音频应用   音频插件联盟,正版插件,欢迎大家选择!
阅读: 10333|回复: 0
[软件] AbyssMedia Streaming Audio Recorder 3.0
发表于 2022-8-28 | |阅读模式
AbyssMedia Streaming Audio Recorder Download has become very popular last years. Streaming Audio Recorder is an easy-to-use program that allows you to top up your music collection with unlimited free music. The recorder supports multiple streaming services like Spotify, YouTube, Pandora, Apple Music, Sirius Radio, Yahoo Music, SoundCloud, and many others to record audio with a single click. The recorder is a 100% legal way to record your favorite tracks from music stations for free for personal use. You May Also Like To Download: GiliSoft Audio Recorder Pro Crack
AbyssMedia Streaming Audio Recorder Free Download is worth mentioning because the application automatically detects the format of streamed files. It supports multiple services, from YouTube and Spotify to SoundCloud and Sirius Radio. While the app usually determines the optimal recording parameters, you can select the quality and the file size.
AbyssMedia Streaming Audio Recorder Key Features:
  • Automatic format detection
    The recorder determines the optimal recording parameters, and you only need to choose between quality and file size. It supports the most popular MP3 and OGG formats and WAV and FLAC lossless formats for the highest quality.
  • Automatic splitter
    It allows you to split tracks for a specified time or to work in Smart mode. Smartly, the software detects the silences between songs and creates a separate file for each channel. Short tracks, most of which are commercials, can be deleted automatically.
  • Advanced Scheduler
    You can schedule recording for many months ahead. The scheduler can launch and close programs, open a web page and automatically generate a file name for the recording.
  • Simple but feature-rich
    The interface is maximally simplified, and even a child can understand it. At the same time, advanced users can use the advanced settings.
  • Do not clutter up your system.
    We do not install virtual sound cards that degrade performance and stability; we use only standard Windows functions that ensure compatibility with future updates.
  • Easily edit recordings
    You can use a free sound editor add-on if you wish to edit the audio files after recording. Open the recording browser, select your recording, and click the “Edit file in sound editor” button. The first time it will download and install the add-on, the next time, it will load an audio file to the editor automatically.
  • Recording Browser
    It allows you to listen, delete, copy, edit tags, and send recordings to iTunes.
AbyssMedia Streaming Audio Recorder Full Crack
How To Patch, Activated & Crack AbyssMedia Streaming Audio Recorder Full Version?
  • Download,Newest Version From PcCrackWorld.com
  • Copy Crack Folder Files And Replace To Install Directory
  • Done! Enjoy The Latest Version Of AbyssMedia Streaming Audio Recorder Cracked
https://www.pccrackworld.com/abyssmedia-streaming-audio-recorder-crack-download/
