Pendulum Audio MDP-1˫ͨµÀÕæ¿Õµç×ӹܻ°·Å
É豸
Pendulum Audio MDP-1˫ͨµÀÕæ¿Õµç×ӹܻ°·Å/DI ÌØÕ÷ÃèÊö£º
ËùÓеĹÜ,¶ÌÐźÅ·¾¶Éè¼Æ
´¿,¸ßѹµç·
ÎÞ±äѹÆ÷µÄ¹ÜÊä³ö¼¶Ìṩ+ 35 dbuµÄÄÜÁ¦
ÔëÒôµÍ¡¢¿íµÄ´ø¿íºÍÓÅÔ½µÄ˲̬ÏìÓ¦
Âó¿Ë·çÊäÈë±äѹÆ÷µÄÑ¡Ôñ¡°È«²¿¡±»ò¡°¼¯ÖС±µÄÉùÒô
30·Ö±´ÔöÒæ·¶Î§ÔÚ3 dbµÄ²½Öè
ÍêÈ«Óë100 kÎÞ±äѹÆ÷µÄDI,1Ã׺Í10Ã×µÄÊäÈë×迹
Ê®¸öλÖÃÂó¿Ë·çlo-cut¹ýÂËÆ÷(20 - 180ºÕ×È)
¶Æ½ð¿ª¹Ø½Ó´¥,ºÍ¹ÜÌ×½Ó×ÖI / OÁ¬½ÓÆ÷
¾Û±ûϩñºÍ½ðÊô±¡Ä¤µç×è(˫ƥÅä0.1%)
È«Ãæ¼à¹Ü¸ßµçѹ(300 v)ºÍµÆË¿µçÔ´ÈíÆô¶¯ÈÈÉíºÍ¾²Òô
¶¨ÖƵĻ·ÐεçÁ¦±äѹÆ÷Óë¶ÜµÄÎËÎËÉù
¼¼Êõ²ÎÊý£º
µç·ÀàÐÍ: AÀàÕæ¿Õµç×Ó¹ÜÐźÅ·¾¶Í¨µÀÓëÎÞ±äѹÆ÷µÄÊä³ö
ÊäÈëÔöÒæ: +33 to +63dB ÿ¿Ì¶È3dB µÝ½ø
ÊäÈë×迹: 1500 ohm, ±äѹÆ÷ƽºâºÍ¸¡¶¯
ƵÂÊÏìÓ¦: -1.0dB 6Hz and 65kHz with 10Kohm¸ºÔØ, +45dBÔöÒæ
ÔëÉù:  ÔÚ150 ohm ¸ºÔØÊäÈëÇé¿öÏ£¬EIN £¼-125dBu , δ¼ÓȨ(Jensen 13K7)
ÔÚ150 ohm ¸ºÔØÊäÈëÇé¿öÏ£¬EIN £¼-118dBu , δ¼ÓȨ (Custom)
Ê§Õæ:   ×Üг²¨Ê§Õæ+ÔëÉùTHD+N£¼ 0.03% ´Ó100Hz-10kHz, СÓÚ0.07% ÔÚ20Hz, measured with -20dBuÊäÈë, +10dBu Êä³ö, +45dB ÔöÒæ
DI ·Å´óÆ÷
ÊäÈëÔöÒæ: +20 to +50dB (ÀÖÆ÷), 0 to +20dB (Ïß·) £¬Ã¿²½3dB
ÊäÈë×迹: 10Mohm or 1Mohm (ÀÖÆ÷), 100Kohm with 20dB pad (Ïß·)
ƵÂÊÏìÓ¦: -1.0dB 5Hz and 250kHz with 10K¸ºÔØ, +20dB ÔöÒæ
ÔëÉù: EIN СÓÚ -116dBu with input shorted, δ¼ÓȨ
Ê§Õæ: THD+N СÓÚ 0.04% ´Ó 20Hz-10kHz
            ²âÁ¿ with +10dBu Êä³ö£¬ +40dB ÔöÒæ
Êä³öµçƽ: +35dBu into 10Kohm ¸ºÔØ, +25dBu into 600 ohm ¸ºÔØ£¬ Êä³ö¿ØÖÆ
µçƽ±í:Ìṩ¿ÉÑ¡ÔñµÄ Êä³öµçƽ (0VU = +4dBu) »òÕßµç×Ó¹ÜÔöÒæ (0VU = +20dBu)
»ÃÏóµçÔ´:+48Vdc applied to pins 2 and 3
