APLÃÀ¹úPϵÁÐÎÞÏßÂó¿Ë·ç(UHF)
¼¼Êõ
APLÃÀ¹úPϵÁÐÎÞÏßÂó¿Ë·ç(UHF)% L, ]/ O* D& y  Z
/ Y6 t+ \0 ~% N6 m! C  O7 I, K
PϵÁÐÎÞÏßÂó¿Ë·ç(UHF)P SERIES WIRELESS MICROPHONE SYSTEM
; [$ P: N2 t& `( [3 V) w²úÆ·ÌØµã(Features):
  A; `: ^; E+ T) Q, ^9 ]" B            .PLLËøÏà»·»ØÂ·Éè¼Æ.
( j  Z. w% m; S: T+ L' h3 T             Pit design.  `8 i* t8 |* X
             2. UHF100ƵµãPLLÊýÎ»Ëø¶¨×Ô¶¯Ñ¡Ñ¶¹¦ÄÜ¡£) Y7 F& m. _/ @( v6 e0 m2 U! l
             Functions of UHF 1000 frequency PLL digital lock and automatic message selection.+ @- j; |1 r! @$ `
            3.ÄÚ½¨Ê½¾²Òô¼°ÒôÂëËø¶¨»ØÂ·¿ÉÒÖÖÆ¸ÉÈÅ¡£- D% [  K0 @+ r/ a0 C0 K; g8 E
            Built-in mute&audio locked loop design pressing disurbance.
5 v6 c' S" ?6 h2 z, V- s             4£¬ÌØÊ⿹¸ÉÈŵç·Éè¼Æ¡£! O# m% N/ a. B3 U. [
              Special Counter-interference circuit design.
& r5 a. L+ U! t% G            5.³¬¸ß¶¯Ì¬Ë«Ñ¹Ëõ·ÖÁ÷¼¼Êõ£¬½«.¸ßµÍƵ×Ô¶¯·ÖÁ÷¼ÓÔØ£¬Õ¹ÏÖ×î¼Ñ¶¯Ì¬ÌØÐÔ¡£) Z$ y; K* \3 z) L
             Super high dynamic double compressed diversity technology,high and low vocal.
7 d! ?' j7 M/ e: s: x            6.¶ÀÁ¢µçÔ´¿ª¹Ø£¬Ìṩƽºâ£¬IVƽºâʽÊä³ö£¬¹¦Äܱí(MENU)¡¢ÏòÉÏ (UP)¡¢ÏòÏÂ(DOWN).É趨(SET)µÈ¿ØÖƹ¦Äܰ´Å¥/ d& H, a; Q% j  u- ~
             Independent power switch, providing balanced and imbalanced outputs and suchFunction Buttons as DOWN, UP, MENU, SET, and so on available.9 g( l3 k0 Y# D" |- q, K
[attachimg]110995[/attachimg1 `3 I. r* `* q  @
# |: r- L# [+ x2 @9 q4 f0 x1 D9 P$ {
. Z9 X- C6 O9 y$ {1 ]5 r: L3 T6 r5 d7 l; @
: t, b+ r5 o4 J9 ?
2 B- Q0 R0 k* ]/ X5 { * C$ `( B: J. @+ U7 J( ^8 `
PF-07XÊÖ³ÖÂó¿Ë·ç½éÉÜ£º
, u' M& o; J! W+ b3 X        ÆµµÀ×ÜÊý(Total Channel):1000H: Y3 c) a* r5 B# J9 k
        ¶¯Ì¬·¶Î§(Dynamic Range) : >110dB6 b! \+ _4 `& W* t; i( P1 C
        Ôز¨Îó²î(Carrier Errors):ÍÁ0.005%
) e" i* k2 R. W& _6 \2 J4 `, ]        µ÷±äÆ«ÒÆ¶È(Deviation):148KHz
- Y' h# |6 S, e4 ^9 H3 k        ¸±Ð³²¨(Vice harmonic) : <-60dBc* M0 h! J4 A+ m' c, X; o) G: |
        É䯵Êä³ö¹¤ÂÊ(RF Output Power) :10mW' x/ `9 y( Y% j2 ]; H; @5 n
        µçÔ´ÏûºÄ(Power Supply Consumption):¡Ü100mA@3V
0 `9 C4 \3 R0 q2 Y6 @3 a        µçÔ´¹©Ó¦(Power Supply):Um3, AAA 1.5vx2"
7 B( C6 K0 f6 l. o: |" L7 f        ¹¦ÄÜÏÔʾ·½Ê½(Function Display):Òº¾§ÏÔʾLCD% N! s( n8 w( V2 h/ x+ N5 |
PF-02XÑü¹Òʽ·¢ÉäÆ÷£º0 O5 |' d) L; I# V
         ÆµÂÊÕñµ´Ä£Ê½(Frequency Oscillation Mode):ËøÏà»·»ØÂ·PLL5 ~3 \$ M/ x  U9 f. t6 W) }% G3 {
         Ôز¨ÆµÂÊ·¶Î§(Carrier Frequency Range) : 71OMHz--865MHz
