Apogee Symphony I/O 8x8x8TB À×µçÌ××°
A Symphony I/O System With Blazing-fast Thunderbolt!
Apogee&££39;s Symphony I/O 8x8x8 System + ThunderBridge Bundle quips your studio with the pristine audio quality, high channel counts, and the ultra-low latency you need for pro studio work. Apogee packed 25 years of industry-leading digital audio expertise into their amazing-sounding Symphony I/O interface/converter. Equipped with 8x8 Analog I/O + 8x8 AES/Optical I/O and 8 Mic Preamp Modules and the lightning-fast 64-channel ThunderBridge unit, you&££39;ve got a convenient, high-performance, cost-saving solution for your Mac-based studio. Supercharge your setup with Apogee&££39;s Symphony I/O 8x8x8 System + ThunderBridge Bundle.
Apogee Symphony I/O 8x8x8 System + ThunderBridge Bundle at a Glance:
Symphony I/O - the base unit
Analog and AES - plus optical I/O
Eight superb preamps onboard
Blazing-fast Thunderbolt performance
Apogee&££39;s uncompromising digital audio quality
The Symphony I/O comes as a single base unit. This unit features built-in Ethernet and USB output, as well as Symphony/Pro Tools HD PC-32 I/O - but no additional I/O. A pair of module bays lets you decide what additional I/O you need, allowing you to build the system you want. Choose from five different modules, each with a different assortment of analog and digital I/O. You can even add banks of Apogee&££39;s ultra-transparent microphone preamps! Each of the Symphony I/O&££39;s module cards offers Apogee&££39;s finest conversion technology, and the Symphony I/O itself sports enhanced C777 clocking for completely reliable jitter-free performance.
The Symphony 8x8 Analog I/O + 8x8 AES/Optical I/O Module adds a eight channels of analog inputs and outputs to your Apogee Symphony I/O on two 25-pin D-Sub connectors: one for input and one for output, each carrying eight balanced channels. A third 25-pin D-Sub connector gives you eight channels of AES/EBU digital I/O. You can also configure this connector in a single-wide 192kHz format. You can switch between the AES I/O and optical ports that support eight channels of 44.1-48kHz ADAT, eight channels of 88.2-96kHz S/MUX, or two channels of up to 96kHz S/PDIF. As if that&££39;s not enough, you also get two channels of S/PDIF coax I/O (up to 192kHz) on RCA.
The Symphony 8 Mic Preamp Module adds Apogee&££39;s incredible digitally controlled microphone preamplifiers to eight of your analog I/O module&££39;s line inputs. Based on Apogee&££39;s amazing Trak2 preamp technology, these ultra-transparent microphone preamps deliver the results that pro studios demand. Plus, the Symphony 8 Mic Preamp Module also adds four incredible hi-Z instrument inputs as well as eight fully balanced insert points.
Apple&££39;s Thunderbolt connectivity has opened up a world of professional recording possibilities. Apogee&££39;s Symphony 64 | ThunderBridge is a 64-channel Thunderbolt connection for Apogee&££39;s Symphony I/O. On the back panel, you&££39;ll find two PC-32 ports for connection to Apogee interfaces, and two Thunderbolt ports that let you take advantage of the protocol&££39;s daisy-chain feature. From the second port, you can connect high-bandwidth Thunderbolt devices such as hard drives and DisplayPort monitors in parallel from a single Thunderbolt port on your Mac. A trim desktop unit, Symphony | 64 ThunderBridge will also connect X-Symphony-equipped AD-16X, DA-16X, and Rosetta Series converters to Thunderbolt Macs.
For more than two decades, Apogee has developed some of the finest pro audio technology, including the famous X-series and Rosetta series converters, the Big Ben master clock, the Trak2 mic preamps, and the Symphony PCI protocol. Now, they put all that experience into one amazing interface: the Symphony I/O. You get to choose the I/O, so you can get up to 32 channels of jaw-dropping AD/DA conversion set up for any DAW, including native DAWs such as Logic, Cubase, and Ableton Live, as well as Pro Tools|HD! And standalone operation even lets you use the Symphony I/O with proprietary systems such as Pro Tools LE.
Apogee Symphony I/O 8x8x8 System + ThunderBridge Bundle Features:
The pristine audio quality you need for professional tracking
This system includes:
Symphony I/O base unit
ThunderBridge 64-channel Thunderbolt module
Requirements for Mac OS X:
Thunderbolt-equipped Mac including MacBook Air, MacBook Pro, Mac Mini, and iMac
Mac OS X 10.7 or later
Apogee Symphony I/O: the I/O you need and the uncompromising quality you demand!
Tech Specs| Form Factor | Desktop/Rackmount | | Simultaneous I/O | 16 x 16 | | A/D Resolution | 24-bit/192kHz | | Built In DSP/FX | Yes | | Audio Input Types | 2 x 25-pin D-Sub | | Audio Output Types | 2 x 25-pin D-Sub | | Digital Input Types | AES (1 x 25-pin D-Sub) | | Clock I/O | 1 x Word Clock (In/Out via BNC), 1 x Sync Loop (In/Out via BNC) |
