! H# s `8 O3 ~9 E2 h `¼¼ÊõÖ¸±ê
; }$ i0 j; i$ K4 I1 b3 s& a0 n8 w8 F5 i$ g
Ä£ÄâÊäÈë
R, D# P" s2 v. R0 m6 f A9 w! b' ?1 O! D
XLR
9 r0 j! e2 D( h! Q, q; E! R1 Z; ^7 ~) A# J/ ]9 u
? ÊäÈë: XLR£¬ËÅ·þƽºâ
7 m4 h, q) O% q4 Q9 s$ R, j1 K* Q" Y2 j) d4 G2 x; D
? ÊäÈëÁéÃô¶È¿ÉÑ¡+24 dBu, +19 dBu, +13 dBu, +4 dBu @ 0 dBFS
' ~8 _. O. L7 D+ w7 G
' Y/ }# [/ l5 y9 Q? ÐÅÔë±È(SNR) @ +13/19/24 dBu: 120.x dB RMS δ¼ÓȨ, 124.x dBA1 \- ?2 R% E& G( a3 J1 q
/ m0 v F5 b" d0 x& j
? ÐÅÔë±È(SNR) @ +4 dBu: 119 dB RMS δ¼ÓȨ, 123 dBA
( N/ j8 S2 N% g: [6 _: ^' O
; | A0 z1 ~& p$ E3 i. t. b? ƵÂÊÏìÓ¦ @ 44.1 kHz, -0.1 dB: 5 Hz ¨C 20.5 kHz* Q7 O% V$ ] }+ q7 M5 K
; {3 c, }, q! `
? ƵÂÊÏìÓ¦@ 96 kHz, -0.5 dB: 3 Hz ¨C 45.5 kHz# F) f. h5 y' `
) M+ H3 r; b/ R4 X
? ƵÂÊÏìÓ¦@ 192 kHz, -1 dB: 2 Hz ¨C 92.7 kHz8 a6 I7 |& E9 a! c& F
0 Q3 [0 o1 _; N. k9 m7 `6 m' g+ ^
? ƵÂÊÏìÓ¦@ 384 kHz, -1 dB:<1 Hz ¨C 124 kHz0 ~ R; v; V" O% H
0 q) T, K4 G0 Y) ^8 z: ?? ƵÂÊÏìÓ¦@ 768 kHz, -3 dB:<1 Hz ¨C 180 kHz6 u& [* j8 p s. X4 F
" J% M5 p4 j( e8 Q( j7 |7 l T? THD @ -1 dBFS: -116 dB, 0.00016 %
* n% @5 R3 v5 s) Y1 f/ _+ I' Q% t' n. ]& {2 d' L6 {% {9 ^8 Q+ W" b4 o3 G
? THD+N @ -1 dBFS: -112 dB, 0.00025 %
7 q5 g$ a/ Y/ s) c4 M; x
# P) t: V; {2 O, S% Y5 f5 F6 Z? ͨµÀ¸ôÀë > 110 dB
5 j9 r( f) g4 C
/ Q1 M& x9 H# x0 j. K& X. c; ~+ s, `- E' F4 M5 }$ o: c
+ A6 E+ s* H5 x5 L$ DTRS
5 D7 O0 Z9 M9 e. h) p/ J) }, T- d" w; ]. m; W" T- h- p7 z4 M
ÓëXLRÊäÈëÒ»Ñù£¬µ«ÊÇ:( A( I- U5 B; U) y" F0 K7 \% m
0 }4 g h+ q# \2 ^! R' Y
? ÊäÈë: 6.3 mm TRS½Ó¿Ú, ËÅ·þƽºâ£¬ÍêÈ«¼æÈÝTSºÍRCA+ a( A! M1 _5 u/ Y5 \2 w
/ V# X4 d( E# z* L; `5 ^/ i. L0 X
( J( j4 c, B- v2 p+ L- ?9 |7 A. K7 Y: k1 n# ^% p# ]( }
Ä£ÄâÊä³ö
3 u; f. r: S/ l" [( B" R
9 D5 U6 j# b5 {# D1/2 XLR
m {3 C* B5 U2 `$ ^% D" ^/ P
8 C- o( c( r0 s) E$ h. n1 V? Êä³öµçƽ¿É±ä +24 dBu, +19 dBu, +13 dBu, +4 dBu @ 0 dBFS
" t9 |! p% n5 `# @: ~- X5 v