: V0 [/ s1 G; J8 c         RFÊä³ö(RF Output) : 10mW
: t: D* V; h1 z$ |         ÁéÃô¶È(Sensitivity) : 1 0.005%7 T0 v1 \. Y: v( L) B
         Æµ´ø¿í¶È(Bandwidth):24MHz
  h4 q  `1 J  K0 f         ÆµÂʼä¸ô(Frequency Interval):75KHz0 e, Z- P' N! H/ d8 E5 Z
         ¿ÉÇл»ÆµÂÊÊý(Switchable Frequencies):320CH
. \' a! p% H5 U& m         Òº¾§ÏÔʾLCD:ƵÂÊ¡¢µç³ØÁ¿Frequency£¬Hattery Volume
$ p; }7 C$ o1 Q9 F         ¿ØÖÆ·½Ê½(Control Mode):µçÔ´¿ª¹Ø¡¢É趨ģʽ£¬AF,ƵÂÊÉÏ/Ï¡¢¹¦ÄÜËø¶¨Ä£Ê½ Power Switch. Mode Setting. Frequency Up/Down.  HOLD Function
! D3 v: c. U" {         ¼ÙÏó¸ÉÈÅLL(Image Reject):<-50 d BC
0 _3 g0 ?# m3 @$ I7 x" `% f# h$ J         ÒôƵÏìÓ¦(Frequency Response):40Hz-18KHz* g/ O" N0 s5 p7 _, f5 z' D0 Y9 ~% ?
         µç³ØÐÍʽ(Battery Type):UM3, AA 1.5V*2; b6 w  _6 D% p' c
PF-04XÁì¼ÐÂó¿Ë·ç:  N7 x' ^8 r. ]# {
         ÒôÍ·(Microphone Cartridge):±³¼«Ê½×¤¼«ÌåBack Electret condenser+ t$ e; T7 U& R" U
         ÒôÍ·³ß´ç(Dimension): ( P6.0X5mm
5 Y7 i7 W/ l1 ^9 p2 o1 I2 z         Ö¸ÏòÐÔ(Directivity) : ÐÄÐÍCardioid$ }  q( A! z6 Q+ D' O/ W* Z' u3 t
         ÆµÂÊÏìÓ¦(Frequency Response):50Hz-16KHz
2 u8 Y4 i* J( V+ K8 b4 E         ÁéÃô¶È(Sensitivity):-45dB13dB/Pa (at 1 KHz) (5.6mV/Pa )( x9 }& ?4 f5 ]# i* n" W- L
         Êä³ö×迹(Output Impedance) : 2500130%' t1 ^* N; L% F6 m# [9 E7 k
         ¸ºÔØ×迹(Load Impedance) :  ( ×îСMin.) 12500
" ?7 ^* q2 Y. i+ ~) T% ^         µÈЧÉùѹ¼¶(Equivalent SPL) : 21 d BA
! r# c0 g2 G9 Z: D         ×î´óÉùѹ¼¶(M¸Íimum SPL):130dB(г²¨Ê§Õæ(harmonic distortion)<_0.5% 1000 Hz)2 M" c* j8 q. P: ^  Q
         ÐÅÔë±È(S/N):70dB
0 w* P/ f4 Z' u         ¶¯Ì¬·¶Î§(Dynamic Range) : 113dB* M! [8 d( k3 d, ]! i; Z
         ¹©µçµçѹ(Voltage) : 1.5-10V D.C.  L9 A, ~6 q1 S) h" ~. a0 c  }
         Ïß²Ä(Wire):01.5*1.2m
( w, o' p6 N) H- W        ÍâÐͳߴç(Outer Size):15mmX15mm5 K- I; D8 Z( O# E( V/ a
        ÖØÁ¿(Weight):Ô¼20¿Ëabout 20g8 W, \4 m$ x3 X
        ÑÕÉ«(Color):ºÚÉ«Black(¿É¸ù¾ÝÒªÇóÅäÉ«Color selectable)0 u7 U4 C  C/ ?; q. f" {2 j& |+ H- E( m
        Êä³öÁ¬½Ó¼þ(Output Connection):3pin»ò4pinÃÔÄãXLRÁ¬½ÓÆ÷£¬»ò3.5MM²åÍ·3 l- k: g6 j# Z. \" R& h* o
        Connector (3 pin or 4 pin mini XLR connector or 3.5mm connector)/ ^6 q# `2 L4 t7 Q7 ]
P F-04XÁì¼ÐÂó¿Ë·ç£º$ x# o9 D" |9 V, q) {) H- c, ^
2 ?% r* p$ b! Z# _( x         ÒôÍ·³ß´ç(Dimension ):  (  P6.0X5mm! r+ J6 }; G' x1 [# Q, _" {: _
         Ö¸ÏòÐÔ(Directivity):ÐÄÐÍCardioid
7 m6 b; W8 L8 s         ÆµÂÊÏìÓ¦(Frequency Response):50Hz-16KHz
