50¸öÄã±ØÐëÒªÖªµÀµÄÉùÒôÓëÒôÉ«ÊõÓÉÏÆª£©
ÒôÉ«
ǰÑÔ
ÓÃÎÄ×ÖÈ¥ÐÎÈÝÉùÒôÊǼþºÜ³éÏóµÄÊÂ,±ÈÈçÕâÒôÉ«ð¤ð¤µÄ(´¥¾õ)£»ÕâÒôÉ«»áÅç³öÒ»µÀµ­×ØÉ«µÄ¹ââ(ÊÓ¾õ)£»ÓÐÄÌÓ͵ÄÏãζ(Ðá¾õ)¡£ µ±È»²»ÊÇÿ¸öÈ˶¼ÄÜͨ¹ýÎÄ×ÖÓÐͬ¸Ð£¬µ«ÐÎÈÝÒôɫʱÈËÃÇ»¹ÊÇ»á¶àÓÃÕâЩ·ÇÌý¾õ¸Ð¹ÙµÄÐÎÈÝ´Ê×öÚ¹ÊÍ¡£ ²»¹ýÏ£ÍûÏÂÃæÕâЩÊõÓïµÄרÓÐÃû´Ê½âÊÍÄÜΪÄã½ÚʡһЩÊÕ¼¯ÕûÀíµÄʱ¼ä¡«
01
ÆðÒô£ºÒôµ÷ÆðʼµÄËÖ´à¸Ð¡£»ò¿ì»òÂý£¬Çå´à»ò¶Ù×Ç¡£
attack: the initial crispness of the note; it can be fast or slow, crisp or dull.
02
ƽºâ£ºÀÖÆ÷µÄÌØá磬ָµÄÊǸߡ¢ÖС¢µÍƵµÄÒôɫӵÓзdz£½Ó½üµÄÒôÁ¿´óС¡£
balance: the characteristic of an instrument in which the upper, mid, and lower tones have very similar loudness.
03
µÍÒô£ºµÍλÏÒµÄÒôµ÷¡£µÍƵ¡£
bass: the notes on the lower strings; the lower frequencies.
(×¢£ºÕâÑeµÄµÍλÏÒ·ºÖ¸¼ªËûµÄµÚËÄ¡¢Îå¡¢ÁùÏҵĵÍÒôÏÒ£¬
Òô¸ßΪE2 82Hz, A2 110Hz, G3 195Hz)
04
Òô·±ÆÚ(?)¿ª»¨ÆÚ(X)£¬·±ÈÙÆÚ(X)£ºÒôµ÷ÔÚÆðÒôÖ®ºó±ä´óÉùµÄʱÆÚ¡£
bloom: the way a note seems to get louder just after the initial attack.
05
•ÅÁÁ£ºÇ¿µ÷¸ßÒô²¿·¢ÒôµÄ¸ß´Îг²¨¡£
bright: a pronounced upper harmonic that accentuates the upper register.
(×¢£ºÐ³Òô£¬»òָг²¨£¬Õâ¸öÒ²ÒªÁíÍâ½âÊÍ¡£¸ßÒô²¿·ºÖ¸¸ßÓÚ2000Hz»ò3000HzµÄÒô¸ß¡£Õâ±ßºÜÄѽ綨£¬µ«¾Í¼ªËû¶øÑÔ»áÊǵÚÒ»¡¢¶þÏÒµÄB3 247Hz, E4 330Hz¡£
Ö»²»¹ý¾ÍËãµÚÒ»ÏÒ22¸ñµÄÒô¸ßD6 1175Hz£¬ÒÔEQÀ´¿´¶¼»¹²»µ½2KHz¡£ÁíÍ⣬ÎÒÖ»Ìáµ½»ùÒô£¬Ã»°Ñг²¨Ëã½øÈ¥À²)¡£
06
ÀÖÖÓÉù(Chime)£º³ÖÐøÑÓ³¤ÇÒ´øÖøÉÁÉÁ·¢ÁÁµÄ¸ßÒôг²¨¡£
chimey: sustains with shimmery, high harmonics.
07
Æ·µÈ(?)¿³¡¢Åü¡¢¶ç(X)£º·ºÖ¸ÒôÀÖÉϵÄÊìÁ·¡£
¾ÙÀýÀ´Ëµ£¬Ò»¸öÑÝ×àÕßÓÐÁ¼ºÃµÄÆ·µÈ¾ÍÊǸö¼¼Êõ´¿ÊìµÄ±íÑÝÕß¡£
chops: refers to musical proficiency; for example, a player with good chops a skilled player.