0 ]* j, @% H; @9 ]0 A5 @& n: u?ÐÅÔë±È(SNR) @ +13/19/24 dBu: 117 dB RMSδ¼ÓȨ, 120 dBA
C4 G* c" t1 A" X$ N$ ?/ l0 {4 r- j, m
? ÐÅÔë±È(SNR) @ +4 dBu: 115 dB RMSδ¼ÓȨ, 118 dBA' v, @4 H% E" Q- R$ K5 o
# H, W% y3 A/ L: Z$ |: O
? ƵÂÊÏìÓ¦ @ 44.1 kHz, -0.1 dB: 0 Hz ¨C 20.2 kHz
+ o% r7 \6 u- I& |5 Y. h* l O# g1 D* E J) X9 y1 W c
? ƵÂÊÏìÓ¦ @ 96 kHz, -0.5 dB: 0 Hz ¨C 44.9 kHz2 V. a# w! U* ?3 _5 `
0 o @* k% j- M
? ƵÂÊÏìÓ¦ @ 192 kHz, -1 dB: 0 Hz ¨C 88 kHz
" Y+ ^9 T5 Y( u* Z% C; m' c' }7 V$ l& d1 q& w1 \7 J+ I$ g
? ƵÂÊÏìÓ¦ @ 384 kHz, -1 dB: 0 Hz ¨C 115 kHz
" R y8 j$ y) o/ _) K! p4 z" C4 S+ J
1 ~( B+ P+ B' X' Z$ E? ƵÂÊÏìÓ¦ @ 768 kHz, -3 dB: 0 Hz ¨C 109 kHz
+ x( ^4 l+ ~5 r0 ]- D( Q5 C3 q5 @7 o9 Y) c2 R. J
?THD @ -1 dBFS: -112 dB, 0.00025 %
* r( y; |( {! x/ {! L$ @! Y4 |9 a K
6 J7 c- f# s% h, Q. A6 h?THD+N @ -1 dBFS: -110 dB, 0.00032 %# N6 X! e9 P$ S& Y
% A: V+ M4 K5 }/ a" ]; p! z6 y7 g? THD @ -3 dBFS: -116 dB, 0.00016 %
|; `$ i5 r# h
: n# Y G0 ]' X7 s( O2 o? ͨµÀ¸ôÀë: > 110 dB; K& @0 `* [& v
" m" f; f: A3 P' _
? Êä³ö×迹: 200 Ohmƽºâ, 100 Ohm·Çƽºâ
. I- \8 {- D" ^
x1 Y; x" n6 r7 V, s- u1 d3 z; m. m# f/ b. k& R" v
: H/ x# j8 J. Y( B' D
1/2 TS (ºóÃæ°å)" b6 I; h+ k" H& N' N! V
6 F; r; H- s0 {0 c
ÓëXLRÊä³öÒ»Ñù£¬µ«ÊÇ:: G" y5 W* N4 ?7 J5 u
2 @: t/ n/ E- {& K1 z8 h
? Êä³ö: 6.3 mm TS½Ó¿Ú, ·Çƽºâ7 t' {! y/ u& |8 u/ M* s$ O
) b. V8 u! T0 J? Êä³öµçƽ: +19 dBu0 H2 P- Y* N6 _! [/ i5 Z* L
: I& H s; t0 e) L5 ~& F? ÐÅÔë±È(SNR) @ +13/+19 dBu: 117 dB RMS δ¼ÓȨ, 120 dBA$ v$ Z; x% W4 F# y
" b, I% R7 H5 M. ?3 b
? ÐÅÔë±È(SNR) @ +4 dBu: 113 dB RMSδ¼ÓȨ, 117 dBA
2 X+ ^* ~' O1 A1 A" }
e. S4 u% n$ U? Êä³ö×迹: 100 Ohm
( t3 L/ d( A N2 C. b: l+ W2 q
/ p% }; }2 i" ]9 R: k7 t. a/ m+ ]/ ~8 \' s% V+ k3 N' h
6 c0 l2 }7 [1 ^0 {3 \ MPhones 1/2
' p/ r; P; O4 N- T! l; i) B0 i* m
8 y5 @1 H% D0 n. @' ~# lÓëTSµÄÊä³ö1/2Ò»Ñù£¬µ«ÊÇ:. L4 Z: B9 Q0 b4 Y
