¡¾ÁÔÈËľ¹ÜºÏ¼¯¡¿Kirk Hunter Diamond Woodwinds Complete
²úÆ·Ãû³Æ :        ¡¾ÁÔÈËľ¹ÜºÏ¼¯¡¿Kirk Hunter Diamond Woodwinds Complete
Kirk Hunter Diamond Woodwinds Complete KONTAKT | 1.14 GB
¡¡¡¡Ä¾¹ÜÀÖÆ÷ÑùÆ·´Ó×êʯ¿â¡£×êʯ¿âÊÇÔÚ65gb¡£¼òµ¥µØËµ£¬×êʯ½áºÏºì±¦Ê¯ºÍ׿ďÂÌ£¬ËùÒÔËü¾ÍÏñ»ñµÃ2¸öÍêÕûµÄÀÖ¶ÓÔÚÒ»¸ö°ü¡£¶ÔÓÚ¼Û¸ñ£¬Äã²»»áÔÚÈκεط½ÕÒµ½¸üºÃµÄ¹ÜÏÒÀÖÑù±¾¿â¡£Çë²Î¼û×êʯÖаüº¬µÄ²¿·Ö¡£
Ò×ÓÚʹÓõÄͼÐνçÃæ
¡¡¡¡°´Å¥¡¢ÐýÅ¥ºÍ²Ëµ¥¸üÈÝÒ×ÔĶÁºÍ²¼¾Ö¸üºÏºõÂß¼­¡£
ËùÓеİ´Å¥ÏÖÔÚ×Ô¶¯»¯
¡¡¡¡ÏÖÔÚÿ¸ö¹¦Äܶ¼¿ÉÒÔ×Ô¶¯»¯¡£ÕâÉõÖÁ°üÀ¨ËùÓа´Å¥¡£Òò´Ë£¬ÎÒÃÇÒѾ­È¡ÏûÁË×Ô¶¯»¯Ò³Ã棬ÒòΪÏÖÔÚÒ»Çж¼¿ÉÒÔÔÚGUIµÄǰ¶ËÍê³É¡£
Woodwinds samples from Diamond library. Diamond library - is over 65GB. Simply put, Diamond combines Ruby with Emerald, so it is like getting 2 complete orchestras in one package. For the price, you will not find a better orchestral sample library anywhere. See the sections below that are included in Diamond.
-Easy to use Graphic Interface
Buttons, knobs and menus are easier to read and laid out more logically
-All buttons are now automatable
Every feature can now be automated. This even includes all buttons. Therefore, we have eliminated the Automation page since everything can now be done on the front end of the GUI.
-Vibrato for solos
You can choose to use the modwheel for vibrato when you select solos. (For flutes, piccolo and bassoon, this feature adds more vibrato since the default samples already have a degree of vibrato in them.)
-Keyswitching
If you're the type who likes keyswitching, not only is this available, but you can even customize which keys to use. Or, if you're not a fan of keyswitching, you can turn this feature off altogether.
-Improved SmartLegato
Suppose you choose an aggressive articulation such as Accent ff. Until now, when you have selected SmartLegato, that attacks, even during legato-style playing, would still be rather aggressive. Now, SmartLegato will compensate and make very smooth transitions between notes no matter what articulation you choose. This way, you get the best possible flexibility and musical phrasing!
-Separate velocity and modwheel settings for short note articulation.
We have received numerous requests to create separate velocity and modwheel settings for the short articulations. So now, this is also included.
-New release trigger duplets and triplets.
You can create amazingly realistic duplets and triplets. When engaged, this feature will automatically play an upbow when you release the note. (An upbow and downbow when you select Triplet.) It may take some practice, but once you get the feel of it, the results are very impressive.
-Dynamic Layer Control
You can choose to use the modwheel, velocity or both to control dynamic layers..
-New purge feature that allows you to purge the samples of selected articulations or divisions.
Typically, only one "master patch" per instrument is included with TVEC 3. This is so that you can create your own customized, stripped-down patches. Additionally, it makes things a lot easier for us to update on a regular basis for you since we don't have to port the updates to all of the instruments. So you can expect updates and improvements to TVEC 3 with a lot of regularity! So therefore, you can create, for example, an instrument that only contains the Smooth and Adagio articulations, etc. Or an instrument that only contains short notes, or only solos, etc and on and on.
-No external tutorial needed since every feature is described when you move the mouse over the feature.
All of the features of TVEC 3 are easy to understand because when you hover the mouse over the feature, a brief explanation is shown in Kontakt's info pane.
ÆÀÂÛÁÐ±í£¨2£©
¡¾ÁÔÈËľ¹ÜºÏ¼¯¡¿Kirk Hunter Diamond Woodwinds Complete ,Ö§³ÖÅóÓÑ![em10][em10]
2006-11-15 09:06:00 »Ø¸´
ÏÈ¿´¿´£¬ÈçºÎÏÂÔØ°¡ ¡£:loveliness:
2007-4-14 18:23:32 »Ø¸´