08
ºÏÉù£ºÎïÀíÉÏÊÇÖ¸·Ç³£¶ÌµÄÑÓ³Ù£¬´ó¸Å20 ~ 50ms£¬ÓëÔ­À´µÄѶºÅ»ìºÏ²úÉúÈçÃÎËÆ»ÃµÄЧ¹û¡£
09
¸±¸è£ºÒ»Ê׸èÖз´¸²Öظ²»òÊÇÓëÖ÷¸è²»Ò»ÑùµÄ¶ÎÂä¡£
chorus: in a song, the part that either repeats or is considerably different from the verse; electronically, a very short delay, 20-50 milliseconds, blended with the original signal for a dreamy effect.
ÆÀÂÛÁÐ±í£¨7£©
sonar Â¥Ö÷
10
Ç峺£ºÒô·ûÓëºÍ½LÄܹ»ÓÐÇø±ðÇÒÂÖÀª·ÖÃ÷£¬µ«ÓÖ²»»áÌ«¼âÈñ´Ì¶ú¡£
clarity: the way notes and chords are distinct and well defined, but not strident.
11
ѹËõ£ºÒ»ÖÖ½«ÉùÒôµ÷ÕûµÄ·½·¨£¬ÒÔ·ÀÖ¹¹ý´óÉù»ò̫СÉù£¬
ά³ÖÕûÌåÒôÁ¿µ½Ò»¸ö½ÏÏÁÕ­µÄ¶¯Ì¬·¶Î§(Dynamic Range)£»
ѹËõÒ²Ðí»áÔö¼ÓÑÓÒô(Sustain)£¬»òÕßËü¿ÉÄÜ»áÏÞÖÆÒôÁ¿»ù»´(Level)¶ø²úÉúÆÆÒô(Distortion)¡£
compression: the way a sound is altered to prevent overly loud or overly soft sounds, keeping the overall volume to a narrower dynamic range; compression may enhance sustain, or it may limit the level that might cause distortion.
(×¢£º¶Ô³õѧÕßÀ´Ëµ£¬Ò»¸öÃû´Ê½âÊÍÑeÓÖ¿´µ½ÑÓÒô¡¢¶¯Ì¬·¶Î§¸úÆÆÒôÕæµÄÌ«²ÐÈÌÁË¡£ºÃÔÚÑÓÒôÓ붯̬·¶Î§ÔÚÕâÑeÓнâÊ͵½¡£)
12
ÇиîÁ¦£ºÄÜ´Ó¸÷ʽ¸÷ÑùµÄÀÖÆ÷ºÍÒôÉ«Öб»Ìýµ½»ò±æÊ¶µ½µÄÄÜÁ¦¡£
ͨ³£¸úÒôÁ¿´óС¡¢Ã÷ÏÔµÄÆðÒôÒÔ¼°¸ß´Îг²¨º¬Á¿¡£
cutting power: the ability to be heard through a variety of instruments and tones. Usually associated with loudness, a pronounced attack and upper-harmonic content.
13
Ë¥¼õ£ºÒ»¶ÎÔÚÆðÒôÖ®ºóµÄÉùÒô²¿Î»£¬ÔÚÆðÒôÓëÑÓÒôÖ®¼ä¡£
decay: the portion of the note immediately after the attack, just between attack and sustain.
(×¢£º¿´Õâ±ßµÄͼ¾ÍÖªµÀµÀÁË£º RolandרÃÅÊõÓï´Êµä£ºAttack
ÆðÒôËæÊ±¼äÀ´µ½×î´óÒôÁ¿µÄ¶¥µã£¬½ÓÖø¾Í»áÒòΪÒôÁ¿¼õÉÙ¶øÍùÏÂ×ß¡£
¶øÍùϵÄÕâÒ»¶Î¾ÍÊÇË¥¼õÁË¡£)
2005-3-20 03:56:00 »Ø¸´
sonar Â¥Ö÷
14
ÇåÎú¶È£ºÇå³þ½¨¹¹µÄÒô¸ßÓëÆðÒô¡£
definition: clearly established pitch and attack.
15
Éî¶È£º¶ÔµÍÒôµÄÒôµ÷È·¶¨ÊôÐÔ£»ÈôÒ»°Ñ¼ªËûÓкõÄÉî¶È£¬ÄǾÍÓкÜÇ¿µÄµÍÒôÒôµ÷£º
16
²»´Ì¶ú£¬²»±¬Òô£¬²»ºý³ÉÒ»¿é¡£
depth: the positive attribute of low notes; a guitar with good depth haves strong ¨C not strident, boomy or mushy ¨C bass notes.
17
ǬÔï¸Ð£ºÖ÷Òª¶¨ÒåÔÚ»ùÒô(Ô­Òô)ÒÔ¼°µÍÐòµÄг²¨º¬Á¿£»
³£ÓÃÀ´ÃèÊöÒ»°Ñ¼ªËûÒôɫûÓйýÓÚÑ}ÔÓµÄг²¨º¬Á¿¡£
dry or dryness: defined primarily by the fundamental and low-order harmonic content; often used to describe a guitar without complex harmonic content.
