ÁçÑòAntelope FX ²å¼þ
¹ºÂòZEN GO¡¢D4PRO D8PRO£¬´øÓÐ Synergy Core ±êʶµÄÁçÑòÉù¿¨£¬ÔùËÍÏÂÁвå¼þ£¬ÀÛ¼ÆÓÐ37¸ö
STAY-LEVIN ¹ÜʽѹËõ¶¯Ì¬´¦ÀíÆ÷
¼òµ¥µÄÉè¼ÆºÍ¿ØÖÆ£¬Ê·Ê«°ãµÄÍâ¹Û£¬½áʵµÄÉùÒô¡£Stay-LevinÊÇÒ»¸öËÜÔìÃÀ¹ú20ÊÀ¼Í60Äê´ú¾­µäÉùÒôµÄµ¥Ôª¡£ºÁÎÞÒÉÎÊ£¬Ëü¾ßÓÐ×Ô¼ºµÄÌØÕ÷ºÍȾɫ£¬ËüÖØÏÖÁ˵ç×Ó¹ÜѹËõÆ÷µÄ´«Ææ£¬¸Ã´«Ææ½«ÎªÄúµÄµ±´ú×÷Æ·Ìí¼ÓËùÐèµÄÄ£ÄâÓÅÊÆ¡£Æä¼òµ¥µÄÇ°Ãæ°å¿ØÖÆ£¬Ö»ÓÐÁ½¸öÐýÅ¥ºÍÁ½¸ö¿ª¹Ø£¬¿ÉÒÔ²úÉúÁîÈ˾ªÑȵIJ»Í¬Ñ¹Ëõ·ç¸ñ£¬¿ÉÒÔÔöÇ¿ÈËÉù¡¢Ô­Éù¼ªËûºÍºÏ³ÉÆ÷Ö÷Òô¡£ÓÃËü¶Ô´ýÄãµÄµÍÒôºÍ¹Ä£¬ËüÃÇ»á±äµÃ¸ü´ó¡¢¸ü¾ùÔÈ¡£×îºÃµÄ¸´¹ÅѹËõ£¬ÔÚFPGA¼¼ÊõÁìÓòÖÐÖØÐ´´½¨£¬ÒÔ»ñµÃʵʱFXÔËÐС£
Simple design and controls, epic looks, massive sound. Stay-Levin is a unit that shaped the sound of the US 1960s classics. Without a doubt carrying a character and color of its own, it recreates a valve compressor legend that will add a desired analog edge to your contemporary production. Its simple front panel set of controls, featuring only two knobs and two switches, can result in a surprisingly varying compression styles, which can enhance vocals, acoustic guitars and synth leads. Treat your bass and drums with it and they¡¯ll grow bigger and meaner. Vintage compression at its finest, recreated in the FPGA domain for real-time FX perfection.
https://en.antelopeaudio.com/products/stay-levin/
A-TUNER¼ªËûµ÷ÒôÆ÷
ÊÇÒ»ÖÖ»ùÓÚÓ²¼þµÄÈí¼þЧ¹ûÆ÷£¬ÔÚAntelope Audio½çÃæµÄÄÚÖÃSynergy Core FX´¦ÀíÆ½Ì¨ÉÏʵʱÔËÐС£Èç¹ûÄúϲ»¶ÄúµÄÀÖÆ÷ÍêÃÀµ÷Òô£¬µ÷ÒôÆ÷ÊÇÒôƵ¿âÖбز»¿ÉÉٵŤ¾ß¡£Antelope µ÷ÒôÆ÷ÊÇÒ»¸ö¼òµ¥µÄ¡¢¿ÉÁ¢¼´Ê¹Óõĵ÷ÒôÆ÷µÄ¾­µäʾÀý£¬ÊÊÓÃÓÚÄúµÄ¼ªËû¡¢±´Ë¾ºÍÄú¿ÉÄÜÕýÔÚʹÓÃµÄÆäËûÀÖÆ÷¡£Antelopeµ÷ÒôÆ÷µÄƵÂÊ¿ÉÒÔÒ»Ö±½µµÍµ½30Hz£¨B0£©£¬Ò»Ö±µ½1400Hz£¨F6£©£¬ÊÇÄúÒôÀÖÊÂÒµÖÐÖµµÃÐÅÀµµÄºÏ×÷»ï°é¡£µÃÒæÓÚAntelope½çÃæµÄÁãÑÓ³ÙFX´¦Àí£¬ËüÒ²¿ÉÒÔÁ¢¼´ÏìÓ¦£¡ËùÒÔ²»Òªº¦ÅÂÔÚÏÖ³¡ºÍ¹¤×÷ÊÒʹÓÃÕâ¸ö¡£
A-Tuner is a hardware-based software effect which runs in real-time on your Antelope Audio interface¡¯s built-in Synergy Core FX processing platform.
