Cloud Microphones 44-A ÂÁ´ø»°Í²
39960150
2006-9-20 19:26:00
¸´¹ÅµÄÂÁ´ø¸ÐÓ¦£¬ÏÖ´úµÄÐÔÄÜ
´«ËµÖеÄRCA44µÄ¿Ú±®Ò»Ö±ÊÇÊÜÈË×𾴵ġ£ÔÚ¡°ÄñÁý¡±ÌýÆðÀ´Èç´ËÌðÃÛµÄÍ­ - ºÍ¼¸ºõÒ»ÇС£ÏÖÔÚÔÆ44-AÌṩÔÚ¹ú¼ÒµÄ½øµÄ´ø×´Âó¿Ë·çרΪµ±½ñµÄÓ¦ÓÃÕâЩÁîÈË´¹Ïѵij¬ÒôËÙ¶Ó¡£ÄÚ²¿ÔÆ44-A£¬ÔÆÂó¿Ë·ç²¢Ã»ÓÐ¸Ä±ä´ø±¾Éí - ËüÈÔÈ»ÒÔÊÖ¹¤RCA×î³õµÄ1930¹æ¸ñ¡£µ«Ò»ÇÐÒѾ­±»ÖØÐÂÉè¼Æ£¬ÒÔ21ÊÀ¼ÍµÄ±ê×¼¡£¶ÀÌØµÄÔ˶¯¹¦ÄÜ£¬ÈçCloudµÄÔÞÓþCloudlifterµç·ºÍÓïÒô/ÒôÀÖÏìÓ¦ÇúÏߣ¬44-AΪÄúÌṩÁËÈçË¿°ã¹â»¬£¬³¬½à¾»µÄÏìÓ¦£¬ÔÚ»îԾ˿´øÂó¿Ë·çÓ븴¹ÅµÄ·ÕΧºÍÏÖ´úµÄ±íÏÖ¡£
  R9 [) w5 s5 E2 @% C9 t) z
Cloud Microphones 44-A Ribbon Mic at a Glance:
  • Choose your response curve: Voice or Music
  • Cloudlifter technology, for pristine, transparent gain
    . _$ f% c& _* _: H6 r4 l
The Cloud 44-A is the only active ribbon mic with switchable Voice/Music response curves for controlling proximity effect. This patent-pending technology includes a switchable interface that gives you two frequency response voicings that are quite useful across a wide range of recording situations. Vocalists and voiceover artists can use the "Voice" setting to immediately reduce boomy proximity effect from being close to the microphone. It&££39;s also great for reducing rumble or vibration noise present when capturing an instrument at close range. Of course, there are times when you&££39;ll want full-range bass response of the "Music" setting. Either way, the Cloud 44-A&££39;s switchable interface gives you a microphone with two distinct voices, letting you deploy the special sound of a ribbon microphone on a variety of new sources.
The phantom-powered Cloudlifter technology onboard the Cloud 44-A provides you with gobs of pristine, totally transparent gain, which turns any preamplifier into a "ribbon" pre. And when you&££39;ve got extra-long cable runs, the Cloudlifter is a real lifesaver. The Cloud 44-A requires phantom power and has an output level compatible with any modern preamp. Included is the Cloud U1 shockmount, a beautiful handcrafted wooden box and a microfiber mic cover, designed to properly store and clean the microphone.
Cloud Microphones 44-A Ribbon Mic Features at a Glance:
  • Figure-8 polar pattern, excellent side-null rejection
  • Frequency Response: 20Hz to above 20kHz
  • Maximum SPL: 138dB SPL > 1kHz
  • Output Sensitivity: -25.3 dBv/Pa
  • Phantom-powered "Cloudlifter" circuity
  • Ribbon element dimensions: .19" wide, 2.35" long, 1.8 microns thick
  • New mount offers 180-degree range of motion
  • Internally shock mounted; built in XLR connector
  • Two-year ribbon warranty
  • Limited lifetime warranty on all other parts, with registration
    / j' _6 O* ]5 z7 o5 a/ H
    + M; }: p" o7 c0 Z 3_506_66301_291_800.jpg
  • Handmade at Cloud&££39;s manufacturing lab in Tucson, Arizona
    3 w- M  X) ~# `4 H
Juice your studio with the inimitable sound and performance of the Cloud 44-A!
( X+ A3 P2 p! ^) z
Tech Specs
Microphone TypeRibbon
Polar PatternFigure-8
Ribbon Type1.8 microns Thick, .19" x 2.35"
Frequency Response20Hz-20kHz
Max SPL138 dB SPL (1kHz at 1% THD, 1 Kohm)
ConnectorXLR
Included AccessoriesShockmount, Wooden Box, Microfiber Mic Cover
+ L0 _- J* c' Q- [: h+ q2 a9 J& j* n1 R( ]
ÆÀÂÛÁÐ±í£¨1£©
ÐÀÉÍ Cloud Microphones 44-A ÂÁ´ø»°Í²
2006-9-22 05:51:00 »Ø¸´
