 N( J. G. U' Y$ m7 P) W$ cDetermine your own project design - In FL11, you decide how your project will be laid out. Unlike the competition, FL11's Playlist is a totally flexible and virtually unbounded workspace where Note Pattern, Audio and Automation data can be arranged and edited to suit your creative ideas and preferred workflow.
8 a  G( L! r4 w$ a" x8 L( u ' m7 {0 p2 N; y7 b( o$ q$ z
Mixing & Mastering, d: x$ ?; Q0 l/ y1 A- ~
FL Studio provides all the tools you need to produce your tracks to high professional standards.
# P- u$ A' U( b. d-The mixer - is about precision, control and flexibility. The mixer¡¯s tracks each hold up to 8 effects (VST, DX or FL's proprietary format). To create sub-mixes or mixing chains of almost unlimited complexity, each mixer track can be routed to any other mixer track, one of 4 dedicated 'send' channels and or the Master track. Sends provide the ability to sidechain inputs to multi-input effects plugins. Finally, each of the mixer tracks can be routed to any output on your audio interface, now that¡¯s flexibility.
; ?! W/ Q- N4 [) \5 k1 C-Effects - What about effects? FL Studio includes more than 40 effects spanning maximization, limiting, compression, delay, distortion, equalization (graphic & parametric), filtering, phasing, flanging, chorus, vocoding and reverb. These have you covered for the creative broad-brush effects, through to the minutia of the mastering process.4 Z$ d' o' W/ \& j, l
-Open plugin standards ¨C FL Studio supports all PC industry plugin effect standards including VST (1/2), DX(1/2), Buzz and Rewire. This means you can mix with your favorite plugins and applications.
0 m7 v4 ^7 ]/ G4 s
. a! E' o( }. v" g6 x- c
: m# {/ {+ i" @) e, Q( {ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨2£©
´ó¸çÐÁ¿à£¡ÏÖÔڵĺã¡
2008-7-6 08:04:46 »Ø¸´
ºÃ ,Ö§³Ö ::victory: :victory:
2008-7-12 18:18:38 »Ø¸´