& ]0 Z( `$ W% q& g         ÁéÃô¶È(Sensitivity):-45dB13dB/Pa (at 1 KHz) (5.6mV/Pa); x, [# O- }# G0 s1 {1 f1 J
         Êä³ö×迹(Output Impedance) : 2500ÍÁ30%
4 @5 J  U: a7 h( J& S        ¸ºÔØ×迹(Load Impedance) :  ( ×îСMin.) 12500- V5 B7 K$ R3 t9 I/ M2 C
        µÈЧÉùѹ¼¶(Equivalent SPL):21 dBA
# J, s( V% `5 X6 \        ×î´óÉùѹ¼¶(Maximum SPL):130dB(г²¨Ê§Õæ(harmonic distortion)<_0.5% 1000 Hz)( E& _* q; n/ h4 v* j, E* m/ U
        ÐÅÔë±È(S/N):70dB# u1 }+ P- A$ c5 p- X$ s
        ¶¯Ì¬·¶Î§(Dynamic Range) : 113dB5 A9 X. w' N" L+ T5 Q- q
; a. G/ A3 W! M. G) \        Ïß²Ä(Wire):01.5`1.2m& o7 K; a1 I* B$ @6 t( h
3 u5 e1 _4 m+ S$ W* C! X) X        ÖØÁ¿(Weight):Ô¼20¿Ëabout 20g
- Z. g, {  v( p* G7 }; ^# `! P       ÑÕÉ«(Color):ºÚÉ«Black(¿É¸ù¾ÝÒªÇóÅäÉ«Color selectable)
) M- A  T2 v, m# M- ]        Êä³öÁ¬½Ó¼þ(Output Connection):3pin»ò4pinÃÔÄãXLRÁ¬½ÓÆ÷£¬»ò3.5MM²åÍ·Connector (3 pin or 4 pin mini XLR connector or 3.5mm connector)! W  _4 k' C' O# ^
PF-08XÍ·´÷ʽÂó¿Ë·ç£º
" D  b$ L; Q; X7 X% A' y5 l0 |          ÒôÍ·(Microphone Cartridge):±³¼«Ê½µçÈÝBack Electret condenser; f9 L7 U6 u$ ^' g: g: }, o8 k
          Ö¸ÏòÐÔ(Directivity):ÐÄÐÎcardioid- e2 X+ B0 N( F" G
          »»ÄÜÔ­Àí(Acoustical operating principle):ѹÁ¦ÌݶÈÐÍ£¬FETǰÖ÷Ŵó.   Pressure Gradient FET preamp
; b4 n) D* `" a- X" N1 r           ÆµÂÊÏìÓ¦(Frequency Response):50-18000ÈÕzÁéÃô¶È(Sensitivity):-42dB (7.9mV/Pa)
# W7 Q" I" `$ `1 Y          ×迹((Impedance) : 2.2K0(¸ù¾ÝÑü¹ÒʽÎÞÏß·¢ÉäÆ÷ºÍÂó¿Ë·ç¹©µçÆ÷Êä³öµç·±ä»¯)Change according to power supply output circuit of body pack wireless& q! T$ k/ S: D$ ~0 t. y6 K+ g
transmitter and microphone)
  s, D! F( ]2 v+ \! i         ¸ºÔØ×迹(Impedance) :  (  ×îСMinimum) 11KU(¸ù¾ÝÑü¹ÒʽÎÞÏß·¢ÉäÆ÷ºÍÂó¿Ë·ç¹©µçÆ÷Êä³öµç·±ä»¯Change according to power supply output circuit of body pack wireless transmitter anc microphone)
& L8 |2 {2 `  `4 V( C5 C         µÈЧÉùѹ¼¶(Equivalent SPL):25dBA; J% M, s9 w  s
         ×î´óÉùѹ¼¶(Maximum SPL):30dB(г²¨Ê§Õæ(Harmonic Distortion)50.5% 1000 Hz)0 ?9 }' k: W/ X0 ^: n
         ÐÅÔë±È(S/N) : 70dB¶¯Ì¬·¶Î§(Dynamic Range):113dB
0 X( n% H7 U. q" @+ E, w. ]         µçÔ´(Power Supply) :1.5V-10V D.CºÄµçµçÁ÷(Current Consumption) : 3.5mA$ h( v3 w, D# Q6 e* r
         Êä³öÁ¬½Ó¼þ(Output Connection) : 3pin»ò4pinÃÔÄãXLRÁ¬½ÓÆ÷£¬»ò3.5MM²åÍ· Connector (3 pin or 4 pin mini XLR connector or 3.5mm connector)¸üºÃµØ¸Ä½øºÍÌá¸ß¡£/ l0 L6 n7 y: |% [
1 {4 B  h  j: c6 d3 h2 b
ÆÀÂÛÁÐ±í£¨1£©
²»´í
2006-6-2 17:55:00 »Ø¸´
