Spitfire Audio ·¢²¼ÓÃÓÚKONTAKT ÀÖÆ÷µÄ¹Ü·çÇÙÒôÉ«¿âSymphonic Organ
ʵÏÖÔÚ¡¶ÐǼʴ©Ô½¡·¡¢¡¶2001£ºÌ«¿ÕÂþÓΡ·ºÍ¡¶´´¡·µÈ´óƬÖÐÎÅÃûµÄò¯³ÏµçÓ°ÉùÒô¡£Â¡ÖؽéÉÜÀ­¸ñ±ÈѧУ½ÌÌùܷçÇÙ - Ò»ÖÖ¾Þ´óµÄ´ó½ÌÌôóСµÄ¹Ü·çÇÙ£¬ÓÉ 3,721 ¸ö¹Ü·çÇÙ×é³É£¬°²ÖÃÔÚÒ»¸ö˽ÃܵĽÌÌÃÖУ¬´´Ôì³öÓëÆäËûÈκιܷçÇÙ²»Í¬µÄÊ·Ê«°ãµ«Ö±½ÓµÄÉùÒô¡£
¸ñʽ£º KONTAKT
ÖÊÁ¿£º 24 λ 48 kHz Á¢ÌåÉù
ÃèÊö£º ׿ԽµÄµçÓ°·çÇÙ
ϵͳҪÇó£ºKONTAKT PLAYER »ò FULL£¨°æ±¾ 5.6.8 »ò¸ü¸ß°æ±¾£©¡£
To capture its unique depth, power and beauty, we teamed up with composer, producer and organ expert Andy Richards, who has curated stop combinations for instant playability, enabling you to get the best out of this beautifully-voiced instrument.
His impressive discography includes work on huge film scores, including Slumdog Millionaire, and records by iconic artists from Grace Jones to George Michael. Every pitch has been recorded with multiple mic positions for ultimate realism and control, accompanied by 50 mind-bending warped presets presented in our eDNA engine.
The ultimate organ
A hugely versatile instrument now widely used beyond its original church or horror film setting, the organ is perfect for adding depth, power and beauty to orchestral scores and compositions. As well as in renowned symphonic works such as Saint-Saens¡¯ Organ Symphony, the organ provides the foundations for countless blockbuster film scores of various genres, including Koyaanisqatsi (Philip Glass), Vertigo (Bernard Herrmann), Interstellar (Hans Zimmer), 2001: A Space Odyssey (from Richard Strauss¡¯ 1896 work Also Sprach Zarathustra) and Tron (Wendy Carlos). There is no orchestral instrument that can go lower in pitch, giving you thunderous sub-bass like depth that you feel rather than hear.
As soon as Spitfire founder and composer Paul Thomson heard the Rugby School Chapel Organ, he knew Spitfire had to sample it.
Heard in the opening sequence to Tim Burton¡¯s Sweeney Todd, the contrast of this cathedral-sized organ ¡ª four manuals (keyboards), 71 stops (of which 55 are speaking stops) and 3,721 pipes ¡ª with its intimate chapel acoustic setting, creates an epic sound, producing a unique intensity and immediacy. Expertly recorded and presented, this definitive organ library has been designed to fit perfectly with our Symphonic range, enabling you to create rich sounding scores.
The overview panel
This is the main interface for melodic instruments. Its default view displays all available playing techniques, has a simple microphone mixer and includes the main feature controllers.
eDNA Engine
This interface houses our own sample-synthesiser engine. You can use it to combine two sounds and modulate between them with envelopes, filters and wobbles per sound, as well as a gate sequencer and a selection of go-to FX.
Tech specs
Mac system requirements
~ Mac OS 11, 12 or 13
~ Both Intel and Apple Silicon/ARM are supported
~ Minimum: 2.8GHz i5 minimum (quad-core), 8GB RAM
~ Recommended: 2.8GHz I7 (six-core), 16GB RAM
~ 32-bit systems are not supported
PC system requirements
~ Windows 10 or Windows 11 - (Latest Service Pack, 64-bit)
~ Minimum: Intel 2.8 GHz i5 (quad-core) or AMD Ryzen 5, 8GB RAM
~ Recommended: Intel Core i7 6th gen and later or AMD Ryzen 7, 16GB RAM
File size
~ 17760 samples
~ 23.8 GB download size
~ 24.00 GB disk space required during install
Kontakt player
~ Kontakt Full or Kontakt Player 5.6.8 or higher required
¹ÙÍø£ºhttps://www.spitfireaudio.com/symphonic-organ#overview
ÏÂÔØ£º Spitfire Audio - Symphonic Organ (KONTAKT) [rutracker-6461580].zip (125.82 KB, ÏÂÔØ´ÎÊý: 1)
