查看: 28057|回复: 2
[资讯] Zero-G.Perpetuo.Live.Flute.Phrases.KONTAKT
6万
音频应用高级会员
Rank: 7Rank: 7Rank: 7
发表于 2007-10-16 22:11:32 | 显示全部楼层 |阅读模式
由利物浦皇家爱乐乐团的世界级长笛和短笛手演奏,并在利物浦著名的帕尔街工作室录制,永存的:活的长笛短语是一个8Gb的集合,用Kontakt的无损压缩技术压缩到4.6Gb。
尽管只记录了一名选手,但该仪器巧妙地将3个不同的表演实时地演奏出了长笛三重奏的有效声音,或者你可以把它拨给二重奏或独奏长笛的声音。
而且,尽管有六十二种预先录制好的短语制成的Kontakt仪器,但永续仍然是高度可控和灵活的。这是通过记录相同的模式有许多规模的音高和动态范围宽变化,通过选择模式,融入特别好各种各样的音乐风格,然后通过允许您自动同步到您的项目的节奏与各种各样的节奏和规模类型所有关键控制开关。动态等级pp到ff可以顺利通过mod轮的淡入淡出,整体大小可以从solo到三个播放器,两个麦克风位置(close 和 room)可以选择或混合。
原文
Zero-G and Xfonic present PERPETUO Live Flute Phrases. Following on from our extremely popular Animato, Spiritoso and Luminoso titles, the addition of Perpetuo forms a quartet of titles dedicated to introducing more realism to sampled instruments.
Performed by a world-class flute and piccolo player from the Liverpool Royal Philharmonic Orchestra and recorded in Liverpool's famous Parr Street studios, Perpetuo: Live Flute Phrases is an 8Gb collection of thousands of live recorded looped phrases compressed down to 4.6Gb using Kontakt’s lossless compression technology.
Despite recording only one player, the instrument cleverly layers up to 3 different performances in real time for the effective sound of a flute trio, or you can dial it down to the sound of a duo or solo flute.
And, despite the sixty-two Kontakt instruments being made from pre-recorded phrases, Perpetuo remains highly controllable and flexible. This has been achieved by recording the same patterns across a wide pitch and dynamic range with many scale variations, by choosing patterns that blend in particularly well to a wide variety of musical styles, and then by allowing you to automatically sync to the tempo of your projects with a wide variety of rhythm and scale types all controlled with key switches. Dynamic levels pp to ff can be smoothly crossfaded by mod wheel, the ensemble size can be zoomed from solo to three players, and two mic positions (close and room) can be chosen or blended.
Perpetuo gives you the advantages of fluidity and realism of recorded patterns and phrases and yet also many of the advantages of the flexibility of a standard orchestral library. Although it sounds great alone, Perpetuo works particularly well when blended with other premium orchestral sample libraries as a way of introducing a new layer of realism into the sound.
"All in all, this is a very flexible pre-recorded phrase and pattern library that works great on its own and, importantly, blends well with other orchestral libraries… An excellent tool for creating rhythmic patterns both for upfront minimalist flute ensembles and for subtle background work in cinematic-style productions." - Music Tech magazine, UK. (Read the full review HERE)
"Perpetuo provides a seamless continuation of the strengths of the first three parts of the series [Animato, Spiritoso, and Luminoso]. Also, this library provides the flow and realism of live-rehearsed phrases, paired with enormous flexibility. Just the simple but effective flute rhythms offer great musical value in use, and can make sample-based orchestral arrangements impressive. In terms of sound, the recordings harmonise perfectly with the other libraries in the series." - BEAT magazine, Germany.
LIBRARY FEATURES
Arpeggios and Runs (selectable from key switches): Major, melodic minor, harmonic minor, sus2, sus4, diminished, augmented, minor 6th, minor 7th, 7th, major 7th, fifths, eastern, chromatic, whole note and other scales.
Rhythm Types (selectable from key switches): 8ths, 16ths, 8th triplets, 16th triplets, quarter note triplets.
Ensemble Size: Switchable between Solo, Duo and Trio
Mic Positions: Close and Room (with separate volume and pan controls).
