Burl Audio B32 Vancouver ¹¦·Å
תÌû
Want Huge-sounding Mixes?
While the convenience and power of DAWs is indisputable, some engineers prefer the sound of analog, particularly when it comes to mixing. That&££39;s where the Burl Audio B32 Vancouver analog mix bus comes in. Designed specifically for the digital audio environment, this summing amp lets you realize the full potential of your DAW by delivering the kind of sound quality you&££39;d expect from a classic, large-format analog console - from a compact 1U device. Built in the USA using only the finest mastering-grade components, Burl Audio&££39;s B32 Vancouver sums 32 channels (24 stereo, eight mono inputs) to dual stereo outputs, and gives you the flexibility of a 6dB gain boost and tone-enhancing switchable output transformer.
Burl Audio B32 Vancouver 32-channel Mix Bus at a Glance:
Large-format analog console hugeness
Impressive Sonic versatility and ease of use
Burl Audio: pro gear driven by an audiophile sensibility
If you&££39;ve ever worked on a classic large-format analog console, you&££39;ve likely got that inimitable sound stuck in your head, and the results you&££39;re getting out of your DAW may not be cutting it. Enter the the Burl Audio B32 Vancouver. With no capacitors in its discrete analog Class A signal path, this 32-channel "mix bus" embues your mixes with the hugeness, impact, spatial detail, and clarity. It gives your mixes the "glue" they&££39;ve been missing.
Impressive sonic versatility and ease of use
Burl Audio&££39;s B32 Vancouver gives you impressive sonic versatility, and it&££39;s so easy to use. Aside from your left- and right-channel mix level pots, there are just two other controls for each channel - a button that engages a 6dB summing amp Gain Boost, and a button to insert Burl&££39;s BX5 output transformer into the circuit. The Gain Boost endows your mix with hugeness and slam factor, while the BX5 output transformer provides an alternate tonality (which sounds amazing, trust us). The bottom line? If you want massive-sounding mixes, the Burl Audio B32 Vancouver is a no-brainer.
At Sweetwater, we&££39;ve been nothing but impressed with Burl Audio gear. Based in a professional Santa Cruz, CA recording studio, Paradise Recording, Burl is driven by an audiophile sensibility; their gear is designed by pro recording engineers, for recording engineers of all levels. The company&££39;s directive is simple: to provide you with high-quality recording equipment that will improve your recording, mixing, and mastering. Their innovative solutions not only sound amazing; they intelligently address the challenges of the digital age.
Burl Audio B32 Vancouver 32-channel Mix Bus Features:
Discrete analog Class A signal path
Eight mono inputs, 24 stereo inputs
Audiophile-grade 0.1% stepped attenuators
Switchable BX5 output transformer
Summing amp Gain Boost
Dual stereo outputs
Made in the USA
Get huge-sounding mixes, with the Burl Audio B32 Vancouver!
ÆÀÂÛÁÐ±í£¨6£©
austrian Â¥Ö÷
Tech Specs
Number of Input Channels
32
Number of Output Channels
Analog Inputs
4 x DB-25
Analog Outputs
4 x XLR
Form
Rackmount
Height
1.75"
Width
19"
2006-10-15 10:02:00 »Ø¸´
2006-10-18 03:11:00 »Ø¸´
·ÖÏí £¬µãÔÞÁË
2006-10-31 05:33:00 »Ø¸´
лÀÏʦ·ÖÏí£¬µãÔÞÁ˰¡
2006-12-30 00:42:00 »Ø¸´
·Ç³£°ô£¬²»´í°¡
2007-5-31 10:06:42 »Ø¸´
·Ç³£°ô
·Ç³£·Ç³£°ôµÄÐýÂÉ£¬ÕæµÃ²»´í£¡£¡£¡
2007-5-31 10:09:46 »Ø¸´
