Burl Audio B2 Bomber Ä£Êýת»»Æ÷ A/D
תÌû
ÊÇÄãÏëÒªµÄÄ£Êýת»»Æ·ÖÊ!
Burl Audio Audio B2 Bomber ADCÄ£Êýת»»Æ÷¿ÉÄܽöÊÇÄãÔÚ¹¤×÷ÊÒÀï×îÖØÒªµÄÒ»²¿·Ö¡£ÎÞÂÛÄãʹÓöàºÃµÄ»°Í²£¬Ñ¹ËõÆ÷£¬»òÕ߯äËûÊäÈëÐźŹ¤¾ß£¬Èç¹ûÄãµÄת»»Æ÷²»ÐУ¬Ä㽫ÎÞ·¨µÃµ½µÄÒôÖÊ¡£ÓÅÒìµÄʱÖÓÊDz»¹»µÄ¡£Õâ¾ÍÊÇΪʲôÊ÷¸ù½¨Á¢ÁË×Ô¼ºµÄB2ºäÕ¨»úADC¾ßÓÐÆ·ÖʵÄÄ£ÄâÐźÅ·¾¶£¬ÒÔÆ¥ÅäÆäÊý×Öת»»Æ÷¡£ÔÚÌðË®£¬ÎÒÃÇÒѾ­Ìýµ½Á˺ܶàAµ½Dת»»Æ÷ - ÕÒ³ö×Ô¼ºÎªÊ²Ã´ÎÒÃÇ¿¼ÂÇBurl Audio B2 Bomber ADCµÄÑ¡ÔñÖ®Ò»£¡
Burl Audio B2 Bomber ADC Analog-to-digital Converter at a Glance:
An A-to-D that&££39;s more than just a converter
The finishing touch to your analog signal path
The simplest front-panel interface on the market
The Burl Audio B2 Bomber ADC isn&££39;t your typical run-of-the-mill analog-to-digital converter. The reason for this is simple. Most A-to-D converters use top-shelf clocking circuits, isolated power rails, and other key conversion components. By contrast, their analog signal paths are merely adequate. That&££39;s where the Burl Audio B2 Bomber ADC goes leaps and bounds beyond typical A-to-D converters. Not only does it provide you with unrivaled A-to-D conversion, but its analog signal path is on par with the best all-analog audio gear out there - no 10-cent capacitors or 25-cent op-amps here! Better-sounding audio before conversion means better sounding tracks. Don&££39;t settle for less.
For most engineers, it&££39;s hard to think of your A-to-D converter as the last step in your analog signal path. Fortunately, that&££39;s exactly the approach Burl Audio took when they designed their B2 Bomber ADC. That&££39;s why they gave the B2 Bomber ADC their revolutionary BURL AUDIO BX1 hybrid circuit/proprietary transformer combination. Using a discrete Class A, zero-feedback, zero-capacitor signal path, the B2 Bomber ADC responds to incoming audio like tape. The hotter you hit it, the more natural saturation you get. Coupled with Burl&££39;s top-of-the-line clock, the B2 Bomber ADC gives you unrivaled conversion with unheard-of headroom.
From the layout of the B2 Bomber ADC&££39;s front panel, it&££39;s easy to see that Burl Audio doesn&££39;t believe in senseless overengineering. Whereas many A-to-D converters sport fancy digital displays with controls that make them about as pleasant to setup as a digital wrist watch, the B2 Bomber ADC features a streamlined set of simple dials. Changing the B2 Bomber ADC&££39;s settings from an internal clock set to 48kHz with -12dB of input attenuation to an external clock at 192kHz with -20dB attenuation takes less time than it just took you to read this sentence. How cool is that!? What&££39;s more, you get a bright, easy-to-read 30-segment LED meter, so you know exactly how hot you&££39;re running your input signal.
Burl Audio B2 Bomber ADC Analog-to-digital Converter Features:
Professional 2-channel analog-to-digital conversion with a unique high-quality analog input signal path provides the missing link between your analog input path and your DAW
Proprietary, high-definition, BURL Audio BX1 transformer input reacts to incoming signal like tape
Discrete Class A transistor-based signal path with zero feedback and no capacitors ensure absolute audio fidelity
Simple front-panel knob-based controls make dialing in settings easy
6-position audiophile-quality attenuator lets you select form common headroom settings
Impressive 120dB of dynamic range gives you plenty of headroom
30-segment RMS-based LED meter provides bright, easy-to-read input-level feedback for both channels
Select from 6 sample rate settings, including 44.1kHz, 48kHz, 88.2kHz, 96kHz, 176.4kHz, and 192kHz
BNC word clock input with two outputs of extremely low jitter clock
2x AES outputs and 1 x (2-channel) SPDIF output with dual-wire AES support
Proudly made in the USA
The Burl Audio B2 Bomber ADC analog-to-digital takes quality A-to-D conversion to the next level!
Tech Specs
Channels2
A to DYes
Sample Rate44.1kHz/48kHz/88.2kHz/96kHz/176.4kHz/192kHz
Bit Depth24-bit
Analog Inputs2 x XLR
Digital Outputs2 x AES/EBU, 2 x S/PDIF (coaxial)
Clock Inputs1 x Word Clock
Clock Outputs2 x Word Clock
Rack Spaces1U
Height1.75"
Width19"
ÆÀÂÛÁÐ±í£¨1£©
²»´í!   Burl Audio B2 Bomber Ä£Êýת»»Æ÷ A/D
2006-10-12 02:13:00 »Ø¸´
