Ê¥µ®¡¾¶À×àСÌáÇÙ¡¿8Dio Studio Solo Violin (KONTAKT)
²úÆ·Ãû³Æ : Ê¥µ®¡¾¶À×àСÌáÇÙ¡¿8Dio Studio Solo Violin (KONTAKT)
ÊÔÌýµØÖ·£ºhttp://8dio.com/instrument/studiosoloviolin/
8Dio Studio Solo Violin KONTAKT | 2.97 GB
8DioÒѾ·¢²¼ÁËStudio Solo Violinkontakt¶À×àСÌáÇÙ£¬ÀïÃæ°üº¬ÁËÓÉÖøÃûСÌáÇÙÊÖThomas YeeÂ¼ÖÆµÄ4000¶à¸ö²ÉÑùÒôÉ«¡£ÏÖÔڵļ۸ñΪ$149¡£
Studio Solo Violin µÄÏë·¨¾ÍÊÇʵÏÖÍêÃÀµÄСÌáÇÙ¶À×࣬ͨ¹ýÑÝ×à¿ÉÒÔÈÃÈËÃǸÐÊܵ½ËûÊÇÒ»¸ö¡°ÄÑÒÔÖÃÐÅ¡±µÄÒôÉ«¡£8DioµÄ±à³Ì·½Ê½ÊÇÈÃÄú×î´ó³Ì¶ÈµÄ¿ØÖÆÒôÉ«²ÉÑù£¬´Ó¶øÈÃÄúËÜÔì 100%ÕæÊµµÄСÌáÇÙSolo¡£ËûµÄ³öÏÖÉõÖÁ¿ÉÒÔÔÙijЩÇé¿öÏÂÈ¡´úÏÖÓеÄСÌáÇÙ²ÉÑùÒôÉ«£¬¿ÉÒÔ²»¿äÕŵÄ˵Õâ¸ö²ÉÑùÒôÉ«°üº¬Á˺ܶàÆäËûСÌáÇÙÒôÉ«ÎÞ·¨ÑÝ×àµÄ ¼¼ÇÉ£¬ÕâÒ²ÊÇStudio Solo Violin ÌØÊâÖ®´¦¡£
Studio Solo Violin »¹¾ßÓÐÐ޸IJÉÑùµÄ¹¦ÄÜ£¬°üÀ¨Òô¸ß¿ØÖÆ£¬ËÙ¶È£¬Ê±¼äÀÉ죬ʱ¼äѹËõ£¬²ÉÑùµÄÆ«ÒÆ£¨Ëû¿ÉÒÔÈÃÄã¿ìËÙä¯ÀÀÇл»µ½²ÉÑù£¬²¢ÇÒ¿ÉÒÔ´¥·¢ËûÃǵÄÈκβ¿·Ö£©Ð§¹ûºÍ»ìÏì¡£ Ëû¶ÔÒô¸ßºÍËٶȵĵ÷½Ú²»»á»¥ÏàÓ°Ï죬¶øÊ±¼äÀÉì ʱ¼äѹËõ £¬²ÉÑùÆ«ÒÆ¼¸ºõ¿ÉÒÔÈÃÄã ʤÈÎÈκεıàÇú¹¤×÷¡£
´ËÍ⣬8Dio»¹ÓÐÆäËûÓÐÒâ˼µÄ¹¦ÄÜ £¬ ±ÈÈçÄã¿ÉÒÔ¿ØÖƶ¯Ì¬£¬Ã¿¸ö²ÉÑùµÄÆðÒôºÍÊÍ·Åʱ¼ä¡£Äã¿ÉÒÔ¿ØÖÆEQ£¬Gates ºÍÂ˲¨Æ÷. ÄãÒ²¿ÉÒÔ´Ó¼üÅÌ¿ØÖƸ÷ÖÖFX ÐÅÏ¢£¬°üÀ¨²ÉÑùÂÊ£¬ÑÓ³Ù£¬»ìÏì£¬Ê§ÕæÏà룬»¹ÓÐ8Dio×Ô´øµÄ»ìÏì¡£
STUDIO SOLO VIOLIN is a massive collection of over 4.000 phrases performed by renowned concert violinist: Thomas Yee. The intention of the library was to sample completely realistic solo violin by creating an incredible collection of musical phrases. We programmed the library in a way that gives you maximum control over the phrases and literally allows you to sculpt 100% realistic solo violin performances. It was deliberately designed to support, augment and in some cases replace existing solo violin libraries. Essentially this library takes over where normal multi-samples (ex. legato, sustains) can¡¯t perform. This is what we call deep phrase-sampling.
STUDIO SOLO VIOLIN comes with a variety of phrase sculpting tools, including pitch-control, time-stretching / time-compression, sample offset (which allows you to ¡°scroll¡± into any phrase and trigger any part of it, FX and convolution reverbs. The pitch-control is not affected by tempo, so by controlling pitch, time-stretching/compression and sample offset you can essentially adapt the phrase to match the pitch and tempo of your composition.
In addition we added a variety of other features. You can control the dynamics, attack and releases of each sample. You can control the EQ (high, mids and lows), Gates and Filter. You can also control a variety of FX directly from the keyboard, including bit-resolution, delay, reverb, distortion, rotator and we added a beefy collection of custom convolution reverbs.
Full Retail version of Kontakt 4.2 or later required |
