»¶Ó¹âÁ٠¼ÒôÅïϵͳ¼¯³ÉÉÌ¡ª¡ª±±¾©ÀÖ³ÇÊ˹ú¼Ê¿Æ¼¼ÓÐÏÞ¹«Ë¾
±¾¹«Ë¾ÎªÊµÌå¾ÓªµÄºÏ·¨×¢²á¹«Ë¾£¬ËùÓвɹº¼°ºÏ×÷ÏîÄ¿¾ù¿ÉÇ©ÊðºÏ·¨ÕýʽºÏͬ£¡
±¾¹«Ë¾ÊÛǰ³Ðŵ£ºËù¹©É豸¾ùΪȫÐÂÔ×°£¡±£Ö¤°´³§¼Ò¹æ¶¨Ãâ·Ñ±£ÐÞ£¡
±¾¹«Ë¾ÊÛºó³Ðŵ£º±¾¹«Ë¾Å䱸·Ç³£×¨ÒµµÄÒôƵ¼¼ÊõÍŶӣ¬"365 x 24È«ÄêÈ«Ììºò"ΪÄúÌṩ¼¼ÊõÖ§³Ö·þÎñ£¡
»¶ÓÀ´µç×Éѯ£¨µË¾Àí £© QQ£º3490029085£» µç»°/΢ÐÅ£º 13370149101£¨ÍƼö£© £»¶þÊ®ËÄСʱΪÄú¿ª»ú£¡
¶¥¼¶µÄÄ£Äâת»»£¬¾ßÓиߴï192kHzºÍDSDÊä³ö²ÉÑùÂʵÄÊý×Öת»»¿¨¡£ÖÕ¼«Ä£Äâµç·¼¼ÊõÓë׿ԽµÄÊý×Öת»»ºÍ8816ÅäºÏʹÓᣠ¹«Ë¾ÏÖÒѳÉΪ´«ÆæµÄÉùÒôÄá·ò8816»ìºÏÆ÷£¬»ùÓÚÉú²úÕß¡£×ÛºÏÊäÈ룬»ìºÏºÍ¼à¿Ø¹¦ÄÜÉý¼¶µÄDAWרҵµÄ»ìºÏÉ豸¡£Ê®ÁùÊäÈëͨµÀ°üÀ¨Ë®Æ½£¬ÇиîºÍÌáʾ¿ØÖÆ¡£Ò»¸ö15dbÔöÒæ·¶Î§¿ÉÈÝÄÉÁ½-10dBv¹¤×÷ºÍ+4dBmµÄÊäÈëµçƽ¡£Èç¹ûÊ®ÁùµÄͶÈë²»×ãÒÔÈÃÄãµÄ×éºÏ£¬8816¶à¸öµ¥Î»¿ÉÒÔ¼¶ÁªÔÚÒ»Æð£¬Í¨¹ý¹Ì¶¨Ë®Æ½Ë«¹ìBuss¡£***ÖÕµÄÄ£ÄâµÄ»ìºÏ×ÜÏßÀûÓþµäNeve±äѹÆ÷»ìºÏ²¼¾Ö¡£»ìºÏÊä³öͬʱƽºâ+4 -10dBv¹¤×÷³öÏÖ²»Æ½ºâ¡£»ìºÏ²åÈëÔ¤ÍÊÉ«ÍêÈ«¿ØÖÆ£¬¿ÉÒÔÕý³£²åÈëģʽºÍÕÆÎÕ·ç¸ñºÍÁ¢ÌåÉù¿í¶È¿ØÖƵIJ»Í¬Ä£Ê½Ö®¼äÇл»¡£ºó²åÈë×éºÏ¹¦ÄÜ¿ÉÓÃÓÚÔÚÒ»¸öµ¥¶ÀµÄ¸É»ò»ìºÏÓÐÌØÊâЧ¹ûµÄ»ìºÏ¡£ Features:•Total Recall stored via USB ÌØµã£º•¹²ÕÙ»ØÍ¨¹ýUSB´æ´¢ •16 inputchannels plus aux additional inputs •16ÊäÈëͨµÀ¼Ó¸¨Öú¶îÍâÊäÈë •Cue, Level,Pan, Solo and Mute controls •ÏßË÷£¬Ë®Æ½£¬ÉùÏñ£¬¶À×àºÍ¾²Òô¿ØÖÆ •ClassicNeve analogue transformer mix buss •¾µäÄá·òÄ£Äâ±äѹÆ÷µÄ»ìºÏ×ÜÏß •Mix Insertpoints •»ìºÏ²åÈëµã •Varioussolo and solo in place functions ÔÚ¹¦ÄÜ•¸÷ÖÖ¶À³ªºÍ¶À×à •Sum anddifference insert with exclusive "Stereo Width Control" •ºÍ¶ÀÌØµÄ¡°Á¢Ìå¿í¶È¿ØÖƲî²åÈ롱 •Dance mixstyle insert Mix function •ÎèÇú·ç¸ñ²åÈë»ìºÏ¹¦ÄÜ •SeparateMonitor and Cue levels •¶ÀÁ¢µÄ¼à¿ØºÍÌáʾµÄˮƽ •Main andAlt speaker outs •Ö÷ÒªºÍALTÑïÉùÆ÷³ö¾Ö •In builttalkback mic and headphone Output •ÄÚÖöԽ²»°Í²ºÍ¶ú»úÊä³ö •Optionaldigital output card •¿ÉÑ¡µÄÊý×ÖÊä³ö¿¨ •Units canbe cascaded for multiple output •µ¥Î»¿ÉÒÔ¼¶Áª¶à¸öÊä³ö •2 rack Uhigh with special shielded power supply •2¼Ü¸ßÌØÊâÆÁ±ÎµçÔ´ An optionaldigital output converts the analogue mix to any standard PCM sample rate up to192kHz or DSD, a unique feature extending Neve¡¯s commitment to the ultimateanalogue and digital sound. Output PPM meters are complemented by overload LEDsto indicate clipping at the ADC or analogue output. The monitor section selectsbetween Mix Out, 2 Track Return, Channels 1 & 2 (DAW mix replay) and"i- mon" front panel input min-jack, handy for quick mix comparisons.The monitor level is independent of the mix level and the monitor outputs canbe switched between Main and Alt speakers. A separate Cue Output can be fedfrom three sources and the inbuilt Talkback mic. Headphones can be used tolisten to either Cue or Monitor source. The final touch? Total recall! A USBconnector allows snapshots of the 8816 setting to be saved to a PC and recalledready for remix! •Creating a professional mix environment for Ò»¸ö¿ÉÑ¡µÄÊý×ÖÊä³öת»»³ÉÄ£Äâ»ìºÏµ½Èκαê×¼µÄPCM²ÉÑùÂʸߴï192kHz»òDSD£¬ÑÓÉì***ÖÕµÄÄ£ÄâºÍÊý×ÖÉùÒô¶ÀÌØµÄÌØÕ÷¡£Êä³öPPMÃ׸¨ÒÔ¹ýÔØLEDÏÔʾ¿¨ÔÚADC»òÄ£ÄâÊä³ö¡£¼à²â¶ÏÃæÑ¡ÔñÖ®¼äµÄ»ìºÏ£¬2¹ìµÀ·µ»Ø£¬Í¨µÀ1ºÍ2£¨DAW»ìÒôÖØ·Å£©ºÍ¡°ÎÒ-ÎÒ¡±Ãæ°åÊäÈë***Сǧ½ï¶¥£¬·½±ã¿ìËÙ×éºÏµÄ±È½Ï¡£¼à¿ØË®Æ½ÊǶÀÁ¢µÄ»ìºÏˮƽºÍÏÔʾÆ÷Êä³ö¿ÉÒÔÖ÷ÒªºÍALTÑïÉùÆ÷Ö®¼äÇл»¡£Ò»¸öµ¥¶ÀµÄÐźÅÊä³ö¿ÉÓÉÈýÔ´ºÍÄÚÖõĶԽ²»°Í²¡£¶ú»ú¿ÉÒÔÌýÈκÎÌáʾ»ò¼àÊÓÔ´¡£***ºóµÄÁªÏµÂð£¿È«Ãæ»ØÒ䣡һ¸öUSBÁ¬½ÓÆ÷ÔÊÐí¿ìÕÕ8816ÉèÖñ»±£´æµ½µçÄÔÕÙ»Ø×¼±¸»ìÒô£¡•´´½¨Ò»¸öרҵµÄ»ìºÏ»·¾³ •DAW basedproducers