If you like your instruments to be in perfect tune, the tuner is an essential, indispensable tool in your audio arsenal. The Antelope Tuner is a classic example of a no-frills, immediately usable tuner for your guitar, bass, and other instruments you may be using.
Reaching all the way down to 30Hz (B0) all the way up to 1400Hz (F6), the Antelope Tuner is a trusty partner in your musical endeavors. It¡¯s also one to respond immediately, thanks to your Antelope interface¡¯s zero-latency FX processing! So do not fear using this one both live and in the studio.
https://en.antelopeaudio.com/products/a-tuner/
ÈçºÎʹÓÃ
Ö»Ð轫A-Tuner²åÈëFXÁ´µÄ¶¥²¿£¬²¢¸ù¾ÝÊÓ¾õÒDZíµ÷ÕûÒÇÆ÷¼´¿É¡£ËæÒâʹÓÿª/ÈÆ¹ý°´Å¥´ÓÐéÄâ×ê»úÖÐÆôÓûòÅųýµ÷гÆ÷¡£
*A-Tuner×÷ΪÃâ·Ñ²å¼þÌṩ¸øËùÓÐSynergy CoreÓû§¡£Ö»Ð轫½çÃæ¸üе½×îеÄÀ¦°ó°æ±¾£¬²¢ÔÚ¿ØÖÆÃæ°åÖÐÕÒµ½Ð§¹û¡£
POWERGATEÔëÒôÃŶ¯Ì¬´¦ÀíÆ÷
ÊǵÚÒ»¸öAntelope AudioÔëÒôÃŹ¤¾ß¡£Ó¦ÎÒÃÇÖµµÃÐÅÀµµÄÓû§µÄÒªÇó£¬ÎÒÃÇËùÓÐµÄ Thunderbolt ºÍ USB »ò HD ½Ó¿Ú¶¼¿ÉÒÔÃâ·ÑʹÓÃËü¡£PowerGateÔÊÐíÄú¸ú×ÙÀ´×Ô¾ßÓв»ÐèÒª±³¾°»òµØÃæÔëÒôµÄÀ´Ô´µÄÒôƵ¡£Ëü½«Ê¹ÄúµÄÉùÒôÃâÊÜÈκÎÈ˹¤ÖÆÆ·µÄÓ°Ï죬ÀýÈç²»Á¼µÄ¹²Õñ¡¢À´×ÔÆäËûÀ´Ô´µÄ´®Òô»ò¹ý³¤µÄÑÓÒô¡£PowerGate¾ßÓÐÒ»×é±ê×¼¿Ø¼þ£¬ÈçãÐÖµ¡¢Æô¶¯¡¢±£³Ö¡¢Ë¥¼õ¡¢·¶Î§ºÍÔöÒæ¡£ËüÃÇʹÄú¿ÉÒÔ¸ù¾ÝÈκÎÉùÒôµ÷ÕûЧ¹û¡£
PowerGate is the very first Antelope Audio noise gate tool. Requested by our trusted users, it is available with all our Thunderbolt & USB or HD interfaces for free. PowerGate allows you to track audio from sources with unwanted background or ground noise. It will keep your sound free of any artifacts, such as bad resonances, bleeds from other sources, or excessive sustain. PowerGate features a standard set of controls, such as Threshold, Attack, Hold, Decay, Range, and Gain. They let you adapt the effect to any kind of sound.
