PreSonus Notion v5.0.359 For WiN MAC
PreSonus Notion is famed for outstanding playback sounds, speedy workflow, compatibility, and ease of use, and it's the only notation software that works with a standalone iPad app. It offers powerful features for scoring to picture. And it costs a fraction of what those slow, bloated, overcomplicated scoring programs soak you for. That¡¯s why Notion 5 is the best notation software for composers, performers, producers, worship teams, arrangers, orchestrators, educators, and music students.
Hear Your Music Played by World-Class Musicians.
Notion gives you by far the best playback of any notation product, including orchestral samples recorded by the London Symphony Orchestra. But that¡¯s just the beginning of its playback features.
Notion has many strengths but it¡¯s best known for superb playback. The orchestral samples were recorded by the London Symphony Orchestra at the legendary Abbey Road Studios. Guitar samples were performed by Neil Zaza, bass samples by Victor Wooten, and drum samples by Roy ¡°Futureman¡± Wooten. There¡¯s a wonderful Steinway piano, too. All were painstakingly recorded by top engineers using the best equipment. You get a wide array of dynamics, articulations, and performance techniques.
Although Notion comes with a generous sound library, you are by no means limited to the included sounds. Buy high-quality, yet inexpensive new Notion add-on instrument packs from the ever-increasing library at the PreSonus Marketplace. Use your favorite VST instruments and libraries, too¡ªthey work great with Notion.
Notion ships with several rules templates for other orchestral VST libraries, so for instance, when you load an instrument for Vienna Symphonic Library Special Edition, you can quickly and easily write dynamics, effects, and instrumental techniques into the score without ever having to see the VSL interface or programming key switches. An exclusive Notion feature enables you to simply click and select from drop-down menus to create custom rules for any VST library, without having to edit XML files. With these features, you can mix sounds from libraries and experiment with combinations without concern about syntax errors.
Before you know it, Notion will become your default playback software of choice!
Interactive Tools Make Entry Fast and Intuitive.
Enter notes with ease using Notion 5¡¯s interactive fretboard, keyboard, and drum pad. Choose chords from a generous chord library (enhanced in version 5), and create your own chords.
For many musicians, Notion¡¯s interactive keyboard, fretboard, and drum pad are the fastest and most convenient way to capture pitches, drum parts, and guitar fingerings. You can even customize the number of guitar strings on the fretboard and the order of entry for each voice for the drum pad.
The chord library makes it simple to enter the chord name or voicing you want to appear in your score. Choose from standard chord symbols and fretted chord symbols and design custom chord symbols and diagrams. You can work even faster in Notion 5 than in previous versions; chords now remain on the fretboard for repeated entry, and version 5 adds the ability to recall recently used chords. Chord symbols can vertically align on the page, too!
Picture This.
If you compose to picture, Notion 5 is your new best friend.
Film, video, and TV composers have specialized needs that just start with a synchronized video window. Notion¡¯s video window includes a new timecode view, and you can add hitpoints and select the volume, frame rate, and start time. That's all important stuff but not uncommon.
However, other scoring software falls short when it comes to supporting modern video file formats. In contrast, Notion can handle all of the most important formats, including mp4, WMV (Windows only), H.264, mpeg, mov, avi, m4v, and 3gp on Mac and Windows.
Furthermore, Notion can handle video while in 32-bit or native 64-bit mode for Mac and Windows¡ªand Notion is the only major scoring program that handles video natively on 64-bit Windows.
Plays Well with Others.
In addition to working well with VST instruments and transferring to and from iPad, Notion offers support for standard file formats¡ªand ReWire.
Notion 5 offers compatibility with other applications in several ways. It can import and export Wave files, including upsampling for export, and can export the audio for each staff or bus as an individual stem and import it into PreSonus¡¯ popular Studio One® DAW. Want to share audio files online? Simply upload them to SoundCloud™ from within Notion!
Notion¡¯s ability to export in a variety of modern video formats is one of several features that make it a great choice for scoring to picture. It can also import and export Standard MIDI Files, MusicXML files¡ªespecially useful for collaborating with people who are using other notation applications¡ªand Arobas Guitar Pro tablature files (v. 3 to 5).