»°Í² Pad: -20dB pad Ö÷ÒªµÄÂó¿Ë·çÊäÈë±äѹÆ÷
»°Í²Ïàλ: ·´×ªÏศÖúµÄÂó¿Ë·çÊäÈë±äѹÆ÷
»°Í²µÍÇÐ: 6 dB/octave ¹ö¶¯ ´Ó20-180Hz Ϊ10 ÿ²½
¼«ÐÔ: ÊäÈëºÍÊä³ö XLR Á¬½ÓÍ·ÊÇ pin 2 hot
Õæ¿Õµç×Ó¹Ü: (2) ECC83/12AX7A, (2) 6922
µçÔ´: 120Vac, 30W (240Vac optional)
µçѹ¹©Ó¦: +300Vdc and +12.6Vdc, fully regulated with soft-start warm-up
¹æ¸ñ³ß´ç: 2U enclosure, 19" x 3.5" x 12.5" (48.2 x 8.8 x 31.8 cm)
ÖØÁ¿: 14lbs (6.4kg)
×¢ÊÍ: 0 dBu = 0.775 Vrms
ËùÓÐÔëÉù²âÁ¿ÊÇδ¼ÓȨµÄ, 20 - 20,000 Hz ´ø¿í
ËùÓйæ¸ñÈçÓбä¸ü,ÁíÐÐ֪ͨ¡£
¸ÅÊö£º
MDP-1ÊÇÒÔÁ½¸öͨµÀµÄÕæ¿Õµç×Ó¹ÜÂó¿Ë·ç/ DIǰÖ÷ŴóÆ÷Éè¼ÆÎª×îÖյķ½Ê½ÈÃÄãµÄÂó¿Ë·ç»òÉùÒôÀ´Ô´Ö±½Óµ½´Å´ø»òÓ²ÅÌ¡£²»Í¬Äê·Ý»ò»ìºÏÉè¼Æ,MDP-1ʹÓô¿µç×Ó¹ÜAÀà¸ßѹµçÂ·ÍØÆËÓëÎÞ±äѹÆ÷µÄÊä³ö¼¶Ìṩһ¸ö¿ª·ÅµÄ¡¢Ç×ÃܵÄÉùÒôÓëϸ½Ú²ã´Î,Âú×ã×î¿Á¿ÌµÄÒªÇó¼Ç¼µÄÓ¦ÓóÌÐò¡£ÎÒÃǶÌÐźÅͨ·Éè¼ÆÉó¤ÒôƵÐÔÄÜ,Ìṩ¼«¿íµÄ´ø¿í,µÍÔëÒô,¸ß¿Õ¼ä¡£
Ò»¸ö¹Ø¼ü×é³É²¿·ÖµÄÉùÒô¹ÜÂó¿Ë·çǰÖ÷ŴóÆ÷ÊäÈë±äѹÆ÷¡£ÔÚÕâÀï,ÎÒÃÇÈÃÄãÑ¡ÔñÄúÏëÉùÒôµÄǰÖ÷ŴóÆ÷¡£MDP-1¿ÉÒÔ¶©¹ºÓëÄãËùÑ¡ÔñµÄÁ½¸öµÍת»»±È±äѹÆ÷¸ù¾ÝÄúµÄÒªÇó:Jensen 13K7A ÌṩÁËÈ«²¿,¿ª·ÅµÄÉùÒô,ÓÐÐí¶àÉÁÉÁ·¢¹âµÄ¸ß¶ËºÍµÍ¶ËÉî´¦¡ª¡ªÍêÃÀµÄ¼Ç¼ËùÓÐÀ´Ô´,ÓÈÆäÊÇÆ÷ÀÖ;»òcustom-wound±äѹÆ÷¸ü¼¯ÖеÄÉùÒô,¶îÍâµÄ´æÔÚ,ÇåÎúÔÚÖеµ-ÀíÏëµÄÉùÒôÌýÆðÀ´ºÜÈÝÒ×Çø·Ö±¾ÉíÔÚÒ»¸ö»ìºÏ¡£
MDP-1Ò²ÓÐËùÓÐÄãÏëÒªµÄ¶«Î÷ÔÚÒ»¸öÈ«¹¦ÄܵÄÂó¿Ë·çǰÖ÷ŴóÆ÷,»ÃÏóµçÔ´,·´Ïà,-20·Ö±´ÊäÈëPAD,µÍÇÐÂ˲¨Æ÷ÓÐ10hzºÍÖµ,VU±íÕÕÃ÷½á¹¹¡£
DIÐźÅ·¾¶ÊÇÍêÈ«ÎÞ±äѹÆ÷µÄ,Ñ¡ÔñÈý¸öÊäÈë¸ºÔØ×迹:ѹµçÉùѧÒÇÆ÷Ƥ¿¨10M,Ϊ´ÅƤ¿¨1M,Óë20 dbPAD100 kÏß·µçƽÈç¼üÅÌ»òÆäËû-10dBVÉ豸À´Ô´¡£
ÆÀÂÛÁÐ±í£¨1£©
lurssen Â¥Ö÷
:handshake
2008-5-28 10:58:14 »Ø¸´
