The Maselec STM-822 Features:
•Eight stereo inputs
•Two stereo outputs with separate amplifiers; both can drive 600 ohms and be unbalanced
•The signal path is completely balanced from input to output
•Only three, very wide bandwidth, amplifiers in the signal path
•Cut and Solo, with one common gas filled relay, for each input
•Output noise lower than -88dBu with maximum gain and all inputs open (matches converters with 120dB dynamic range)
•Output noise lower than -100dBu with all inputs open and gain set to -10dB (typical mix setting)
•VU meters with switch for 0VU = +4dBu or +10dBu
•Signal present LED for each input
•Gain adjustable in 1/2dB steps between –15dB and +5dB
•Max level in/out: +29dBu
•Distortion < 0.0003%