7 V S" h! ]& `! m2 `) V4 D; b) U? Êä³ö: 6.3 mm TRS½Ó¿Ú, ƽºâ, Á¢ÌåÉù
5 ?! J. T, v# S: r5 \. ?3 x. Z
% V% M2 t2 s @! C( j& e? Êä³ö×迹: 0.1 Ohm
0 Z7 c2 M6 n, ?/ T5 Y7 k7 l
' K+ w9 c8 D/ q" V. v? ÐÅÔë±È(SNR) @ +22 dBu: 117 dB RMSδ¼ÓȨ, 120 dBA/ g5 n( Q; e# P8 O% K' C) U) j
! P9 d0 s4 t$ M: }' R" ?4 i& j
? ÐÅÔë±È(SNR) @ +7 dBu: 114 dB RMSδ¼ÓȨ, 118 dBA
6 n% @ e5 Y% ^2 ~8 R- x
1 Z8 `3 @! X) E3 k0 Y+ a? Êä³öµçƽ@0 dBFS, Ref Level +19 dBu, ¸ºÔØ100 Ohm ¼°ÒÔÉÏ: +22 dBu (10 V)
" h: ?/ A9 w/ R. v. s
+ _- t/ `9 c+ m3 o& G? Êä³öµçƽ@0 dBFS, Ref Level +4 dBu, ¸ºÔØ8 Ohm¼°ÒÔÉÏ: +7 dBu (1.73 V)
0 I2 x/ E# u1 M7 E+ S) t/ g! V* X" p: S7 Y2 d
? THD @ +18 dBu, 32 Ohm¸ºÔØ, 1.2 Watt: -110 dB, 0.0003 %
" {. ~( m* L0 F9 ?8 u) R3 O& S) r, U% G# b' a
? THD+N @ + 18 dBu, 32 Ohm¸ºÔØ: -107 dB, 0.00045 %. c8 {: b7 \2 X8 V, f( n
. m0 R' e/ ~5 s- R7 b2 |2 L/ D- v
? THD @ +14 dBu, 16 Ohm¸ºÔØ, 0.94 Watt: -110 dB
( U7 {/ U; I8 O' j R0 \) k, X" K6 L, h1 t/ ~
7 X& e# H- [: H) S+ `; C! l
$ n/ M& r# Y6 [7 |' f Q
Phones 3/4% L6 D* S0 E8 |' c0 F3 P$ L# B( G8 s% E
) r$ L$ ^4 z7 y
Óë¶ú»úÊä³ö1/2Ò»Ñù£¬µ«ÊÇ:" o( a/ a6 `% `, o
8 c8 E2 {6 v$ Q; j/ q? Êä³öµçƽ@ 0 dBFS: ¹Ø±Õ´ó¹¦ÂÊ+7 dBu, ¿ªÆô´ó¹¦ÂÊ+22 dBu' c- _ J9 U7 b2 S5 K" X+ m7 }" l6 [
* A. @# i2 Z* e8 C4 s3 B5 n
7 V/ T( l H: d3 ^( ?6 o
5 {5 i; m, F+ m$ X6 d. t
ƽºâµÄ¶ú»úģʽ
- C1 P6 I. B, d* ^; J" u
* j4 S0 z: O% V' wÓëÒÔÍùÒ»Ñù£¬µ«ÊÇ::
" q6 I3 O9 L @8 M
0 l1 u e# ~( j& h0 p? Êä³öµçƽ@ 0 dBFS: ¹Ø±Õ´ó¹¦ÂÊ+13 dBu (9.8 V), ¿ªÆô´ó¹¦ÂÊ+28 dBu (19.5 V)
, |1 ^9 A W2 a: H4 ~- H/ `4 _' h. z( g) x+ o3 W
? Êä³ö×迹: 0.2 Ohm
1 b$ g4 @! z/ e: v9 G y) U7 k7 M5 s; s+ g
? ÐÅÔë±È (SNR) @ +28 dBu: 120 dB RMSδ¼ÓȨ, 123 dBA
# y3 L" w* l) H7 q. L) @3 z3 M; h- M; q7 T! H6 G% ~- ?$ {9 [
? ÐÅÔë±È (SNR) @ +13 dBu: 118.4 dB RMSδ¼ÓȨ, 122 dBA# [1 z5 j9 ~9 o1 L; O0 g
