AVID Artist DNxIV È«¸ñʽÊÓÆµ½Ó¿ÚÏä
Ó²¼þ²úÆ·
»¶Ó­¹âÁ٠¼ÒôÅïϵͳ¼¯³ÉÉÌ¡ª¡ª±±¾©ÀÖ³ÇÊ˹ú¼Ê¿Æ¼¼ÓÐÏÞ¹«Ë¾
±¾¹«Ë¾ÎªÊµÌå¾­ÓªµÄºÏ·¨×¢²á¹«Ë¾£¬ËùÓвɹº¼°ºÏ×÷ÏîÄ¿¾ù¿ÉÇ©ÊðºÏ·¨ÕýʽºÏͬ£¡
±¾¹«Ë¾ÊÛǰ³Ðŵ£ºËù¹©É豸¾ùΪȫÐÂÔ­×°£¡±£Ö¤°´³§¼Ò¹æ¶¨Ãâ·Ñ±£ÐÞ£¡
±¾¹«Ë¾ÊÛºó³Ðŵ£º±¾¹«Ë¾Å䱸·Ç³£×¨ÒµµÄÒôƵ¼¼ÊõÍŶӣ¬"365 x 24È«ÄêÈ«Ììºò"ΪÄúÌṩ¼¼ÊõÖ§³Ö·þÎñ£¡
»¶Ó­À´µç×Éѯ£¨µË¾­Àí £© QQ£º2752796326£» µç»°/΢ÐÅ£º 13370149101£¨ÍƼö£© £»¶þÊ®ËÄСʱΪÄú¿ª»ú£¡
Avid Artist | DNxIV ÊÇÓÉAJA´ú¹¤Éú²úµÄÒ»¿îÖ§³ÖAvid DNxHRºÍDNxHD¸ñʽµÄÈ«¸ñʽÊÓÆµ½Ó¿ÚÏ䣬ͨ¹ýÀ×µçIIIÐͽӿÚÖ±Á¬ÖÁÆ»¹ûÖ÷»ú£¬ÊµÏÖMedia ComposerµÄÈ«¸ñʽ£¨SD£¬HD£¬UHD£¬2K£¬4K£©ÊÓÆµÊäÈëÓëÊä³ö¹¦ÄÜ
²úÆ·ÏêÇ飺
Âú×ãÄãÐèÒªµÄËùÓÐÁ¬½Ó½Ó¿Ú
Avid Artist | DNxIV ÄÜΪÄã½ñÌìʹÓõĶàÑù»¯µÄýÌå²úÆ·ÌṩËùÓеÄרҵģÄâºÍÊý×ÖI/O£¬´Ó 12G£¨µ¥Í¨µÀ£©/6G£¨Ë«Í¨µÀ£©/ 3G£¨ËÄͨµÀ£© SDI¡¢HDMI 2ºÍDB-25£¬µ½XLR¡¢LTC¡¢RS-422ºÍ¶ú»ú²å¿×£¬ÄãÓи÷ÖÖ¸÷ÑùµÄÁ¬½Ó£¬¿ÉÒÔ½«ÄãµÄÉ豸¼¯³Éµ½Ò»Æð£¬ÓÃÓÚ¹¤×÷ÊÒÊÓÆµºÍºóÆÚÖÆ×÷£¬»òÕßÈκδø¸øÄãÁé¸ÐµÄµØ·½¡£
À©Õ¹ÄãµÄDZÁ¦
ËäÈ»Ìå»ýС£¬µ«Êǹ¦ÄÜÇ¿º·£¬Avid Artist | DNxIVÔöÇ¿ÁËÄúµÄýÌåÉú²úÄÜÁ¦£¬³¬³öÁ˱ê×¼µÄ²¶»ñ¡¢¼àÊÓºÍÊä³ö¹¤×÷Á÷³ÌµÄ¶¨Òå¡£¿ÉÒÔ²¿ÊðÔÚÏîÄ¿ÔË×÷ÖеÄÈκνڵ㣬ȡ¾öÓÚÆä³öÉ«µÄ¿ÉÒÆÖ²ÐÔ¡£Ö±½ÓÂ¼ÖÆ»­ÍâÒôµ½Media ComposerµÄʱ¼äÏߺÍÇáËɵÄÒôƵ²åÈ롣ʵʱ¼à¿´HDRµÄÄÚÈÝ¡£¿ÉÍâ½Óͬ²½Ðźš£¿ØÖÆ´Å´øÂ¼Ïñ»úµÄÖ¡¾«¶È²¶»ñºÍ×ßÂë¡£ÄúÉõÖÁ¿ÉÒÔʹÓøýӿÚ×÷Ϊ8ͨµÀÒôƵ»·ÈÆÉù¼àÌý½â¾ö·½°¸¡£
ΪͼÏñ½øÐб༭ÒÔ¼°»ìºÍÒôƵ
Avid | Artist DNxIV»¹¿ÉÒÔÓëProToolsºÍProTools| UltimateÒ»ÆðʹÓã¬ÒÔÖ§³Ö¸ßÖÊÁ¿ÊÓÆµÔڹ㲥¼àÊÓÆ÷Éϻطš£ÕâʹµÃ¸Ã½Ó¿Ú³ÉΪһÖÖ¶àÓÃ;µÄ½â¾ö·½°¸£¬¿ÉÒÔ½«ÒôƵºÍ×÷Çú»ìºÏµ½»­ÃæÖУ¬Ò²¿ÉÒԱ༭¶Ô»°¿ò¡¢ADRºÍFoley£¬Æäͬ²½¾«¶È³¬¹ý1/4Ö¡¡£
¼¼Êõ²ÎÊý£º
Ö§³ÖµÄýÌå¸ñʽ
ÊÓÆµ¸ñʽ:
SD¡ªPAL 25i, NTSC 30i HD¡ª720p (50, 59.94, 60*), 1080i (50, 59.94, 60), 1080PsF (23.98, 24, 25, 29.97, 30), 1080p (23.98, 24, 25, 29.97, 30, 47.96*, 48*, 50, 59.94, 60) 2K¡ª23.98PsF, 24PsF, 25PsF, 29.97PsF, 30PsF, 23.98p, 24p, 25p, 29.97p, 30p, 47.96p*, 48p*, 50p, 59.94p, 60p Ultra HD¡ª23.98p, 24p, 25p, 29.97p, 30p, 47.952p*, 48p*, 50p, 59.94p, 60p4K¡ª23.98p, 24p, 25p, 29.97p, 30p, 47.952p*, 48p*, 50p, 59.94p, 60pRaster support¡ªSupports thin raster media scaled up to full frame on output