https://en.antelopeaudio.com/products/power-gate/
Antelope Audio Power EXÄÚ²¿À©Õ¹Æ÷
ÔÚÎÒÃÇËùÓеĽӿÚÖж¼ÓС£Ëü¾ßÓÐÒ»×éÈ«ÃæµÄ¿Ø¼þ£¬°üÀ¨ãÐÖµ¡¢·¶Î§¡¢±ÈÂÊ¡¢ÆðÒôºÍË¥¼õÐýÅ¥£¬ÒÔ¼°¶îÍâµÄÔöÒæÐýÅ¥£¬ÔÊÐíÄú¶ÔÒôÁ¿½øÐÐһЩ¶îÍâµÄ¿ØÖÆ¡£ÕâÊÇÒ»¸öÆÓʵÎÞ»ªµÄµ¥Ôª£¬µ«Æä¼òµ¥ÐÔÒþ²ØÁËÐí¶àÉùÒôËÜÔìµÄDZÁ¦£¬ÓÉAntelope Audio FPGAƽ̨Ìṩ֧³Ö£¬±£Ö¤ÁËÉùÒôµÄÕæÊµ£¬¿ÉÓëÕæÕýµÄÓ²¼þÀ©Õ¹Æ÷ÏàæÇÃÀ¡£
The Antelope Audio Power EX is an in-house expander, featured in all our interfaces. It features a comprehensive set of controls, including Threshold, Range, Ratio, Attack and Decay knobs with additional Gain knob allowing you some extra control over the volume. It¡¯s an unpretentious unit, but its simplicity hides a lot of potential for sound shaping and being powered by the Antelope Audio FPGA platform is a guarantee for an authentic sound, comparable to real hardware expanders.
https://en.antelopeaudio.com/products/power-ex/
CLEAR Q²ÎÊý¾ùºâÆ÷
Antelope AudioµÄ¼¯³É¾ùºâÆ÷Ìṩ5¸öÈ«²ÎÊýƵ¶Î£¬ÆäÖÐÁ½¸ö¿ÉÒÔÔÚÂ˲¨Æ÷»ò¸é¼ÜÉϹ¤×÷£¬ÖмäµÄÈý¸ö¿ÉÒÔË¥¼õ»òÔöǿѡ¶¨µÄƵÂÊ·¶Î§¡£ÎÒÃǵÄÓû§Ò»Ö±ÔÚʹÓÃÕâ¸öÉè¼Æ¼òµ¥µ«ÉùÒôÍêÃÀµÄ²å¼þÀ´½øÐмÒô»ìÒô£¬ÒòΪËü¼òµ¥µØÌṩÁËÄúÔÚ¾ùºâÆ÷ÖпÉÄÜÐèÒªµÄËùÓж«Î÷¡£
Antelope Audio¡¯s integrated EQ offers 5 fully parametric bands, two of those can work in filter or shelving motde the three in the middle can cut or boost selected frequency ranges. Our users have been using this simply designed yet perfectly sounding plug-in for both tracking in mixing, because it simply provides all that you might need in an EQ.