18
³ÖÐøÊ±¼ä£ºÍ¨³£¸úÑÓÒô×öÁ¬½áµÄÒ»¶Îʱ¼ä²âÁ¿£»
Ò»¸öµ¯×àÒ»¸öºÍÏÒ»òÒ»¸öµ¥Òô³ÖÐøµÄʱ¼äÁ¿¡£
(Ò»°ãÀ´Ëµ£¬¶àÊýµÄºÍ½LÄܳÖÐøÁùµ½Ê®¶þÃëÖÓ¡£)
duration: a measure of time usually associated with sustain; the amount of time a chord or note lasts when played (most chords will last six to twelve seconds).
2005-3-20 05:17:00 »Ø¸´
sonar Â¥Ö÷
19
¶¯Ì¬·¶Î§£ºÒ»ÏîÀÖÆ÷´Ó×îСµ½×î´óÉù£¬ÔÚÄÜÌý¼ûµÄÒôÀÖÓÐÓÃÊä³ö¡£
dynamic range: The audible and musically usable output of an instrument from its quietest to its loudest.
20
Á¦¶È±ä»¯£ºÒ»ÏîÀÖÆ÷ÔÚµ¯×à·Ç³£ÇᣬÇáÇáµØ£¬Öеȣ¬´óÁ¦Ê±²úÉú²»Í¬ÒôÁ¿µÄÄÜÁ¦¡£
Ò²¿ÉÒÔ˵ÊǼªËûÊä³ö´ÓÇáÈáµ½³³àеķ¶Î§¡£Çë¼û¶¯Ì¬·¶Î§¡£
dynamics: an instrument¡¯s ability to produce different sounds when played very softly, softly, medium, and hard; also, the range of the guitar¡¯s output from soft to loud. See dynamic range.
21
·´Ó¦Æ½¾ù£ºÒ»ÏîÀÖÆ÷²úÉú³öÓëÕñ·ùÓëг²¨º¬Á¿Ê®·Ö½Ó½üµÄÒôµ÷¡£
evenness of response: when the notes from an instrument are very close in amplitude and harmonic content.
(×¢£ºÕâÕæµÄÒª¿´Õñ·ùµÄÎÄÕ²ŻáÇå³þ¡£ÑeÃæ»áÌáµ½even harmonics¡¢odd harmonics¡£)
22
±¥Âú£ºÍ¨³£ÊÇÖ¸·á¸»µÄ»ùÒôÓëгÒô¡£
full: usually refers to abundant fundamental and harmonics.
23
»ùÒô£º¸ùÒô£¬ÓëËûµÄг²¨º¬Á¿·Ö¸ô¡£
fundamental: the root note, separate from its harmonic content.
24
гÒô£ºÒ»ÏîÀÖÆ÷×ÔÈ»³öÏÖÉùÒô¸ß·åµÄƵÂÊÏìÓ¦£¬Óë¸ùÒôÖ®Éϵĸô¼ä£¬
°Ë¶ÈÒôµÄÐÎʽ£¬½Ï¸ßµÄËÄÎå¶È£¬ºÍһЩµ¥¼ä¸ôÓйء£
harmonics: the naturally occurring peaks in the frequency response of an instrument that correspond to intervals above the root note, in the form of octaves, higher fourths and fifths, and some odd intervals.(×¢£ºÕâÒ»¶¨Òª°ÑÕñ·ù½²Çå³þ²ÅÐÐÁË¡£)
25
Éùµ÷£ºÒ»ÏîÀÖÆ÷£¬ÓÃÕýÈ·Òô»´µ¯×àËüµÄÕû¸ö·¶Î§£¬Í¸¹ý²¹³¥µÄ¼¼ÊõÀ´´ï³ÉµÄÄÜÁ¦¡£
intonation: the ability of an instrument to play in tune through its entire range, which is accomplished via a technique called compensation.(×¢£ºÕâ¾ÍÊÇËùνµÄÎÄç§ç§µÄ·­Ò룬ÆóͼÈÃÈË¿´²»¶®¡£ÓÃÓïÑÔѧÀ´¿´¾ÍÊÇÓïµ÷µÄÑöÑï¶Ù´ì)
2005-3-20 05:42:00 »Ø¸´
ºÃ£¬Çå³þÁË£¬Ð»Ð»£¡¿´ÎÒ±¿µÄ¡£
2005-3-20 06:09:00 »Ø¸´
´óÁ¦Ö§³Ö¡£
2005-3-20 06:24:00 »Ø¸´
Ö§³ÖÖ§³Ö£¡£¡ºÇºÇ¡£¡£¡£¿É¾ÍÊDzÙ×÷²»À´ÄØ¡£¡£¡£
2005-3-20 20:47:00 »Ø¸´
<P>ºÃ½¨Òé</P><P>Ö§³Ö</P>
2005-3-26 18:33:00 »Ø¸´