( M( R% N7 u& ] Z/ }; \8 X? Êä³öµçƽ@ 0 dBFS, ¿ªÆô´ó¹¦ÂÊ, ¸ºÔØ150 Ohm¼°ÒÔÉÏ: +28 dBu (19.5 V)
z8 q Z; \* H* X3 d' n1 F" [9 M- ^) ~* O8 K! j4 [2 j
? Êä³öµçƽ@ 0 dBFS, ¹Ø±Õ´ó¹¦ÂÊ, ¸ºÔØ8 Ohm¼°ÒÔÉÏ: +13 dBu (9.8 V)1 G" H$ B3 @- u: N% T. A. y( D
' _3 a- H* Z* [+ i
? ¹¦ÂÊ@ 0.001% THD: 2.9 WÿͨµÀ _. `" v5 `* |4 R
0 H: U8 c* b5 I+ p- N# K( j. H
! Q% p7 l$ c* e% E& p. t! h7 Q* l7 h; X8 n9 a' |5 f
Êý×ÖÊäÈë1 Q- Z& v; n$ Z4 P
. a; ]+ P" p: h9 D1 M
ͨÓÃ
/ f& s7 D; L2 n% w+ i' A# D6 X) @9 l5 I
? Ëø¶¨·¶Î§: 28 kHz ¨C 200 kHz" @7 R$ \3 G0 M: S& o9 S
9 S& C- i' c1 Y( d0 d% f5 A? ¶¶¶¯ÒÖÖÆ: > 50 dB (2.4 kHz)' Q) Z& h ?0 ?$ \7 a3 s( Z
) \" ?, \% C" m$ ~. _% L* h+ l/ @+ ^, L
0 P6 R; b+ J/ P9 E( ^AES/EBU' M! T5 r# P8 \1 ]% y/ s. V; k
6 h* f% ]1 {! w1 s! z? 1 x XLR, ƽºâ±äѹ, µçλ¸ôÀë, ·ûºÏAES3-1992# q4 q, z' n; p' ~9 q7 Q
2 U) i! M5 u3 T/ n! B4 u? ¼æÈÝSPDIF(IEC 60958)' u% ^% A* e6 y
# X7 R3 F! x6 x5 `+ y* K. d
Y' h2 V \7 {2 V9 d% }% `* Q' Q6 p/ r
SPDIFͬÖá1 q, @$ M+ H2 I
4 c7 a, }* k: _) Z: K1 b* M& T% _? 1 x RCA, ƽºâ±äѹ, ·ûºÏIEC 609586 n1 K$ s# w/ @. s- @
! T8 \) u2 z7 `9 x
? ¼æÈÝAES/EBU (AES3-1992)
: `$ T, _: J8 q, U5 J6 W4 B. D- c( @. a# d% k! }$ a( j. y- L
( h; b5 J0 a, d9 f# _
/ P, J. L: @# ^: U/ W8 n6 }SPDIF¹âÏË% ?% q W; Z) y% h' z
* Y/ x/ O8 p7 u# W5 g
? 1 x¹âÏË, ·ûºÏIEC 60958
% ~( f. l3 i) F F# W0 _" k' ?! W1 S6 u6 r. V
? ¼æÈÝADAT" X6 h6 d; ^/ s1 z* N
1 u( A5 r$ l9 b" |# {* k
, E6 f1 v9 q+ p5 L: G1 q! F2 e, C7 [
Êý×ÖÊä³ö( Y. u* }! X! \& b+ p
2 k% O6 m4 Q3 e$ K; s
AES/EBU
$ n3 L6 o) T( v: `/ s& G$ @) l! f B4 [: P
? 1 x XLR, ƽºâ±äѹ, µçλ¸ôÀë, ·ûºÏ AES3-19923 W" R, e' m9 p
$ d1 x6 C/ v7 q0 s l5 _, h? µ¥Ïßģʽ, ²ÉÑùÂÊ 28 kHz ~ 200 kHz1 N |% Q4 G+ ]# D5 w
2 P, I7 K# r! P3 ~& v( v. o) E4 S* E: ? H: q
- F5 ]6 W* |% Y+ _9 N4 ]" k
SPDIFͬÖá
+ N8 v; B3 b' D% j2 T/ g- @- k' t! h+ d
? 1 x RCA, ·ûºÏ IEC 60958* X0 a3 R7 _$ k( G* D9 H
* ^. o+ }2 p2 l" ?