https://en.antelopeaudio.com/products/clear-q/
POWERFFCǰ·´À¡Ñ¹ËõÆ÷
Antelope Audio FeedForward Compressor³öÏÖÔÚÎÒÃÇËùÓеĽçÃæÖС£ËüÅ䱸ÁËËùÓбØÒªµÄ¿Ø¼þ¡ª¡ªãÐÖµ¡¢±ÈÂÊ¡¢Æô¶¯¡¢Êͷź͹յ㡣´ËÍ⣬¼ì²âÆ÷ÏÂÀ­²Ëµ¥ÌṩÁ˶àÖÖ·åÖµ/RMS¸ÐӦģʽ¿É¹©Ñ¡Ôñ£¡FeedForward CompressorÒ×ÓÚʹÓ㬵«ËüµÄ¹¤×÷×öµÃºÜºÃ¡ª¡ªÍ¬Ê±ÌýÆðÀ´ºÜÏñÒ»¸öÕæÕýµÄÓ²¼þµ¥Ôª¡£ÏíÊÜÓëËüÒ»Æð¹¤×÷µÄÀÖȤ£¡
The Antelope Audio FeedForward Compressor is featured in all our interfaces. It comes with all the necessary controls ¡ª Threshold, Ratio, Attack, Release, and Knee. Furthermore, the Detector drop-down menu offers several Peak / RMS sense modes to choose from! The FeedForward Compressor is easy to use, but it gets the job done just right ¡ª all while sounding quite like a real hardware unit. Enjoy working with it!
ͼƬhttps://en.antelopeaudio.com/products/powerffc/
VEQ-HLF¾ùºâÆ÷
Õâ¸ö¼òµ¥ÓÐЧµÄÂ˲¨Æ÷ÓÐÁ½¸öÐýÅ¥£ºÒ»¸öÓÃÓÚÔÚ¾«ÐÄÑ¡ÔñµÄƵÂʼä¸ôϽøÐб»¶¯Ê½µÍÇк͸ßÇÐÂ˲¨Æ÷¡£Ã¿¸öƵ¶ÎÓÐ10¸öƵÂʿɹ©Ñ¡Ôñ£¬Í¨¹ýÏû³ýÒôƵƵÆ×¼«¶ËµÄ²»ÐèÒªµÄƵÂÊ£¬Í¬Ê±È·±£ÒôÀÖÐÔµÄÄ£ÄâÒôÖÊ£¬ÊÇ´´½¨»ìÒô¿Õ¼äµÄÍêÃÀ¹¤¾ß¡£¼´Ê¹Äú²»´òËãʹÓýØÖ¹Â˲¨Æ÷£¬Ò²Çë³¢ÊÔ½«VEQ-HLF²åÈëÄúµÄ´¦ÀíÁ´ÖУ¬ÒÔ»ñµÃÆä¶ÀÌØÇÒ±¸ÊÜ×·ÅõµÄÒôÉ«¡£
This simple and effective filter features two knobs: one each for passive low-cut and high-cut filters at carefully selected frequency intervals. With 10 frequency selections available per band, it is the perfect tool for creating space in your mix by eliminating unneeded frequencies at the extremes of the audio spectrum ¡ª while ensuring a musical analog tone.Even if you don¡¯t intend to use the cutoff filters, try inserting the VEQ-HLF in your processing chain to obtain its peculiar and highly sought-after sound coloration.
https://en.antelopeaudio.com/products/veq-hlf/
VEQ-1A ¾ùºâÆ÷
Èç¹ûÄúÕýÔÚ¶ÁÕâÆªÎÄÕ£¬Äã¿Ï¶¨»á½øÈ빤×÷ÊÒ´«Ææ£¬ËùÒÔÈÃÎÒÃÇ´øÄú»Øµ½60Äêǰ£¬µ±Ê±Ò»¸öµç×ӹܴ«Ææµ®ÉúÁË£¬²¢³ÉΪÊÀ½çÉÏÿ¸öרҵ¹¤×÷ÊÒµÄÒ»²¿·Ö¡£VEQ-1A²å¼þ²»½öΪ¾­µä×÷Æ·×¢ÈëÁËеĻîÁ¦£¬¶øÇÒÌýÆðÀ´ºÍÕæµÄÓ²¼þÒ»Ñùºñʵ£¬ËüȷʵÒþ²ØÁ˺ܶàµÄ¼¼ÇÉ¡£ÀýÈ磬ͬһƵÂʵÄͬʱ˥¼õºÍÔöÇ¿£¬ÕâʹÉùÒô¾ßÓÐÄúÎÞ·¨ÕæÕý»ñµÃµÄÁíÒ»¸ö¾ùºâÆ÷µÄ¶ÀÌØÆ·ÖÊ¡£½áʵµÄµÍÒô¡¢ÈáºÍµÄ¸ßÒôºÍ·á¸»µÄÉùÒô¡ª¡ªÕâЩÐýÅ¥¿Ï¶¨»á²úÉúһЩģÄâħÁ¦£¡
You¡¯re surely into studio legends if you¡¯re reading this, so let¡¯s take you back 60 years ago when a tube legend was born to become a part of every pro studio in the world. The VEQ ¨C 1A plugin is not only breathing a new life into a classic, but sounds as thick as the real piece and it does hide quite a few tricks. For example simultaneous cut and boost of the same frequency, which gives the sound a unique quality you can¡¯t really get with another EQ. Massive bass, gentle highs and richness ¨C these knobs surely do some analog magic!
