SmartSound Sonicfire Pro v5 is designed to create soundtracks for your video. The program has all the facilities necessary for the Creation of excellent soundtracks. Preview in real time with your video. Automatic editing of any sound file. Mixing and the match is based on your needs. Fully organized clippings ¨C No Loops to build. Supports Windows Media and Quicktime video formats. Convenient design ¨C suitable for beginners and professionals. With a new multitrack interface and added support for the latest SmartSound Multi-Layer Music, editors can orchestrate sophisticated music tracks that would otherwise require a professional music editor or composer. The intuitive design of Sonicfire Pro 5 gives quick access to a professional note of music, as well as editing of the conservation of the advanced features easily accessible for complete control over your music.
Key features
¡°Mapping the mood¡± ( ¡°Mood Mapping¡±)
Now you can achieve greater musical heights with Sonicfire Pro 5, the only music solution that offers mood mapping. With mood mapping you can determine the emotional and structural requirements for the stage, as the mood map on the graph in Sonicfire Pro. With this technology, any ¡°multi-layered¡± music. track will be fits from start to finish and saranzhirovana well in accordance with changes in your video. This new level of flexibility and immediate results will provide a final emotional impact on your products.
Multidorozhechny Interface
Sonicfire Pro combines intelligence technology from SmartSound multidorozhechnymi terms of information for the steepest path to the current fit (custom-fit) of music. In addition to the dynamic tuning of musical elements based on your ¡°mood map¡± (mood map), Sonicfire Pro also gives you full control over each individual muses. element. Remove the horns, make a sharp strings ¡ everything you need to achieve maximum impact ¨C Sonicfire Pro gives you the tools to easily create the best track.
Multi music with SmartSound
In muses. SmartSound library was introduced the following innovations: the addition of multi-layered music. tracks in the new series of Strata. Each multi muses. track comes with 8 separate instrument tracks that can be independently controlled. Team of experts SmartSound carefully prepared each track to work with the possibilities of Sonicfire Pro, so that video editors mogdi quickly generate music that fills their scenes well.
SonicFire Pro v5.8.0.0 Network Edition
ÏÂÔØµØÖ·£ºÓοͣ¬Èç¹ûÄúÒª²é¿´±¾ÌûÒþ²ØÄÚÈÝÇë »Ø¸´ |
