Bricasti Design M21 ÊýÂëÄ£Äâת»»Æ÷
M21ÊýÂëÄ£Äâת»»Æ÷(½âÂëÆ÷)
M21 Platinum°×½ðϵÁÐÊÇһ̨ÈýÁ¬Ê¤µÄÊýÂëÄ£Äâת»»Æ÷¡£ÌṩÈýÖÖ¶ÀÁ¢µÄÓû§¿ÉÑ¡Êý×ÖÖÁÄ£ÄâÐźÅ·¾¶£ºdelta sigmaºÍÌÝÐÎÊýλÀà±Èת»»Æ÷ÓÃÓÚPCMת»»ºÍÓÃÓÚDSD²¥·Å£¬ÕæÕýÖ±½ÓµÄDSD¡£Ö§³ÖËùÓÐÀàÐÍÊý×ÖÊäÈ룬¿Éͨ¹ýÄ£ÄâË¥¼õÆ÷µÄÖ±½ÓÊä³ö»òʹÓÃʵÏßÈÆ¹ýÄ£ÄâË¥¼õÆ÷¾ù¿É¡£
M21½âÂëÆ÷ÊÇM1SE (ÌØ±ð°æ)ºÍM12Ë«µ¥ÉùµÀÒôÔ´¿ØÖÆÆ÷³ÖÐø·¢Õ¹µÄÁíÒ»½Ü×÷¡£
Êý×Ö/ Ä£Äâ(½âÂëÆ÷) ±íÏÖX3
ƾ½èM21µÄÏȽø¼Ü¹¹£¬ÏÖÔÚ¿ÉÒÔÈÃÄãÑ¡Ôñ¡¢ÆÀ¹ÀºÍÏíÊÜÈýÖÖ¶ÀÁ¢²»Í¬µÄÊý×ÖתģÄâÐźÅ·¾¶£º24 bit delta sigma£¬20 bitÌÝÐÎÊýλÀà±Èת»»Æ÷ºÍΪDSDÄÚÈÝÌṩµÄÕæÕý1bit DSD¡£×ÔÖ÷ת»»Â·¾¶¹¤³ÌΪÄú´´×÷Ò»¸ö·½±ãµÄƽ̨£¬ÈÃÄúÄܹ»ÐÀÉÍÒôÀÖ²¢Óë´Ëͬʱ̽Ë÷¸÷×ÔµÄÓÅÊÆ¡£
ÍøÂç´®Á÷
M21ÄÜÓëÄúµÄÍøÂçÁ¬½ÓÎ޷죬ΪÒôƵ²¥·ÅÌṩÁËÒ»¸ö´óµÄÓÅÊÆ¡£Ò»µ©ÄúµÄÍøÂçͨ¹ýÓÐÏßÒÔÌ«Íø¼ì²âµ½£¬M21¾Í±»Ê¶±ðΪDNLAÉ豸£¬²¢³ÉΪһ¿î¹¦ÄÜÇ¿´óµÄýÌå´«ÊäÆ÷£¬¿É³¤¾àÀë´«ÊäԭʼÊý¾Ý£¬¶ø²»»á¶ªÊ§ÐźŻò½µ¼¶¡£ÏÖÔÚ£¬ÄúµÄ·þÎñÆ÷¿ÉÒÔ·ÅÖÃÔÚÍøÂçÉϵÄÈκεط½£¬²¢ÇÒ¿ÉÒÔÔ¶³ÌÔËÐУ¬´Ó¶øÓÐÖúÎÞÔÓÒôµÄñöÌý»·¾³¡£
Ö±½Ó»òÄ£Äâ
M21ÀûÓÃ׼ȷµÄÄ£ÄâÔöÒæ¿ØÖÆÀ´Ö´ÐÐÖ±½ÓDSD¹¦ÄܺÍÇý¶¯·Å´ó¡£Ëü¾ßÓÐÒ»¸öÕæÕýµÄʵÏßÈÆ¹ýÄ£ÄâË¥¼õÆ÷£¬½«¸Ã¿ØÖÆÉèÖÃΪ0db£¬¿ÉÒÔ½«M21Ö±½ÓÓÃ×÷ÍⲿǰÖ÷ŴóÆ÷¡£Áé»îÐÔ±ãÊÇM21µÄÕû²¿Éè¼Æ¡£
¼¼Êõ¹æ¸ñ
ÊýÂëÊäÈ룺XLR: AES/EBU 24 bit Single Wire, BNC: SPDIF, RCA: SPDIF, Optical: Toslink 44.1- 96k, USB 2
ËùÓÐÊýÂëÊäÈëÖÆÊ½È¡ÑùƵÂÊ£º44.1 kHz, to, 192khz
USBÊäÈë֮ȡÑùƵÂÊ£º44.1 kHz, to, 384kHz, DSD 64fs 128Fs as DoP
Ethernet ÊäÈë֮ȡÑùƵÂÊ£º44.1 kHz, to, 192kHz, DSD 64fs as DoP
ÊýÂë¶¶ÌøÂÊ£º8 psec @ 48k / 6psec @ 96k
ÊýÂë¶¶ÌøÂÊ£ºXLR balanced (pin 2 hot)
Êä³öÒôƵ×迹£º40 ohm