? µ¥Ïßģʽ, ²ÉÑùÂÊ28 kHz ~ 200 kHz! j d/ d- x( n% {7 N
: S. s+ u) V$ b8 J1 M) ?: [: c4 ~* \0 s( q ?6 B7 f/ H
& Q* Y5 R* I4 l8 H. L
SPDIF¹âÏË) e6 i5 f. Y/ ]% c* X, [( o
4 v2 b0 A; c, d% `' Z o? 1 x optical, ·ûºÏ IEC 60958
4 h v/ l( r# Z" n: r* m' X B
5 ~$ P) D, M; s0 p: ?- ~: \? ²ÉÑùÂÊ28 kHz ~ 200 kHz3 d- j1 b, \1 T9 e
7 E% t" T3 n, @- l" A! r Z p% `
& }! |0 Z0 Y! Q4 x+ n- r4 B
( {7 B, Z" H( h0 K. Z- }5 K
Êý×Ö- p/ F3 K. }; y4 {
: y; R" P: d/ \" P7 ~
? ʱÖÓ: ÄÚ²¿¡¢AES¡¢SPDIF¡¢ADATÊäÈë, G0 p, X* C0 z* G
6 u4 Z# ~5 o3 l1 W
? ÍⲿʱÖӵͶ¶¯ÒÖÖÆ£º>50 dB£¨2.4kHz£©
# y* R2 V9 P) }8 `: A2 W" ]4 m0 v7 W/ n0 _+ u' B' H: Q( g
? ÍⲿʱÖÓÖ§³ÖµÄ²ÉÑùÂÊ: 28 kHz ~ 200 kHz( e) `# g9 T+ G( g* i
, C0 b0 w2 t* ?0 p) k? ÄÚ²¿Ê±ÖÓÖ§³ÖµÄ²ÉÑùÂÊ: 44.1 kHz ~ 768 kHz
/ k, u3 N @2 z' L6 N- J+ {
) a' D l, s3 u: [2 t7 ]' u( N# V3 M' k/ c+ {1 G) d
1 Y9 N0 d& r0 b. }5 y( z( T2 IͨÓÃ( q" P' Y6 W. I- M
4 g1 ^5 G x. t; y( B? °üÀ¨µçÔ´: ÍⲿPSU, 100 - 240 V AC, 2 A, 24 Watts/ s0 H* R, N0 ^
+ p' n: v! e& T0 x |# T% w8 `3 K? ´ý»ú¹¦ºÄ: 50 mW5 @' z T6 _0 B. u4 s: ]& s2 C
1 t1 U# Q q* a0 w/ C+ R; |; y
? ÀíÏ빦ºÄ: 10 Watts,¹¦ºÄ: 22 Watts% i7 o0 a1 ^1 R8 U, n0 V1 K# v
* G4 \5 i' m) k? ÀíÏëµçÁ÷@12 V: 850 mA (10 Watts)
1 z! L6 x/ ? L! r4 @' I% M- O5 s: {. a! \) g
? ³ß´ç (WxHxD): 215 x 44 x 130 mm (8.5" x 1.73" x 5.1")
& d* C. V% K8 Q' f5 u& z/ k( S8 w! F* H$ O