And of course, you can import and export between Notion and Notion for iPad or Progression for iPad.
Last, and far from least, Notion supports ReWire as a host and slave in 64-bit or 32-bit mode. During playback, with Notion as the host, you have full access to Notion¡¯s playback and performance features using the computer keyboard or MIDI keyboard. As the stereo stream from the slave application arrives at Bus A in the mixer, you can alter gain, panning, effects, and so on, just like any other instrument.
As a slave, Notion follows the commands of a host application but. Notion can send up to 32 streams to the host application, plus start and stop playback and audition new notes. In fact, you may even forget that Notion is in slave mode until the host begins a playback operation.
For an extremely potent, yet easy-to-use combination, ReWire Notion with Studio One. Now you can take advantage of Notion¡¯s superior playback sounds and notation capabilities, including video scoring, plus Studio One¡¯s in-depth editing, processing, and (with Studio One Professional) mastering and digital release features¡ªincluding direct upload to PreSonus¡¯ Nimbit direct-to-fan online marketing and promotion platform. Of course you also can save your scores as PDF files!
Capture MIDI Parts and Edit Them with Your Score.
Recording and editing MIDI data is easy in Notion. Viewing MIDI and standard notation together makes the experience special.
Capture your MIDI performances better than ever before in Notion. Choose keyboard, guitar, or drum entry and dial in exactly how Notion will follow your playing. Enter in real time or in step time. Then view your MIDI performance data in Notion¡¯s Sequencer Staff.
Better yet, use the Sequencer Overlay, which allows you to see notation and MIDI performance data on the same staff. Edit each individual note¡¯s velocity, duration, start point, and end point using drag-and-drop. For precise values, double-click each note and enter in the numeric values as well. With this feature, Notion combines the power of the MIDI sequencer with the clarity of standard notation in a unique and powerful way.
Overdubbing MIDI performance data is great for adding expressive controllers, recording key switches, or trying that line one more time, and it¡¯s easy to do in Notion. You also may want to merge recorded MIDI data and new events. Notion allows you to overdub your MIDI recordings in either Merge or Replace mode, giving you full control over the performance.
Every Bit Helps.
Here¡¯s a bit of good news: Notion 5 can run with 64-bit or 32-bit addressing on Mac and Windows. It works great with Windows 8 touchscreens and Mac Retina displays, too.
Take advantage of your 64-bit computer and operating system's ability to address more than 4 GB of RAM and watch the speed and performance of Notion and VSTs and sample libraries increase!
You can also run Notion in 32-bit mode on a 64-bit computer for compatibility with other products. And in version 5, Notion adds Mac Retina display support and Windows 8 touchscreen optimization.
Don¡¯t Just Play Your Music: Perform and Produce it, Too.
Notion 5 enables you to perform your scores live and even offers features you expect in a digital audio workstation¡ªincluding PreSonus plug-ins!
Notion lets you play back a score with playback following metronome marks¡ªand does so better than any of the competition thanks to its superior sound library.
But with Notion, you also can perform your score live, using NTempo mode, continuously controlling tempo (and volume if using a velocity-sensitive MIDI controller) by tapping keys on a MIDI controller or computer keyboard. The faster you tap, the faster the tempo. A playback marker shows you where you are in the score. Performing in NTempo mode has many uses but it¡¯s especially great for music students and educators.
Notion also lets you import audio files and mix them with your score using the built-in software mixer, which includes eight buses, panning, inserts, subgroups, and more. Process your audio with the built-in reverb, guitar-amp simulator, and Native Effects™ EQ, compressor, and limiter plug-ins from PreSonus¡¯ Studio One DAW.
Yes, Notion is a professional notation program but it's clearly much more!
Score a Copy of Notion 5!
By now, you should have the notion that PreSonus Notion 5 is a fast, modern, efficient, easy-to-use, great-sounding notation program¡ªand it's far more affordable than its slow, bloated, old-school competition. Notion is available in U.S. and British English, French, German, Japanese, and Latin American Spanish.
So head for your PreSonus dealer, visit the online PreSonus Marketplace, or contact the good folks at Hal Leonard Publishing and score your copy of Notion.
