Dynaudio BM14S II ÓÐÔ´µÍÒô¼àÌýÒôÏä
The Perfect Match for Your BM MkIII Monitors!
Designed to compliment BM mkIII series monitors, the Dynaudio BM14S II active subwoofer adds extended bass in mid-sized mixing and recording environments. After all, even if your monitors deliver ample bass, sometimes you still need more low-end to ensure an accurate mix. Employing a handcrafted 12" driver and a closed-cabinet design, the BM14S II will bring rock-solid bass response to your monitoring system. At Sweetwater, we understand that your monitoring chain is the most important part of your studio. After all, if you can&££39;t hear it, you can&££39;t mix it! You can trust your ears when you use the Dynaudio BM14S II active subwoofer.
The Dynaudio BM14S II Active Subwoofer Features at a Glance:
12" woofer with pure aluminum voice coil provides clean, deep bass
Auto on/off for conserving power
Selectable LFE or slave mode for linking
Seamless adjustment of lowpass/highpass frequencies provides smooth crossover
Closed cabinet design delivers extremely precise low-frequency reproduction
Hear your mix, your whole mix, and nothing but your mix with The Dynaudio BM14S II active subwoofer!
Tech Specs| Powered | Yes | | Speaker Size | 12" | | Driver Type | Cone | | Driver Material | Molded MSP (Magnesium Silicate Polymer) | | Total Power | 300W | | Frequency Range | 18Hz-250Hz | | Input Types | 3 x XLR | | Output Types | 3 x XLR | | Height | 13.8" | | Width | 13.8" | | Depth | 14.5" | | Weight | 46.3 lbs. |
