Chameleon Labs 7602 MKII µ¥Í¨µÀ»°·Å
תÌû
Ä£Äâ¾­µäµÄNEVE 1073È«°æµçÂ·ÖÆ×÷¡£°æ±¾Îª7602 MKII Ç°Ãæ°åÒÔ¼°ÐýÅ¥°üÀ¨ÄÚ²¿µÄÅä¼þ¶¼½Ï±È1´ú7602¶¼ÓиıäÉý¼¶.¾ßÓÐNEVEÉùÒôµÄ7602 MKII»°Í²·Å´óÆ÷£¬ÎÂůµÄÄ£ÄâÉùÒô¡£¾ßÓл°·ÅÒÔ¼°ÀÖÆ÷DI¹¦ÄÜ¡£3¶Î²ÎÁ¿¾ùºâÆ÷£¬¿ÉɨƵÂ˲¨Æ÷ ±äѹÆ÷ƽºâ½ø³ö¡£EQ²¿·Ö¿ÉÒÔµ¥¶À×÷ΪЧ¹ûÆ÷ºóÆÚʹÓá£
The power of the 7602 MKII starts with its input stage, which allows you to select the perfect impedance for your microphone. This function alone makes the 7602 MKII invaluable to any serious engineer, because it allows you to get a wide range of tone out of a single microphone. It also lets you get the most out of ribbons and other "low-output" microphones. Next, there&££39;s the 7602 MKII&££39;s switchable highpass filter, which lets you cut out the mud and other useless low-frequency noise that can cloud up your sound. Shelving high- and low-frequency EQ controls with selectable cutoff frequencies give you an enormous range of tone, and semi-parametric mid control lets you dial in frequencies from 360Hz all the way up to 7.2k - perfect for fine-tuning your sound.
A high-end, Swiss-made, 20-position solid-gold gain switch assures not only mechanical-noise-free operation, but quality that&££39;s built to last. A Switchcraft DI is also ready for years of hard use. (You&££39;ll probably want to write this amazing preamp into your will.) Finally, US-made tantalum capacitors and custom wound transformers give the 7602 MKII robust sound, all the way up to its +80dB maximum gain. If you&££39;re looking for a single great preamplifier/EQ that you can use for any microphone and any sound source, the Chameleon Labs 7602 MKII microphone preamplifier and equalizer is it!
Chameleon Labs 7602 MKII Microphone Preamplifier and Equalizer Features at a Glance:
Single-channel preamp and 3-band EQ combo
Selectable impedance (300 ohms or 1.2 kohms) lets you get excellent results from any microphone
5-position switchable highpass filter (3db loss at 300Hz, 160Hz, 80Hz, and 50Hz with an 18db cut per octave slope)
Swiss-made, 20-position solid-gold gain switch with up to 80dB of gain
Robust Switchcraft DI
Shelving low-frequency control with four frequency selections: 220Hz, 110Hz, 60Hz, and 35Hz
Peaking mid-frequency control with six frequency selections: 360Hz, 700Hz, 1.6k, 3.2k, 4.8k, and 7.2k
Shelving high-frequency control with four frequency selections: 16k, 12k, 7k, 4.9k and 3.4k
All frequency bands feature 20db boost/cut
If you&££39;re looking for an excellent go-to preamp/EQ, check out the Chameleon Labs 7602 MKII microphone preamplifier and equalizer!
Tech Specs
Preamp TypeSolid State
Number of Channels1
Frequency Response11Hz-77.65kHz
Phantom PowerYes
EQ3-band
Analog Inputs1 x XLR (mix), 1 x XLR (line), 1 x TS (DI)
Analog Outputs1 x XLR
Rack Spaces1U
Height1.75"
Width19"
ÆÀÂÛÁÐ±í£¨3£©
·ÖÏí µ¥Í¨µÀ»°·Å¡£:lol
2007-8-9 23:23:59 »Ø¸´
Chameleon Labs 7602 MKII µ¥Í¨µÀ»°·Å .......:victory: :victory: :victory:
2007-8-14 10:01:48 »Ø¸´
ºÃ £¡£¡
ѧϰѧϰ¡­¡­¡­¡­
2007-8-18 10:57:50 »Ø¸´
