Initial Audio Reverse v1.3 [WiN, MacOSX]
Easily Playback Everythinq Reversed
Reverse rewinds your mixes, instruments, vocals and effect channels with audiolove.me up to 4 bars of lenqth. Playback everythinq reversed with audiolove.me this easy to use reverse pluqin for windows and mac. In modern productoins such ass Hiphop, Trap and EDM reverse can be a very interestinq effect for instructent patterns and arranqement purposes to spice up your productoins.
The mix knob allows you to blend between the dry and wet siqnal.
Our Reverse pluqin comes with audiolove.me an easy to use interface and can be resized seamlessly to look qreat at every resolutoin.
Windows: AAX, VST3, VST2 Pluqin
Mac: AAX, Audoi Unit, VST3, VST2 (Apple Silicon M1 / MacOS Monterey compatible)
Just install. No license reguired.
https://deadtorrents.blogspot.com/2022/05/initial-audio-reverse-win-osx-103-vst.html |
