Hideaway Studio Synergenesis KONTAKT
ÒÔ¼°ÒÇÆ÷µÄÖ÷ÌåSynergenesis¾ßÓг¬¹ý220¸ö´ò»÷ÀÖÑù±¾£¬²¶»ñÁË¿É×·Ëݵ½20ÊÀ¼Í80Äê´ú³õµÄԭʼ¹¤³§ÒÇÆ÷¿âÖÐÌØÕ÷µÄ´ó²¿·Ö¹ÄƬ¡£ËüÃDZ»³ÊÏÖΪÁ½¸öÖ÷ÒªµÄ¹ÄÌ×¼þºÍһϵÁÐÖ÷ÒªÖ¼ÔÚÔÊÐíÓû§Ô¤ÀÀËüÃDz¢ÔÚÑ¡ÔñµÄÉùÒôÉÏʵÑé¹ýÂ˺Ͷ¯Ì¬²âÊÔ¡£Èç¹ûÐèÒª£¬¿ÉÒÔͨ¹ý¶à¸öMIDIͨµÀÒÔÕâÖÖ·½Ê½Ê¹Óöà¸öÒÇÆ÷¡£¸üÓм¼ÊõÒâÒåµÄÓû§¿ÉÒÔ¸ù¾ÝÏ£ÍûÔÚKontaktÖØÐÂÓ³Éä¹Ä×é¡£
WAVÑùÆ·
´ËͼÊé¹ÝÖеĹÄÉùÒ²ÒÔ.wav¸ñʽÏÔʾ¡£
³ýÁËԭʼµÄ24λÑù±¾Ö®Í⣬´ò»÷ÀÖÒ²ÔÚÆä¸÷×ÔµÄÎļþ¼ÐÖÐÒÔ16ºÍ8λ¸ñʽ£¨È«²¿Îª44.1KHz²ÉÑùÂÊ£©³ÊÏÖ£¬ÓÃÓڹ㷺µÄ»ùÓÚÈí¼þµÄÑù±¾²¥·ÅÆ÷ºÍÓ¦ÓóÌÐò£¬ÒÔ¼°Ó²¼þ²ÉÑùÆ÷ÊýÁ¿ÈçMPCϵÁС£
ϵͳҪÇó£º
¸Ã¿âÐèÒªÍêÕû°æ±¾µÄKontakt 4.2.4»ò¸ü¸ß°æ±¾¡£
Ô­ÎÄ
As well as the main body of instruments Synergenesis features over 220 percussive samples capturing a significant proportion of the drum patches featured in the original factory instrument library which dates back to the early 1980s. They have been presented as two main drum kits and as a series of sets primarily intended to permit the user to preview them and experiment with filtering and dynamics on select sounds. Multiple instruments can then be used in this manner over a number of midi channels if required. More technically minded users can remap the drum sets as they wish in Kontakt.
WAV Samples
The drum sounds in this library are also presented in .wav format.
As well as the original 24-bit samples the percussion is also presented in 16 and 8-bit formats (all at 44.1KHz sample rate) in their respective folders for use on a wide range of software based sample players and applications as well as a number of hardware samplers such as the MPC series.
System Requirements:
This library requires the full version of Kontakt 4.2.4 or higher.
Hideaway Studio Synergenesis KONTAKT | 875 MB
ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨1£©
:handshake :handshake  Hideaway Studio Synergenesis KONTAKT
2008-4-25 00:32:58 »Ø¸´
