Sugar Bytes Turnado 1.7.4 ʵʱÒôƵ´¦ÀíÈí¼þ
ignite
2006-11-28 17:35:00
Èí¼þ
SugarBytes Turnado for MacÊÇÒ»¿îʵʱÒôƵ´¦ÀíÈí¼þ¡£Turnado ÅäÓÐ 8 ¸öÐýÅ¥£¬Ã¿¸öÐýÅ¥¶¼»á·¢³öЧ¹û£¬²¢Í¨¹ý±íÅ̸ıäËü¡£ËüÑûÇëÒ»¸ö»ò¼¸¸öЧ¹ûµÄÓÎÏ·ºÍʵÑé¡£ÔÚר¼ÒģʽÏÂ×Ô¶¨Òå 24 ÖÖЧ¹û
Keep it simple! Turnado comes with 8 knobs, each firing up an effect and varying it with their dial. It invites play and experimentation with one or several effects. Customize 24 effects in expert mode. If you want it even more compact: in Dictator Mode, you can control all 8 effects simultaneously with a single fader.
Key Features
The Silver Bullet of Audio Manipulation
24 Effects in 8 Slots
Classic: Delay, Reverb, Amplifier, Filter
Hi-Tech: Modulation, Tranformation, Loops & DJ
Modulation via 2 LFOs & Step Sequencer
Dynamic Signal Flow
Dictator Mode
NKS support for Komplete Kontrol and Maschine
Whats new in this version
v1.7.4
migration from VST2 to VST3 issues fixed
System Requirements
Requires macOS 10.12 or higher
Audio Unit, VST2, VST3, AAX, Standalone
HomePage https://sugar-bytes.de/en/turnado
ÆÀÂÛÁÐ±í£¨1£©
Sugar Bytes Turnado 1.7.4  ÊµÊ±ÒôƵ´¦ÀíÈí¼þ
2006-11-29 00:29:00 »Ø¸´