Effects suite: Convolution and algorithmic reverbs, delay, modulation effects, distortion, compression.
Patch Types: Main (natural sounding flutes & piccolos with only major & minor patterns loaded by default to save memory), Hi-Memory (all scale types loaded), Mod Wheel Filter versions (versions of the Live patches, but with the Mod Wheel controlling the filter for a gently synthesized effect) and Mutated (processed, sound designed patches).
Additional Options: Load and unload scale types to save memory. Play at double or half project tempo. Spread the players from widely-panned to a close central group
WHY IT WAS CREATED
Library producer and trailer music composer Dan Graham started out needing a tool that would add realism to his sampled scores on projects that didn’t have a budget for live orchestra. In particular, fast runs, arpeggios and simple rhythms remain difficult to get totally convincing even with the best and most expensive collections, and so he set out to create something that could sit well in the mix, based on live phrases for realism, but flexible enough to blend in with any track. 2011’s hit library ‘Spiritoso: Live Cello Phrases’ was the first stage of this plan, followed by ‘Luminoso: Live Violin Phrases’ in 2012. Now after a year in development Perpetuo extends the principle to flutes & piccolos.
BENEFITS OF LIVE PHRASES
Because the flautist played the actual patterns you hear, they sound real. They are built from 3 bar loops so that no two notes or consecutive bars sound exactly the same - there is natural variation. When you hear slight legato connections between notes it's because that's what were played, not a clever reconstruction of a legato interval using advanced scripting. And with fast rhythms, you are not hearing the usual round-robin repetition articulations; you are hearing 3 bars of completely different notes being played naturally in slightly different ways, flowing smoothly just as they were performed.
FLEXIBILITY
This collection is built around the principle of flexibility. The tempo will fit your project. The same patterns were recorded at 3 dynamic levels, pp (pianissimo - soft) mf (mezzo forte - medium loud) and ff (fortissimo - loud) and by controlling this with your mod wheel you can make the patterns constantly undulate, expressively following the crescendos and diminuendos of your compositions. You can also use this mod wheel control to accent particular notes and therefore create syncopations and rhythmical emphasis tailored exactly to the music. As a case in point, with the 'Rhythms' patch you can automate the different rhythm key-switches (e.g. 8ths, 16ths, 8th triplets) in fine detail in your sequencer, and therefore build your own custom rhythm patterns, and finally add accents by automating the mod wheel dynamics.
THE HIDDEN POWER OF THE UNOBTRUSIVE
Whereas some of the patterns might start to sound too recognizable if overused, others are very neutral, for example “Up Down 8ths” which simply goes up and down from root to fifth, or ‘Rhythms’ played on one note. These are simple patterns which will blend well within a complex piece of music yet impart that elusive quality of realism, expressiveness, humanity and live playing which is still missing from many orchestral libraries. You may find these ‘Up Down’ and ‘Rhythms’ instruments to be the ones you keep going back to.
3 x ROUND ROBIN
These instruments have a 3 x round-robin effect created by randomizing the start point of the 3 bar loops, which greatly helps realism by avoiding machine-gun effects.
REQUIREMENTS and RECOMMENDATIONS
Kontakt’s Time Machine 2 algorithm requires Perpetuo to run entirely in memory. Although you can keep memory low by not loading up unused scale types, for maximum flexibility it is recommended that you use this in a 64bit environment with over 4GB RAM. A full version of Kontakt (version 5.2 or above) is needed.
Features:
* 4.9Gb of sounds on two DVDs (or download)
* 1327 samples (.ncw files) in total
* 60 Kontakt 5 Instruments with custom Graphic Interface
下载地址:
游客,如果您要查看本帖隐藏内容请回复
Zero-G.Perpetuo.Live.Flute.Phrases.KONTAKT  | 3.45 GB
1万
发表于 2007-10-16 23:57:39 | 显示全部楼层
Zero-G.Perpetuo.Live.Flute.Phrases.KONTAKT :victory:
132
发表于 2022-3-13 19:13:44 | 显示全部楼层
太感谢了,正好需要这个音源
GMT+8, 2025-10-10 17:37 , Processed in 0.039233 second(s), 8 queries , Redis On.