https://en.antelopeaudio.com/products/veq-1a/
VMEQ-5¾ùºâÆ÷
ûÓÐÐĵÄÖÐÆµ²ÅÊÇÇ¡µ±µÍƵºÍµÄË¥¼õµÍƵºÍ¸ßƵÌýÆðÀ´ÊDzÅÊÇÖÐÆµ?  VMEQ-5ÊÇÖÐÆµ×îºÃµÄÅóÓÑ£¡Í¨¹ýÁ½¸öPEAK£¨ÌáÉý£©´ø¿íºÍÒ»¸öDIP£¨Ë¥¼õ£©´ø¿í¾Í¿ÉÒÔΪÄúµÄÈËÉù¡¢ºÏ³ÉÆ÷¡¢¼ªËûÖ÷Òô»òС¾ü¹ÄÌṩËûÃÇÒ»Ö±ÐèÒªµÄÄ£Äâ³å»÷Á¦¡£ÕâֻСҰÊÞÒ²¿ÉÒÔÏñÀÏ´óÒ»ÑùÊÕʰ»ë×ǵÄÖÐÆµ£¡
What¡¯s proper low- and high-end with no guts in the mids? VMEQ-5 is mid range¡¯s best friend! Two peak bands and a dip band are all you need to give your vocals, synth, guitar leads or snare drum the analog punch they¡¯ve always needed. This little beast can also clean up a murky mid range like a boss!
https://en.antelopeaudio.com/products/vmeq-5/
ÆÀÂÛÁÐ±í£¨1£©
53203780 Â¥Ö÷
Shred Guitar Cabinets Bundle¼ªËû¹ñÌ××°
Shred Guitar Cabinets Bundle ÊÇÓÃÓÚ Shred Guitar Amps Bundle µÄÆ¥ÅäÑïÉùÆ÷ÏäµÄ¼¯ºÏ¡£´ÓСÇɵÄ1 x 12ÏäÌ嵽ǿ´óµÄ4 x 12°ë¶ÑµþÏäÌ壬ËüÓµÓÐÈÃÕâЩ·Å´óÆ÷Ïì³öËùÐèµÄÒ»ÇУ¡ËùÓÐÑïÉùÆ÷ºÍÏäÌ彨ģ¶¼ÊÇʵʱµÄ£¬ÈÃÄú¿ÉÒÔʹÓÃËùÐèµÄÈ·ÇÐÉèÖýøÐÐÏÖ³¡Â¼ÒôºÍ¼àÌý¡£²»Óõ£ÐÄÑÓ³Ù-ËüÏÖÔÚÒѳÉΪ¹ýÈ¥¡£
The Shred Guitar Cabinets Bundle is a collection of matching speaker cabinets for the Shred Guitar Amps Bundle. From tiny, yet shrieking 1 x 12 cabs all the way to mighty 4 x 12 half-stacks, it has everything you need to make those amplifiers sing !All speaker and cabinet modeling happens in real-time, letting you record and monitor live with the exact settings you want. Don't worry about latency - it's now a thing of the past.