New in Notion 5
Notion 5 makes it easier than ever for you to write your ideas quickly and includes a new video window, new effects from PreSonus Studio One, an enhanced chord library, a custom rules editor, and many notation and publishing improvements.
Notation improvements make Notion 5 even faster and easier to use than previous versions, including an enharmonic spelling tool, cross-staff notation, layout and printing improvements, and new shortcut sets. You also get an enhanced chord library with more library chords, user-created chords, and recent-chord recall.
Major new Notion 5 features include:
Studio: Video window (64-bit Windows and Mac) and new Film Score staff and tools; the ability to bounce all stems; 8 buses (4 more than in Notion 4); audio upsampling for export; support for new VST libraries
PreSonus plug-ins: Includes three PreSonus Native Effects™ plug-ins from Studio One®: Limiter, Compressor, EQ
Custom Rules Editor: New editor for creating custom rules for VST sound libraries makes it faster and easier to use third-party libraries and helps you avoid time-consuming syntax errors
Notation: Many notation improvements make Notion the fastest and easiest scoring software on the planet, including new enharmonic spelling tool, cross-staff notation, layout and printing improvements, and new shortcut sets.
Chords: An enhanced chord library provides more library chords, user created chords, and Recent Chord Recall
Look and feel: The user interface has been redesigned to be more consistent with PreSonus¡¯ award-winning Studio One DAW
International localization: Available in English (U.S. and UK), French, German, Japanese, Latin American Spanish
Display: Mac Retina display and Windows 8 touchscreen optimization
New VST Library presets: New presets for LA Scoring Strings and marching libraries from Sample Logic and System Blue, including Fanfare (marching brass), Rumble (marching percussion), Impakt (orchestral/cinematic percussion), and Virtual Ensemble Trilogy (selection from Fanfare, Rumble and Impakt)
In addition, the following new Add-on packs are available coincident with the release of Notion 5:
Brass: Alto Trombone, Bass Trumpet, Cornet, Flugelhorn, Piccolo Trumpet, Soprano Trumpet
Woodwind: Alto Flute, Bass Flute, Bass Oboe, Basset Horn, Contrabass Clarinet, Oboe d'Amore
Click here for a more extensive list of new features in Notion 5.
Features£º
Composing
-Easily compose, play back, and edit music
-Best playback of any notation product, with orchestral samples recorded by the London Symphony Orchestra and more
-Perform scores using Notion as a live instrument and save your performance
-Create a score on a Mac or Windows computer and continue to edit on iPad and vice versa
-Compose to picture with the video window
-Interactive Entry Tools: Keyboard, Fretboard, Drum Pad, Chord Library
Editing
-Process audio with PreSonus Native Effects™ Limiter, Compressor, and Pro EQ plug-ins
-See notation and MIDI data on the same staff
Compatibility
-Import/export files to/from Finale and Sibelius via MusicXML
-Import video in a variety of formats
-Native 64-bit support
-ReWire support (host and slave)
Computer system requirements:
Below are the minimum computer-system requirements for Notion.
Mac®
-Mac OS® X 10.7 or later (32-/64-bit)
-Intel® Core Solo 1.8 GHz processor (Recommended: Intel Core 2 Duo 2 GHz or better)
-2 GB RAM (4 GB or more recommended)
-8 GB free hard-drive space
Windows®
-Windows 7 or 8 (32- or 64-bit)
-Intel Pentium® 4 2 GHz (Intel Core 2 Duo 2 GHz or better recommended)
ÏÂÔØµØÖ·£º
Óοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë»Ø¸´
ÆÀÂÛÁÐ±í£¨4£©
PreSonus Notion v5.0.359 For WiN MAC ¡£Ñ§Ï°ÐÀÉÍ£¡victory: :victory: :victory:
2007-12-5 21:00:42 »Ø¸´
лл´ó¸ç£¡£¡:handshake
2007-12-5 21:48:04 »Ø¸´
ÐÀÉÍѧϰ:victory:
2007-12-6 12:31:32 »Ø¸´
ÏÂÔØÊÔÊÔ¿´
2020-12-6 12:51:54 »Ø¸´
