查看: 23237|回复: 2
[转帖] Antelope Audio Satori 监听/Summing控制器
6万
音频应用高级会员
Rank: 7Rank: 7Rank: 7
发表于 2008-4-26 21:32:58 | 显示全部楼层 |阅读模式
Antelope Audio Satori 监听/Summing控制器8 Z& `; K& q: {, s
8 l3 N& j) K8 X  b& O
  D8 O5 M) E# \  `1 f* T1 R* f
* o' m# n( l, \6 g9 @3 @THE FINE ART OF SUMMING AND MONITORING1 p2 X, N, a% d% @. c
Antelope Audio has once again set about advancing their own creation, expanding on the immensely popular and award winning Eclipse 384 to create the brand new Satori High-End Monitoring Controller. Utilizing Antelope’s impressive relay-controlled stepped attenuator, analog circuitry and unique connectivity options, the Satori is the perfect tool for preserving pristine audio and making the subtleties of your recordings more noticeable.
; [" z' `' R' T2 _* m+ ~; r
' A2 o" g7 L: S 5 T9 |# @1 Z8 D1 t) O* g* ~8 {- [
$ b/ b" l$ u3 ?5 g! i: B$ a3 j  f7 k- B
FORM FOLLOWS FUNCTIONALITY
4 Y# B% Y3 A. R6 U) X6 F7 OOutfitted with an analog 8-channel summing mixer, the Satori allows for age old mixing techniques to be used, in addition to receiving the glorious benefits of an all-analog sound. While this technology remains the same as classic analog consoles, Antelope Audio has given users the ability to run the system via their new software control panel. By using digital to control analog, sound engineers will have a seamless workflow at their disposal with completely accurate and flexible controls at all times.
* t* P9 y8 Y- W! K9 T- p
. Y6 ~3 y+ K, p/ R4 m0 P 3_695_56640_800_534.jpg , J/ I* Q1 E( Z) H  `' z8 \/ i/ }
9 y" x4 ]% O2 u3 Q
AN IMPRESSIVE RANGE OF DETAILS
2 [" }/ ^, N% UThe level of thought and detail put into Satori’s makeup surpasses many like-minded products. The headphone setup features four individual amps (capable of driving low and high impedance headphones), that makes it extremely easy to let multiple musicians hear playback at the same exact time. In terms of connectivity, the Satori has a whole host of options ranging from the eight stereo inputs and four stereo outputs to XLR, D-Sub 25 and ?” TRS connections.
3 o  [, \& Y3 R- y/ M$ h0 K/ R
/ D0 g5 Y! q6 N; N$ y! {: i' t 7 J( n" I. n  ~% Q' x
' R2 U6 [! j- D) `* ]1 b1 bSLEEK CONTROL AND LOOK$ k9 \8 B" N# N+ I6 W
With an extremely refined front panel control, the Antelope Audio Satori simplifies the summing and monitoring process with a simple button scheme and easy-to-use controls. The device’s large buttons and large volume knob make operating the Satori a dream.
1万
发表于 2008-4-26 21:50:03 | 显示全部楼层
:victory: :victory: :victory:
4万
音频应用中级会员
Rank: 5Rank: 5Rank: 5
发表于 2008-4-26 23:18:09 | 显示全部楼层
Antelope Audio Satori 监听/Summing控制器!:victory: :victory:
GMT+8, 2025-6-7 02:42 , Processed in 0.031509 second(s), 8 queries , Redis On.