https://en.antelopeaudio.com/products/shred-guitar-cabinets-bundle/
Shred Guitar Amps Bundle¼ªËû·Å´óÆ÷Ì××°
×îÈÈÃŵķŴóÆ÷ϵÁУ¬¿ÉÒÔΪÎę̀Ôö¹âÌí²Ê¡£³ýÁËÏÖ´úµÄ¸ßÔöÒæÒ°ÊÞÍ⣬Õâ¸öÀ¦°ó°ü»¹°üº¬Ðí¶àÖøÃûµÄ¾­µä×÷Æ·£¬¶¼ÊǹØÓÚÖØÒ¡¹öºÍ½ðÊôµÄÉùÒô¡£ÃÔÈ˵ÄÉùÒô¡¢Çå´àµÄ½Ú×à¡¢¼â½ÐµÄÖ÷ÒôÒÔ¼°½éÓÚÁ½ÕßÖ®¼äµÄÒ»ÇУ¬ÎÒÃDz»ÒÅÓàÁ¦¡£ÓëAntelope AudioµÄËùÓвúÆ·Ò»Ñù£¬Ã¿¸ö·Å´óÆ÷¶¼¾­¹ý¾«ÐĽ¨Ä££¬Ö±ÖÁÆäµç·ºÍ×é¼þ£¬ÆäÐÔÄÜÓëԭʼӲ¼þÍêÈ«Ïàͬ¡£ÕâÒ»Çж¼ÊÇʵʱ·¢ÉúµÄ£¬ÈÃÄúʹÓÃÄúÏëÒªµÄÈ·ÇÐÉèÖýøÐÐÊµÊ±Â¼ÖÆºÍ¼à¿Ø¡£²»Óõ£ÐÄÑÓ³Ù-ÏÖÔÚÒѳÉΪ¹ýÈ¥
The Shred Guitar Amps Bundle is the most hot-rodded collection of amplifiers to grace the stage. Featuring a number of well-known classics in addition to modern hi-gain beasts, this bundle is all about heavy rock and metal sounds. With captivating cleans, crunchy rhythms, screaming leads, and everything in-between, no stone has been left unturned.As with everything Antelope Audio, each amplifier is meticulously modeled down to its circuit and components, behaving exactly like the original hardware. It's all happening in real-time, letting you record and monitor live with the exact settings you want. Don't worry about latency - it's now a thing of the past
https://en.antelopeaudio.com/products/shred-guitar-amps-bundle/
AURAVERB »ìÏì
Antelope AudioÍÆ³öÁËAuraVerb*£¬ÕâÊÇרҵÒôƵ¹«Ë¾µÄµÚÒ»¸ö»ìÏì¡£»ùÓÚÈí¼þµÄ»ìÏìÀûÓÃÁËAntelope AudioÇ¿´óµÄ64λFPGAоƬ£¬²¢²ÉÓÃÓÉÎÒÃǵÄÊýѧ¼ÒÍŶӣ¨°üÀ¨¹«Ë¾´´Ê¼ÈË Igor Levin£©Éè¼ÆµÄ¶ÀÌØËã·¨¡£¶ÔÁçÑòĿǰÔÚÊ۵ĺÍδÀ´µÄÒôƵ½Ó¿ÚËùÓÐÕßÃâ·Ñ£¬²¢ÇÒÓëÆäËû¼´½«ÍƳöµÄAntelope Audio²úÆ·ÍêÈ«¼æÈÝ¡£»ìÏì¾ßÓаËÖÖ²»Í¬µÄ¿Ø¼þ£¬°üÀ¨£º¡°Color¡±²ÎÊý£¬ÓÃÓÚ´´½¨´Ó°µµ½¸üÁÁµÄ´æÔÚÖ®¼äµÄÒ»ÇУ»ÒÔ¼°ÓëÔ´ÒôƵÏà±È¿ØÖÆ»ìÏìÃܶȵġ°Richness¡±²ÎÊý¡£
Antelope Audio introduces AuraVerb*, the professional audio company¡¯s first reverb. The software-based reverb leverages Antelope Audio¡¯s powerful 64-bit FPGA chip and features a unique algorithm designed by our team of mathematicians, including company founder Igor Levin. AuraVerb is free for all current and future audio interface owners and it is fully compatible with other upcoming Antelope Audio products. The reverb features eight different controls including: a ¡°Color¡± parameter to create everything between darkened textures to a brighter presence; and the ¡°Richness¡± parameter that controls the reverb density compared with the source audio.