Êä³öÒôƵ£º@ full scale +16.5 dbm (5.2V RMS)
¿Éµ÷Êä³öÒôƵˮƽ£º90db in 1 db steps ¾ÅÊ®¼¶£¬Ä¸¼¶Ò»¸ödB
½âÂëÆ÷£ºPCM 24 bit delta sigma È¡Ñù8±¶£¬DSDÖ±½Ó1 bit£¬384KhzÌÝÐÎÊýλÀà±Èת»»Æ÷
ƵÂÊÏìÓ¦@44.1k£º10 hz- 20 kHz +0dB, -.2 dB
¶¯Ì¬·ù¶È£º>120dB A-Weighted
¶¯Ì¬·ù¶È@ 1k£º.0008% @ 0dbfs / .0004% @-30dbfs
ÒôƵ·Çƽºâµ¥¶ËÊä³ö£ºRCA
Êä³öÒôƵ×迹£º40 ohm
³öÁ¦Ë®Æ½£ºFull scale at front panel +6 dbm (1.2V RMS)
½âÂëÆ÷£º24 bit delta sigma Èý½Ç»ý·Öµ÷±ä8±¶È¡Ñù
ƵÂÊÏìÓ¦@ 44.1k£º10 hz- 20 kHz -.2 dB
×Üг²¨Ê§Õæ@ 1k£º.0008% @ 0dbfs / .0004% @-30dbfs
×Üг²¨Ê§Õ棺EMC: Complies with: EN 55103-1, EN 55103-2, FCC part 15 and Class B
RoHS£º×ñÊØÅ·Â½EU RoHS Directive 2002/95/EC
°²Õû±ê×¼£ºÈÏÖ¤Ìõ¿îIEC 60065, EN 55103-2
ÀíÏ빤×÷ζȣº32 F to 105 F (0 C to 40 C)
ÊÕʰ»·¾³Î¶ÈÌõ¼þ£º-22 f to 167 F (-30 C to 70 C)
Íâ±í¿îÉ«£ºÑô¼«´¦ÀíÂÁÖÊ
²úÆ·³ß´ç£º17¡± x 12¡° x 4.5¡±
ÖØÁ¿£º15 °õ
ÔËÊä°ü×°ÖØÁ¿£º18 °õ
ÔËÊä°ü×°³ß´ç£º22¡±x 17¡±x 7¡±
³§·½¿ÉÉ趨ÒÔÏÂÈκÎÒ»ÖÖ²»Í¬µØÓòµÄµçѹÓëÆµÂʱê×¼£º-100, 120, 220, 240 VAC, 50 Hz ¨C 60 Hz factory set
Trigger out:TRS connector for 5V external trigger.
ºÄµçÁ¿:28 Watts (6W standby)
µ¥Ò»ÊÖÎïÖ÷ÎåÄêÓÐÏÞ±£Ñø:Á½ÄêÓÐÏ޵ĵ¥ÊÖÒµÖ÷
»¶Ó­¹âÁ٠¼ÒôÅïϵͳ¼¯³ÉÉÌ¡ª¡ª±±¾©ÀÖ³ÇÊ˹ú¼Ê¿Æ¼¼ÓÐÏÞ¹«Ë¾
±¾¹«Ë¾ÎªÊµÌå¾­ÓªµÄºÏ·¨×¢²á¹«Ë¾£¬ËùÓвɹº¼°ºÏ×÷ÏîÄ¿¾ù¿ÉÇ©ÊðºÏ·¨ÕýʽºÏͬ£¡
±¾¹«Ë¾ÊÛǰ³Ðŵ£ºËù¹©É豸¾ùΪȫÐÂÔ­×°£¡±£Ö¤°´³§¼Ò¹æ¶¨Ãâ·Ñ±£ÐÞ£¡
±¾¹«Ë¾ÊÛºó³Ðŵ£º±¾¹«Ë¾Å䱸·Ç³£×¨ÒµµÄÒôƵ¼¼ÊõÍŶӣ¬"365 x 24È«ÄêÈ«Ììºò"ΪÄúÌṩ¼¼ÊõÖ§³Ö·þÎñ£¡
»¶Ó­À´µç×Éѯ£¨µË¾­Àí £© QQ£º3490029085£» µç»°/΢ÐÅ£º 13370149101£¨ÍƼö£© £»¶þÊ®ËÄСʱΪÄú¿ª»ú£¡
