Rane MP2015 Rotary Mixer µ÷Òǫ̂
/ I9 \+ E# [3 {/ ]5 d5 w 5 ]5 I! R) r& R! S( U* v L7 @
' o. }" J1 s3 ]' @2 z
The Perfect Mixer for the Quality-obsessed DJ. U* h9 S! H0 M) R
When it comes to premium rotary DJ mixers, the 4-channel Rane MP2015 stands on the shoulders of such giants as Bozak&££39;s CMA-10-2DL and UREI&££39;s 1620. Just like these legendary mixers, the MP2015 is a 100% no-nonsense, no-compromises design built around the best available components to deliver the highest sound quality. From its top-shelf RIAA phono preamps and AKM Audio 4 Pro digital converters, the MP2015 delivers jaw-dropping dynamic range and sonic clarity. At the same time, Sweetwater DJs are just as impressed by the MP2015&££39;s awesome onboard filters and routing, and dual class-compliant USB ports are just icing on the cake.
0 B8 S& F: f' w
' s* n2 J6 _ t* m1 JRane MP2015 Rotary Mixer at a Glance:6 m6 F2 ?7 |6 v
No hype, no compromises, just the best mixer Rane has ever made& E. Q. z; X( A- s
4 L6 W3 H. E, q" @. HPremium filters deliver all the sound-shaping power you need5 z; R. b8 D+ ]' u+ x1 F/ x4 ]* p# U
0 ]. u7 N5 W# F J
The ideal I/O and routing options for any professional DJ system Y5 K5 Y1 \3 o" y& m
, c+ G3 o( S! D, b4 @6 V
No hype, no compromises, just the best mixer Rane has ever made2 X* u3 Z" x: M+ o; M! w
Whether you&££39;re a vinyl purist or a digital DJ who demands the uncompromised dynamics of 24-bit digital audio, the Rane MP2015 delivers. On the purely analog side, Rane took painstaking measures to make the MP2015 as transparent as possible, offering a total of 113dB of dynamic range (A-weighted) with a dramatically low THD+N spec of just 0.0009%. Equally impressive are the digital converters onboard the MP2015, which consist of a set of AKM Audio 4 Pro delta-sigma modulators - the same type found in top-end studio gear. And while we could continue to geek out about these amazing specs, one thing&££39;s for sure, your Rane MP2015 mixer won&££39;t be the bottleneck in your system.
! R2 P0 k( h! N/ i. p
" R, v; G, |: V9 n+ d5 {: x) ]
' E9 Z0 O# ?8 ~: x% ?Although the Rane MP2015 certainly meets the sound quality standards you need to hang with the studio consoles, it&££39;s still a DJ mixer at heart, and that means top-notch filtering and EQs are a must. Rane loaded the MP2015 with outstanding sweep filters, killer 3-band EQs, and a 3-band isolator EQ on the output too. You can set the 24dB/octave sweep filters to highpass, lowpass, or highpass/lowpass mode on a channel-to-channel basis for a variety of filtering options, whereas a single resonance control drives them all. Each channel (including the submix) also includes a 3-band EQ with 12dB/octave Linkwitz-Riley filter bands that go all the way down to full kill. The output isolator EQ gives you a final chance to shape your tone, with 24dB/octave bands and dedicated crossover knobs.
' Y8 U9 ~6 J3 F0 ]
4 H. |9 r' u* D4 R: p9 S. x1 r( d1 {The ideal I/O and routing options for any professional DJ system
% Y8 a3 E9 \. \" x8 K* b ]No matter if you&££39;re running an old-school vinyl setup, and quartet of CDJs, or a modern computer-based DJ rig, the Rane MP2015 can not only handle your gear, it will make it shine. Each of the four main inputs includes phono and line-level RCA inputs, complete with a relay-isolated RIAA preamp that includes dual highpass filters to cut out infrasonic rumble. They also include S/PDIF inputs to accommodate CDJs and other digital sources, cutting out unnecessary analog circuity to preserve the highest sound-quality standards. Furthermore, the MP2015 gives you a stereo effects loop plus a microphone input with onboard ducking so you can easily talk over the music. Dual USB Type-B connection let you stream audio from your computer and make changeovers smooth. And if you need even more inputs, you can plug straight into the Submix channel too.5 V- {& h. U2 c/ W4 g2 z% Q& G$ j# s3 A
$ K) h3 u F# O* ]8 I
Rane MP2015 Rotary Mixer Features:
7 z$ Q/ j1 S5 mA 4-channel performance-oriented rotary mixer created for DJs who demand uncompromising audio quality
2 H- a: C$ o0 f, x: p% A& N, @' A5 F% Q8 p+ @
Main stereo input channels include relay-isolated RIAA phono preamps, line inputs, and S/PDIF connections
) N$ C: \+ X2 G% t7 l* G. i- R* Z1 e6 U4 z$ N8 h& V% @0 A
3-band channel equalizers include total kills and software-adjustable crossover points; ^6 S, N' {5 u6 ]# ]2 ^2 P# J
5 f2 F. Y/ u& B1 @; CSweep filters on each channel include highpass, lowpass, and bidirectional highpass/lowpass modes8 m9 a/ m1 L& [+ w+ g7 D5 _
3 n0 N, g2 `1 Q- @5 gSubmix channel lets you combine input channels and offers bath equalization and filtering6 O$ [# J+ W. E- V/ O$ E
' e! j: W& i# P+ ^7 p$ B3 f
3-band output isolator equalizer includes crossover adjustment knobs and 24dB/octave slopes
5 Q" a, Q0 O' _6 M" t
6 a9 d' T- ?- ~# s# cAdditional I/O includes a microphone input with ducking, a stereo effects loop, analog aux input, and USB
( A8 J. z5 e; N! \% P4 ]" `' n* V! g' `3 o- S; ~0 v" V
Dual class-compliant USB connections allow for smooth transitions between digital DJs4 P# R( j) e2 n, @) ]" T* z
6 u/ z; B2 k- u1 N# g+ jDJs who demand the best sound quality trust the Rane MP2015 rotary mixer!
! [0 m0 i- ^- `% i+ _ nTech Specs| Channels | 4 | | Analog Inputs | 1 x XLR/TRS Combo, 6 x stereo RCA, 1 x stereo RCA (Loop Return) | | Analog Outputs | 2 x XLR, 2 x 1/4", 1 x stereo RCA, 1 x stereo RCA (Loop Send) | | Digital Inputs | 5 x Coax | | Digital Outputs | 1 x Coax | | Headphones | 2 x 1/4" | | EQs | 3-band | | Width | 15" | | Depth | 19.25" | | Height | 14" | | Weight | 15 lbs. |
& p4 B; C" E+ n5 K- x8 b |