https://en.antelopeaudio.com/products/auraverb/
BA-31Âó¿Ë·çǰÖ÷ŴóÆ÷
Ä£·ÂÁ˳¬¼¶Ï¡Óе쬵±È»Ò²Êdz¬¼¶ÊÜ»¶Ó­µÄ¾­µä£¬ËüÉè·¨±£ÁôÁËÆäÓ²¼þÁé¸ÐÖÐÕྦྷÌå¹ÜµÄԭʼÉùÒô¡£Õâ¿îÂó¿Ë·çǰÖ÷ŴóÆ÷ÐͺÅÅ䱏տÕýµÄÄ£ÄâµçÔ´£¬½«ÎªÄúµÄ¼ÒôÔöÌíÀÏʽ·ç¸ñ£¬Í¬Ê±³ä·ÖÀûÓÃÁé»îÒ×ÓõÄÏÖ´ú²å¼þÉè¼Æ¡£
Modeled after a super rare and, of course, super sought after classic, BA-31 has managed to preserve the original sound of the Germanium transistors of its hardware inspiration. Packed to the top with real analog power, this mic preamp model will add an oldschool touch of your recordings while making the best of flexible and easy-to-use modern plugin design.
https://en.antelopeaudio.com/products/ba-31/
GYRAF GYRATEC IXË«¹ÜÂó¿Ë·çǰÖ÷ŴóÆ÷
ÎÒÃÇϲ»¶Gyraf Audio¼òµ¥¶øÇ¿´óµÄÄ£Ä⹦ÄÜ£¬Ë«¹ÜÂó¿Ë·çǰÖ÷ŴóÆ÷G9Ò²²»ÀýÍâ¡£Ëü¼òµ¥ÒײÙ×÷£¬µ«ÈÔÈ»·Ç³£Í¨Óá£Õâ¿î¾ßÓÐSRPPÊä³ö¼¶µÄ¿É±äÔöÒæÊäÈë¹Ü¾ßÓÐÒ»×é¿ÉÀí½âµÄ¿Ø¼þ£¬°üÀ¨ÊäÈëºÍÊä³öµçƽ¿ª¹Ø£¬¿ÉÈÃÄúƽºâÊäÈëºÍÊä³öÐźš£Ç°Ö÷ŴóÆ÷»¹¾ßÓиßͨÂ˲¨Æ÷ºÍÏàλ·´Ïò¿ª¹Ø¡£Ò×ÓÚÕÆÎÕÇÒÉùÒô¾Þ´óµÄG9ÊÇÍêÃÀÄ£Äâ·Å´óÆ÷µÄ´úÃû´Ê¡£
We love the simple and massive analog powerful of all things Gyraf Audio and the dual tube microphone preamp G9 is not an exception. It¡¯s simple and easy to control, but still extremely versatile. This variable-gain input tube with a SRPP output stage features a comprehensible set of controls including input and output level siwtches allowing you to balance both the input and output signals. The preamp also features a high pass filter and a phase reverse switch. Easy to master and sounding massive G9 is the synonym for flawless analog amplification.
