Big Fish Audio Sequence Hip Hop Beat Creator
´óÐÍÓãÀàÒôƵÒÔÏÖÔÚµÄ˳ÐòΪ°Á:Hip Hop Beat Creator£¬Ò»¸öÇ¿´ó¶øÓÐЧµÄÒôÐòÆ÷£¬ÄÚÖÃ808 bassesºÍÒ»¸ö¹öͲ¹ö×àµÄ´´ÔìÕß¡£ÐòÁÐΪÏÖ´úÐòÁÐÉ趨ÁËÒ»¸öбê×¼£¬³¬Ô½Á˹淶£¬ÎªÕæÕýµÄÉú²úÕßÌṩÁËÕæÕýµÄ¹¤¾ß¡£Óг¬¹ý4000¸ö¹ÄÑù£¬32¸ö¶ÀÌØµÄ808¸öbasses£¬ºÍÒ»¸ö¹ö¶¯µÄ´´ÔìÕߣ¬°ÑtrapstyleµÄhi-hatºÍ¾ü¹Ä·ÅÔÚÄãµÄÖ¸¼â£¬Ñ°ÕÒ½Ú×࣬µÍÒôºÍ½Ú×à½áÊøÁË¡£
Õâ¸ö12ƵµÀµÄÒôÐòÆ÷ʹÓá°³¡¾°¡±°´Å¥ºÍÏàÓ¦µÄ(ÂÌÉ«)MIDIÒô·ûÀ´Ìṩ12¸ö½ÚÅı仯¡£Äú¿ÉÒÔÔÚÄúµÄÐòÁÐÖдò¿ª»ò¹Ø±ÕÒ»¸ö»ò¹Ø±Õ64¸ö²½ÖèµÄʾÀý£¬²»Í¬ÓÚÆäËûµÄÐòÁУ¬ÐòÁеÄÿһ²½¶¼ÓпØÖÆÀ´µ÷ÕûÒôÁ¿¡¢Òôµ÷¡¢Æ½ÒƺÍÑù±¾³¤¶È£¬´Ó¶øÔÊÐíÄÑÒÔÖÃÐŵĶÀÌØºÍ¸»ÓбíÏÖÁ¦µÄ¹ÄÉù²¿·Ö¡£´ËÍ⣬ÿһ¸öÔØÈëÄãµÄÒôÐòÆ÷µÄÑùÆ·Ò²¿ÉÒÔ´ÓÄãµÄmidi¿ØÖÆÆ÷Öв¥·Å¡£
Õâ¸ö»ìƵÆ÷Ò³ÃæÔÊÐíÄãµ÷ÕûÒôÁ¿ºÍÆ½ÒÆËùÓÐͨµÀ£¬ÒÔ¼°Ìí¼ÓFX¡£ÐòÁÐÓÐ14¸ö²»Í¬µÄFX£¬¿ÉÒÔ·Ö±ðÓ¦Óõ½Ã¿¸öƵµÀ»òÖ÷Êä³ö¡£´ËÍ⣬»¹¶Ôÿ¸öͨµÀµÄ¼ÓÔØÊ¾Àý½øÐÐÁ˱༿ØÖÆ¡£¹ö¶¯´´½¨Õß¿ÉÒÔʹÓÃÐòÁÐÖеÄÈκÎʾÀýÀ´´´½¨¸´ÔӺͿìËÙµÄģʽ¡£ºÜÄÑÖ´ÐеĹÄÐÎģʽºÍ³ÌÐò£¬Ê¹ÓÃÕâÒ»½ÚµÄ˳ÐòºÜ¼òµ¥¡£²Ëµ¥Ò³ÃæÔÊÐíÄã¿ìËÙÔ¤ÀÀÈκγ¬¹ý4000¸ö¹öͲÑù±¾Ê¹ÓÃÁùÊ®¶þÖÖ²»Í¬µÄ¹ÄµÄÉùÒô¡£Ò»µ©ÄãÕÒµ½ÁËÒ»¸öÄãÏëҪʹÓõÄÑù±¾£¬Ëü¿ÉÒÔÁ¢¼´Ó¦Óõ½ÈκÎÒ»¸ö12¸öÒôÐòÆ÷ͨµÀ»ò¹ö×àµÄ´´ÔìÕß¡£
ÔÎÄ
Big Fish Audio is proud to present Sequence: Hip Hop Beat Creator, a powerful and effective sequencer with built-in 808 basses and a drum roll creator. Sequence sets a new standard for modern sequencers, going beyond the norm and providing real tools for real producers at a real value. With over 4,000 drum samples, 32 unique 808 basses, and a roll creator that puts Trap-style hi-hat and snare rolls at your fingertips, the search for beat, bass and rhythm is over.
This twelve channel sequencer offers up to twelve beat variations using the ¡°Scenes¡± buttons and corresponding (green) MIDI notes for playback. You can turn a sample on or off for up to 64 steps in your sequence, and unlike other sequencers, each step of the sequence has controls to adjust volume, pitch, pan, and sample length, allowing for incredibly unique and expressive drum parts. In addition, every sample loaded into your sequencer can also be played as one shots from your midi controller.
The Mixer page allows you to adjust volume and pan for all channels as well as add FX. Sequence comes with fourteen different FX that can be applied to each channel individually or to the master output. In addition, there are Sample Edit controls for shaping each channel¡¯s loaded sample. The Roll Creator can use any sample from Sequence to create complex and fast patterns. Drum patterns that are difficult to perform and program are made simple using this section of Sequence. The Menus page allows you to quickly preview any of over 4,000 drum samples using the sixty-two different banks of drum sounds. Once you find a sample you want to use, it can be instantly applied to any of the twelve sequencer channels or the Roll Creator.
Big Fish Audio Sequence Hip Hop Beat Creator KONTAKT | 753 Mb
Big Fish Audio Sequence Hip Hop Beat Creator |
