Ò»¿îÒôÀÖÖÆ×÷Èí¼þ£¬ÖÆ×÷µç×ÓÒôÀÖ£¬º¸ÇÁË 133 Ö֏߯·ÖʵÄÀÖÆ÷£¬¿ìËÙÇû÷±à³ÌºÍÇÐÆ¬Ñ»·ÔÙÔìµÄ²½½øÒôÐòÆ÷ £¬¹Ä°üºÍÇÐÆ¬ºÍÑ»·½ÚÅÄ£¬Ò²¿É¿ÉÅäÖõÄÐéÄâ¸ÖÇÙ¼üÅÌ¡£
) B& U& Q' C/ C: S ~+ Q
) T5 T5 j" V& w& x3 s% ^( V . |7 v+ @9 s2 @0 z: \% s, A6 I
9 n8 }) E0 S! ~5 E( IFEATURES" U' d) n9 ]/ K/ ~! I \
7 R; q2 i; q% W6 E M
• 133 high quality instruments, drum kits & sliced-loop beats4 B4 f8 I: E" {
• In-app shop with 6 sample packs (220 instruments), 2 of them are free4 T) k( I9 j2 \. f: y8 Z
• All instruments have FL Studio desktop counterparts for FL Studio desktop import and extension, @( P4 A- {4 _% [* @) S0 s
• Step sequencer for fast percussion programming and sliced-loop reworking
B& }! M4 s( q0 Z# \• Configurable virtual piano-keyboard
# a! U( S) N3 p& D9 E• Drum pads
4 u9 ]; k! j5 S( B& }• Audio tracks: audio recording (with monitoring), iPod library import, wav/mp3/aac import, AudioCopy & AudioPaste( V# ]1 _8 ~0 \7 I
• Wave editor: cut, trim, normalize, reverse, insert silence, fade in/out (3 curves)5 v# y0 w6 A6 ^. u" n) n
• Record up to 8 channels simultaneously with CoreAudio (class compliant) hardware
' F7 n! N. v7 w1 U: W; Y# k# H• Background audio playback and recording5 O( P* V3 D+ `# Z5 I" ]/ S; |# T
• Browser with preview button and logical sorting into Instruments, Synths, Drum kits & Loops
! j+ f x2 \6 R1 h• Sampling: custom kits and instruments can be created from wav/mp3 files, AudioPaste, .zip and .instr files (created with FL Studio desktop)% ?( R' f( {. q: D7 y/ ^
• Pan, volume, release and attack time configurable per instrument
+ [. U% _. S/ W: A! I' S7 |• Pitch bend via accelerometer
5 ^4 j* [) u, L# Y6 Y1 m• Low-latency, iOS-optimized, high quality, battery-friendly audio engine
0 y/ ~7 R8 I1 J" s E1 ~• Drum loops and sliced loops ready to start your project with a cool beat
6 s& I1 N, Z$ o p: w* ^% X• Effects include Limiter, Reverb, Delay, EQ, Amp simulator & Filter to enhance your mix.: ?9 T1 J( h; M3 S* Y% S% A
• 99 track sequencer and intuitive editing options2 p0 }1 p! k# i# |) {
• Per-track mute, solo, effect bus, pan and volume adjustment1 \+ s8 g4 Q1 E) W/ b* U
• Edit at the level of tracks, bars or down to individual notes
|3 b* a" X$ y; y7 d: c3 g6 g& h• Piano roll editor for manual entry of note & chord sequence data or detailed editing of recorded performances 9 J8 h4 p% L" ~9 K) |" B" {+ g
• Unlimited undo and redo for all editable screens
' e: Y8 P8 K0 T/ K$ `• Metronome with tempo & time-signature settings1 [# E' z3 E% h2 L( _
• Intuitive positioning of screens with the slide gesture and resize with the pinch gesture8 P' m" f \0 w5 S/ ]$ p& E* w0 F
• Save and load your songs, export to wave and AAC
8 n* }" J8 I# _$ s& H; q5 r• MIDI file import/export
$ k; J; B$ c7 @: _2 H1 K• SoundCloud and Dropbox upload
. D, T; x, E8 ^) W5 ~2 c% {• In-app user manual
1 f+ c# I+ k. [3 q8 U- C% P• iPhone 4/4S and iPad Retina Display supported" ^5 q& V' \0 f
• Compatible with: CoreMIDI (MIDI in and out), Line 6 MIDI Mobilizer I & II, Akai SynthStation 25, iRig, iRig Mic, iRig MIDI, Yamaha i-MX1, Apogee Jam, Blue Mikey, Alesis IO Dock, iConnectMIDI, Line 6 Mobile Keys, Line 6 Mobile In, Tascam iU2 and many more.; F3 ^2 l7 A5 o' x
3 ^5 K$ _8 R" y' \3 M/ f" z