https://en.antelopeaudio.com/products/gyratec-ix/
X903 VCAѹËõÆ÷/ÏÞÖÆÆ÷
X903ÒÔ cultѹËõÆ÷Ä£¿éΪģÐÍ£¬½«Ìí¼ÓËùÐèµÄÊʵ±ÊýÁ¿µÄÄ£Ä⣡X903Å䱸ÁËÖÇÄÜRMS¼ì²â£¬½«ÒԸ߶ˡ¢ÕæÊµµÄÄ£ÄâѹËõºÍÏÞÖÆÀ´´¦ÀíÄúµÄÉùÒô¡£½èÖúX903µÄ¸º±ÈÂʹ¦ÄÜ£¬ÄúÉõÖÁ¿ÉÒÔ½«ÒôƵ²ÄÁϵĶ¯Ì¬·´ÏòÀ­»ØË²Ì¬·åÖµÒÔ»ñµÃ¶ÀÌØµÄÌØÊâЧ¹û¡£×ܶøÑÔÖ®£¬X903ÊÇÒ»¿îÉùÒô×ÔÈ»µÄѹËõÆ÷£¬Äܹ»ÒÔ³öÉ«µÄ·½Ê½¹ÜÀí¶¯Ì¬£¡
The X903 is modeled after a cult compressor module which will add just the right amount of analog punch needed! Equipped with smart RMS detection, the X903 will treat your sound to high-end, authentic analog compression and limiting. With the X903¡¯s Negative Ratio capabilities, you can even inverse the dynamics of audio material, pulling back the transient peaks for a unique special effect. All in all, the X903 is a natural-sounding compressor capable of managing dynamics in great ways!
https://en.antelopeaudio.com/products/x903/
VCA 160ѹËõÆ÷/ÏÞÖÆÆ÷
½áºÏÁ˾­µäµÄÉùÒô¡¢ÍêÃÀµÄ±íÍ·ºÍÒ×ÓÃÐÔ¡£ÊÊÓÃÓÚ¡°×©Ç½¡±ÏÞÖÆºÍ΢ÃîÍÆÁ¦£¬Ó²¼þÔ­×°¾­¹ý¾«ÐĽ¨Ä££¬ÒÔ±£³ÖÆä¶ÀÌØµÄ¸öÐÔ¡£ÕâÖÖ¿ìËÙ¶ø¼á¹ÌµÄVCA·ç¸ñµÄѹËõÆ÷·Ç³£ÊʺϿØÖÆÈËÉù¡¢µÍÒô¼ªËû»òµ¥¸ö¹Ä¡£µ±Ó뼤½øµÄ˲̬ÉùÒô£¨ÀýÈçµ×¹Ä»ò±´Ë¹£©Ò»ÆðʹÓÃʱ£¬VCA160µÄ¿ìËÙÏìÓ¦¿ÉÒÔ´´Ôì³ö¾­µäµÄ³å»÷Á¦£¬ÕâÒѳÉΪÆäÖøÃûµÄ³å»÷Á¦Æ×ϵÖжÀÒ»ÎÞ¶þµÄÒ»²¿·Ö¡£
VCA160 combines classic sound, perfect metering and ease of use. Suitable for both ¡°brick wall¡± limiting and subtle pushing, the hardware original has been carefully modeled to preserve its distinct character in both bad-ass hard knee or gentle low ratio compression. This fast and firm VCA-style compressor is great for controlling vocals, bass guitar or individual drums. When used with aggressive transient sounds, such as kick drums or bass, the VCA160¡¯s fast response can create a classic punch or ¡°thwack¡±, which has become a unique part of its famously punchy pedigree.
https://en.antelopeaudio.com/products/vca160/
FET-A76 ѹËõÆ÷/ÏÞÖÆ·Å´óÆ÷
FETÉè¼ÆÑ¹ËõÆ÷ÒѳÉΪÊг¡ÉÏ×îÊÜ»¶Ó­µÄѹËõÆ÷ÀàÐÍÖ®Ò»,ÕâÊÇÓгä·ÖÀíÓɵġ£
ÕâÊÇ1960Äê´úÍÆ³öµÄÉùÒô£¬Ò²Êǹ¤³ÌʦºÍÖÆ×÷È˵Ä×î°®¡£
The FET design compressor has become one of the most popular compressor types on the market, and for good reason. It¡¯s the sound that made its introduction in the 1960s and is a favorite among engineers and producers.
https://en.antelopeaudio.com/products/fet-a76/
2022-7-16 15:45:10 »Ø¸´