ÒôƵ²ÉÑù:
16-bit, 24-bit, 48 kHz (television standard)
É«Óò:
YUV 4
ÊÓÆµÒÔ¼°ÒôƵÁ¬½Ó ¡¡
SDI I/O:
Four bidirectional SDI ports and one 3G-SDI monitor output
Ö÷»úÁ¬½ÓÒÔ¼°Í¬²½½Ó¿Ú ¡¡
µçÄÔ:
Two Thunderbolt 3 ports (cable sold separately)
LTC I/O:
Switchable LTC or video reference input on BNC, LTC output on BNC
É豸¿ØÖÆ:
One RS-422 machine control port
Ó²¼þ¼¶±ðµÄÉÏϱ任ÒÔ¼°ÐźŴ¦Àí ¡¡
Down-scaling/conversion:
4K to 2K, UHD to HD, HD to SD
Up-scaling/conversion:
SD to HD
Cross-conversion:
720p to 1080i HD, 1080i to 1080p, 1080i to 720p
Other conversion:
Color space conversion*, hardware deinterlacing
Real-time keyer:
Alpha channel over video, matte, or frame buffer over incoming video or matte
3D processing:
Frame Compatible/Frame Packed
¶îÍâµÄ¹¦ÄÜ ¡¡:
Audio pass-through mixing:
Monitor mix the audio being captured (8 channels)
Clock source (selectable/detectable):
Genlock/Reference Clock (BBG or Tri-level), Internal Clock, SDI (SD and HD), HDMI
Ancillary data support:
SDI VITC reader, RP188 Timecode I/O, NTSC (closed captioning), HD-SDI (closed captioning), pass through all (HD), pass through all (4K)
¶îÍâµÄ¹æ¸ñ ¡¡:
Power (device only):
10¨C20V, 30W typical, 36W max, 70W max with USB-C power delivery to external devices
Power supply:
One built-in international AC power supply (120¨C240V, 50¨C60 Hz)
Operating temperature:
32¡ã¨C104¡ã F (0¡ã¨C40¡ã C)
Storage temperature:
-40¡ã¨C140¡ã F (-40¡ã¨C60¡ã C)
Relative humidity:
10¨C90% non-condensing
Operating altitude:
<10,000 feet (<3,000 meters)
Dimensions (H x W x D):
1.7 x 8.7 x 8.1 inches (42 x 222 x 206 mm)
Weight:
3.4 °õ (1.5 ¹«½ï)
¸ü¶àͼƬ Сͼ ´óͼ
×éͼ´ò¿ªÖУ¬ÇëÉÔºò......
